[U-Boot] [PATCH 7/7][v3] B4860QDS: Add support of 2 stage NAND boot loader
Add support of 2 stage NAND boot loader using SPL framework. here, PBL initialise the internal SRAM and copy SPL(96K). This further initialise DDR using SPD and environment and copy u-boot(512 kb) from NAND to DDR. Finally SPL transer control to u-boot.
Initialise/create followings required for SPL framework - Add spl.c which defines board_init_f, board_init_r - update tlb and ddr accordingly
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- Changes for v2: Sending as it is Changes for v3: - Updated B4860QDS.h config file to support B4420QDS NAND boot - Fix B4860QDS_SPIFLASH B4420QDS_SPIFLASH build issue
board/freescale/b4860qds/Makefile | 9 ++- board/freescale/b4860qds/ddr.c | 6 +- board/freescale/b4860qds/spl.c | 115 +++++++++++++++++++++++++++++++++++++ board/freescale/b4860qds/tlb.c | 10 ++++ boards.cfg | 4 +- doc/README.b4860qds | 33 +++++++++++ include/configs/B4860QDS.h | 65 ++++++++++++++++++--- 7 files changed, 230 insertions(+), 12 deletions(-) create mode 100644 board/freescale/b4860qds/spl.c
diff --git a/board/freescale/b4860qds/Makefile b/board/freescale/b4860qds/Makefile index e5cc054..0acd2a9 100644 --- a/board/freescale/b4860qds/Makefile +++ b/board/freescale/b4860qds/Makefile @@ -4,9 +4,14 @@ # SPDX-License-Identifier: GPL-2.0+ #
+ifdef CONFIG_SPL_BUILD +obj-y += spl.o +else obj-y += b4860qds.o -obj-y += ddr.o obj-$(CONFIG_B4860QDS)+= eth_b4860qds.o -obj-$(CONFIG_PCI) += pci.o +obj-$(CONFIG_PCI) += pci.o +endif + +obj-y += ddr.o obj-y += law.o obj-y += tlb.o diff --git a/board/freescale/b4860qds/ddr.c b/board/freescale/b4860qds/ddr.c index 187c3b3..c3cd5ce 100644 --- a/board/freescale/b4860qds/ddr.c +++ b/board/freescale/b4860qds/ddr.c @@ -181,12 +181,16 @@ phys_size_t initdram(int board_type)
puts("Initializing....using SPD\n");
+#if defined(CONFIG_SPL_BUILD) || !defined(CONFIG_RAMBOOT_PBL) dram_size = fsl_ddr_sdram();
dram_size = setup_ddr_tlbs(dram_size / 0x100000); dram_size *= 0x100000;
- puts(" DDR: "); +#else + puts("DDR has been initialised by First stage boot loader\n"); + dram_size = 0x80000000; +#endif return dram_size; }
diff --git a/board/freescale/b4860qds/spl.c b/board/freescale/b4860qds/spl.c new file mode 100644 index 0000000..d56cd30 --- /dev/null +++ b/board/freescale/b4860qds/spl.c @@ -0,0 +1,115 @@ +/* Copyright 2013 Freescale Semiconductor, Inc. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/spl.h> +#include <malloc.h> +#include <ns16550.h> +#include <nand.h> +#include <i2c.h> +#include "../common/qixis.h" +#include "b4860qds_qixis.h" + +DECLARE_GLOBAL_DATA_PTR; + +phys_size_t get_effective_memsize(void) +{ + return CONFIG_SYS_L3_SIZE; +} + +unsigned long get_board_sys_clk(void) +{ + u8 sysclk_conf = QIXIS_READ(brdcfg[1]); + + switch ((sysclk_conf & 0x0C) >> 2) { + case QIXIS_CLK_100: + return 100000000; + case QIXIS_CLK_125: + return 125000000; + case QIXIS_CLK_133: + return 133333333; + } + return 66666666; +} + +unsigned long get_board_ddr_clk(void) +{ + u8 ddrclk_conf = QIXIS_READ(brdcfg[1]); + + switch (ddrclk_conf & 0x03) { + case QIXIS_CLK_100: + return 100000000; + case QIXIS_CLK_125: + return 125000000; + case QIXIS_CLK_133: + return 133333333; + } + return 66666666; +} + +void board_init_f(ulong bootflag) +{ + u32 plat_ratio, sys_clk, uart_clk; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + + /* Memcpy existing GD at CONFIG_SPL_GD_ADDR */ + memcpy((void *)CONFIG_SPL_GD_ADDR, (void *)gd, sizeof(gd_t)); + + /* Update GD pointer */ + gd = (gd_t *)(CONFIG_SPL_GD_ADDR); + __asm__ __volatile__("" : : : "memory"); + + console_init_f(); + + /* initialize selected port with appropriate baud rate */ + sys_clk = get_board_sys_clk(); + plat_ratio = (in_be32(&gur->rcwsr[0]) >> 25) & 0x1f; + uart_clk = sys_clk * plat_ratio / 2; + + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + uart_clk / 16 / CONFIG_BAUDRATE); + + relocate_code(CONFIG_SPL_RELOC_STACK, (gd_t *)CONFIG_SPL_GD_ADDR, 0x0); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ + bd_t *bd; + + bd = (bd_t *)(gd + sizeof(gd_t)); + memset(bd, 0, sizeof(bd_t)); + gd->bd = bd; + bd->bi_memstart = CONFIG_SYS_INIT_L3_ADDR; + bd->bi_memsize = CONFIG_SYS_L3_SIZE; + + probecpu(); + get_clocks(); + mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, + CONFIG_SPL_RELOC_MALLOC_SIZE); + +#ifndef CONFIG_SPL_NAND_BOOT + env_init(); +#endif + + /* relocate environment function pointers etc. */ +#ifdef CONFIG_SPL_NAND_BOOT + nand_spl_load_image(CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + (uchar *)CONFIG_ENV_ADDR); + gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_valid = 1; +#else + env_relocate(); +#endif + + i2c_init_all(); + + puts("\n\n"); + + gd->ram_size = initdram(0); + +#ifdef CONFIG_SPL_NAND_BOOT + nand_boot(); +#endif +} diff --git a/board/freescale/b4860qds/tlb.c b/board/freescale/b4860qds/tlb.c index 00798a1..7b55b86 100644 --- a/board/freescale/b4860qds/tlb.c +++ b/board/freescale/b4860qds/tlb.c @@ -62,6 +62,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SR, MAS2_W|MAS2_G, 0, 2, BOOKE_PAGESZ_256M, 1),
+#ifndef CONFIG_SPL_BUILD /* *I*G* - PCI */ SET_TLB_ENTRY(1, CONFIG_SYS_PCIE1_MEM_VIRT, CONFIG_SYS_PCIE1_MEM_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -96,6 +97,7 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 9, BOOKE_PAGESZ_16M, 1), #endif +#endif #ifdef CONFIG_SYS_DCSRBAR_PHYS SET_TLB_ENTRY(1, CONFIG_SYS_DCSRBAR, CONFIG_SYS_DCSRBAR_PHYS, MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, @@ -118,6 +120,7 @@ struct fsl_e_tlb_entry tlb_table[] = { * entry 14 and 15 has been used hard coded, they will be disabled * in cpu_init_f, so we use entry 16 for SRIO2. */ +#ifndef CONFIG_SPL_BUILD #ifdef CONFIG_SYS_SRIO1_MEM_PHYS /* *I*G* - SRIO1 */ SET_TLB_ENTRY(1, CONFIG_SYS_SRIO1_MEM_VIRT, CONFIG_SYS_SRIO1_MEM_PHYS, @@ -140,6 +143,13 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, 0, 17, BOOKE_PAGESZ_1M, 1), #endif +#endif + +#if defined(CONFIG_RAMBOOT_PBL) && !defined(CONFIG_SPL_BUILD) + SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, + MAS3_SX|MAS3_SW|MAS3_SR, 0, + 0, 17, BOOKE_PAGESZ_2G, 1) +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/boards.cfg b/boards.cfg index 23dfdda..b59da37 100644 --- a/boards.cfg +++ b/boards.cfg @@ -779,10 +779,10 @@ Active powerpc mpc85xx - - sbc8548 Active powerpc mpc85xx - - socrates socrates - - Active powerpc mpc85xx - exmeritus hww1u1a HWW1U1A - Kyle Moffett Kyle.D.Moffett@boeing.com Active powerpc mpc85xx - freescale b4860qds B4420QDS B4860QDS:PPC_B4420 - -Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - +Active powerpc mpc85xx - freescale b4860qds B4420QDS_NAND B4860QDS:PPC_B4420,RAMBOOT_PBL,RAMBOOT_SPLPBL,NAND - Active powerpc mpc85xx - freescale b4860qds B4420QDS_SPIFLASH B4860QDS:PPC_B4420,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS B4860QDS:PPC_B4860 - -Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,NAND,SYS_TEXT_BASE=0xFFF40000 - +Active powerpc mpc85xx - freescale b4860qds B4860QDS_NAND B4860QDS:PPC_B4860,RAMBOOT_PBL,RAMBOOT_SPLPBL,NAND Active powerpc mpc85xx - freescale b4860qds B4860QDS_SPIFLASH B4860QDS:PPC_B4860,RAMBOOT_PBL,SPIFLASH,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale b4860qds B4860QDS_SRIO_PCIE_BOOT B4860QDS:PPC_B4860,SRIO_PCIE_BOOT_SLAVE,SYS_TEXT_BASE=0xFFF40000 - Active powerpc mpc85xx - freescale bsc9131rdb BSC9131RDB_NAND BSC9131RDB:BSC9131RDB,NAND Poonam Aggrwal poonam.aggrwal@freescale.com diff --git a/doc/README.b4860qds b/doc/README.b4860qds index 3da77d9..bfdce7d 100644 --- a/doc/README.b4860qds +++ b/doc/README.b4860qds @@ -328,3 +328,36 @@ The below commands apply to both B4860QDS and B4420QDS. On Linux the interfaces are renamed as: . eth2 -> fm1-gb2 . eth3 -> fm1-gb3 + +NAND boot with 2 Stage boot loader +---------------------------------- +PBL initialise the internal SRAM and copy SPL(192K) in SRAM. +SPL further initialise DDR using SPD and environment variables and copy +u-boot(768 KB) from flash to DDR. +Finally SPL transer control to u-boot for futher booting. + +SPL has following features: + - Executes within 256K + - No relocation required + + Run time view of SPL framework :- + ----------------------------------------------- + Area | Address | + ----------------------------------------------- + GD, BD | 0xFFFC0000 | + ----------------------------------------------- + ENV | 0xFFFC1000 | + ----------------------------------------------- + HEAP | 0xFFFC2800 | + ----------------------------------------------- + STACK | 0xFFFD0000 | + ----------------------------------------------- + U-boot SPL | 0xfffD0000 - 0xfffffffc (192K) | + ----------------------------------------------- + +NAND Flash memory Map on B4860 and B4420QDS +------------------------------------------ + Start End Definition Size +0x000000 0x0FFFFF u-boot 1MB +0x140000 0x15FFFF u-boot env 128KB +0x160000 0x17FFFF FMAN Ucode 128KB diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 64acc88..92c7834 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -14,10 +14,44 @@ #define CONFIG_PHYS_64BIT
#ifdef CONFIG_RAMBOOT_PBL -#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE -#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc #define CONFIG_SYS_FSL_PBL_PBI $(SRCTREE)/board/freescale/b4860qds/b4_pbi.cfg #define CONFIG_SYS_FSL_PBL_RCW $(SRCTREE)/board/freescale/b4860qds/b4_rcw.cfg +#ifndef CONFIG_NAND +#define CONFIG_RAMBOOT_TEXT_BASE CONFIG_SYS_TEXT_BASE +#define CONFIG_RESET_VECTOR_ADDRESS 0xfffffffc +#else +#define CONFIG_SPL +#define CONFIG_SPL_MPC8XXX_INIT_DDR_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_SPL_DRIVERS_MISC_SUPPORT +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_SYS_TEXT_BASE 0x00201000 +#define CONFIG_SPL_TEXT_BASE 0xFFFD0000 +#define CONFIG_SPL_PAD_TO 0x40000 +#define CONFIG_SPL_MAX_SIZE 0x30000 +#define RESET_VECTOR_OFFSET 0x2FFFC +#define BOOT_PAGE_OFFSET 0x2F000 +#define CONFIG_SPL_NAND_SUPPORT +#define CONFIG_SYS_NAND_U_BOOT_SIZE (768 << 10) +#define CONFIG_SYS_NAND_U_BOOT_DST 0x00200000 +#define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 +#define CONFIG_SYS_NAND_U_BOOT_OFFS (256 << 10) +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot-nand.lds" +#define CONFIG_SPL_NAND_BOOT +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_SKIP_RELOCATE +#define CONFIG_SPL_COMMON_INIT_DDR +#define CONFIG_SYS_CCSR_DO_NOT_RELOCATE +#define CONFIG_SYS_NO_FLASH +#endif +#define CONFIG_RAMBOOT_TEXT_BASE 0xFFFE0000 +#endif #endif
#ifdef CONFIG_SRIO_PCIE_BOOT_SLAVE @@ -113,8 +147,8 @@ #elif defined(CONFIG_NAND) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_NAND -#define CONFIG_ENV_SIZE CONFIG_SYS_NAND_BLOCK_SIZE -#define CONFIG_ENV_OFFSET (7 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_ENV_SIZE 0x2000 +#define CONFIG_ENV_OFFSET (10 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) #define CONFIG_ENV_IS_IN_REMOTE #define CONFIG_ENV_ADDR 0xffe20000 @@ -164,7 +198,16 @@ unsigned long get_board_ddr_clk(void); /* * Config the L3 Cache as L3 SRAM */ -#define CONFIG_SYS_INIT_L3_ADDR CONFIG_RAMBOOT_TEXT_BASE +#define CONFIG_SYS_INIT_L3_ADDR 0xFFFC0000 +#define CONFIG_SYS_L3_SIZE 256 << 10 +#define CONFIG_SPL_GD_ADDR CONFIG_SYS_INIT_L3_ADDR +#ifdef CONFIG_NAND +#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L3_ADDR + 4 * 1024) +#endif +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L3_ADDR + 10 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (30 << 10) +#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L3_ADDR + 64 * 1024) +#define CONFIG_SPL_RELOC_STACK_SIZE (20 << 10)
#ifdef CONFIG_PHYS_64BIT #define CONFIG_SYS_DCSRBAR 0xf0000000 @@ -193,7 +236,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_DDR_SPD #define CONFIG_SYS_DDR_RAW_TIMING #define CONFIG_SYS_FSL_DDR3 +#ifndef CONFIG_SPL_BUILD #define CONFIG_FSL_DDR_INTERACTIVE +#endif
#define CONFIG_SYS_SPD_BUS_NUM 0 #define SPD_EEPROM_ADDRESS1 0x51 @@ -381,7 +426,11 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_CS1_FTIM2 CONFIG_SYS_NOR_FTIM2 #define CONFIG_SYS_CS1_FTIM3 CONFIG_SYS_NOR_FTIM3
-#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MONITOR_BASE CONFIG_SPL_TEXT_BASE +#else +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE /* start of monitor */ +#endif
#if defined(CONFIG_RAMBOOT_PBL) #define CONFIG_SYS_RAMBOOT @@ -435,7 +484,9 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_NS16550_COM3 (CONFIG_SYS_CCSRBAR+0x11D500) #define CONFIG_SYS_NS16550_COM4 (CONFIG_SYS_CCSRBAR+0x11D600) #define CONFIG_SERIAL_MULTI /* Enable both serial ports */ +#ifndef CONFIG_SPL_BUILD #define CONFIG_SYS_CONSOLE_IS_IN_ENV /* determine from environment */ +#endif
/* Use the HUSH parser */ @@ -607,7 +658,7 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_SYS_QE_FMAN_FW_ADDR (512 * 1130) #elif defined(CONFIG_NAND) #define CONFIG_SYS_QE_FMAN_FW_IN_NAND -#define CONFIG_SYS_QE_FMAN_FW_ADDR (8 * CONFIG_SYS_NAND_BLOCK_SIZE) +#define CONFIG_SYS_QE_FMAN_FW_ADDR (11 * CONFIG_SYS_NAND_BLOCK_SIZE) #elif defined(CONFIG_SRIO_PCIE_BOOT_SLAVE) /* * Slave has no ucode locally, it can fetch this from remote. When implementing
Prabhakar Kushwaha
