[U-Boot] [PATCH] sunxi: Restore lowlevel_init usage
2 recent sunxi changes have removed the usage of lowlevel_init by moving some code around and then setting CONFIG_SKIP_LOWLEVEL_INIT. This is problematic for 2 reasons:
1) It does not just stop s_init from being called, it also stops cpu_init_cp15 from getting called, which is undesirable.
2) We want u-boot.bin to be usable standalone, without SPL, some people e.g. use an upstream u-boot.bin together with Allwinner's boot0 loader. So u-boot.bin must (re)initialize the gpios, timer, etc.
This commit restores the lowlevel_init / s_init usage, while keeping the changes to no longer use the global-data (gd) struct in the SPL.
Signed-off-by: Hans de Goede hdegoede@redhat.com --- arch/arm/cpu/armv7/sunxi/board.c | 42 ++++++++++++++++++++-------------------- include/configs/sunxi-common.h | 1 - 2 files changed, 21 insertions(+), 22 deletions(-)
diff --git a/arch/arm/cpu/armv7/sunxi/board.c b/arch/arm/cpu/armv7/sunxi/board.c index f4a580a..6e28bcd 100644 --- a/arch/arm/cpu/armv7/sunxi/board.c +++ b/arch/arm/cpu/armv7/sunxi/board.c @@ -27,26 +27,6 @@
#include <linux/compiler.h>
-#ifdef CONFIG_SPL_BUILD -/* Pointer to the global data structure for SPL */ -DECLARE_GLOBAL_DATA_PTR; - -/* The sunxi internal brom will try to loader external bootloader - * from mmc0, nand flash, mmc2. - * Unfortunately we can't check how SPL was loaded so assume - * it's always the first SD/MMC controller - */ -u32 spl_boot_device(void) -{ - return BOOT_DEVICE_MMC1; -} - -/* No confirmation data available in SPL yet. Hardcode bootmode */ -u32 spl_boot_mode(void) -{ - return MMCSD_MODE_RAW; -} - static int gpio_init(void) { #if CONFIG_CONS_INDEX == 1 && defined(CONFIG_UART0_PORT_F) @@ -85,7 +65,7 @@ static int gpio_init(void) return 0; }
-void board_init_f(ulong dummy) +void s_init(void) { #if defined CONFIG_MACH_SUN6I || defined CONFIG_MACH_SUN8I /* Magic (undocmented) value taken from boot0, without this DRAM @@ -105,7 +85,27 @@ void board_init_f(ulong dummy) timer_init(); gpio_init(); i2c_init_board(); +}
+#ifdef CONFIG_SPL_BUILD +/* The sunxi internal brom will try to loader external bootloader + * from mmc0, nand flash, mmc2. + * Unfortunately we can't check how SPL was loaded so assume + * it's always the first SD/MMC controller + */ +u32 spl_boot_device(void) +{ + return BOOT_DEVICE_MMC1; +} + +/* No confirmation data available in SPL yet. Hardcode bootmode */ +u32 spl_boot_mode(void) +{ + return MMCSD_MODE_RAW; +} + +void board_init_f(ulong dummy) +{ preloader_console_init();
#ifdef CONFIG_SPL_I2C_SUPPORT diff --git a/include/configs/sunxi-common.h b/include/configs/sunxi-common.h index 2bad807..59a298d 100644 --- a/include/configs/sunxi-common.h +++ b/include/configs/sunxi-common.h @@ -168,7 +168,6 @@ #define CONFIG_SYS_PBSIZE 1024 /* Print Buffer Size */ #define CONFIG_SYS_MAXARGS 16 /* max number of command args */ #define CONFIG_SYS_GENERIC_BOARD -#define CONFIG_SKIP_LOWLEVEL_INIT
/* Boot Argument Buffer Size */ #define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE
- It does not just stop s_init from being called, it also stops
- We want u-boot.bin to be usable standalone, without SPL, some people e.g.
Hans de Goede
