[PATCH] mtd: rawnand: omap_gpmc: fix BCH8 HW based correction
commit 04fcd2587321 ("mtd: rawnand: omap_gpmc: Fix BCH6/16 HW based correction")
broke AM335x based boards booting from NAND with ECC BCH8 code.
Use omap_enable_hwecc() instead of omap_enable_hwecc_bch() in SPL restores correct SPL nand_read_page functionality.
Tested on draco thuban board.
Signed-off-by: Heiko Schocher hs@denx.de
--- fix NAND boot for BCH8 based TI AM335x boards
Fix is based on series from Enrico:
https://lists.denx.de/pipermail/u-boot/2023-November/536793.html
and fixes NAND boot for the draco thuban board. But this patch apply also without the patches from above patchseries, see azure build:
https://dev.azure.com/hs0298/hs/_build/results?buildId=111&view=results
which is clean.
Above commit seems to change only U-Boot code and did not adapt am335x_spl_bch.c, which breaks nand_read_page in SPL code for AM335x based boards. So use in SPL "old" hw setup and reading page from NAND in SPL works again.
drivers/mtd/nand/raw/omap_gpmc.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/mtd/nand/raw/omap_gpmc.c b/drivers/mtd/nand/raw/omap_gpmc.c index 1a5ed0de31..c9b66dadbd 100644 --- a/drivers/mtd/nand/raw/omap_gpmc.c +++ b/drivers/mtd/nand/raw/omap_gpmc.c @@ -983,7 +983,11 @@ static int omap_select_ecc_scheme(struct nand_chip *nand, nand->ecc.strength = 8; nand->ecc.size = SECTOR_BYTES; nand->ecc.bytes = 14; +#if defined(CONFIG_SPL_BUILD) + nand->ecc.hwctl = omap_enable_hwecc; +#else nand->ecc.hwctl = omap_enable_hwecc_bch; +#endif nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; nand->ecc.read_page = omap_read_page_bch;
Patch is working by me.
-----Original Message----- From: Heiko Schocher hs@denx.de Sent: Wednesday, November 15, 2023 6:41 AM To: U-Boot Mailing List u-boot@lists.denx.de; Leto, Enrico (SI BP R&D ZG FW CCP) enrico.leto@siemens.com Cc: Schocher, Heiko (EXT) (DENX Software Engineering GmbH) hs@denx.de; Dario Binacchi dario.binacchi@amarulasolutions.com; Michael Trimarchi michael@amarulasolutions.com Subject: [PATCH] mtd: rawnand: omap_gpmc: fix BCH8 HW based correction
https://lists.d/ enx.de%2Fpipermail%2Fu-boot%2F2023- November%2F536793.html&data=05%7C01%7Cenrico.leto%40siemens.com %7Cbd939f15167c49cc97b708dbe59d6e9e%7C38ae3bcd95794fd4addab4 2e1495d55a%7C1%7C0%7C638356236545245361%7CUnknown%7CTWFp bGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXV CI6Mn0%3D%7C3000%7C%7C%7C&sdata=IUqjryYUtp%2Fdm9GgCALPTl8f% 2BlcrO0ErXjkvoDwz7v4%3D&reserved=0
https://dev.a/ zure.com%2Fhs0298%2Fhs%2F_build%2Fresults%3FbuildId%3D111%26vie w%3Dresults&data=05%7C01%7Cenrico.leto%40siemens.com%7Cbd939f15 167c49cc97b708dbe59d6e9e%7C38ae3bcd95794fd4addab42e1495d55a% 7C1%7C0%7C638356236545245361%7CUnknown%7CTWFpbGZsb3d8eyJ WIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D %7C3000%7C%7C%7C&sdata=S2itRHsR49lD9TlBexYw9J5waXiuFcS%2BhUp %2B7Yi60MA%3D&reserved=0
which is clean.
+#else nand->ecc.hwctl = omap_enable_hwecc_bch; +#endif nand->ecc.correct = omap_correct_data_bch; nand->ecc.calculate = omap_calculate_ecc_bch; nand->ecc.read_page = omap_read_page_bch; -- 2.37.3
Hi
We need test the boards that Roger add here.
Michael
which is clean.
Hello Michael,
On 15.11.23 11:38, Michael Nazzareno Trimarchi wrote:
Hi
Thanks!
Are this AM335x based boards booting from NAND ?
bye, Heiko
Michael
which is clean.
which is clean.
I don't think this is correct. omap_enable_hwecc does not setup the BCH settings and should be used only for 1-bit ECC i.e. OMAP_ECC_HAM1_CODE_*
I'm sure it will break the boards not using CONFIG_SPL_NAND_AM33XX_BCH which is pretty much most TI boards that are not AM335x.
Now, I need to identify why AM335x NAND is broken.
Hello Roger,
which is clean.
Yes, I played with setting up stuff in drivers/mtd/nand/raw/am335x_spl_bch.c but failed ...
If I can help you testing, feel free to ask!
bye, Heiko
On 15/11/2023 13:36, Heiko Schocher wrote:
Hello Roger,
which is clean.
OK. So I did some tests and we are ending up in a different ECC config on AM335x. The ecc.steps is not set at all by the driver (it is at 0) and so so nsectors gets set to -1 and so 7 (0b111) which is wrong.
static void __maybe_unused omap_enable_hwecc_bch(struct mtd_info *mtd, int mode) { ... case OMAP_ECC_BCH8_CODE_HW: bch_type = 1; nsectors = chip->ecc.steps; ... /* BCH configuration */ val = ((1 << 16) | /* enable BCH */ (bch_type << 12) | /* BCH4/BCH8/BCH16 */ (wr_mode << 8) | /* wrap mode */ (dev_width << 7) | /* bus width */ --> (((nsectors - 1) & 0x7) << 4) | /* number of sectors */ (info->cs << 1) | /* ECC CS */ (0x1)); ... }
setting chip->ecc.steps needs to be fixed in original commit c3754e9cc23a ("omap_gpmc: BCH8 support (ELM based)")
But this will still not fix the issue for AM335x as am335x_spl_bch.c expects 1 sector at a time ECC calculation.
I also realized that the error correction logic (ELM) is not in page mode and so is not suitable for multi-sector error correction.
This means we have to revert the commit 04fcd2587321 ("mtd: rawnand: omap_gpmc: Fix BCH6/16 HW based correction")
and go back to 1 sector BCH ECC generation and correction.
I will send a patch fix in a day or two after doing some tests at my end.
Hello Roger,
Hello Roger,
which is clean.
Yep...
Okay!
Uff... I did exactly this to get it working (in first shot) but feared sending such a "drastic" patch, as I had the hope to fix "AM335x SPL code", as U-Boot part works on AM335x...
What I wonder is that above commit introduced "omap_calculate_ecc_bch_multi" but did not use it in SPL! For U-Boot code omap_calculate_ecc_bch_multi is used in drivers/mtd/nand/raw/omap_gpmc.c omap_read_page_bch()
but drivers/mtd/nand/raw/am335x_spl_bch.c has no adaption ... so I tried to adapt this file... but did not get it up working without digging very deep into it...
Okay, thanks!
bye, Heiko
Heiko Schocher
Leto, Enrico
Roger Quadros
