Re: [PATCH v3] Makefile: use shell to calculate map_size
On 2024-03-05 18:15, Dragan Simic wrote:
On 2024-03-05 17:46, Leon M. Busch-George wrote:
The error message "bc: command not found" is easily missed since the build continues. bc is not a part of coreutils or base-devel. POSIX sh can also do the calculation.
Signed-off-by: Leon M. Busch-George leon@georgemail.eu
Sorry, I totally missed the v3. It's still looking good to me, and my Reviewed-by tag still applies, together with the small nitpick.
Makefile | 13 +++++++++---- 1 file changed, 9 insertions(+), 4 deletions(-)
diff --git a/Makefile b/Makefile index a2bc9d5903..0aef07ef3b 100644 --- a/Makefile +++ b/Makefile @@ -1275,10 +1275,15 @@ OBJCOPYFLAGS_u-boot-nodtb.bin := -O binary \ binary_size_check: u-boot-nodtb.bin FORCE @file_size=$(shell wc -c u-boot-nodtb.bin | awk '{print $$1}') ; \ map_size=$(shell cat u-boot.map | \
awk '/_image_copy_start/ {start = $$1} /_image_binary_end/ {end =
$$1} END {if (start != "" && end != "") print "ibase=16; " toupper(end) " - " toupper(start)}' \
| sed 's/0X//g' \
| bc); \
- if [ "" != "$$map_size" ]; then \
awk ' \
/_image_copy_start/ { start = $$1 } \
/_image_binary_end/ { end = $$1 } \
END { \
if (start != "" && end != "") \
print end " " start; \
| sh -c 'read end start && echo $$((end - start))'); \
- if [ -n "$$map_size" ]; then \ if test $$map_size -ne $$file_size; then \ echo "u-boot.map shows a binary size of $$map_size" >&2 ; \ echo " but u-boot-nodtb.bin shows $$file_size" >&2 ; \
Dragan Simic
