[U-Boot] [PATCH v2 00/08] Please pull https://github.com/OSSystems/u-boot for-imx
The following changes since commit 053ed25ecc694087308e3313e35d7d977de8173f:
configs: pico-imx7d: Convert to DM_VIDEO (2019-09-16 12:44:57 +0200)
for you to fetch changes up to 2dd8f58da73d4292870f486ecd798ea464f8cb23:
pico-imx6: Add Falcon mode (2019-09-20 11:45:46 -0300)
---------------------------------------------------------------- Fabio Estevam (6): mx53loco: Fix U-Boot corruption after saving the environment mx6: clock: Allow enable_ipu_clock() to be built for SPL code pico-imx6: Add initial support pico-imx6: Add Ethernet support pico-imx6: Add splashscreen support pico-imx6: Add Falcon mode
Otavio Salvador (2): configs: Sync all baseboard specific pico-imx7d pico-imx6: Fix bootmenu handling
arch/arm/dts/Makefile | 2 + arch/arm/dts/imx6dl-pico.dts | 17 ++ arch/arm/dts/imx6q-pico.dts | 17 ++ arch/arm/dts/imx6qdl-pico.dtsi | 424 +++++++++++++++++++++++++++++++++ arch/arm/mach-imx/mx6/Kconfig | 11 + arch/arm/mach-imx/mx6/clock.c | 32 +-- board/technexion/pico-imx6/Kconfig | 15 ++ board/technexion/pico-imx6/MAINTAINERS | 9 + board/technexion/pico-imx6/Makefile | 5 + board/technexion/pico-imx6/README | 73 ++++++ board/technexion/pico-imx6/pico-imx6.c | 362 ++++++++++++++++++++++++++++ board/technexion/pico-imx6/spl.c | 314 ++++++++++++++++++++++++ configs/pico-dwarf-imx7d_defconfig | 3 +- configs/pico-hobbit-imx7d_defconfig | 2 +- configs/pico-imx6_defconfig | 73 ++++++ configs/pico-nymph-imx7d_defconfig | 3 +- configs/pico-pi-imx7d_defconfig | 2 +- include/configs/mx53loco.h | 14 +- include/configs/pico-imx6.h | 164 +++++++++++++ 19 files changed, 1520 insertions(+), 22 deletions(-) create mode 100644 arch/arm/dts/imx6dl-pico.dts create mode 100644 arch/arm/dts/imx6q-pico.dts create mode 100644 arch/arm/dts/imx6qdl-pico.dtsi create mode 100644 board/technexion/pico-imx6/Kconfig create mode 100644 board/technexion/pico-imx6/MAINTAINERS create mode 100644 board/technexion/pico-imx6/Makefile create mode 100644 board/technexion/pico-imx6/README create mode 100644 board/technexion/pico-imx6/pico-imx6.c create mode 100644 board/technexion/pico-imx6/spl.c create mode 100644 configs/pico-imx6_defconfig create mode 100644 include/configs/pico-imx6.h
Hi Otavio,
thanks for "preparation" - I have pulled it and I will send to Tom after Travis run.
Regards, Stefano
Otavio Salvador
Stefano Babic
