[PATCH] arm: dts: imx8m*-venice: add gpio hog support
Add gpio hog support for board-specific gpio lines: - put hogs in u-boot.dtsi so as to keep the regular dts files in sync with the kernel. The hogs will not be put in the kernel as that makes them un-usable by userspace as well as re-initializes them to dt defaults overriding changes which may have been done by bootloader commands. - specify gpio names and initial config - enable GPIO_HOG
Signed-off-by: Tim Harvey tharvey@gateworks.com --- .../dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi | 46 ++++++ .../dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi | 81 ++++++++++ .../dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi | 81 ++++++++++ arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi | 118 ++++++++++++++ arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi | 150 ++++++++++++++++++ arch/arm/dts/imx8mm-venice-gw7903-u-boot.dtsi | 83 ++++++++++ arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi | 108 +++++++++++++ configs/imx8mm_venice_defconfig | 1 + configs/imx8mn_venice_defconfig | 1 + 9 files changed, 669 insertions(+)
diff --git a/arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi index f5d52c2fe259..b3592331c72b 100644 --- a/arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw71xx-0x-u-boot.dtsi @@ -3,3 +3,49 @@ * Copyright 2021 Gateworks Corporation */ #include "imx8mm-venice-gw700x-u-boot.dtsi" + +&gpio1 { + pci_usb_sel { + gpio-hog; + output-low; + gpios = <6 GPIO_ACTIVE_HIGH>; + line-name = "pci_usb_sel"; + }; + + dio_0 { + gpio-hog; + input; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "dio0"; + }; + + dio_1 { + gpio-hog; + input; + gpios = <9 GPIO_ACTIVE_HIGH>; + line-name = "dio1"; + }; +}; + +&gpio4 { + dio_2 { + gpio-hog; + input; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "dio2"; + }; + + dio_3 { + gpio-hog; + input; + gpios = <4 GPIO_ACTIVE_HIGH>; + line-name = "dio3"; + }; + + pci_wdis { + gpio-hog; + output-high; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "pci_wdis#"; + }; +}; diff --git a/arch/arm/dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi index f5d52c2fe259..92e44d4ba96b 100644 --- a/arch/arm/dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw72xx-0x-u-boot.dtsi @@ -3,3 +3,84 @@ * Copyright 2021 Gateworks Corporation */ #include "imx8mm-venice-gw700x-u-boot.dtsi" + +&gpio1 { + rs485_term { + gpio-hog; + output-low; + gpios = <0 GPIO_ACTIVE_HIGH>; + line-name = "rs485_term"; + }; + + mipi_gpio4 { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio4"; + }; + + pci_usb_sel { + gpio-hog; + output-low; + gpios = <6 GPIO_ACTIVE_HIGH>; + line-name = "pci_usb_sel"; + }; + + dio_0 { + gpio-hog; + input; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "dio0"; + }; + + dio_1 { + gpio-hog; + input; + gpios = <9 GPIO_ACTIVE_HIGH>; + line-name = "dio1"; + }; +}; + +&gpio4 { + rs485_en { + gpio-hog; + output-low; + gpios = <0 GPIO_ACTIVE_HIGH>; + line-name = "rs485_en"; + }; + + mipi_gpio3 { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio3"; + }; + + rs485_half { + gpio-hog; + output-low; + gpios = <2 GPIO_ACTIVE_HIGH>; + line-name = "rs485_hd"; + }; + + mipi_gpio2 { + gpio-hog; + input; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio2"; + }; + + mipi_gpio1 { + gpio-hog; + input; + gpios = <4 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio1"; + }; + + pci_wdis { + gpio-hog; + output-high; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "pci_wdis#"; + }; +}; diff --git a/arch/arm/dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi index f5d52c2fe259..92e44d4ba96b 100644 --- a/arch/arm/dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw73xx-0x-u-boot.dtsi @@ -3,3 +3,84 @@ * Copyright 2021 Gateworks Corporation */ #include "imx8mm-venice-gw700x-u-boot.dtsi" + +&gpio1 { + rs485_term { + gpio-hog; + output-low; + gpios = <0 GPIO_ACTIVE_HIGH>; + line-name = "rs485_term"; + }; + + mipi_gpio4 { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio4"; + }; + + pci_usb_sel { + gpio-hog; + output-low; + gpios = <6 GPIO_ACTIVE_HIGH>; + line-name = "pci_usb_sel"; + }; + + dio_0 { + gpio-hog; + input; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "dio0"; + }; + + dio_1 { + gpio-hog; + input; + gpios = <9 GPIO_ACTIVE_HIGH>; + line-name = "dio1"; + }; +}; + +&gpio4 { + rs485_en { + gpio-hog; + output-low; + gpios = <0 GPIO_ACTIVE_HIGH>; + line-name = "rs485_en"; + }; + + mipi_gpio3 { + gpio-hog; + input; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio3"; + }; + + rs485_half { + gpio-hog; + output-low; + gpios = <2 GPIO_ACTIVE_HIGH>; + line-name = "rs485_hd"; + }; + + mipi_gpio2 { + gpio-hog; + input; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio2"; + }; + + mipi_gpio1 { + gpio-hog; + input; + gpios = <4 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio1"; + }; + + pci_wdis { + gpio-hog; + output-high; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "pci_wdis#"; + }; +}; diff --git a/arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi index a801ee1deb93..11c773bb70d6 100644 --- a/arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw7901-u-boot.dtsi @@ -5,6 +5,124 @@
#include "imx8mm-venice-u-boot.dtsi"
+&gpio1 { + uart1_rs422 { + gpio-hog; + output-high; + gpios = <0 GPIO_ACTIVE_HIGH>; + line-name = "uart1_rs422#"; + }; + + uart1rs485 { + gpio-hog; + output-high; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "uart1_rs485#"; + }; + + uart1rs232 { + gpio-hog; + output-high; + gpios = <5 GPIO_ACTIVE_HIGH>; + line-name = "uart1_rs232#"; + }; + + dig1in { + gpio-hog; + input; + gpios = <6 GPIO_ACTIVE_HIGH>; + line-name = "dig1_in"; + }; + + dig1out { + gpio-hog; + output-low; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "dig1_out"; + }; +}; + +&gpio4 { + uart3_rs232 { + gpio-hog; + output-high; + gpios = <6 GPIO_ACTIVE_HIGH>; + line-name = "uart3_rs232#"; + }; + + uart3_rs422 { + gpio-hog; + output-high; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "uart3_rs422#"; + }; + + uart3_rs485 { + gpio-hog; + output-high; + gpios = <8 GPIO_ACTIVE_HIGH>; + line-name = "uart3_rs485#"; + }; + + uart4_rs485 { + gpio-hog; + output-high; + gpios = <27 GPIO_ACTIVE_HIGH>; + line-name = "uart4_rs485#"; + }; + + sim1det { + gpio-hog; + input; + gpios = <29 GPIO_ACTIVE_HIGH>; + line-name = "sim1_det"; + }; + + sim2det { + gpio-hog; + input; + gpios = <30 GPIO_ACTIVE_HIGH>; + line-name = "sim2_det"; + }; +}; + +&gpio5 { + dig2out { + gpio-hog; + output-low; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "dig2_out"; + }; + + dig2in { + gpio-hog; + input; + gpios = <4 GPIO_ACTIVE_HIGH>; + line-name = "dig2_in"; + }; + + sim2sel { + gpio-hog; + output-low; + gpios = <5 GPIO_ACTIVE_HIGH>; + line-name = "sim2_sel"; + }; + + uart4_rs232 { + gpio-hog; + output-high; + gpios = <10 GPIO_ACTIVE_HIGH>; + line-name = "uart4_rs232#"; + }; + + uart4_rs422 { + gpio-hog; + output-high; + gpios = <13 GPIO_ACTIVE_HIGH>; + line-name = "uart4_rs422#"; + }; +}; + &fec1 { phy-reset-gpios = <&gpio4 19 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; diff --git a/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi index d0e5d6c5b634..1e1769f55127 100644 --- a/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw7902-u-boot.dtsi @@ -5,6 +5,156 @@
+&gpio1 { + m2rst { + gpio-hog; + output-low; + gpios = <13 GPIO_ACTIVE_HIGH>; + line-name = "m2_reset"; + }; + + m2wdis { + gpio-hog; + output-high; + gpios = <15 GPIO_ACTIVE_HIGH>; + line-name = "m2_wdis#"; + }; +}; + +&gpio2 { + uart2en { + gpio-hog; + output-high; + gpios = <8 GPIO_ACTIVE_HIGH>; + line-name = "uart2_en#"; + }; +}; + +&gpio3 { + m2gdis { + gpio-hog; + output-high; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "m2_gdis#"; + }; + + m2off { + gpio-hog; + output-high; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "m2_off#"; + }; +}; + +&gpio4 { + ampgpio3 { + gpio-hog; + input; + gpios = <11 GPIO_ACTIVE_HIGH>; + line-name = "amp_gpio3"; + }; + + ampgpio2 { + gpio-hog; + input; + gpios = <12 GPIO_ACTIVE_HIGH>; + line-name = "amp_gpio2"; + }; + + ampgpio1 { + gpio-hog; + input; + gpios = <14 GPIO_ACTIVE_HIGH>; + line-name = "amp_gpio1"; + }; + + ltrpwr { + gpio-hog; + output-low; + gpios = <16 GPIO_ACTIVE_HIGH>; + line-name = "lte_pwr#"; + }; + + lterst { + gpio-hog; + output-low; + gpios = <17 GPIO_ACTIVE_HIGH>; + line-name = "lte_rst"; + }; + + ampgpio4 { + gpio-hog; + input; + gpios = <20 GPIO_ACTIVE_HIGH>; + line-name = "amp_gpio4"; + }; + + appgpio1 { + gpio-hog; + input; + gpios = <21 GPIO_ACTIVE_HIGH>; + line-name = "app_gpio1"; + }; + + uart1rs485 { + gpio-hog; + output-low; + gpios = <23 GPIO_ACTIVE_HIGH>; + line-name = "uart1_rs485"; + }; + + uart1term { + gpio-hog; + output-low; + gpios = <25 GPIO_ACTIVE_HIGH>; + line-name = "uart1_term"; + }; + + uart1half { + gpio-hog; + output-low; + gpios = <26 GPIO_ACTIVE_HIGH>; + line-name = "uart1_half"; + }; + + appgpio2 { + gpio-hog; + input; + gpios = <27 GPIO_ACTIVE_HIGH>; + line-name = "app_gpio2"; + }; + + mipigpio1 { + gpio-hog; + input; + gpios = <28 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio1"; + }; +}; + +&gpio5 { + mipigpio4 { + gpio-hog; + input; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio4"; + }; + + mipigpio3 { + gpio-hog; + input; + gpios = <4 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio3"; + }; + + mipigpio2 { + gpio-hog; + input; + gpios = <5 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio2"; + }; +}; + &fec1 { phy-reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; diff --git a/arch/arm/dts/imx8mm-venice-gw7903-u-boot.dtsi b/arch/arm/dts/imx8mm-venice-gw7903-u-boot.dtsi index 36a605468b22..896e5d4edde3 100644 --- a/arch/arm/dts/imx8mm-venice-gw7903-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-venice-gw7903-u-boot.dtsi @@ -5,6 +5,89 @@
+&gpio1 { + rs422en { + gpio-hog; + output-high; + gpios = <10 GPIO_ACTIVE_HIGH>; + line-name = "rs422_en#"; + }; + + rs485en { + gpio-hog; + output-high; + gpios = <11 GPIO_ACTIVE_HIGH>; + line-name = "rs485_en#"; + }; + + rs232en { + gpio-hog; + output-low; + gpios = <12 GPIO_ACTIVE_HIGH>; + line-name = "rs232_en#"; + }; +}; + +&gpio2 { + dig2in { + gpio-hog; + input; + gpios = <0 GPIO_ACTIVE_HIGH>; + line-name = "dig2_in"; + }; + + dig2out { + gpio-hog; + output-high; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "dig2_out#"; + }; + + dig1out { + gpio-hog; + output-high; + gpios = <8 GPIO_ACTIVE_HIGH>; + line-name = "dig1_out#"; + }; + + dig1in { + gpio-hog; + input; + gpios = <9 GPIO_ACTIVE_HIGH>; + line-name = "dig1_in"; + }; +}; + +&gpio5 { + sim1det { + gpio-hog; + input; + gpios = <7 GPIO_ACTIVE_LOW>; + line-name = "sim1_det#"; + }; + + sim2det { + gpio-hog; + input; + gpios = <8 GPIO_ACTIVE_LOW>; + line-name = "sim2_det#"; + }; + + sim2sel { + gpio-hog; + output-low; + gpios = <9 GPIO_ACTIVE_HIGH>; + line-name = "sim2_sel"; + }; + + pci_wdis { + gpio-hog; + output-high; + gpios = <12 GPIO_ACTIVE_HIGH>; + line-name = "pci_wdis#"; + }; +}; + &fec1 { phy-reset-gpios = <&gpio4 25 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; diff --git a/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi b/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi index b334b56b82a1..9431e2a6cde7 100644 --- a/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-venice-gw7902-u-boot.dtsi @@ -5,6 +5,114 @@
#include "imx8mn-venice-u-boot.dtsi"
+&gpio1 { + m2rst { + gpio-hog; + output-low; + gpios = <13 GPIO_ACTIVE_HIGH>; + line-name = "m2_reset"; + }; + + m2wdis { + gpio-hog; + output-high; + gpios = <15 GPIO_ACTIVE_HIGH>; + line-name = "m2_wdis#"; + }; +}; + +&gpio2 { + uart2en { + gpio-hog; + output-high; + gpios = <8 GPIO_ACTIVE_HIGH>; + line-name = "uart2_en#"; + }; +}; + +&gpio3 { + m2gdis { + gpio-hog; + output-high; + gpios = <1 GPIO_ACTIVE_HIGH>; + line-name = "m2_gdis#"; + }; + + m2off { + gpio-hog; + output-high; + gpios = <7 GPIO_ACTIVE_HIGH>; + line-name = "m2_off#"; + }; +}; + +&gpio4 { + appgpio1 { + gpio-hog; + input; + gpios = <21 GPIO_ACTIVE_HIGH>; + line-name = "app_gpio1"; + }; + + uart1rs485 { + gpio-hog; + output-low; + gpios = <23 GPIO_ACTIVE_HIGH>; + line-name = "uart1_rs485"; + }; + + uart1term { + gpio-hog; + output-low; + gpios = <25 GPIO_ACTIVE_HIGH>; + line-name = "uart1_term"; + }; + + uart1half { + gpio-hog; + output-low; + gpios = <26 GPIO_ACTIVE_HIGH>; + line-name = "uart1_half"; + }; + + appgpio2 { + gpio-hog; + input; + gpios = <27 GPIO_ACTIVE_HIGH>; + line-name = "app_gpio2"; + }; + + mipigpio1 { + gpio-hog; + input; + gpios = <28 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio1"; + }; +}; + +&gpio5 { + mipigpio4 { + gpio-hog; + input; + gpios = <3 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio4"; + }; + + mipigpio3 { + gpio-hog; + input; + gpios = <4 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio3"; + }; + + mipigpio2 { + gpio-hog; + input; + gpios = <5 GPIO_ACTIVE_HIGH>; + line-name = "mipi_gpio2"; + }; +}; + &fec1 { phy-reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 78dc7acb3e60..03caef612790 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -74,6 +74,7 @@ CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MM=y CONFIG_CLK_IMX8MM=y +CONFIG_GPIO_HOG=y CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_LED=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index dbfda3706dbc..d0723c440708 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -76,6 +76,7 @@ CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MN=y CONFIG_CLK_IMX8MN=y +CONFIG_GPIO_HOG=y CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_LED=y
Subject: [PATCH] arm: dts: imx8m*-venice: add gpio hog support
- enable GPIO_HOG
Acked-by: Peng Fan peng.fan@nxp.com
- Copyright 2021 Gateworks Corporation
+&gpio1 {
- pci_usb_sel {
gpio-hog;
output-low;
- dio_0 {
gpio-hog;
input;
line-name = "dio0";
- dio_1 {
gpio-hog;
input;
line-name = "dio1";
+&gpio4 {
- dio_2 {
gpio-hog;
input;
line-name = "dio2";
- dio_3 {
gpio-hog;
input;
line-name = "dio3";
- pci_wdis {
gpio-hog;
output-high;
+&gpio1 {
- rs485_term {
gpio-hog;
output-low;
- mipi_gpio4 {
gpio-hog;
input;
- pci_usb_sel {
gpio-hog;
output-low;
- dio_0 {
gpio-hog;
input;
line-name = "dio0";
- dio_1 {
gpio-hog;
input;
line-name = "dio1";
+&gpio4 {
- rs485_en {
gpio-hog;
output-low;
- mipi_gpio3 {
gpio-hog;
input;
- rs485_half {
gpio-hog;
output-low;
- mipi_gpio2 {
gpio-hog;
input;
- mipi_gpio1 {
gpio-hog;
input;
- pci_wdis {
gpio-hog;
output-high;
+&gpio1 {
- rs485_term {
gpio-hog;
output-low;
- mipi_gpio4 {
gpio-hog;
input;
- pci_usb_sel {
gpio-hog;
output-low;
- dio_0 {
gpio-hog;
input;
line-name = "dio0";
- dio_1 {
gpio-hog;
input;
line-name = "dio1";
+&gpio4 {
- rs485_en {
gpio-hog;
output-low;
- mipi_gpio3 {
gpio-hog;
input;
- rs485_half {
gpio-hog;
output-low;
- mipi_gpio2 {
gpio-hog;
input;
- mipi_gpio1 {
gpio-hog;
input;
- pci_wdis {
gpio-hog;
output-high;
+&gpio1 {
- uart1_rs422 {
gpio-hog;
output-high;
- uart1rs485 {
gpio-hog;
output-high;
- uart1rs232 {
gpio-hog;
output-high;
- dig1in {
gpio-hog;
input;
- dig1out {
gpio-hog;
output-low;
+&gpio4 {
- uart3_rs232 {
gpio-hog;
output-high;
- uart3_rs422 {
gpio-hog;
output-high;
- uart3_rs485 {
gpio-hog;
output-high;
- uart4_rs485 {
gpio-hog;
output-high;
- sim1det {
gpio-hog;
input;
- sim2det {
gpio-hog;
input;
+&gpio5 {
- dig2out {
gpio-hog;
output-low;
- dig2in {
gpio-hog;
input;
- sim2sel {
gpio-hog;
output-low;
- uart4_rs232 {
gpio-hog;
output-high;
- uart4_rs422 {
gpio-hog;
output-high;
+&gpio1 {
- m2rst {
gpio-hog;
output-low;
- m2wdis {
gpio-hog;
output-high;
+&gpio2 {
- uart2en {
gpio-hog;
output-high;
+&gpio3 {
- m2gdis {
gpio-hog;
output-high;
- m2off {
gpio-hog;
output-high;
+&gpio4 {
- ampgpio3 {
gpio-hog;
input;
- ampgpio2 {
gpio-hog;
input;
- ampgpio1 {
gpio-hog;
input;
- ltrpwr {
gpio-hog;
output-low;
- lterst {
gpio-hog;
output-low;
- ampgpio4 {
gpio-hog;
input;
- appgpio1 {
gpio-hog;
input;
- uart1rs485 {
gpio-hog;
output-low;
- uart1term {
gpio-hog;
output-low;
- uart1half {
gpio-hog;
output-low;
- appgpio2 {
gpio-hog;
input;
- mipigpio1 {
gpio-hog;
input;
+&gpio5 {
- mipigpio4 {
gpio-hog;
input;
- mipigpio3 {
gpio-hog;
input;
- mipigpio2 {
gpio-hog;
input;
+&gpio1 {
- rs422en {
gpio-hog;
output-high;
- rs485en {
gpio-hog;
output-high;
- rs232en {
gpio-hog;
output-low;
+&gpio2 {
- dig2in {
gpio-hog;
input;
- dig2out {
gpio-hog;
output-high;
- dig1out {
gpio-hog;
output-high;
- dig1in {
gpio-hog;
input;
+&gpio5 {
- sim1det {
gpio-hog;
input;
- sim2det {
gpio-hog;
input;
- sim2sel {
gpio-hog;
output-low;
- pci_wdis {
gpio-hog;
output-high;
+&gpio1 {
- m2rst {
gpio-hog;
output-low;
- m2wdis {
gpio-hog;
output-high;
+&gpio2 {
- uart2en {
gpio-hog;
output-high;
+&gpio3 {
- m2gdis {
gpio-hog;
output-high;
- m2off {
gpio-hog;
output-high;
+&gpio4 {
- appgpio1 {
gpio-hog;
input;
- uart1rs485 {
gpio-hog;
output-low;
- uart1term {
gpio-hog;
output-low;
- uart1half {
gpio-hog;
output-low;
- appgpio2 {
gpio-hog;
input;
- mipigpio1 {
gpio-hog;
input;
+&gpio5 {
- mipigpio4 {
gpio-hog;
input;
- mipigpio3 {
gpio-hog;
input;
- mipigpio2 {
gpio-hog;
input;
&fec1 { phy-reset-gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; phy-reset-duration = <1>; diff --git a/configs/imx8mm_venice_defconfig b/configs/imx8mm_venice_defconfig index 78dc7acb3e60..03caef612790 100644 --- a/configs/imx8mm_venice_defconfig +++ b/configs/imx8mm_venice_defconfig @@ -74,6 +74,7 @@ CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MM=y CONFIG_CLK_IMX8MM=y +CONFIG_GPIO_HOG=y CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_LED=y diff --git a/configs/imx8mn_venice_defconfig b/configs/imx8mn_venice_defconfig index dbfda3706dbc..d0723c440708 100644 --- a/configs/imx8mn_venice_defconfig +++ b/configs/imx8mn_venice_defconfig @@ -76,6 +76,7 @@ CONFIG_SPL_CLK_COMPOSITE_CCF=y CONFIG_CLK_COMPOSITE_CCF=y CONFIG_SPL_CLK_IMX8MN=y CONFIG_CLK_IMX8MN=y +CONFIG_GPIO_HOG=y CONFIG_MXC_GPIO=y CONFIG_DM_I2C=y CONFIG_LED=y -- 2.17.1
Peng Fan
Tim Harvey
