[GIT PULL] Pull request: u-boot-imx u-boot-imx-20200623
Hi Tom,
I hope last i.MX fixes for relese. List is still quite long, but are pretty just fixes or related to single boards.
The following changes since commit f5a821459384a8fc1c8d0a44ce50f7f919257fa8:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-sh (2020-06-20 18:51:50 -0400)
https://gitlab.denx.de/u-boot/custodians/u-boot-imx.git tags/u-boot-imx-20200623
for you to fetch changes up to 824e6fe0ae0280cabd9df763fbc3bbaca2682b32:
mx6cuboxi: remove unused code (2020-06-23 00:08:53 +0200)
---------------------------------------------------------------- Fixes for 2020.07 -----------------
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/701059103
- Fixes for atheros und cubox - Toradex: mostly environment - i.MX7: DDR fixes - switch to DM - sabrelite : fix MMC access
---------------------------------------------------------------- Fabio Estevam (9): phy: atheros: ar8035: Fix clock output calculation net: fec: Allow the PHY node to be retrieved ARM: dts: imx6qdl-sr-som: Sync with kernel 5.8-rc1 mx6cuboxi: Convert to DM_ETH ARM: dts: imx6qdl-sabreauto: Fix AR8031 phy-mode ARM: dts: imx6qdl-sabresd: Fix AR8031 phy-mode mx6slevk_spinor: Convert to DM_ETH mx6slevk_spl: Convert to DM_ETH mx6ull_14x14_evk_plugin: Convert to DM_ETH
Heinrich Schuchardt (1): arm: wandboard: move CONFIG_MXC_UART to defconfig
Igor Opaniuk (6): apalis-tk1: enable distroboot apalis-tk1: fix setting fdtfile value toradex: imx: enable BOOTCOUNT feature apalis_imx6: boot env configuration updates colibri_imx7: boot env configuration updates colibri_imx6: boot env configuration updates
Marcel Ziswiler (1): apalis-imx8: enable of_system_setup
Marek Vasut (4): ARM: imx6: Fetch MAC address in board_init_late() on DH iMX6 PDK2 ARM: imx: ddr: Fill in missing DDRC ZQCTLx on i.MX7 ARM: imx: soc: Switch BOARD_EARLY_INIT_F to imply on MX7 ARM: imx: soc: Select default TEXT_BASE for MX7
Martyn Welch (1): Fix MMC access on Sabrelite
Max Krummenacher (3): apalis/colibri-imx8: re-enable CONFIG_IMX_SCU_THERMAL colibri_vf_defconfig: enable part cmd configs/colibri_vf.h: drop sdboot in favour of distro_bootcmd
Oleksandr Suvorov (1): colibri-imx8x: declare consoleargs
Oliver Graute (1): imx: imx8qm_rom7720_a1: update README
Otavio Salvador (2): mx6ul_14x14_evk: Enable SPL USB and SDP support mx6ul_14x14_evk: Avoid overlap of environment over U-Boot proper
Stefan Agner (2): colibri_imx7: add addresses required for distro boot colibri-imx6ull/imx7: define bootubipart for distro boot
Walter Lozano (4): mx6cuboxi: enable MMC and eMMC in DT for SPL mx6cuboxi: customize board_boot_order to access eMMC mx6cuboxi: enable OF_CONTROL and DM in SPL mx6cuboxi: remove unused code
Ye Li (2): gpio: mxc_gpio: change gpio index for i.MX8 arm: dts: imx: fsl-imx8qm.dtsi: fix gpio aliases
arch/arm/Kconfig | 2 +- arch/arm/dts/fsl-imx8qm.dtsi | 15 +-- arch/arm/dts/imx6qdl-hummingboard2-emmc-som-v15-u-boot.dtsi | 8 ++ arch/arm/dts/imx6qdl-sabreauto.dtsi | 2 +- arch/arm/dts/imx6qdl-sabresd.dtsi | 2 +- arch/arm/dts/imx6qdl-sr-som.dtsi | 11 ++ arch/arm/include/asm/arch-mx7/mx7-ddr.h | 4 +- arch/arm/mach-imx/mx7/Kconfig | 7 ++ arch/arm/mach-imx/mx7/ddr.c | 1 + board/advantech/imx8qm_rom7720_a1/README | 11 ++ board/boundary/nitrogen6x/nitrogen6x.c | 72 ------------- board/dhelectronics/dh_imx6/dh_imx6.c | 4 +- board/solidrun/mx6cuboxi/mx6cuboxi.c | 247 ++++++++++++-------------------------------- board/wandboard/README | 10 ++ configs/apalis-imx8qm_defconfig | 2 + configs/apalis-tk1_defconfig | 2 +- configs/apalis_imx6_defconfig | 3 + configs/cl-som-imx7_defconfig | 2 - configs/colibri-imx6ull_defconfig | 3 + configs/colibri-imx8qxp_defconfig | 1 + configs/colibri_imx6_defconfig | 3 + configs/colibri_imx7_defconfig | 3 + configs/colibri_imx7_emmc_defconfig | 3 + configs/colibri_vf_defconfig | 3 +- configs/mx6cuboxi_defconfig | 6 ++ configs/mx6qsabrelite_defconfig | 3 + configs/mx6slevk_spinor_defconfig | 3 + configs/mx6slevk_spl_defconfig | 3 + configs/mx6ul_14x14_evk_defconfig | 13 ++- configs/mx6ull_14x14_evk_plugin_defconfig | 6 ++ configs/pico-dwarf-imx7d_defconfig | 2 - configs/pico-hobbit-imx7d_defconfig | 2 - configs/pico-imx7d_defconfig | 2 - configs/pico-nymph-imx7d_defconfig | 2 - configs/pico-pi-imx7d_defconfig | 2 - configs/wandboard_defconfig | 1 + drivers/gpio/mxc_gpio.c | 5 +- drivers/net/fec_mxc.c | 7 +- drivers/net/fec_mxc.h | 1 + drivers/net/phy/atheros.c | 7 +- include/configs/apalis-tk1.h | 51 +++------ include/configs/apalis_imx6.h | 29 +----- include/configs/colibri-imx6ull.h | 1 + include/configs/colibri-imx8x.h | 8 +- include/configs/colibri_imx6.h | 29 +----- include/configs/colibri_imx7.h | 28 +---- include/configs/colibri_vf.h | 18 +--- include/configs/mx6cuboxi.h | 6 -- include/configs/wandboard.h | 1 - 49 files changed, 222 insertions(+), 435 deletions(-)
Best regards, Stefano
On Tue, Jun 23, 2020 at 10:46:14AM +0200, Stefano Babic wrote:
Hi Tom,
Stefano Babic
