Re: [U-Boot] [PULL] Please pull u-boot-imx
On 17/05/2018 18:33, Lukasz Majewski wrote:
Hi Stefano, Tom,
Tom was not in CC, added
On 17 May 2018 17:50, Stefano Babic sbabic@denx.de wrote:
Hi Tom, please pull from u-boot-imx, thanks ! The following changes since commit f2d0f5e7ab3b8a7b4bf6e2ac499b4867c701d52d: ARM: re-enable MVGBE for edminiv2 (2018-05-16 11:38:08 -0400) are available in the git repository at: git://www.denx.de/git/u-boot-imx.git master for you to fetch changes up to 2f5988533d5c447d7bda79b0d9719f84db9e1835: imx6: sabrelite: update defconfig to use distro defaults (2018-05-17 17:47:17 +0200) ---------------------------------------------------------------- Guillaume GARDET (2): imx6: Convert sabrelite and nitrogen6x boards to distro boot support imx6: sabrelite: update defconfig to use distro defaults Ian Ray (6): board: ge: bx50v3: add winbond SPI NOR support board: ge: bx50v3: rename detect_baseboard function board: ge: bx50v3: fix display support for b{46}50v3 board: ge: bx50v3: use VPD instead of compile-time checks board: ge: bx50v3: configure video arguments using VPD board: ge: bx50v3: remove redundant targets Lukasz Majewski (8): dts: imx53: Add gpio and i2c nodes to imx53.dtsi file dts: pinctrl: Provide IMX_PAD_SION definition for imx53 pinctrl
Two above patches are correct.
pmic: fsl: Provide some more definitions for MC34708 PMIC pmic: fsl: Define number of bytes sent at once by MC34708 PMIC pmic: dm: Provide *trans_len() callback for pmic-uclass pmic: dm: Rewrite pmic_reg_{read|write} and pmic_clrsetbits to support transmissions larger than 1 byte pmic: dm: Add support for MC34708 for PMIC DM arm: imx53: Add support for imx53 boards from K+P
Stefano, Tom please drop above patches as they were superseded by v2 and v3 (after discussion with Simon).
I have just added the pmic patches due to the dependency in "arm: imx53: Add support for imx53 boards from K+P", and I have not seen any change request in them. I drop the series, Tom please wait, I will send a new PR after.
IMHO v3 is eligible for pulling: https://patchwork.ozlabs.org/patch/913670/
Should they flow into Jaehoon's tree instead of u-boot-imx ?
Best regards, Stefano
BR, Łukasz Majewski
Magnus Lilja (2): mx31pdk: Convert CONFIG_MX31 flag to use Kconfig. mx31: Convert MX31_HCLK_FREQ and MX31_CLK32 to Kconfig. Nandor Han (2): board: ge: bx50v3: unify two switch statements board: ge: bx50v3: detect the monitor type by reading VPD earlier Peter Robinson (4): mx6 common: remove dangling comment mx7: remove empty ifndef statement mx6: Select CONFIG_MP with MX6_SMP mx6: remove duplicated BOUNCE_BUFFER defines Sebastian Reichel (1): ge: ppd: move CONFIG_ENV_IS_IN_MMC to defconfig arch/arm/Kconfig | 14 +++---- arch/arm/dts/imx53-kp.dts | 135 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/imx53-pinfunc.h | 1 + arch/arm/dts/imx53.dtsi | 101 +++++++++++++++++++++++++++++++++++++++++++++++- arch/arm/include/asm/arch-mx31/clock.h | 8 ---- arch/arm/mach-imx/mx3/Kconfig | 34 +++++++++++++++++ arch/arm/mach-imx/mx5/Kconfig | 12 ++++++ arch/arm/mach-imx/mx6/Kconfig | 15 ++------ board/ge/bx50v3/Kconfig | 2 +- board/ge/bx50v3/bx50v3.c | 71 ++++++++++++++++++++++------------ board/k+p/kp_imx53/Kconfig | 15 ++++++++ board/k+p/kp_imx53/MAINTAINERS | 6 +++ board/k+p/kp_imx53/Makefile | 8 ++++ board/k+p/kp_imx53/kp_id_rev.c | 121 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ board/k+p/kp_imx53/kp_id_rev.h | 28 ++++++++++++++ board/k+p/kp_imx53/kp_imx53.c | 212 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ configs/ge_b650v3_defconfig | 43 --------------------- configs/ge_b850v3_defconfig | 43 --------------------- configs/{ge_b450v3_defconfig => ge_bx50v3_defconfig} | 4 +- configs/kp_imx53_defconfig | 40 +++++++++++++++++++ configs/mx31pdk_defconfig | 3 +- configs/mx53ppd_defconfig | 1 + configs/mx6qsabrelite_defconfig | 15 +++----- drivers/power/pmic/Kconfig | 7 ++++ drivers/power/pmic/Makefile | 1 + drivers/power/pmic/mc34708.c | 103 +++++++++++++++++++++++++++++++++++++++++++++++++ drivers/power/pmic/pmic-uclass.c | 48 +++++++++++++++++------ include/configs/advantech_dms-ba16.h | 1 - include/configs/apalis_imx6.h | 1 - include/configs/colibri_imx6.h | 1 - include/configs/dh_imx6.h | 1 - include/configs/ge_bx50v3.h | 17 +-------- include/configs/kp_imx53.h | 113 ++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/configs/kp_imx6q_tpc.h | 2 - include/configs/mx31pdk.h | 2 - include/configs/mx53ppd.h | 1 - include/configs/mx6_common.h | 3 -- include/configs/mx7_common.h | 3 -- include/configs/nitrogen6x.h | 179 +++++++++++++++++++++---------------------------------------------------------------- include/fsl_pmic.h | 41 ++++++++++++++++++++ include/power/pmic.h | 2 + 41 files changed, 1126 insertions(+), 332 deletions(-) create mode 100644 arch/arm/dts/imx53-kp.dts create mode 100644 arch/arm/mach-imx/mx3/Kconfig create mode 100644 board/k+p/kp_imx53/Kconfig create mode 100644 board/k+p/kp_imx53/MAINTAINERS create mode 100644 board/k+p/kp_imx53/Makefile create mode 100644 board/k+p/kp_imx53/kp_id_rev.c create mode 100644 board/k+p/kp_imx53/kp_id_rev.h create mode 100644 board/k+p/kp_imx53/kp_imx53.c delete mode 100644 configs/ge_b650v3_defconfig delete mode 100644 configs/ge_b850v3_defconfig rename configs/{ge_b450v3_defconfig => ge_bx50v3_defconfig} (93%) create mode 100644 configs/kp_imx53_defconfig create mode 100644 drivers/power/pmic/mc34708.c create mode 100644 include/configs/kp_imx53.h -- ===================================================================== DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-53 Fax: +49-8142-66989-80 Email: sbabic@denx.de ===================================================================== _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
Hi Stefano, Tom,
OK.
I'm fine with this coming along via the imx tree so we can get it in now.
Hi Tom, Stefano,
Hi Stefano, Tom,
-0400)
pinctrl
OK.
I would also opt for this option.
For the future - I've looked at:
http://git.denx.de/?p=u-boot/u-boot-pmic.git;a=summary https://www.denx.de/wiki/U-Boot/Custodians (which seems outdated anyway)
It seems like u-boot-pmic repo is dead (as Przemek is not doing any open source work since 2017). If you think that it helps - I can take it and rise my hand to be PMIC maintainer (again).
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Lukasz Majewski
Stefano Babic
