[U-Boot-Users] [PATCH 4/8] New board SIMPC8313 support: support for booting from NAND in start.S
Reorganization/optimization of a few functions to fit into the 4K FCM boot RAM of the MPC8313 for nand_spl build.
Signed-off-by: Ron Madrid --- cpu/mpc83xx/start.S | 310 ++++++++++++++++++++++++++++++++++++--------------- 1 files changed, 220 insertions(+), 90 deletions(-)
diff --git a/cpu/mpc83xx/start.S b/cpu/mpc83xx/start.S index 309eb30..39bcaa8 100644 --- a/cpu/mpc83xx/start.S +++ b/cpu/mpc83xx/start.S @@ -63,6 +63,9 @@ * Use r14 to access the GOT */ START_GOT +#if defined(CONFIG_NAND_SPL) + GOT_ENTRY(_GOT_TABLE_) +#else GOT_ENTRY(_GOT2_TABLE_) GOT_ENTRY(_FIXUP_TABLE_)
@@ -74,6 +77,7 @@ GOT_ENTRY(__init_end) GOT_ENTRY(_end) GOT_ENTRY(__bss_start) +#endif /* CONFIG_NAND_SPL */ END_GOT
/* @@ -103,7 +107,56 @@ version_string: .ascii U_BOOT_VERSION .ascii " (", __DATE__, " - ", __TIME__, ")" .ascii " ", CONFIG_IDENT_STRING, "\0" + .align 4 + +/*****************************************************************/ + + .globl enable_addr_trans +enable_addr_trans: + /* enable address translation */ + mfmsr r5 + ori r5, r5, (MSR_IR | MSR_DR) + mtmsr r5 + isync + blr + +/* Cache functions. + * + * Note: requires that all cache bits in + * HID0 are in the low half word. + */ + .globl icache_enable +icache_enable: + mfspr r3, HID0 + ori r3, r3, HID0_ICE + li r4, HID0_ILOCK + andc r3, r3, r4 + ori r4, r3, HID0_ICFI + isync + mtspr HID0, r4 /* sets enable and invalidate, clears lock */ + isync + mtspr HID0, r3 /* clears invalidate */ + blr + + .globl dcache_enable +dcache_enable: + mfspr r3, HID0 + li r5, HID0_DCFI|HID0_DLOCK + andc r3, r3, r5 + mtspr HID0, r3 /* no invalidate, unlock */ + ori r3, r3, HID0_DCE + ori r5, r3, HID0_DCFI + mtspr HID0, r5 /* enable + invalidate */ + mtspr HID0, r3 /* enable */ + sync + blr + + .globl get_pvr +get_pvr: + mfspr r3, PVR + blr
#ifndef CONFIG_DEFAULT_IMMR #error CONFIG_DEFAULT_IMMR must be defined @@ -165,7 +218,7 @@ boot_warm: /* time t 5 */
bl init_e300_core
-#ifndef CFG_RAMBOOT +#if !defined(CFG_RAMBOOT) && !defined(CONFIG_NAND_U_BOOT)
/* Inflate flash location so it appears everywhere, calculate */ /* the absolute address in final location of the FLASH, jump */ @@ -181,7 +234,7 @@ in_flash: #if 1 /* Remapping flash with LAW0. */ bl remap_flash_by_law0 #endif -#endif /* CFG_RAMBOOT */ +#endif /* !defined(CFG_RAMBOOT) && !defined(CONFIG_NAND_U_BOOT) */
/* setup the bats */ bl setup_bats @@ -234,6 +287,7 @@ in_flash: /* run low-level CPU init code (in Flash)*/ bl cpu_init_f
+#if !defined(CONFIG_NAND_SPL) /* r3: BOOTFLAG */ mr r3, r21 /* run 1st part of board init code (in Flash)*/ @@ -428,6 +482,7 @@ int_return: lwz r1,GPR1(r1) SYNC rfi +#endif /* CONFIG_NAND_SPL */
/* * This code initialises the E300 processor core @@ -550,6 +605,7 @@ init_e300_core: /* time t 10 */ /*------------------------------*/ blr
+#if !defined(CONFIG_NAND_SPL) .globl invalidate_bats invalidate_bats: /* invalidate BATs */ @@ -577,6 +633,7 @@ invalidate_bats: isync sync blr +#endif /* CONFIG_NAND_SPL */
/* setup_bats - set them up to some initial state */ .globl setup_bats @@ -584,148 +641,228 @@ setup_bats: addis r0, r0, 0x0000
/* IBAT 0 */ +#if ((CFG_IBAT0L == 0) && (CFG_IBAT0U == 0)) + mtspr IBAT0L, r0 + mtspr IBAT0U, r0 +#else addis r4, r0, CFG_IBAT0L@h ori r4, r4, CFG_IBAT0L@l addis r3, r0, CFG_IBAT0U@h ori r3, r3, CFG_IBAT0U@l mtspr IBAT0L, r4 mtspr IBAT0U, r3 +#endif isync
/* DBAT 0 */ +#if ((CFG_DBAT0L == 0) && (CFG_DBAT0U == 0)) + mtspr DBAT0L, r0 + mtspr DBAT0U, r0 +#else addis r4, r0, CFG_DBAT0L@h ori r4, r4, CFG_DBAT0L@l addis r3, r0, CFG_DBAT0U@h ori r3, r3, CFG_DBAT0U@l mtspr DBAT0L, r4 mtspr DBAT0U, r3 +#endif isync
/* IBAT 1 */ +#if ((CFG_IBAT1L == 0) && (CFG_IBAT1U == 0)) + mtspr IBAT1L, r0 + mtspr IBAT1U, r0 +#else addis r4, r0, CFG_IBAT1L@h ori r4, r4, CFG_IBAT1L@l addis r3, r0, CFG_IBAT1U@h ori r3, r3, CFG_IBAT1U@l mtspr IBAT1L, r4 mtspr IBAT1U, r3 +#endif isync
/* DBAT 1 */ +#if ((CFG_DBAT1L == 0) && (CFG_DBAT1U == 0)) + mtspr DBAT1L, r0 + mtspr DBAT1U, r0 +#else addis r4, r0, CFG_DBAT1L@h ori r4, r4, CFG_DBAT1L@l addis r3, r0, CFG_DBAT1U@h ori r3, r3, CFG_DBAT1U@l mtspr DBAT1L, r4 mtspr DBAT1U, r3 +#endif isync
/* IBAT 2 */ +#if ((CFG_IBAT2L == 0) && (CFG_IBAT2U == 0)) + mtspr IBAT2L, r0 + mtspr IBAT2U, r0 +#else addis r4, r0, CFG_IBAT2L@h ori r4, r4, CFG_IBAT2L@l addis r3, r0, CFG_IBAT2U@h ori r3, r3, CFG_IBAT2U@l mtspr IBAT2L, r4 mtspr IBAT2U, r3 +#endif isync
/* DBAT 2 */ +#if ((CFG_DBAT2L == 0) && (CFG_DBAT2U == 0)) + mtspr DBAT2L, r0 + mtspr DBAT2U, r0 +#else addis r4, r0, CFG_DBAT2L@h ori r4, r4, CFG_DBAT2L@l addis r3, r0, CFG_DBAT2U@h ori r3, r3, CFG_DBAT2U@l mtspr DBAT2L, r4 mtspr DBAT2U, r3 +#endif isync
/* IBAT 3 */ +#if ((CFG_IBAT3L == 0) && (CFG_IBAT3U == 0)) + mtspr IBAT3L, r0 + mtspr IBAT3U, r0 +#else addis r4, r0, CFG_IBAT3L@h ori r4, r4, CFG_IBAT3L@l addis r3, r0, CFG_IBAT3U@h ori r3, r3, CFG_IBAT3U@l mtspr IBAT3L, r4 mtspr IBAT3U, r3 +#endif isync
/* DBAT 3 */ +#if ((CFG_DBAT3L == 0) && (CFG_DBAT3U == 0)) + mtspr DBAT3L, r0 + mtspr DBAT3U, r0 +#else addis r4, r0, CFG_DBAT3L@h ori r4, r4, CFG_DBAT3L@l addis r3, r0, CFG_DBAT3U@h ori r3, r3, CFG_DBAT3U@l mtspr DBAT3L, r4 mtspr DBAT3U, r3 +#endif isync
#if (CFG_HID2 & HID2_HBE) /* IBAT 4 */ +#if ((CFG_IBAT4L == 0) && (CFG_IBAT4U == 0)) + mtspr IBAT4L, r0 + mtspr IBAT4U, r0 +#else addis r4, r0, CFG_IBAT4L@h ori r4, r4, CFG_IBAT4L@l addis r3, r0, CFG_IBAT4U@h ori r3, r3, CFG_IBAT4U@l mtspr IBAT4L, r4 mtspr IBAT4U, r3 +#endif isync
/* DBAT 4 */ +#if ((CFG_DBAT4L == 0) && (CFG_DBAT4U == 0)) + mtspr DBAT4L, r0 + mtspr DBAT4U, r0 +#else addis r4, r0, CFG_DBAT4L@h ori r4, r4, CFG_DBAT4L@l addis r3, r0, CFG_DBAT4U@h ori r3, r3, CFG_DBAT4U@l mtspr DBAT4L, r4 mtspr DBAT4U, r3 +#endif isync
/* IBAT 5 */ +#if ((CFG_IBAT5L == 0) && (CFG_IBAT5U == 0)) + mtspr IBAT5L, r0 + mtspr IBAT5U, r0 +#else addis r4, r0, CFG_IBAT5L@h ori r4, r4, CFG_IBAT5L@l addis r3, r0, CFG_IBAT5U@h ori r3, r3, CFG_IBAT5U@l mtspr IBAT5L, r4 mtspr IBAT5U, r3 +#endif isync
/* DBAT 5 */ +#if ((CFG_DBAT5L == 0) && (CFG_DBAT5U == 0)) + mtspr DBAT5L, r0 + mtspr DBAT5U, r0 +#else addis r4, r0, CFG_DBAT5L@h ori r4, r4, CFG_DBAT5L@l addis r3, r0, CFG_DBAT5U@h ori r3, r3, CFG_DBAT5U@l mtspr DBAT5L, r4 mtspr DBAT5U, r3 +#endif isync
/* IBAT 6 */ +#if ((CFG_IBAT6L == 0) && (CFG_IBAT6U == 0)) + mtspr IBAT6L, r0 + mtspr IBAT6U, r0 +#else addis r4, r0, CFG_IBAT6L@h ori r4, r4, CFG_IBAT6L@l addis r3, r0, CFG_IBAT6U@h ori r3, r3, CFG_IBAT6U@l mtspr IBAT6L, r4 mtspr IBAT6U, r3 +#endif isync
/* DBAT 6 */ +#if ((CFG_DBAT6L == 0) && (CFG_DBAT6U == 0)) + mtspr DBAT6L, r0 + mtspr DBAT6U, r0 +#else addis r4, r0, CFG_DBAT6L@h ori r4, r4, CFG_DBAT6L@l addis r3, r0, CFG_DBAT6U@h ori r3, r3, CFG_DBAT6U@l mtspr DBAT6L, r4 mtspr DBAT6U, r3 +#endif isync
/* IBAT 7 */ +#if ((CFG_IBAT7L == 0) && (CFG_IBAT7U == 0)) + mtspr IBAT7L, r0 + mtspr IBAT7U, r0 +#else addis r4, r0, CFG_IBAT7L@h ori r4, r4, CFG_IBAT7L@l addis r3, r0, CFG_IBAT7U@h ori r3, r3, CFG_IBAT7U@l mtspr IBAT7L, r4 mtspr IBAT7U, r3 +#endif isync
/* DBAT 7 */ +#if ((CFG_DBAT7L == 0) && (CFG_DBAT7U == 0)) + mtspr DBAT7L, r0 + mtspr DBAT7U, r0 +#else addis r4, r0, CFG_DBAT7L@h ori r4, r4, CFG_DBAT7L@l addis r3, r0, CFG_DBAT7U@h ori r3, r3, CFG_DBAT7U@l mtspr DBAT7L, r4 mtspr DBAT7U, r3 +#endif isync #endif
@@ -744,15 +881,7 @@ setup_bats:
blr
- .globl enable_addr_trans -enable_addr_trans: - /* enable address translation */ - mfmsr r5 - ori r5, r5, (MSR_IR | MSR_DR) - mtmsr r5 - isync - blr - +#if !defined(CONFIG_NAND_SPL) .globl disable_addr_trans disable_addr_trans: /* disable address translation */ @@ -770,20 +899,6 @@ disable_addr_trans: * Note: requires that all cache bits in * HID0 are in the low half word. */ - .globl icache_enable -icache_enable: - mfspr r3, HID0 - ori r3, r3, HID0_ICE - lis r4, 0 - ori r4, r4, HID0_ILOCK - andc r3, r3, r4 - ori r4, r3, HID0_ICFI - isync - mtspr HID0, r4 /* sets enable and invalidate, clears lock */ - isync - mtspr HID0, r3 /* clears invalidate */ - blr - .globl icache_disable icache_disable: mfspr r3, HID0 @@ -802,20 +917,9 @@ icache_status: mfspr r3, HID0 rlwinm r3, r3, (31 - HID0_ICE_SHIFT + 1), 31, 31 blr +#endif /* CONFIG_NAND_SPL */
- .globl dcache_enable -dcache_enable: - mfspr r3, HID0 - li r5, HID0_DCFI|HID0_DLOCK - andc r3, r3, r5 - mtspr HID0, r3 /* no invalidate, unlock */ - ori r3, r3, HID0_DCE - ori r5, r3, HID0_DCFI - mtspr HID0, r5 /* enable + invalidate */ - mtspr HID0, r3 /* enable */ - sync - blr - +#if !defined(CONFIG_NAND_SPL) .globl dcache_disable dcache_disable: mfspr r3, HID0 @@ -835,11 +939,6 @@ dcache_status: rlwinm r3, r3, (31 - HID0_DCE_SHIFT + 1), 31, 31 blr
- .globl get_pvr -get_pvr: - mfspr r3, PVR - blr - .globl ppcDWstore ppcDWstore: lfd 1, 0(r4) @@ -853,6 +952,7 @@ ppcDWload: blr
/*-------------------------------------------------------------------*/ +#endif /* CONFIG_NAND_SPL */
/* * void relocate_code (addr_sp, gd, addr_moni) @@ -872,10 +972,17 @@ relocate_code: mr r10, r5 /* Save copy of Destination Address */
mr r3, r5 /* Destination Address */ + +#if !defined(CONFIG_NAND_SPL) lis r4, CFG_MONITOR_BASE@h /* Source Address */ ori r4, r4, CFG_MONITOR_BASE@l lwz r5, GOT(__init_end) sub r5, r5, r4 +#else + lis r4, CFG_NAND_BASE@h /* Source Address */ + ori r4, r4, CFG_NAND_BASE@l + li r5, 0x1000 /* 4 kbyte bootloader */ +#endif /* CONFIG_NAND_SPL */ li r6, CFG_CACHELINE_SIZE /* Cache Line Size */
/* @@ -968,8 +1075,72 @@ relocate_code: mtlr r0 blr
+#ifdef CFG_INIT_RAM_LOCK +lock_ram_in_cache: + /* Allocate Initial RAM in data cache. + */ + lis r3, (CFG_INIT_RAM_ADDR & ~31)@h + ori r3, r3, (CFG_INIT_RAM_ADDR & ~31)@l + li r2, ((CFG_INIT_RAM_END & ~31) + \ + (CFG_INIT_RAM_ADDR & 31) + 31) / 32 + mtctr r2 +1: + dcbz r0, r3 + addi r3, r3, 32 + bdnz 1b + + /* Lock the data cache */ + mfspr r0, HID0 + ori r0, r0, 0x1000 + sync + mtspr HID0, r0 + sync + blr + +.globl unlock_ram_in_cache +unlock_ram_in_cache: + /* invalidate the INIT_RAM section */ + lis r3, (CFG_INIT_RAM_ADDR & ~31)@h + ori r3, r3, (CFG_INIT_RAM_ADDR & ~31)@l + li r2,512 + mtctr r2 +1: icbi r0, r3 + dcbi r0, r3 + addi r3, r3, 32 + bdnz 1b + sync /* Wait for all icbi to complete on bus */ + isync + + /* Unlock the data cache and invalidate it */ + mfspr r3, HID0 + li r5, HID0_DLOCK|HID0_DCFI + andc r3, r3, r5 /* no invalidate, unlock */ + ori r5, r3, HID0_DCFI /* invalidate, unlock */ + mtspr HID0, r5 /* invalidate, unlock */ + mtspr HID0, r3 /* no invalidate, unlock */ + sync + blr +#endif + in_ram:
+#if defined(CONFIG_NAND_SPL) + /* + * Adjust got table entries to fix pointers to strings + */ + li r0,__got_entries@sectoff@l + la r4,GOT(_GOT_TABLE_) + cmpwi r0,0 + mtctr r0 + addi r4,r4,-4 + beq 4f +3: lwzu r3,4(r4) + add r3,r3,r15 + stw r3,0(r4) + bdnz 3b +4: + +#else /* * Relocation Function, r14 point to got2+0x8000 * @@ -1035,8 +1206,11 @@ clear_bss:
mr r3, r9 /* Global Data pointer */ mr r4, r10 /* Destination Address */ +#endif /* CONFIG_NAND_SPL */ + bl board_init_r
+#if !defined(CONFIG_NAND_SPL) /* * Copy exception vector code to low memory * @@ -1120,53 +1294,7 @@ trap_reloc:
blr
-#ifdef CFG_INIT_RAM_LOCK -lock_ram_in_cache: - /* Allocate Initial RAM in data cache. - */ - lis r3, (CFG_INIT_RAM_ADDR & ~31)@h - ori r3, r3, (CFG_INIT_RAM_ADDR & ~31)@l - li r2, ((CFG_INIT_RAM_END & ~31) + \ - (CFG_INIT_RAM_ADDR & 31) + 31) / 32 - mtctr r2 -1: - dcbz r0, r3 - addi r3, r3, 32 - bdnz 1b - - /* Lock the data cache */ - mfspr r0, HID0 - ori r0, r0, 0x1000 - sync - mtspr HID0, r0 - sync - blr - -.globl unlock_ram_in_cache -unlock_ram_in_cache: - /* invalidate the INIT_RAM section */ - lis r3, (CFG_INIT_RAM_ADDR & ~31)@h - ori r3, r3, (CFG_INIT_RAM_ADDR & ~31)@l - li r2,512 - mtctr r2 -1: icbi r0, r3 - dcbi r0, r3 - addi r3, r3, 32 - bdnz 1b - sync /* Wait for all icbi to complete on bus */ - isync - - /* Unlock the data cache and invalidate it */ - mfspr r3, HID0 - li r5, HID0_DLOCK|HID0_DCFI - andc r3, r3, r5 /* no invalidate, unlock */ - ori r5, r3, HID0_DCFI /* invalidate, unlock */ - mtspr HID0, r5 /* invalidate, unlock */ - mtspr HID0, r3 /* no invalidate, unlock */ - sync - blr -#endif - +#if !defined(CONFIG_NAND_U_BOOT) map_flash_by_law1: /* When booting from ROM (Flash or EPROM), clear the */ /* Address Mask in OR0 so ROM appears everywhere */ @@ -1245,3 +1373,5 @@ remap_flash_by_law0: stw r4, LBLAWBAR1(r3) stw r4, LBLAWAR1(r3) /* Off LBIU LAW1 */ blr +#endif /* CONFIG_NAND_U_BOOT */ +#endif /* CONFIG_NAND_SPL */
there are a lot of changes here that don't seem necessary or gratuitous
- k
With the limited space I found that I needed to save every byte I could. What in particular concerns you?
- k
[Dave] I strongly suggest we create one lite new start.S for the NAND boot, not modify the original start.S
- Use r14 to access the GOT
- GOT_ENTRY(_GOT_TABLE_)
I'd prefer otherwise, if we can keep the #ifdeffing to a minimum.
-Scott
[Dave] The new start.S for NAND boot should be very lite. same things for 85xx/86xx, creating new start.S for e500/e600 for NAND boot. I don't like some much #ifdefine n the start.S which has not good readable.
Dear Liu,
in message 58A20A281BAF1047B4EAE68DE5C0BDC2C82259@zch01exm21.fsl.freescale.net you wrote:
[Dave] The new start.S for NAND boot should be very lite. same things for 85xx/86xx, creating new start.S for e500/e600 for NAND boot. I don't like some much #ifdefine n the start.S which has not good > readable.
Your quoting is a mess.
Please read http://www.netmeister.org/news/learn2quote.html
Please read it, and fix your quoting.
------_=_NextPart_001_01C8C2A8.E5EB52D1 Content-Type: text/html; charset="iso-8859-1" Content-Transfer-Encoding: quoted-printable
And stop posting HTML.
w/o knowing what has to fit in the first 4k page for NAND for 83xx, 86xx, and 85xx its difficult to suggest solutions. However could we do something evil and #include start_template.S in the two locations or something like that (So the actual source isn't duplicated)?
- k
OK. Thank you for responding, this was my biggest concern. I tried to talk about what should be done about this before, but people didn't appear to be very interested.
Is this something that will go into the cpu/mpc83xx/ folder as well? If you'd like I can strip out everything that isn't involved in the NAND boot (as far as I know) at see what people think. Or is this something that the folks at Freescale would rather do? Let me know.
What actual does the NAND version of start.S need to do?
- k
participants (5)
Kumar Gala
Liu Dave
Ron Madrid
Scott Wood
