[U-Boot] [PATCH 0/2] Add Tinker Board support
This patch set add support for Asus Tinker board.
Eddie Cai (2): rockchip: rename miniarm to tinker board dts: rk3288: change the dmc configuration to LPDDR3
arch/arm/dts/Makefile | 2 +- arch/arm/dts/rk3288-miniarm.dts | 58 ---------------------- arch/arm/dts/rk3288-tinker.dts | 57 +++++++++++++++++++++ .../{rk3288-miniarm.dtsi => rk3288-tinker.dtsi} | 0 arch/arm/mach-rockchip/rk3288-board.c | 2 +- arch/arm/mach-rockchip/rk3288/Kconfig | 8 +-- board/rockchip/miniarm_rk3288/MAINTAINERS | 6 --- .../{miniarm_rk3288 => tinker_rk3288}/Kconfig | 6 +-- board/rockchip/tinker_rk3288/MAINTAINERS | 6 +++ .../{miniarm_rk3288 => tinker_rk3288}/Makefile | 2 +- .../tinker-rk3288.c} | 0 ...rm-rk3288_defconfig => tinker-rk3288_defconfig} | 4 +- doc/README.rockchip | 2 +- .../configs/{miniarm_rk3288.h => tinker_rk3288.h} | 0 14 files changed, 76 insertions(+), 77 deletions(-) delete mode 100644 arch/arm/dts/rk3288-miniarm.dts create mode 100644 arch/arm/dts/rk3288-tinker.dts rename arch/arm/dts/{rk3288-miniarm.dtsi => rk3288-tinker.dtsi} (100%) delete mode 100644 board/rockchip/miniarm_rk3288/MAINTAINERS rename board/rockchip/{miniarm_rk3288 => tinker_rk3288}/Kconfig (64%) create mode 100644 board/rockchip/tinker_rk3288/MAINTAINERS rename board/rockchip/{miniarm_rk3288 => tinker_rk3288}/Makefile (79%) rename board/rockchip/{miniarm_rk3288/miniarm-rk3288.c => tinker_rk3288/tinker-rk3288.c} (100%) rename configs/{miniarm-rk3288_defconfig => tinker-rk3288_defconfig} (95%) rename include/configs/{miniarm_rk3288.h => tinker_rk3288.h} (100%)
Miniarm is the internal project code. Now it is officially named Tinker board. So rename it.
Signed-off-by: Eddie Cai eddie.cai@rock-chips.com --- arch/arm/dts/Makefile | 2 +- arch/arm/dts/{rk3288-miniarm.dts => rk3288-tinker.dts} | 6 +++--- arch/arm/dts/{rk3288-miniarm.dtsi => rk3288-tinker.dtsi} | 0 arch/arm/mach-rockchip/rk3288-board.c | 2 +- arch/arm/mach-rockchip/rk3288/Kconfig | 8 ++++---- board/rockchip/miniarm_rk3288/MAINTAINERS | 6 ------ board/rockchip/{miniarm_rk3288 => tinker_rk3288}/Kconfig | 6 +++--- board/rockchip/tinker_rk3288/MAINTAINERS | 6 ++++++ board/rockchip/{miniarm_rk3288 => tinker_rk3288}/Makefile | 2 +- .../miniarm-rk3288.c => tinker_rk3288/tinker-rk3288.c} | 0 configs/{miniarm-rk3288_defconfig => tinker-rk3288_defconfig} | 4 ++-- doc/README.rockchip | 2 +- include/configs/{miniarm_rk3288.h => tinker_rk3288.h} | 0 13 files changed, 22 insertions(+), 22 deletions(-) rename arch/arm/dts/{rk3288-miniarm.dts => rk3288-tinker.dts} (86%) rename arch/arm/dts/{rk3288-miniarm.dtsi => rk3288-tinker.dtsi} (100%) delete mode 100644 board/rockchip/miniarm_rk3288/MAINTAINERS rename board/rockchip/{miniarm_rk3288 => tinker_rk3288}/Kconfig (64%) create mode 100644 board/rockchip/tinker_rk3288/MAINTAINERS rename board/rockchip/{miniarm_rk3288 => tinker_rk3288}/Makefile (79%) rename board/rockchip/{miniarm_rk3288/miniarm-rk3288.c => tinker_rk3288/tinker-rk3288.c} (100%) rename configs/{miniarm-rk3288_defconfig => tinker-rk3288_defconfig} (95%) rename include/configs/{miniarm_rk3288.h => tinker_rk3288.h} (100%)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 66ea0b3..b117b51 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -36,7 +36,7 @@ dtb-$(CONFIG_ARCH_ROCKCHIP) += \ rk3288-rock2-square.dtb \ rk3288-evb.dtb \ rk3288-fennec.dtb \ - rk3288-miniarm.dtb \ + rk3288-tinker.dtb \ rk3288-popmetal.dtb \ rk3399-evb.dtb dtb-$(CONFIG_ARCH_MESON) += \ diff --git a/arch/arm/dts/rk3288-miniarm.dts b/arch/arm/dts/rk3288-tinker.dts similarity index 86% rename from arch/arm/dts/rk3288-miniarm.dts rename to arch/arm/dts/rk3288-tinker.dts index 9083028..4dacc76 100644 --- a/arch/arm/dts/rk3288-miniarm.dts +++ b/arch/arm/dts/rk3288-tinker.dts @@ -5,11 +5,11 @@ */
/dts-v1/; -#include "rk3288-miniarm.dtsi" +#include "rk3288-tinker.dtsi"
/ { - model = "Miniarm-RK3288"; - compatible = "rockchip,rk3288-miniarm", "rockchip,rk3288"; + model = "Tinker-RK3288"; + compatible = "rockchip,rk3288-tinker", "rockchip,rk3288";
chosen { stdout-path = &uart2; diff --git a/arch/arm/dts/rk3288-miniarm.dtsi b/arch/arm/dts/rk3288-tinker.dtsi similarity index 100% rename from arch/arm/dts/rk3288-miniarm.dtsi rename to arch/arm/dts/rk3288-tinker.dtsi diff --git a/arch/arm/mach-rockchip/rk3288-board.c b/arch/arm/mach-rockchip/rk3288-board.c index 8bf45f7..9894a25 100644 --- a/arch/arm/mach-rockchip/rk3288-board.c +++ b/arch/arm/mach-rockchip/rk3288-board.c @@ -60,7 +60,7 @@ int rk3288_qos_init(void) writel(val, CPU_AXI_QOS_PRIORITY + VIO1_VOP_QOS);
if (!fdt_node_check_compatible(gd->fdt_blob, 0, - "rockchip,rk3288-miniarm")) + "rockchip,rk3288-tinker")) { /* set isp qos to higher priority */ writel(val, CPU_AXI_QOS_PRIORITY + VIO1_ISP_R_QOS); diff --git a/arch/arm/mach-rockchip/rk3288/Kconfig b/arch/arm/mach-rockchip/rk3288/Kconfig index 54545f3..c94df4e 100644 --- a/arch/arm/mach-rockchip/rk3288/Kconfig +++ b/arch/arm/mach-rockchip/rk3288/Kconfig @@ -33,10 +33,10 @@ config TARGET_POPMETAL_RK3288 2GB DDR3. Expansion connectors provide access to I2C, SPI, UART, GPIOs and display interface.
-config TARGET_MINIARM_RK3288 - bool "miniarm-RK3288" +config TARGET_TINKER_RK3288 + bool "Tinker-RK3288" help - Miniarm is a RK3288-based development board with 2 USB ports, HDMI, + Tinker is a RK3288-based development board with 2 USB ports, HDMI, micro-SD card, audio, Gigabit Ethernet. It also includes on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provide access to I2C, SPI, UART, GPIOs. @@ -115,6 +115,6 @@ source "board/rockchip/evb_rk3288/Kconfig"
source "board/rockchip/fennec_rk3288/Kconfig"
-source "board/rockchip/miniarm_rk3288/Kconfig" +source "board/rockchip/tinker_rk3288/Kconfig"
endif diff --git a/board/rockchip/miniarm_rk3288/MAINTAINERS b/board/rockchip/miniarm_rk3288/MAINTAINERS deleted file mode 100644 index 7537b8f..0000000 --- a/board/rockchip/miniarm_rk3288/MAINTAINERS +++ /dev/null @@ -1,6 +0,0 @@ -MINIARM-RK3288 -M: Lin Huang hl@rock-chips.com -S: Maintained -F: board/rockchip/miniarm_rk3288 -F: include/configs/miniarm_rk3288.h -F: configs/miniarm-rk3288_defconfig diff --git a/board/rockchip/miniarm_rk3288/Kconfig b/board/rockchip/tinker_rk3288/Kconfig similarity index 64% rename from board/rockchip/miniarm_rk3288/Kconfig rename to board/rockchip/tinker_rk3288/Kconfig index 529c09f..bca6c37 100644 --- a/board/rockchip/miniarm_rk3288/Kconfig +++ b/board/rockchip/tinker_rk3288/Kconfig @@ -1,13 +1,13 @@ -if TARGET_MINIARM_RK3288 +if TARGET_TINKER_RK3288
config SYS_BOARD - default "miniarm_rk3288" + default "tinker_rk3288"
config SYS_VENDOR default "rockchip"
config SYS_CONFIG_NAME - default "miniarm_rk3288" + default "tinker_rk3288"
config BOARD_SPECIFIC_OPTIONS # dummy def_bool y diff --git a/board/rockchip/tinker_rk3288/MAINTAINERS b/board/rockchip/tinker_rk3288/MAINTAINERS new file mode 100644 index 0000000..cddceaf --- /dev/null +++ b/board/rockchip/tinker_rk3288/MAINTAINERS @@ -0,0 +1,6 @@ +TINKER-RK3288 +M: Lin Huang hl@rock-chips.com +S: Maintained +F: board/rockchip/tinker_rk3288 +F: include/configs/tinker_rk3288.h +F: configs/tinker-rk3288_defconfig diff --git a/board/rockchip/miniarm_rk3288/Makefile b/board/rockchip/tinker_rk3288/Makefile similarity index 79% rename from board/rockchip/miniarm_rk3288/Makefile rename to board/rockchip/tinker_rk3288/Makefile index 9419b91..432367f 100644 --- a/board/rockchip/miniarm_rk3288/Makefile +++ b/board/rockchip/tinker_rk3288/Makefile @@ -4,4 +4,4 @@ # SPDX-License-Identifier: GPL-2.0+ #
-obj-y += miniarm-rk3288.o +obj-y += tinker-rk3288.o diff --git a/board/rockchip/miniarm_rk3288/miniarm-rk3288.c b/board/rockchip/tinker_rk3288/tinker-rk3288.c similarity index 100% rename from board/rockchip/miniarm_rk3288/miniarm-rk3288.c rename to board/rockchip/tinker_rk3288/tinker-rk3288.c diff --git a/configs/miniarm-rk3288_defconfig b/configs/tinker-rk3288_defconfig similarity index 95% rename from configs/miniarm-rk3288_defconfig rename to configs/tinker-rk3288_defconfig index 2b6bd0b..bf7fec8 100644 --- a/configs/miniarm-rk3288_defconfig +++ b/configs/tinker-rk3288_defconfig @@ -3,9 +3,9 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_MALLOC_F_LEN=0x2000 CONFIG_ROCKCHIP_RK3288=y CONFIG_ROCKCHIP_SPL_BACK_TO_BROM=y -CONFIG_TARGET_MINIARM_RK3288=y +CONFIG_TARGET_TINKER_RK3288=y CONFIG_SPL_STACK_R_ADDR=0x80000 -CONFIG_DEFAULT_DEVICE_TREE="rk3288-miniarm" +CONFIG_DEFAULT_DEVICE_TREE="rk3288-tinker" CONFIG_SILENT_CONSOLE=y CONFIG_CONSOLE_MUX=y # CONFIG_DISPLAY_CPUINFO is not set diff --git a/doc/README.rockchip b/doc/README.rockchip index 43cafc7..186a1a0 100644 --- a/doc/README.rockchip +++ b/doc/README.rockchip @@ -42,7 +42,7 @@ At present seven RK3288 boards are supported: - Fennec RK3288 - use fennec-rk3288 configuration - Firefly RK3288 - use firefly-rk3288 configuration - Hisense Chromebook - use chromebook_jerry configuration - - Miniarm RK3288 - use miniarm-rk3288 configuration + - Tinker RK3288 - use tinker-rk3288 configuration - PopMetal RK3288 - use popmetal-rk3288 configuration - Radxa Rock 2 - use rock2 configuration
diff --git a/include/configs/miniarm_rk3288.h b/include/configs/tinker_rk3288.h similarity index 100% rename from include/configs/miniarm_rk3288.h rename to include/configs/tinker_rk3288.h
The final version of Tinker board is using two channel LPDDR3. So modify dmc configuration to meet it.
Signed-off-by: Eddie Cai eddie.cai@rock-chips.com --- arch/arm/dts/rk3288-tinker.dts | 17 ++++++++--------- 1 file changed, 8 insertions(+), 9 deletions(-)
diff --git a/arch/arm/dts/rk3288-tinker.dts b/arch/arm/dts/rk3288-tinker.dts index 4dacc76..090c100 100644 --- a/arch/arm/dts/rk3288-tinker.dts +++ b/arch/arm/dts/rk3288-tinker.dts @@ -17,17 +17,16 @@ };
&dmc { - rockchip,pctl-timing = <0x29a 0xc8 0x1f8 0x42 0x4e 0x4 0xea 0xa - 0x5 0x0 0xa 0x7 0x19 0x24 0xa 0x7 - 0x5 0xa 0x5 0x200 0x5 0x10 0x40 0x0 - 0x1 0x7 0x7 0x4 0xc 0x43 0x100 0x0 - 0x5 0x0>; - rockchip,phy-timing = <0x48f9aab4 0xea0910 0x1002c200 - 0xa60 0x40 0x10 0x0>; - rockchip,sdram-params = <0x30B25564 0x627 3 666000000 3 9 1>; + rockchip,pctl-timing = <0x215 0xc8 0x0 0x35 0x26 0x2 0x70 0x2000d + 0x6 0x0 0x8 0x4 0x17 0x24 0xd 0x6 + 0x4 0x8 0x4 0x76 0x4 0x0 0x30 0x0 + 0x1 0x2 0x2 0x4 0x0 0x0 0xc0 0x4 + 0x8 0x1f4>; + rockchip,phy-timing = <0x48d7dd93 0x187008d8 0x121076 + 0x0 0xc3 0x6 0x2>; + rockchip,sdram-params = <0x20d266a4 0x5b6 2 533000000 6 9 0>; };
- &pinctrl { u-boot,dm-pre-reloc; };
Eddie Cai
