[PATCH] crypto/fsl: add invalidate_dcache_range for hash output buffer
HW accelerated hash operations are giving incorrect hash output. so invalidate cache lines to avoid cache overwriting in DDR memory region.
caam_hash() -moved address alignment check in the beginning of function. -added invalidate_dcache_range for pout buffer before running descriptor.
Fixes: d7af2baa49 (crypto/fsl: Fix HW accelerated hash commands) Signed-off-by: Gaurav Jain gaurav.jain@nxp.com --- drivers/crypto/fsl/fsl_hash.c | 15 +++++++++------ 1 file changed, 9 insertions(+), 6 deletions(-)
diff --git a/drivers/crypto/fsl/fsl_hash.c b/drivers/crypto/fsl/fsl_hash.c index 2379b70c2d..a5d364ea42 100644 --- a/drivers/crypto/fsl/fsl_hash.c +++ b/drivers/crypto/fsl/fsl_hash.c @@ -168,18 +168,19 @@ int caam_hash(const unsigned char *pbuf, unsigned int buf_len, uint32_t *desc; unsigned int size;
- desc = malloc_cache_aligned(sizeof(int) * MAX_CAAM_DESCSIZE); - if (!desc) { - debug("Not enough memory for descriptor allocation\n"); - return -ENOMEM; - } - if (!IS_ALIGNED((uintptr_t)pbuf, ARCH_DMA_MINALIGN) || !IS_ALIGNED((uintptr_t)pout, ARCH_DMA_MINALIGN)) { puts("Error: Address arguments are not aligned\n"); return -EINVAL; }
+ debug("\ncaam hash\n"); + desc = malloc_cache_aligned(sizeof(int) * MAX_CAAM_DESCSIZE); + if (!desc) { + debug("Not enough memory for descriptor allocation\n"); + return -ENOMEM; + } + size = ALIGN(buf_len, ARCH_DMA_MINALIGN); flush_dcache_range((unsigned long)pbuf, (unsigned long)pbuf + size);
@@ -190,6 +191,8 @@ int caam_hash(const unsigned char *pbuf, unsigned int buf_len,
size = ALIGN(sizeof(int) * MAX_CAAM_DESCSIZE, ARCH_DMA_MINALIGN); flush_dcache_range((unsigned long)desc, (unsigned long)desc + size); + size = ALIGN(driver_hash[algo].digestsize, ARCH_DMA_MINALIGN); + invalidate_dcache_range((unsigned long)pout, (unsigned long)pout + size);
ret = run_descriptor_jr(desc);
Hi Gaurav,
Minor nit: please remove this line.
Reviewed-by: Fabio Estevam festevam@denx.de
Fabio Estevam
Gaurav Jain
