[U-Boot] [PATCH] disk: make get_partition_info() always available to disk.c
Now that get_device_and_partition() always calls get_partition_info() when disk.c is compiled, we must always compile the function, rather than ifdef it away.
Technically, this change is required before Rob's "disk/part: introduce get_device_and_partition" patch. However, at least when the compiler optimizer is turned on, it isn't required before then in practice, since get_device_and_partition() calls get_dev(), which is stubbed out in disk.c under exactly the same conditions that get_partition_info() is not compiled, and hence the compiler never generates code for the call to the missing function. However, in my later patch "disk: get_device_and_partition() "auto" partition and cleanup", the optimizer doesn't succeed at this, and may attempt to reference the undefined function.
Signed-off-by: Stephen Warren swarren@nvidia.com --- Rob, I wonder if you shouldn't squash this into your series. Then, I'll need to rebase mine on your again since this causes a few nasty conflicts with my series.
disk/part.c | 109 +++++++++++++++++++++++++++++------------------------------ 1 files changed, 54 insertions(+), 55 deletions(-)
diff --git a/disk/part.c b/disk/part.c index 76f3939..d2ace50 100644 --- a/disk/part.c +++ b/disk/part.c @@ -291,61 +291,6 @@ void init_part (block_dev_desc_t * dev_desc) }
-int get_partition_info (block_dev_desc_t *dev_desc, int part - , disk_partition_t *info) -{ - switch (dev_desc->part_type) { -#ifdef CONFIG_MAC_PARTITION - case PART_TYPE_MAC: - if (get_partition_info_mac(dev_desc,part,info) == 0) { - PRINTF ("## Valid MAC partition found ##\n"); - return (0); - } - break; -#endif - -#ifdef CONFIG_DOS_PARTITION - case PART_TYPE_DOS: - if (get_partition_info_dos(dev_desc,part,info) == 0) { - PRINTF ("## Valid DOS partition found ##\n"); - return (0); - } - break; -#endif - -#ifdef CONFIG_ISO_PARTITION - case PART_TYPE_ISO: - if (get_partition_info_iso(dev_desc,part,info) == 0) { - PRINTF ("## Valid ISO boot partition found ##\n"); - return (0); - } - break; -#endif - -#ifdef CONFIG_AMIGA_PARTITION - case PART_TYPE_AMIGA: - if (get_partition_info_amiga(dev_desc, part, info) == 0) - { - PRINTF ("## Valid Amiga partition found ##\n"); - return (0); - } - break; -#endif - -#ifdef CONFIG_EFI_PARTITION - case PART_TYPE_EFI: - if (get_partition_info_efi(dev_desc,part,info) == 0) { - PRINTF ("## Valid EFI partition found ##\n"); - return (0); - } - break; -#endif - default: - break; - } - return (-1); -} - static void print_part_header (const char *type, block_dev_desc_t * dev_desc) { puts ("\nPartition Map for "); @@ -433,3 +378,57 @@ void print_part (block_dev_desc_t * dev_desc) #endif
#endif + +int get_partition_info(block_dev_desc_t *dev_desc, int part + , disk_partition_t *info) +{ + switch (dev_desc->part_type) { +#ifdef CONFIG_MAC_PARTITION + case PART_TYPE_MAC: + if (get_partition_info_mac(dev_desc, part, info) == 0) { + PRINTF("## Valid MAC partition found ##\n"); + return 0; + } + break; +#endif + +#ifdef CONFIG_DOS_PARTITION + case PART_TYPE_DOS: + if (get_partition_info_dos(dev_desc, part, info) == 0) { + PRINTF("## Valid DOS partition found ##\n"); + return 0; + } + break; +#endif + +#ifdef CONFIG_ISO_PARTITION + case PART_TYPE_ISO: + if (get_partition_info_iso(dev_desc, part, info) == 0) { + PRINTF("## Valid ISO boot partition found ##\n"); + return 0; + } + break; +#endif + +#ifdef CONFIG_AMIGA_PARTITION + case PART_TYPE_AMIGA: + if (get_partition_info_amiga(dev_desc, part, info) == 0) { + PRINTF("## Valid Amiga partition found ##\n"); + return 0; + } + break; +#endif + +#ifdef CONFIG_EFI_PARTITION + case PART_TYPE_EFI: + if (get_partition_info_efi(dev_desc, part, info) == 0) { + PRINTF("## Valid EFI partition found ##\n"); + return 0; + } + break; +#endif + default: + break; + } + return -1; +}
Uggh. Even this isn't quite enough; e.g. CONFIG_DOS_PARTITION can be enabled but not the defines that part_dos.c uses to ifdef out compilation of get_partition_info_dos(). That seems illegal to me, but anyway. I'll send another one once MAKEALL -a arm actually gets all the way to the end...
Stephen Warren
