[PATCH 1/2] configs: rockchip: rk3308: use CONFIG_DEFAULT_FDT_FILE
all rk3308 boards should use their own dtb file.
also, change fdt_addr_r to avoid following error: "ERROR: Did not find a cmdline Flattened Device Tree" it happens on Radxa ROCK Pi S (256MB/512MB) with kernel built from Radxa BSP.
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- configs/evb-rk3308_defconfig | 1 + configs/roc-cc-rk3308_defconfig | 1 + configs/rock-pi-s-rk3308_defconfig | 1 + include/configs/rk3308_common.h | 3 ++- 4 files changed, 5 insertions(+), 1 deletion(-)
diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index a13a809c1e..2c7ac88ed9 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -24,6 +24,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=0 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3308-evb.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x20000 diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index 9a789b212f..9cb90f6ee6 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -24,6 +24,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=0 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3308-roc-cc.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x20000 diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig index cc3274a98b..e2abe4b4f7 100644 --- a/configs/rock-pi-s-rk3308_defconfig +++ b/configs/rock-pi-s-rk3308_defconfig @@ -25,6 +25,7 @@ CONFIG_ANDROID_BOOT_IMAGE=y CONFIG_FIT=y CONFIG_FIT_VERBOSE=y CONFIG_BOOTDELAY=0 +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3308-rock-pi-s.dtb" CONFIG_SYS_CONSOLE_INFO_QUIET=y # CONFIG_DISPLAY_CPUINFO is not set CONFIG_SPL_MAX_SIZE=0x20000 diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index 7d55fcd975..a413af1bd4 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -16,11 +16,12 @@ #define ENV_MEM_LAYOUT_SETTINGS \ "scriptaddr=0x00500000\0" \ "pxefile_addr_r=0x00600000\0" \ - "fdt_addr_r=0x02800000\0" \ + "fdt_addr_r=0x03e00000\0" \ "kernel_addr_r=0x00680000\0" \ "ramdisk_addr_r=0x04000000\0"
#define CFG_EXTRA_ENV_SETTINGS \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ ENV_MEM_LAYOUT_SETTINGS \ "partitions=" PARTS_DEFAULT \ ROCKCHIP_DEVICE_SETTINGS \
enable CONFIG_OF_LIBFDT_OVERLAY and use it on Radxa ROCK Pi S.
Signed-off-by: FUKAUMI Naoki naoki@radxa.com --- configs/rock-pi-s-rk3308_defconfig | 1 + include/configs/rk3308_common.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig index e2abe4b4f7..ca4a1800e7 100644 --- a/configs/rock-pi-s-rk3308_defconfig +++ b/configs/rock-pi-s-rk3308_defconfig @@ -9,6 +9,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x800000 CONFIG_DEFAULT_DEVICE_TREE="rk3308-rock-pi-s" +CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 diff --git a/include/configs/rk3308_common.h b/include/configs/rk3308_common.h index a413af1bd4..861154fbeb 100644 --- a/include/configs/rk3308_common.h +++ b/include/configs/rk3308_common.h @@ -17,6 +17,7 @@ "scriptaddr=0x00500000\0" \ "pxefile_addr_r=0x00600000\0" \ "fdt_addr_r=0x03e00000\0" \ + "fdtoverlay_addr_r=0x03f00000\0" \ "kernel_addr_r=0x00680000\0" \ "ramdisk_addr_r=0x04000000\0"
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- "fdtoverlay_addr_r=0x03f00000\0" \ "kernel_addr_r=0x00680000\0" \ "ramdisk_addr_r=0x04000000\0"
Thanks, - Kever
FUKAUMI Naoki
Kever Yang
