[U-Boot-Users] Boot Sequence
I would like to ask a specific question for the ARM processor at91rm9200.
I have a custumize ARM board that uses two ARM flash model AT49BV64 ( each one is 8 Mbytes ) and two sdram model 48lc8m16a (each one is 16 M Bytes), it looks like an at91rm9200ek board, but the FLASH are not the same.
The first FLASH address is 0x1000.0000. The second FLASH address is 0x3000.0000. The RAM Adress is 0x2000.0000. In the first flash I have the uboot ( 0x1000.8000 ), the kernel( 0x1004.0000) and the ramdisk ( 0x1024.0000 ).
Right now I am using uboot 1.1.3, as far as I know it was modified to meet the board hardware?!
When the system boots up, the first thing that the system do is copy the uboot from the FLASH to the RAM at the adress 0x21f0.0000, and after that uboot programs is running in the RAM.
U-Boot> printenv bootdelay=3 baudrate=115200 bootargs=root=/dev/ram=rw initrd=0x21100000,6000000 ramdisk_size=15360 bootcmd=bootm 10040000 10240000 ethaddr="ca:zz:om:ar:in:oo stdin=serial stdout=serial stderr=serial filesize=BEC5B
The uboot program calls the kernel and the startup process keeps going on
For test purposes, I will update the Uboot to 1.1.4
I am using ELDK 4.0 and the last u-boot version, but there are some questions regarding boot process that I would like to know.
1) What is the physical address of the saved U-BOOT PROGRAM and the ENVIROMENT VARIABLES ( I am using enviroment size 4096 bytes ) in the flash ?
2) When we do boot the system thru xmodem, we send the loader.bin and after that the u-boot.bin, on the ARM doc there is a reference for the program boot.bin, what is the boot.bin for?
Regards,
Carlos
In message 000b01c6bae6$ddf39390$7c01a8c0@corp.tasksistemas.com.br you wrote:
That's an awful setup. Why don't you map the flash devices contigu- ously?
U-Boot 1.1.3 is old and obsolete and not supported any more. Use current code (top of tree in git repository).
Please use top of tree instead, and noit only for testing, but for permanent use.
- What is the physical address of the saved U-BOOT PROGRAM and the
That's defined by your board config file - how could we know?
- When we do boot the system thru xmodem, we send the loader.bin and after
Please ask the ARM guys about their documentation and their files. U-Boot does not need any boot.bin.
Firmware
