[U-Boot] [PATCH v2] tpm: tpm_tis_lpc: Add support for AT97SC3204
The Atmel AT97SC3204 is also TIS compliant. Modify the tpm_tis_lpc driver to check for the vid/did used by the Atmel AT97SC3204 and report an appropriate description.
Signed-off-by: George McCollister george.mccollister@gmail.com ---
Changes in v2: - Reorganized didvid check to make it more consistent with the original code - Return -ENODEV instead of -ENOENT when didvid doesn't match the expected value for the device
drivers/tpm/tpm_tis_lpc.c | 37 ++++++++++++++++++++++++++++--------- 1 file changed, 28 insertions(+), 9 deletions(-)
diff --git a/drivers/tpm/tpm_tis_lpc.c b/drivers/tpm/tpm_tis_lpc.c index b4efbb5..d2b3783 100644 --- a/drivers/tpm/tpm_tis_lpc.c +++ b/drivers/tpm/tpm_tis_lpc.c @@ -21,6 +21,21 @@
#define PREFIX "lpc_tpm: "
+enum i2c_chip_type { + SLB9635, + AT97SC3204, +}; + +static const char * const chip_name[] = { + [SLB9635] = "Infineon SLB9635 TT 1.2", + [AT97SC3204] = "Atmel AT97SC3204", +}; + +static const u32 chip_didvid[] = { + [SLB9635] = 0xb15d1, + [AT97SC3204] = 0x32041114, +}; + struct tpm_locality { u32 access; u8 padding0[4]; @@ -146,9 +161,9 @@ static int tis_wait_reg(struct tpm_tis_lpc_priv *priv, u32 *reg, u8 mask, static int tpm_tis_lpc_probe(struct udevice *dev) { struct tpm_tis_lpc_priv *priv = dev_get_priv(dev); - u32 vid, did; fdt_addr_t addr; u32 didvid; + ulong chip_type = dev_get_driver_data(dev);
addr = dev_get_addr(dev); if (addr == FDT_ADDR_T_NONE) @@ -156,14 +171,15 @@ static int tpm_tis_lpc_probe(struct udevice *dev) priv->regs = map_sysmem(addr, 0); didvid = tpm_read_word(priv, &priv->regs[0].did_vid);
- vid = didvid & 0xffff; - did = (didvid >> 16) & 0xffff; - if (vid != 0x15d1 || did != 0xb) { + if (didvid != chip_didvid[chip_type]) { + u32 vid, did; + vid = didvid & 0xffff; + did = (didvid >> 16) & 0xffff; debug("Invalid vendor/device ID %04x/%04x\n", vid, did); - return -ENOSYS; + return -ENODEV; }
- debug("Found TPM %s by %s\n", "SLB9635 TT 1.2", "Infineon"); + debug("Found TPM: %s\n", chip_name[chip_type]);
return 0; } @@ -421,11 +437,13 @@ static int tpm_tis_lpc_close(struct udevice *dev)
static int tpm_tis_get_desc(struct udevice *dev, char *buf, int size) { + ulong chip_type = dev_get_driver_data(dev); + if (size < 50) return -ENOSPC;
- return snprintf(buf, size, "1.2 TPM (vendor %s, chip %s)", - "Infineon", "SLB9635 TT 1.2"); + return snprintf(buf, size, "1.2 TPM (%s)", + chip_name[chip_type]); }
@@ -438,7 +456,8 @@ static const struct tpm_ops tpm_tis_lpc_ops = { };
static const struct udevice_id tpm_tis_lpc_ids[] = { - { .compatible = "infineon,slb9635lpc" }, + { .compatible = "infineon,slb9635lpc", .data = SLB9635 }, + { .compatible = "atmel,at97sc3204", .data = AT97SC3204 }, { } };
On 17 October 2016 at 08:24, George McCollister george.mccollister@gmail.com wrote:
Changes in v2:
Changes in v2:
Applied to u-boot-dm/next, thanks!
George McCollister
