[U-Boot] [U-BOOT][PATCH 4/4] mflash : Support word unaligned access
Signed-off-by: unsik Kim donari75@gmail.com --- drivers/block/mg_disk.c | 38 ++++++++++++++++++++++++++------------ drivers/block/mg_disk_prv.h | 5 +++++ 2 files changed, 31 insertions(+), 12 deletions(-)
diff --git a/drivers/block/mg_disk.c b/drivers/block/mg_disk.c index 113aa79..b74307a 100644 --- a/drivers/block/mg_disk.c +++ b/drivers/block/mg_disk.c @@ -240,6 +240,7 @@ static unsigned int mg_do_read_sects(void *buff, u32 sect_num, u32 sect_cnt) { u32 i, j, err; u8 *buff_ptr = buff; + union mg_uniwb uniwb;
err = mg_out(sect_num, sect_cnt, MG_CMD_RD); if (err) @@ -250,13 +251,20 @@ static unsigned int mg_do_read_sects(void *buff, u32 sect_num, u32 sect_cnt) if (err) return err;
- /* TODO : u16 unaligned case */ - for(j = 0; j < MG_SECTOR_SIZE >> 1; j++) { - *(u16 *)buff_ptr = - readw(mg_base() + MG_BUFF_OFFSET + (j << 1)); - buff_ptr += 2; + if ((u32)buff_ptr & 1) { + for (j = 0; j < MG_SECTOR_SIZE >> 1; j++) { + uniwb.w = readw(mg_base() + MG_BUFF_OFFSET + + (j << 1)); + *buff_ptr++ = uniwb.b[0]; + *buff_ptr++ = uniwb.b[1]; + } + } else { + for(j = 0; j < MG_SECTOR_SIZE >> 1; j++) { + *(u16 *)buff_ptr = readw(mg_base() + + MG_BUFF_OFFSET + (j << 1)); + buff_ptr += 2; + } } - writeb(MG_CMD_RD_CONF, mg_base() + MG_REG_COMMAND);
MG_DBG("%u (0x%8.8x) sector read", sect_num + i, @@ -372,6 +380,7 @@ static int mg_do_write_sects(void *buff, u32 sect_num, u32 sect_cnt) { u32 i, j, err; u8 *buff_ptr = buff; + union mg_uniwb uniwb;
err = mg_out(sect_num, sect_cnt, MG_CMD_WR); if (err) @@ -382,13 +391,18 @@ static int mg_do_write_sects(void *buff, u32 sect_num, u32 sect_cnt) if (err) return err;
- /* TODO : u16 unaligned case */ - for(j = 0; j < MG_SECTOR_SIZE >> 1; j++) { - writew(*(u16 *)buff_ptr, - mg_base() + MG_BUFF_OFFSET + (j << 1)); - buff_ptr += 2; + if ((u32)buff_ptr & 1) { + uniwb.b[0] = *buff_ptr++; + uniwb.b[1] = *buff_ptr++; + writew(uniwb.w, mg_base() + MG_BUFF_OFFSET + (j << 1)); + } else { + for(j = 0; j < MG_SECTOR_SIZE >> 1; j++) { + writew(*(u16 *)buff_ptr, + mg_base() + MG_BUFF_OFFSET + + (j << 1)); + buff_ptr += 2; + } } - writeb(MG_CMD_WR_CONF, mg_base() + MG_REG_COMMAND);
MG_DBG("%u (0x%8.8x) sector write", diff --git a/drivers/block/mg_disk_prv.h b/drivers/block/mg_disk_prv.h index a6b7299..8f22e28 100644 --- a/drivers/block/mg_disk_prv.h +++ b/drivers/block/mg_disk_prv.h @@ -120,6 +120,11 @@ #define MG_CMD_WR_CONF 0x3C #define MG_CMD_RD_CONF 0x40
+union mg_uniwb{ + u16 w; + u8 b[2]; +}; + /* main structure for mflash driver */ struct mg_host { struct mg_drv_data *drv_data;
unsik Kim
