[PATCH 0/5] sunxi: Control USB VBUS supplies via DT regulators
This series converts sunxi boards from controlling VBUS suppllies using GPIO name strings in Kconfig to using regulator devices probed via the devicetree. ARCH_SUNXI already implies DM_REGULATOR_FIXED, so the only new driver needed is for the AXP PMIC drivevbus regulator. This is part 2 of 3 for removing the PHY driver's GPIO Kconfig options. Part 1 was here[1]. Part 3 will finish converting the VBUS/ID detection GPIOs; it requires adding some missing DT properties to a couple of boards, so it will have to wait for at least the next DT sync from Linux.
I tried to verify (by inspection) every board affected by this change, but there is some possibility that this could break some boards. See the commit message for patch 3. I have CCed some relevant board maintaners; please test this patch series if you have the opportunity.
[1]: https://lore.kernel.org/u-boot/20230122234623.1636-1-samuel@sholland.org/
Samuel Holland (5): power: regulator: Add a driver for the AXP PMIC drivevbus sunxi: Enable PMIC drivevbus regulator support for USB supplies phy: sun4i-usb: Control supplies via the regulator uclass sunxi: Remove obsolete USBx_VBUS_PIN Kconfig symbols gpio: axp: Remove virtual VBUS enable GPIO
arch/arm/mach-sunxi/Kconfig | 29 -------- configs/A10s-OLinuXino-M_defconfig | 1 - configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/A20-Olimex-SOM-EVB_defconfig | 1 - configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 - configs/A20-Olimex-SOM204-EVB_defconfig | 1 - configs/A33-OLinuXino_defconfig | 2 +- configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T003_defconfig | 1 - configs/Auxtek-T004_defconfig | 1 - configs/Bananapi_M2_Ultra_defconfig | 2 - configs/Bananapro_defconfig | 2 - configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 1 - configs/CSQ_CS908_defconfig | 2 - configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 1 - configs/Cubieboard4_defconfig | 4 +- configs/Cubietruck_defconfig | 1 - configs/Cubietruck_plus_defconfig | 4 +- configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/Hummingbird_A31_defconfig | 2 - configs/Hyundai_A7HD_defconfig | 3 - configs/Linksprite_pcDuino3_Nano_defconfig | 1 - configs/Linksprite_pcDuino_defconfig | 2 - configs/MSI_Primo81_defconfig | 2 +- configs/Mele_A1000G_quad_defconfig | 2 - configs/Mele_I7_defconfig | 2 - configs/Mele_M9_defconfig | 2 - configs/Merrii_A80_Optimus_defconfig | 4 +- configs/Mini-X_defconfig | 1 - configs/Orangepi_defconfig | 2 - configs/Orangepi_mini_defconfig | 2 - configs/Sinlinx_SinA31s_defconfig | 2 - configs/Sinovoip_BPI_M2_defconfig | 2 - configs/Sinovoip_BPI_M3_defconfig | 3 +- configs/Sunchip_CX-A99_defconfig | 3 - configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 1 - configs/Wobo_i5_defconfig | 1 - configs/Yones_Toptech_BD1078_defconfig | 1 - configs/Yones_Toptech_BS1078_V2_defconfig | 2 +- configs/ba10_tv_box_defconfig | 2 - configs/bananapi_m2_berry_defconfig | 1 - configs/colorfly_e708_q1_defconfig | 2 +- configs/difrnce_dit4350_defconfig | 1 - configs/dserve_dsrv9703c_defconfig | 1 - configs/ga10h_v1_1_defconfig | 2 +- configs/gt90h_v4_defconfig | 2 +- configs/h8_homlet_v2_defconfig | 2 - configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/iNet_D978_rev2_defconfig | 2 +- configs/icnova-a20-swac_defconfig | 2 - configs/inet1_defconfig | 1 - configs/inet86dz_defconfig | 2 +- configs/inet97fv2_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/inet9f_rev03_defconfig | 1 - configs/inet_q972_defconfig | 2 +- configs/jesurun_q5_defconfig | 1 - configs/mixtile_loftq_defconfig | 2 - configs/mk802_a10s_defconfig | 1 - configs/mk802_defconfig | 1 - configs/orangepi_2_defconfig | 1 - configs/orangepi_plus_defconfig | 2 - configs/parrot_r16_defconfig | 1 - configs/pine_h64_defconfig | 1 - configs/polaroid_mid2407pxe03_defconfig | 2 +- configs/polaroid_mid2809pxe04_defconfig | 2 +- configs/pov_protab2_ips9_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 2 +- configs/q8_a33_tablet_1024x600_defconfig | 2 +- configs/q8_a33_tablet_800x480_defconfig | 2 +- configs/r7-tv-dongle_defconfig | 1 - configs/sun8i_a23_evb_defconfig | 2 - configs/tbs_a711_defconfig | 2 +- configs/teres_i_defconfig | 1 - drivers/gpio/axp_gpio.c | 75 ++++++-------------- drivers/gpio/sunxi_gpio.c | 8 --- drivers/phy/allwinner/phy-sun4i-usb.c | 41 +++++------ drivers/power/pmic/axp.c | 1 + drivers/power/regulator/Kconfig | 7 ++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/axp_drivevbus.c | 57 +++++++++++++++ include/axp221.h | 4 -- include/axp809.h | 4 -- include/axp818.h | 4 -- include/sunxi_gpio.h | 8 --- 96 files changed, 125 insertions(+), 246 deletions(-) create mode 100644 drivers/power/regulator/axp_drivevbus.c
AXP PMICs have a pin which can either report the USB VBUS state, or driving a regulator that supplies USB VBUS. Add a regulator driver for controlling this pin. The selection between input and output is done via the x-powers,drive-vbus-en pin on the PMIC (parent) node.
Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/power/pmic/axp.c | 1 + drivers/power/regulator/Kconfig | 7 +++ drivers/power/regulator/Makefile | 1 + drivers/power/regulator/axp_drivevbus.c | 57 +++++++++++++++++++++++++ 4 files changed, 66 insertions(+) create mode 100644 drivers/power/regulator/axp_drivevbus.c
diff --git a/drivers/power/pmic/axp.c b/drivers/power/pmic/axp.c index 025dac24f28..e9d34c7d38f 100644 --- a/drivers/power/pmic/axp.c +++ b/drivers/power/pmic/axp.c @@ -51,6 +51,7 @@ static const struct pmic_child_info axp_pmic_child_info[] = { { "cldo", "axp_regulator" }, { "dc", "axp_regulator" }, { "dldo", "axp_regulator" }, + { "drivevbus", "axp_drivevbus" }, { "eldo", "axp_regulator" }, { "fldo", "axp_regulator" }, { "ldo", "axp_regulator" }, diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index eb5aa38c1cc..4fe75cda8fc 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -57,6 +57,13 @@ config SPL_REGULATOR_AXP Enable support in SPL for the regulators (DCDCs, LDOs) in the X-Powers AXP152, AXP2xx, and AXP8xx PMICs.
+config REGULATOR_AXP_DRIVEVBUS + bool "Enable driver for X-Powers AXP PMIC drivevbus" + depends on DM_REGULATOR && PMIC_AXP + help + Enable support for sensing or driving the USB VBUS on + X-Powers AXP2xx and AXP8xx PMICs. + config REGULATOR_AXP_USB_POWER bool "Enable driver for X-Powers AXP PMIC USB power supply" depends on DM_REGULATOR && PMIC_AXP diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index d9e0cd5949c..8e59056124f 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -8,6 +8,7 @@ obj-$(CONFIG_$(SPL_)DM_REGULATOR) += regulator-uclass.o obj-$(CONFIG_REGULATOR_ACT8846) += act8846.o obj-$(CONFIG_REGULATOR_AS3722) += as3722_regulator.o obj-$(CONFIG_$(SPL_)REGULATOR_AXP) += axp_regulator.o +obj-$(CONFIG_$(SPL_)REGULATOR_AXP_DRIVEVBUS) += axp_drivevbus.o obj-$(CONFIG_$(SPL_)REGULATOR_AXP_USB_POWER) += axp_usb_power.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_DA9063) += da9063.o obj-$(CONFIG_DM_REGULATOR_MAX77686) += max77686.o diff --git a/drivers/power/regulator/axp_drivevbus.c b/drivers/power/regulator/axp_drivevbus.c new file mode 100644 index 00000000000..c463de8786b --- /dev/null +++ b/drivers/power/regulator/axp_drivevbus.c @@ -0,0 +1,57 @@ +// SPDX-License-Identifier: GPL-2.0+ + +#include <dm.h> +#include <power/pmic.h> +#include <power/regulator.h> + +#define AXP_VBUS_IPSOUT 0x30 +#define AXP_VBUS_IPSOUT_DRIVEBUS BIT(2) +#define AXP_MISC_CTRL 0x8f +#define AXP_MISC_CTRL_N_VBUSEN_FUNC BIT(4) + +static int axp_drivevbus_get_enable(struct udevice *dev) +{ + int ret; + + ret = pmic_reg_read(dev->parent, AXP_VBUS_IPSOUT); + if (ret < 0) + return ret; + + return !!(ret & AXP_VBUS_IPSOUT_DRIVEBUS); +} + +static int axp_drivevbus_set_enable(struct udevice *dev, bool enable) +{ + return pmic_clrsetbits(dev->parent, AXP_VBUS_IPSOUT, + AXP_VBUS_IPSOUT_DRIVEBUS, + enable ? AXP_VBUS_IPSOUT_DRIVEBUS : 0); +} + +static const struct dm_regulator_ops axp_drivevbus_ops = { + .get_enable = axp_drivevbus_get_enable, + .set_enable = axp_drivevbus_set_enable, +}; + +static int axp_drivevbus_probe(struct udevice *dev) +{ + struct dm_regulator_uclass_plat *uc_plat = dev_get_uclass_plat(dev); + int ret; + + uc_plat->type = REGULATOR_TYPE_FIXED; + + if (dev_read_bool(dev->parent, "x-powers,drive-vbus-en")) { + ret = pmic_clrsetbits(dev->parent, AXP_MISC_CTRL, + AXP_MISC_CTRL_N_VBUSEN_FUNC, 0); + if (ret) + return ret; + } + + return 0; +} + +U_BOOT_DRIVER(axp_drivevbus) = { + .name = "axp_drivevbus", + .id = UCLASS_REGULATOR, + .probe = axp_drivevbus_probe, + .ops = &axp_drivevbus_ops, +};
On many boards, the USB ports are powered by the PMIC's "drivevbus" regulator. In preparation for switching the USB PHY driver to use the regulator uclass instead of a virtual GPIO pin, ensure these boards have AXP PMIC regulator support enabled.
configs/A33-OLinuXino_defconfig | 1 + configs/Cubieboard4_defconfig | 1 + configs/Cubietruck_plus_defconfig | 1 + configs/MSI_Primo81_defconfig | 1 + configs/Merrii_A80_Optimus_defconfig | 1 + configs/Sinovoip_BPI_M3_defconfig | 1 + configs/Yones_Toptech_BS1078_V2_defconfig | 1 + configs/colorfly_e708_q1_defconfig | 1 + configs/ga10h_v1_1_defconfig | 1 + configs/gt90h_v4_defconfig | 1 + configs/iNet_D978_rev2_defconfig | 1 + configs/inet86dz_defconfig | 1 + configs/inet_q972_defconfig | 1 + configs/polaroid_mid2407pxe03_defconfig | 1 + configs/polaroid_mid2809pxe04_defconfig | 1 + configs/q8_a23_tablet_800x480_defconfig | 1 + configs/q8_a33_tablet_1024x600_defconfig | 1 + configs/q8_a33_tablet_800x480_defconfig | 1 + configs/tbs_a711_defconfig | 1 + 19 files changed, 19 insertions(+)
diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index df4acaf33e2..705c869c19f 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PB2" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DCDC1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/Cubieboard4_defconfig b/configs/Cubieboard4_defconfig index d3678ad5c75..c8adabe0a0a 100644 --- a/configs/Cubieboard4_defconfig +++ b/configs/Cubieboard4_defconfig @@ -11,5 +11,6 @@ CONFIG_USB1_VBUS_PIN="PH14" CONFIG_USB3_VBUS_PIN="PH15" CONFIG_AXP_GPIO=y CONFIG_SYS_I2C_SUN8I_RSB=y +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP809_POWER=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index 29f4df2b81c..f349d9bc49f 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -21,6 +21,7 @@ CONFIG_SYS_I2C_SLAVE=0x7f CONFIG_SYS_I2C_SPEED=400000 CONFIG_PHY_REALTEK=y CONFIG_SUN8I_EMAC=y +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO3_VOLT=2500 CONFIG_AXP_DLDO4_VOLT=3300 diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index d60eedb482a..709d27d342e 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -12,6 +12,7 @@ CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_MIPI_4_LANE_513_MBPS_VIA_SSD2828=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index a26677e1c05..c7a3af7a8d1 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -11,5 +11,6 @@ CONFIG_USB1_VBUS_PIN="PH4" CONFIG_USB3_VBUS_PIN="PH5" CONFIG_AXP_GPIO=y CONFIG_SYS_I2C_SUN8I_RSB=y +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP809_POWER=y diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index ad41dbd26a1..fcdd7ded82d 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -17,6 +17,7 @@ CONFIG_CONSOLE_MUX=y CONFIG_PHY_REALTEK=y CONFIG_SUN8I_EMAC=y CONFIG_INITIAL_USB_SCAN_DELAY=500 +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_AXP_DLDO3_VOLT=3300 diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index de69ebe9956..67fef2a6202 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_MUSB_HOST=y diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index 07bda049665..201b7425573 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" CONFIG_VIDEO_LCD_PANEL_LVDS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_AXP_DLDO2_VOLT=1800 diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 935071d61ac..5d083742f1f 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -16,6 +16,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 205eab29293..6502ac8cf43 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index ed6a6038424..70be98030a0 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -15,6 +15,7 @@ CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" CONFIG_VIDEO_LCD_PANEL_LVDS=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 # CONFIG_REQUIRE_SERIAL_CONSOLE is not set diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index d215a8375e2..3405bc423a3 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index 24ff6c0062e..a70a83ebcd0 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -13,6 +13,7 @@ CONFIG_VIDEO_LCD_DCLK_PHASE=0 CONFIG_VIDEO_LCD_BL_EN="PA25" CONFIG_VIDEO_LCD_BL_PWM="PH13" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_USB_EHCI_HCD=y diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 6ec7c83be5b..2155fe6646f 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index 1aefc50588e..1faf78f1b54 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 0f8c30ec853..08ba34e08ee 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index b3b5cc704f4..6efbd84f7c3 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index 37ee08fa629..bf5dcd0d018 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -14,6 +14,7 @@ CONFIG_VIDEO_LCD_POWER="PH7" CONFIG_VIDEO_LCD_BL_EN="PH6" CONFIG_VIDEO_LCD_BL_PWM="PH0" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DLDO1_VOLT=3300 CONFIG_CONS_INDEX=5 diff --git a/configs/tbs_a711_defconfig b/configs/tbs_a711_defconfig index 9a70b6bee52..c17815382ec 100644 --- a/configs/tbs_a711_defconfig +++ b/configs/tbs_a711_defconfig @@ -13,6 +13,7 @@ CONFIG_USB0_ID_DET="PH11" CONFIG_AXP_GPIO=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FASTBOOT_CMD_OEM_FORMAT=y +CONFIG_REGULATOR_AXP_DRIVEVBUS=y CONFIG_REGULATOR_AXP_USB_POWER=y CONFIG_AXP_DCDC5_VOLT=1200 CONFIG_USB_EHCI_HCD=y
On Tue, 31 Oct 2023 01:39:52 -0500 Samuel Holland samuel@sholland.org wrote:
Hi Samuel,
I am struggling for figure out how you came up with this list of boards? Shouldn't that be all boards that use drivevbus as some USB power supply in their DT? However this misses some prominent cases, for instance the BananaPi M64.
It looks like every defconfig below also defines "CONFIG_REGULATOR_AXP_USB_POWER=y", but OTOH not every user of that is mentioned here, four boards seem to be missing?
Or is it everyone who also defines CONFIG_AXP_GPIO? Or uses CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE"?
Can you shed some light on this?
Cheers, Andre
The device tree binding for the PHY provides VBUS supplies as regulator references. Now that all boards have the appropriate regulator uclass drivers enabled, the PHY driver can switch to using them. This replaces direct GPIO usage, which in some cases needed a special DM-incompatible "virtual" GPIO from the PMIC.
The following boards provided a value for CONFIG_USB0_VBUS_PIN, but are missing the "usb0_vbus-supply" property in their device tree. None of them have the MUSB controller enabled in host or OTG mode, so they should see no impact: - Ainol_AW1_defconfig / sun7i-a20-ainol-aw1 - Ampe_A76_defconfig / sun5i-a13-ampe-a76 - CHIP_pro_defconfig / sun5i-gr8-chip-pro - Cubieboard4_defconfig / sun9i-a80-cubieboard4 - Merrii_A80_Optimus_defconfig / sun9i-a80-optimus - Sunchip_CX-A99_defconfig / sun9i-a80-cx-a99 - Yones_Toptech_BD1078_defconfig / sun7i-a20-yones-toptech-bd1078 - Yones_Toptech_BS1078_V2_defconfig / sun6i-a31s-yones-toptech-bs1078-v2 - iNet_3F_defconfig / sun4i-a10-inet-3f - iNet_3W_defconfig / sun4i-a10-inet-3w - iNet_86VS_defconfig / sun5i-a13-inet-86vs - iNet_D978_rev2_defconfig / sun8i-a33-inet-d978-rev2 - icnova-a20-swac_defconfig / sun7i-a20-icnova-swac - sun8i_a23_evb_defconfig / sun8i-a23-evb
Similarly, the following boards set CONFIG_USB1_VBUS_PIN, but do not have "usb1_vbus-supply" in their device tree. Neither of them have USB enabled at all, so again there should be no impact: - Cubieboard4_defconfig / sun9i-a80-cubieboard4 (also for USB3) - sun8i_a23_evb_defconfig / sun8i-a23-evb
The following boards use a different pin for USB1 VBUS between their defconfig and their device tree. Depending on which is correct, they may be broken: - Linksprite_pcDuino3_Nano_defconfig (PH11) / sun7i-a20-pcduino3-nano (PD2) - icnova-a20-swac_defconfig (PG10) / sun7i-a20-icnova-swac (PH6)
Finally, this board has conflicting pins given for its USB2 VBUS: - Lamobo_R1_defconfig (PH3) / sun7i-a20-lamobo-r1 (PH12)
drivers/phy/allwinner/phy-sun4i-usb.c | 41 +++++++++++++-------------- 1 file changed, 19 insertions(+), 22 deletions(-)
diff --git a/drivers/phy/allwinner/phy-sun4i-usb.c b/drivers/phy/allwinner/phy-sun4i-usb.c index 6624e9134f4..dc34b828a3a 100644 --- a/drivers/phy/allwinner/phy-sun4i-usb.c +++ b/drivers/phy/allwinner/phy-sun4i-usb.c @@ -87,27 +87,22 @@ struct sun4i_usb_phy_cfg { };
struct sun4i_usb_phy_info { - const char *gpio_vbus; const char *gpio_vbus_det; const char *gpio_id_det; } phy_info[] = { { - .gpio_vbus = CONFIG_USB0_VBUS_PIN, .gpio_vbus_det = CONFIG_USB0_VBUS_DET, .gpio_id_det = CONFIG_USB0_ID_DET, }, { - .gpio_vbus = CONFIG_USB1_VBUS_PIN, .gpio_vbus_det = NULL, .gpio_id_det = NULL, }, { - .gpio_vbus = CONFIG_USB2_VBUS_PIN, .gpio_vbus_det = NULL, .gpio_id_det = NULL, }, { - .gpio_vbus = CONFIG_USB3_VBUS_PIN, .gpio_vbus_det = NULL, .gpio_id_det = NULL, }, @@ -115,12 +110,12 @@ struct sun4i_usb_phy_info {
struct sun4i_usb_phy_plat { void __iomem *pmu; - struct gpio_desc gpio_vbus; struct gpio_desc gpio_vbus_det; struct gpio_desc gpio_id_det; struct clk clocks; struct clk clk2; struct reset_ctl resets; + struct udevice *vbus; int id; };
@@ -209,6 +204,7 @@ static int sun4i_usb_phy_power_on(struct phy *phy) { struct sun4i_usb_phy_data *data = dev_get_priv(phy->dev); struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id]; + int ret;
if (initial_usb_scan_delay) { mdelay(initial_usb_scan_delay); @@ -221,8 +217,11 @@ static int sun4i_usb_phy_power_on(struct phy *phy) return 0; }
- if (dm_gpio_is_valid(&usb_phy->gpio_vbus)) - dm_gpio_set_value(&usb_phy->gpio_vbus, 1); + if (usb_phy->vbus) { + ret = regulator_set_enable(usb_phy->vbus, true); + if (ret && ret != -ENOSYS) + return ret; + }
return 0; } @@ -231,9 +230,13 @@ static int sun4i_usb_phy_power_off(struct phy *phy) { struct sun4i_usb_phy_data *data = dev_get_priv(phy->dev); struct sun4i_usb_phy_plat *usb_phy = &data->usb_phy[phy->id]; + int ret;
- if (dm_gpio_is_valid(&usb_phy->gpio_vbus)) - dm_gpio_set_value(&usb_phy->gpio_vbus, 0); + if (usb_phy->vbus) { + ret = regulator_set_enable(usb_phy->vbus, false); + if (ret && ret != -ENOSYS) + return ret; + }
return 0; } @@ -483,22 +486,16 @@ static int sun4i_usb_phy_probe(struct udevice *dev) for (i = 0; i < data->cfg->num_phys; i++) { struct sun4i_usb_phy_plat *phy = &plat[i]; struct sun4i_usb_phy_info *info = &phy_info[i]; - char name[16]; + char name[32];
if (data->cfg->missing_phys & BIT(i)) continue;
- ret = dm_gpio_lookup_name(info->gpio_vbus, &phy->gpio_vbus); - if (ret == 0) { - ret = dm_gpio_request(&phy->gpio_vbus, "usb_vbus"); - if (ret) - return ret; - ret = dm_gpio_set_dir_flags(&phy->gpio_vbus, - GPIOD_IS_OUT); - if (ret) - return ret; - ret = dm_gpio_set_value(&phy->gpio_vbus, 0); - if (ret) + snprintf(name, sizeof(name), "usb%d_vbus-supply", i); + ret = device_get_supply_regulator(dev, name, &phy->vbus); + if (phy->vbus) { + ret = regulator_set_enable(phy->vbus, false); + if (ret && ret != -ENOSYS) return ret; }
On Tue, 31 Oct 2023 01:39:53 -0500 Samuel Holland samuel@sholland.org wrote:
Hi Samuel,
I like that one, avoids one more Kconfig duplicate. Testing this revealed one problem, though:
} phy_info[] = { {
.gpio_vbus_det = CONFIG_USB0_VBUS_DET, .gpio_id_det = CONFIG_USB0_ID_DET, }, {.gpio_vbus = CONFIG_USB0_VBUS_PIN,
.gpio_vbus_det = NULL, .gpio_id_det = NULL, }, {.gpio_vbus = CONFIG_USB1_VBUS_PIN,
.gpio_vbus_det = NULL, .gpio_id_det = NULL, }, {.gpio_vbus = CONFIG_USB2_VBUS_PIN,
.gpio_vbus_det = NULL, .gpio_id_det = NULL, },.gpio_vbus = CONFIG_USB3_VBUS_PIN,
- struct udevice *vbus; int id;
int ret;
return ret;
- int ret;
return ret;
char name[16];
char name[32];
if (ret == 0) {
if (ret)
return ret;
GPIOD_IS_OUT);
if (ret)
return ret;
if (ret)
if (phy->vbus) {
It's quite likely that this regulator is already disabled, in this case regulator_set_enable() returns -EALREADY, and probe() exists prematurely. There is regulator_set_enable_if_allowed() to cover that case, and also if we want to disable an always-on regulator. When replacing it (and the call above, in sun4i_usb_phy_power_off()), it works for me, for instance for the GPIO controlled Orange Pi Zero3, where is was failing before.
I have fixed that in my tree, if nothing else pops up, there is no need to re-send.
Cheers, Andre
}if (ret && ret != -ENOSYS) return ret;
Now that the USB PHY driver uses the device tree to get VBUS supply regulators, these Kconfig symbols are unused. Remove them.
arch/arm/mach-sunxi/Kconfig | 29 -------------------- configs/A10s-OLinuXino-M_defconfig | 1 - configs/A13-OLinuXinoM_defconfig | 1 - configs/A13-OLinuXino_defconfig | 1 - configs/A20-OLinuXino-Lime2-eMMC_defconfig | 1 - configs/A20-OLinuXino-Lime2_defconfig | 1 - configs/A20-Olimex-SOM-EVB_defconfig | 1 - configs/A20-Olimex-SOM204-EVB-eMMC_defconfig | 1 - configs/A20-Olimex-SOM204-EVB_defconfig | 1 - configs/A33-OLinuXino_defconfig | 1 - configs/Ainol_AW1_defconfig | 1 - configs/Ampe_A76_defconfig | 1 - configs/Auxtek-T003_defconfig | 1 - configs/Auxtek-T004_defconfig | 1 - configs/Bananapi_M2_Ultra_defconfig | 2 -- configs/Bananapro_defconfig | 2 -- configs/CHIP_defconfig | 1 - configs/CHIP_pro_defconfig | 1 - configs/CSQ_CS908_defconfig | 2 -- configs/Chuwi_V7_CW0825_defconfig | 1 - configs/Colombus_defconfig | 1 - configs/Cubieboard4_defconfig | 3 -- configs/Cubietruck_defconfig | 1 - configs/Cubietruck_plus_defconfig | 3 -- configs/Empire_electronix_d709_defconfig | 1 - configs/Empire_electronix_m712_defconfig | 1 - configs/Hummingbird_A31_defconfig | 2 -- configs/Hyundai_A7HD_defconfig | 3 -- configs/Linksprite_pcDuino3_Nano_defconfig | 1 - configs/Linksprite_pcDuino_defconfig | 2 -- configs/MSI_Primo81_defconfig | 1 - configs/Mele_A1000G_quad_defconfig | 2 -- configs/Mele_I7_defconfig | 2 -- configs/Mele_M9_defconfig | 2 -- configs/Merrii_A80_Optimus_defconfig | 3 -- configs/Mini-X_defconfig | 1 - configs/Orangepi_defconfig | 2 -- configs/Orangepi_mini_defconfig | 2 -- configs/Sinlinx_SinA31s_defconfig | 2 -- configs/Sinovoip_BPI_M2_defconfig | 2 -- configs/Sinovoip_BPI_M3_defconfig | 2 -- configs/Sunchip_CX-A99_defconfig | 3 -- configs/UTOO_P66_defconfig | 1 - configs/Wexler_TAB7200_defconfig | 1 - configs/Wobo_i5_defconfig | 1 - configs/Yones_Toptech_BD1078_defconfig | 1 - configs/Yones_Toptech_BS1078_V2_defconfig | 1 - configs/ba10_tv_box_defconfig | 2 -- configs/bananapi_m2_berry_defconfig | 1 - configs/colorfly_e708_q1_defconfig | 1 - configs/difrnce_dit4350_defconfig | 1 - configs/dserve_dsrv9703c_defconfig | 1 - configs/ga10h_v1_1_defconfig | 1 - configs/gt90h_v4_defconfig | 1 - configs/h8_homlet_v2_defconfig | 2 -- configs/iNet_3F_defconfig | 1 - configs/iNet_3W_defconfig | 1 - configs/iNet_86VS_defconfig | 1 - configs/iNet_D978_rev2_defconfig | 1 - configs/icnova-a20-swac_defconfig | 2 -- configs/inet1_defconfig | 1 - configs/inet86dz_defconfig | 1 - configs/inet97fv2_defconfig | 1 - configs/inet98v_rev2_defconfig | 1 - configs/inet9f_rev03_defconfig | 1 - configs/inet_q972_defconfig | 1 - configs/jesurun_q5_defconfig | 1 - configs/mixtile_loftq_defconfig | 2 -- configs/mk802_a10s_defconfig | 1 - configs/mk802_defconfig | 1 - configs/orangepi_2_defconfig | 1 - configs/orangepi_plus_defconfig | 2 -- configs/parrot_r16_defconfig | 1 - configs/pine_h64_defconfig | 1 - configs/polaroid_mid2407pxe03_defconfig | 1 - configs/polaroid_mid2809pxe04_defconfig | 1 - configs/pov_protab2_ips9_defconfig | 1 - configs/q8_a13_tablet_defconfig | 1 - configs/q8_a23_tablet_800x480_defconfig | 1 - configs/q8_a33_tablet_1024x600_defconfig | 1 - configs/q8_a33_tablet_800x480_defconfig | 1 - configs/r7-tv-dongle_defconfig | 1 - configs/sun8i_a23_evb_defconfig | 2 -- configs/tbs_a711_defconfig | 1 - configs/teres_i_defconfig | 1 - 85 files changed, 142 deletions(-)
diff --git a/arch/arm/mach-sunxi/Kconfig b/arch/arm/mach-sunxi/Kconfig index a10e4c06b6a..e3184ccdb3d 100644 --- a/arch/arm/mach-sunxi/Kconfig +++ b/arch/arm/mach-sunxi/Kconfig @@ -732,13 +732,6 @@ config MMC_SUNXI_SLOT_EXTRA slot or emmc on mmc1 - mmc3. Setting this to 1, 2 or 3 will enable support for this.
-config USB0_VBUS_PIN - string "Vbus enable pin for usb0 (otg)" - default "" - ---help--- - Set the Vbus enable pin for usb0 (otg). This takes a string in the - format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H. - config USB0_VBUS_DET string "Vbus detect pin for usb0 (otg)" default "" @@ -753,28 +746,6 @@ config USB0_ID_DET Set the ID detect pin for usb0 (otg). This takes a string in the format understood by sunxi_name_to_gpio, e.g. PH1 for pin 1 of port H.
-config USB1_VBUS_PIN - string "Vbus enable pin for usb1 (ehci0)" - default "PH6" if MACH_SUN4I || MACH_SUN7I - default "PH27" if MACH_SUN6I - ---help--- - Set the Vbus enable pin for usb1 (ehci0, usb0 is the otg). This takes - a string in the format understood by sunxi_name_to_gpio, e.g. - PH1 for pin 1 of port H. - -config USB2_VBUS_PIN - string "Vbus enable pin for usb2 (ehci1)" - default "PH3" if MACH_SUN4I || MACH_SUN7I - default "PH24" if MACH_SUN6I - ---help--- - See USB1_VBUS_PIN help text. - -config USB3_VBUS_PIN - string "Vbus enable pin for usb3 (ehci2)" - default "" - ---help--- - See USB1_VBUS_PIN help text. - config I2C0_ENABLE bool "Enable I2C/TWI controller 0" default y if MACH_SUN4I || MACH_SUN5I || MACH_SUN7I || MACH_SUN8I_R40 diff --git a/configs/A10s-OLinuXino-M_defconfig b/configs/A10s-OLinuXino-M_defconfig index 841fe0d3f09..ddc2a2e2089 100644 --- a/configs/A10s-OLinuXino-M_defconfig +++ b/configs/A10s-OLinuXino-M_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_MMC_SUNXI_SLOT_EXTRA=1 -CONFIG_USB1_VBUS_PIN="PB10" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/A13-OLinuXinoM_defconfig b/configs/A13-OLinuXinoM_defconfig index befe6d86b25..7e58ac112f3 100644 --- a/configs/A13-OLinuXinoM_defconfig +++ b/configs/A13-OLinuXinoM_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=0 -CONFIG_USB1_VBUS_PIN="PG11" # CONFIG_VIDEO_HDMI is not set CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_VIA_LCD_FORCE_SYNC_ACTIVE_HIGH=y diff --git a/configs/A13-OLinuXino_defconfig b/configs/A13-OLinuXino_defconfig index 689ea533ee9..78e7233ca97 100644 --- a/configs/A13-OLinuXino_defconfig +++ b/configs/A13-OLinuXino_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=0 CONFIG_USB0_VBUS_DET="PG1" -CONFIG_USB1_VBUS_PIN="PG11" CONFIG_AXP_GPIO=y # CONFIG_VIDEO_HDMI is not set CONFIG_VIDEO_VGA_VIA_LCD=y diff --git a/configs/A20-OLinuXino-Lime2-eMMC_defconfig b/configs/A20-OLinuXino-Lime2-eMMC_defconfig index 44770ffb048..079e4dd9203 100644 --- a/configs/A20-OLinuXino-Lime2-eMMC_defconfig +++ b/configs/A20-OLinuXino-Lime2-eMMC_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_SPL_SPI_SUNXI=y diff --git a/configs/A20-OLinuXino-Lime2_defconfig b/configs/A20-OLinuXino-Lime2_defconfig index e10660c933c..2b91f3ea02f 100644 --- a/configs/A20-OLinuXino-Lime2_defconfig +++ b/configs/A20-OLinuXino-Lime2_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2" CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 -CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_AHCI=y diff --git a/configs/A20-Olimex-SOM-EVB_defconfig b/configs/A20-Olimex-SOM-EVB_defconfig index ac900477d1e..b9df35d1b98 100644 --- a/configs/A20-Olimex-SOM-EVB_defconfig +++ b/configs/A20-Olimex-SOM-EVB_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC_SUNXI_SLOT_EXTRA=3 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig index 00a98140b37..b1012c08631 100644 --- a/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig +++ b/configs/A20-Olimex-SOM204-EVB-eMMC_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_GMAC_TX_DELAY=4 diff --git a/configs/A20-Olimex-SOM204-EVB_defconfig b/configs/A20-Olimex-SOM204-EVB_defconfig index f4ae3ae6d8b..2fc143680e2 100644 --- a/configs/A20-Olimex-SOM204-EVB_defconfig +++ b/configs/A20-Olimex-SOM204-EVB_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olimex-som204-evb" CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 -CONFIG_USB0_VBUS_PIN="PC17" CONFIG_USB0_VBUS_DET="PH5" CONFIG_I2C1_ENABLE=y CONFIG_GMAC_TX_DELAY=4 diff --git a/configs/A33-OLinuXino_defconfig b/configs/A33-OLinuXino_defconfig index 705c869c19f..854918f4274 100644 --- a/configs/A33-OLinuXino_defconfig +++ b/configs/A33-OLinuXino_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN8I_A33=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=15291 CONFIG_DRAM_ODT_EN=y -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PB3" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:16,ri:209,up:22,lo:22,hs:30,vs:1,sync:3,vmode:0" diff --git a/configs/Ainol_AW1_defconfig b/configs/Ainol_AW1_defconfig index 51f26f48b29..eda0c95584c 100644 --- a/configs/Ainol_AW1_defconfig +++ b/configs/Ainol_AW1_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=123 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:40000,le:87,ri:112,up:38,lo:141,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH8" diff --git a/configs/Ampe_A76_defconfig b/configs/Ampe_A76_defconfig index 1087512235a..6ca73e78e51 100644 --- a/configs/Ampe_A76_defconfig +++ b/configs/Ampe_A76_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-ampe-a76" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/Auxtek-T003_defconfig b/configs/Auxtek-T003_defconfig index 7d81f12f766..d2abb14512a 100644 --- a/configs/Auxtek-T003_defconfig +++ b/configs/Auxtek-T003_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=0 -CONFIG_USB1_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y diff --git a/configs/Auxtek-T004_defconfig b/configs/Auxtek-T004_defconfig index 4c7154b04c4..b121f8c0f01 100644 --- a/configs/Auxtek-T004_defconfig +++ b/configs/Auxtek-T004_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-auxtek-t004" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 -CONFIG_USB1_VBUS_PIN="PG13" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/Bananapi_M2_Ultra_defconfig b/configs/Bananapi_M2_Ultra_defconfig index 2cc7bbbd8b7..b1195afea20 100644 --- a/configs/Bananapi_M2_Ultra_defconfig +++ b/configs/Bananapi_M2_Ultra_defconfig @@ -5,8 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_R40=y CONFIG_DRAM_CLK=576 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB1_VBUS_PIN="PH23" -CONFIG_USB2_VBUS_PIN="PH23" # CONFIG_HAS_ARMV7_SECURE_BASE is not set CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Bananapro_defconfig b/configs/Bananapro_defconfig index 02be8971df9..46025e95fb8 100644 --- a/configs/Bananapro_defconfig +++ b/configs/Bananapro_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-bananapro" CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 -CONFIG_USB1_VBUS_PIN="PH0" -CONFIG_USB2_VBUS_PIN="PH1" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y diff --git a/configs/CHIP_defconfig b/configs/CHIP_defconfig index cd9bdbfd36f..b013c97839f 100644 --- a/configs/CHIP_defconfig +++ b/configs/CHIP_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-r8-chip" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y -CONFIG_USB0_VBUS_PIN="PB10" CONFIG_VIDEO_COMPOSITE=y CONFIG_CHIP_DIP_SCAN=y CONFIG_SPL_I2C=y diff --git a/configs/CHIP_pro_defconfig b/configs/CHIP_pro_defconfig index b7089bced2c..2ad1d3d54f3 100644 --- a/configs/CHIP_pro_defconfig +++ b/configs/CHIP_pro_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-gr8-chip-pro" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_TIMINGS_DDR3_800E_1066G_1333J=y -CONFIG_USB0_VBUS_PIN="PB10" CONFIG_SPL_I2C=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_MTDPARTS=y diff --git a/configs/CSQ_CS908_defconfig b/configs/CSQ_CS908_defconfig index 1cd39d498f2..61fcb61cede 100644 --- a/configs/CSQ_CS908_defconfig +++ b/configs/CSQ_CS908_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-cs908" CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 -CONFIG_USB1_VBUS_PIN="" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Chuwi_V7_CW0825_defconfig b/configs/Chuwi_V7_CW0825_defconfig index 02b3e69584f..c76c07e2d9d 100644 --- a/configs/Chuwi_V7_CW0825_defconfig +++ b/configs/Chuwi_V7_CW0825_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_USB0_ID_DET="PH4" CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:24,pclk_khz:51000,le:19,ri:300,up:6,lo:31,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/Colombus_defconfig b/configs/Colombus_defconfig index 270bd7d351a..368919d6d15 100644 --- a/configs/Colombus_defconfig +++ b/configs/Colombus_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=240 CONFIG_DRAM_ZQ=251 -CONFIG_USB1_VBUS_PIN="" CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:2048,y:1536,depth:24,pclk_khz:208000,le:5,ri:150,up:9,lo:24,hs:5,vs:1,sync:3,vmode:0" diff --git a/configs/Cubieboard4_defconfig b/configs/Cubieboard4_defconfig index c8adabe0a0a..a6bc72daf52 100644 --- a/configs/Cubieboard4_defconfig +++ b/configs/Cubieboard4_defconfig @@ -5,10 +5,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN9I=y CONFIG_DRAM_CLK=672 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH16" -CONFIG_USB1_VBUS_PIN="PH14" -CONFIG_USB3_VBUS_PIN="PH15" CONFIG_AXP_GPIO=y CONFIG_SYS_I2C_SUN8I_RSB=y CONFIG_REGULATOR_AXP_DRIVEVBUS=y diff --git a/configs/Cubietruck_defconfig b/configs/Cubietruck_defconfig index 184143d7086..f4829d38dbe 100644 --- a/configs/Cubietruck_defconfig +++ b/configs/Cubietruck_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-cubietruck" CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 -CONFIG_USB0_VBUS_PIN="PH17" CONFIG_USB0_VBUS_DET="PH22" CONFIG_USB0_ID_DET="PH19" CONFIG_VIDEO_VGA=y diff --git a/configs/Cubietruck_plus_defconfig b/configs/Cubietruck_plus_defconfig index f349d9bc49f..e24cf553e1c 100644 --- a/configs/Cubietruck_plus_defconfig +++ b/configs/Cubietruck_plus_defconfig @@ -7,10 +7,7 @@ CONFIG_DRAM_CLK=672 CONFIG_DRAM_ZQ=15355 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH11" -CONFIG_USB1_VBUS_PIN="PD29" -CONFIG_USB2_VBUS_PIN="PL6" CONFIG_I2C0_ENABLE=y CONFIG_AXP_GPIO=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Empire_electronix_d709_defconfig b/configs/Empire_electronix_d709_defconfig index 4bd3b569392..26f3ee03c26 100644 --- a/configs/Empire_electronix_d709_defconfig +++ b/configs/Empire_electronix_d709_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_EMR1=0 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/Empire_electronix_m712_defconfig b/configs/Empire_electronix_m712_defconfig index 18873dba340..4745329e33f 100644 --- a/configs/Empire_electronix_m712_defconfig +++ b/configs/Empire_electronix_m712_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-empire-electronix-m712" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=408 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/Hummingbird_A31_defconfig b/configs/Hummingbird_A31_defconfig index 24e8b5be1b5..2bc9a0917c5 100644 --- a/configs/Hummingbird_A31_defconfig +++ b/configs/Hummingbird_A31_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-hummingbird" CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 -CONFIG_USB1_VBUS_PIN="PH24" -CONFIG_USB2_VBUS_PIN="" CONFIG_VIDEO_VGA_VIA_LCD=y CONFIG_VIDEO_VGA_EXTERNAL_DAC_EN="PH25" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Hyundai_A7HD_defconfig b/configs/Hyundai_A7HD_defconfig index 482e0fb7a83..03e9fdca66f 100644 --- a/configs/Hyundai_A7HD_defconfig +++ b/configs/Hyundai_A7HD_defconfig @@ -4,10 +4,7 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-hyundai-a7hd" CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB09" CONFIG_USB0_VBUS_DET="PH5" -CONFIG_USB1_VBUS_PIN="" -CONFIG_USB2_VBUS_PIN="PH6" CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:51000,le:45,ri:274,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH2" CONFIG_VIDEO_LCD_BL_EN="PH9" diff --git a/configs/Linksprite_pcDuino3_Nano_defconfig b/configs/Linksprite_pcDuino3_Nano_defconfig index 9eb9a918aee..3e6c28018b2 100644 --- a/configs/Linksprite_pcDuino3_Nano_defconfig +++ b/configs/Linksprite_pcDuino3_Nano_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=122 -CONFIG_USB1_VBUS_PIN="PH11" CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/Linksprite_pcDuino_defconfig b/configs/Linksprite_pcDuino_defconfig index 49dcfa098ee..222fbc5e4ef 100644 --- a/configs/Linksprite_pcDuino_defconfig +++ b/configs/Linksprite_pcDuino_defconfig @@ -3,8 +3,6 @@ CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pcduino" CONFIG_SPL=y CONFIG_MACH_SUN4I=y -CONFIG_USB1_VBUS_PIN="" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/MSI_Primo81_defconfig b/configs/MSI_Primo81_defconfig index 709d27d342e..9a7d80fce0d 100644 --- a/configs/MSI_Primo81_defconfig +++ b/configs/MSI_Primo81_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=360 CONFIG_DRAM_ZQ=122 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:768,y:1024,depth:18,pclk_khz:66000,le:56,ri:60,up:30,lo:36,hs:64,vs:50,sync:3,vmode:0" CONFIG_VIDEO_LCD_BL_EN="PA25" diff --git a/configs/Mele_A1000G_quad_defconfig b/configs/Mele_A1000G_quad_defconfig index c697d286dc1..1f4739e0005 100644 --- a/configs/Mele_A1000G_quad_defconfig +++ b/configs/Mele_A1000G_quad_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-mele-a1000g-quad" CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 -CONFIG_USB1_VBUS_PIN="PC27" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Mele_I7_defconfig b/configs/Mele_I7_defconfig index 2b9bca13d08..be2e4d1809f 100644 --- a/configs/Mele_I7_defconfig +++ b/configs/Mele_I7_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-i7" CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 -CONFIG_USB1_VBUS_PIN="PC27" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Mele_M9_defconfig b/configs/Mele_M9_defconfig index be6dd417545..9b1bb97eedd 100644 --- a/configs/Mele_M9_defconfig +++ b/configs/Mele_M9_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31-m9" CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=120 -CONFIG_USB1_VBUS_PIN="PC27" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Merrii_A80_Optimus_defconfig b/configs/Merrii_A80_Optimus_defconfig index c7a3af7a8d1..373dbf4bfb1 100644 --- a/configs/Merrii_A80_Optimus_defconfig +++ b/configs/Merrii_A80_Optimus_defconfig @@ -5,10 +5,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN9I=y CONFIG_DRAM_CLK=672 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH3" -CONFIG_USB1_VBUS_PIN="PH4" -CONFIG_USB3_VBUS_PIN="PH5" CONFIG_AXP_GPIO=y CONFIG_SYS_I2C_SUN8I_RSB=y CONFIG_REGULATOR_AXP_DRIVEVBUS=y diff --git a/configs/Mini-X_defconfig b/configs/Mini-X_defconfig index e8bc1485766..b6ae6f643fe 100644 --- a/configs/Mini-X_defconfig +++ b/configs/Mini-X_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mini-xplus" CONFIG_SPL=y CONFIG_MACH_SUN4I=y -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y diff --git a/configs/Orangepi_defconfig b/configs/Orangepi_defconfig index 53edf525ec0..2ca40fdf2a0 100644 --- a/configs/Orangepi_defconfig +++ b/configs/Orangepi_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-orangepi" CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 -CONFIG_USB1_VBUS_PIN="PH26" -CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_VGA=y CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 diff --git a/configs/Orangepi_mini_defconfig b/configs/Orangepi_mini_defconfig index ccf32670170..6b6e4025370 100644 --- a/configs/Orangepi_mini_defconfig +++ b/configs/Orangepi_mini_defconfig @@ -5,8 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=432 CONFIG_MMC_SUNXI_SLOT_EXTRA=3 -CONFIG_USB1_VBUS_PIN="PH26" -CONFIG_USB2_VBUS_PIN="PH22" CONFIG_VIDEO_COMPOSITE=y CONFIG_GMAC_TX_DELAY=3 CONFIG_AHCI=y diff --git a/configs/Sinlinx_SinA31s_defconfig b/configs/Sinlinx_SinA31s_defconfig index 59869b74ac5..1c4c8519711 100644 --- a/configs/Sinlinx_SinA31s_defconfig +++ b/configs/Sinlinx_SinA31s_defconfig @@ -6,8 +6,6 @@ CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=251 CONFIG_MMC_SUNXI_SLOT_EXTRA=3 -CONFIG_USB1_VBUS_PIN="" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Sinovoip_BPI_M2_defconfig b/configs/Sinovoip_BPI_M2_defconfig index aba95270eb2..d7ef265d213 100644 --- a/configs/Sinovoip_BPI_M2_defconfig +++ b/configs/Sinovoip_BPI_M2_defconfig @@ -4,8 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun6i-a31s-sinovoip-bpi-m2" CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 -CONFIG_USB1_VBUS_PIN="" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/Sinovoip_BPI_M3_defconfig b/configs/Sinovoip_BPI_M3_defconfig index fcdd7ded82d..d03e1ebb23e 100644 --- a/configs/Sinovoip_BPI_M3_defconfig +++ b/configs/Sinovoip_BPI_M3_defconfig @@ -8,9 +8,7 @@ CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=15355 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH11" -CONFIG_USB1_VBUS_PIN="PD24" CONFIG_AXP_GPIO=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/Sunchip_CX-A99_defconfig b/configs/Sunchip_CX-A99_defconfig index 348140dcc0c..0d78a13bd71 100644 --- a/configs/Sunchip_CX-A99_defconfig +++ b/configs/Sunchip_CX-A99_defconfig @@ -7,7 +7,4 @@ CONFIG_DRAM_CLK=600 CONFIG_DRAM_ZQ=3881915 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="PH15" -CONFIG_USB1_VBUS_PIN="PL7" -CONFIG_USB3_VBUS_PIN="PL8" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/UTOO_P66_defconfig b/configs/UTOO_P66_defconfig index 88a082c0567..7c88d237324 100644 --- a/configs/UTOO_P66_defconfig +++ b/configs/UTOO_P66_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_EMR1=0 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="PB04" CONFIG_USB0_VBUS_DET="PG01" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/Wexler_TAB7200_defconfig b/configs/Wexler_TAB7200_defconfig index 40aeb6680c2..bdbd48e2c08 100644 --- a/configs/Wexler_TAB7200_defconfig +++ b/configs/Wexler_TAB7200_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-wexler-tab7200" CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_ID_DET="PH4" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:210,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/Wobo_i5_defconfig b/configs/Wobo_i5_defconfig index 9e9bddb7649..97939200146 100644 --- a/configs/Wobo_i5_defconfig +++ b/configs/Wobo_i5_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-wobo-i5" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 -CONFIG_USB1_VBUS_PIN="PG12" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/Yones_Toptech_BD1078_defconfig b/configs/Yones_Toptech_BD1078_defconfig index 9b13659bccd..d7988616f6d 100644 --- a/configs/Yones_Toptech_BD1078_defconfig +++ b/configs/Yones_Toptech_BD1078_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=408 CONFIG_MMC1_PINS_PH=y CONFIG_MMC_SUNXI_SLOT_EXTRA=1 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:24,pclk_khz:63000,le:32,ri:287,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_DCLK_PHASE=0 diff --git a/configs/Yones_Toptech_BS1078_V2_defconfig b/configs/Yones_Toptech_BS1078_V2_defconfig index 67fef2a6202..e5196b78cf6 100644 --- a/configs/Yones_Toptech_BS1078_V2_defconfig +++ b/configs/Yones_Toptech_BS1078_V2_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=420 CONFIG_DRAM_ZQ=251 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PA15" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:24,pclk_khz:70000,le:120,ri:180,up:17,lo:15,hs:20,vs:3,sync:3,vmode:0" diff --git a/configs/ba10_tv_box_defconfig b/configs/ba10_tv_box_defconfig index b89dd8ea62b..cde8bf1f89d 100644 --- a/configs/ba10_tv_box_defconfig +++ b/configs/ba10_tv_box_defconfig @@ -5,8 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=384 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" -CONFIG_USB2_VBUS_PIN="PH12" CONFIG_VIDEO_COMPOSITE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y diff --git a/configs/bananapi_m2_berry_defconfig b/configs/bananapi_m2_berry_defconfig index f4edcf43708..94d29a4743e 100644 --- a/configs/bananapi_m2_berry_defconfig +++ b/configs/bananapi_m2_berry_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-v40-bananapi-m2-berry" CONFIG_SPL=y CONFIG_MACH_SUN8I_R40=y CONFIG_DRAM_CLK=576 -CONFIG_USB1_VBUS_PIN="PH23" # CONFIG_HAS_ARMV7_SECURE_BASE is not set CONFIG_AHCI=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/colorfly_e708_q1_defconfig b/configs/colorfly_e708_q1_defconfig index 201b7425573..2d95f23bf3f 100644 --- a/configs/colorfly_e708_q1_defconfig +++ b/configs/colorfly_e708_q1_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=251 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PA15" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:1280,depth:24,pclk_khz:64000,le:20,ri:34,up:1,lo:16,hs:10,vs:1,sync:3,vmode:0" diff --git a/configs/difrnce_dit4350_defconfig b/configs/difrnce_dit4350_defconfig index f54a83d929d..347a85f18a5 100644 --- a/configs/difrnce_dit4350_defconfig +++ b/configs/difrnce_dit4350_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-difrnce-dit4350" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=408 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/dserve_dsrv9703c_defconfig b/configs/dserve_dsrv9703c_defconfig index f5ff69d7d63..6442998ba20 100644 --- a/configs/dserve_dsrv9703c_defconfig +++ b/configs/dserve_dsrv9703c_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-dserve-dsrv9703c" CONFIG_SPL=y CONFIG_MACH_SUN4I=y -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_USB0_ID_DET="PH4" CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:80000,le:479,ri:544,up:5,lo:26,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/ga10h_v1_1_defconfig b/configs/ga10h_v1_1_defconfig index 5d083742f1f..44aeb859aa8 100644 --- a/configs/ga10h_v1_1_defconfig +++ b/configs/ga10h_v1_1_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN8I_A33=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=15291 CONFIG_DRAM_ODT_EN=y -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:52000,le:138,ri:162,up:22,lo:10,hs:20,vs:3,sync:3,vmode:0" diff --git a/configs/gt90h_v4_defconfig b/configs/gt90h_v4_defconfig index 6502ac8cf43..527851d8e8e 100644 --- a/configs/gt90h_v4_defconfig +++ b/configs/gt90h_v4_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A23=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=32767 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:55000,le:159,ri:160,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/h8_homlet_v2_defconfig b/configs/h8_homlet_v2_defconfig index 29f965200e1..2fcae46e33e 100644 --- a/configs/h8_homlet_v2_defconfig +++ b/configs/h8_homlet_v2_defconfig @@ -6,8 +6,6 @@ CONFIG_MACH_SUN8I_A83T=y CONFIG_DRAM_CLK=480 CONFIG_DRAM_ZQ=15355 CONFIG_DRAM_ODT_EN=y -CONFIG_USB0_VBUS_PIN="PL5" -CONFIG_USB1_VBUS_PIN="PL6" CONFIG_AXP_GPIO=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONSOLE_MUX=y diff --git a/configs/iNet_3F_defconfig b/configs/iNet_3F_defconfig index 5cc1a1d57f4..aa6d6f81175 100644 --- a/configs/iNet_3F_defconfig +++ b/configs/iNet_3F_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:100000,le:799,ri:260,up:15,lo:16,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH8" diff --git a/configs/iNet_3W_defconfig b/configs/iNet_3W_defconfig index 38b20109a57..da103a6b1f3 100644 --- a/configs/iNet_3W_defconfig +++ b/configs/iNet_3W_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_ZQ=127 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:24,pclk_khz:65000,le:159,ri:160,up:22,lo:15,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH8" diff --git a/configs/iNet_86VS_defconfig b/configs/iNet_86VS_defconfig index 2c8ecb51de0..d5fb50fded3 100644 --- a/configs/iNet_86VS_defconfig +++ b/configs/iNet_86VS_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-86vs" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=408 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_AXP_GPIO=y # CONFIG_VIDEO_HDMI is not set diff --git a/configs/iNet_D978_rev2_defconfig b/configs/iNet_D978_rev2_defconfig index 70be98030a0..2eb3e65a2e7 100644 --- a/configs/iNet_D978_rev2_defconfig +++ b/configs/iNet_D978_rev2_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A33=y CONFIG_DRAM_CLK=456 CONFIG_DRAM_ZQ=15291 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:65000,le:120,ri:180,up:22,lo:13,hs:20,vs:3,sync:3,vmode:0" diff --git a/configs/icnova-a20-swac_defconfig b/configs/icnova-a20-swac_defconfig index 30c28f70857..f91db056065 100644 --- a/configs/icnova-a20-swac_defconfig +++ b/configs/icnova-a20-swac_defconfig @@ -9,9 +9,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=384 CONFIG_OLD_SUNXI_KERNEL_COMPAT=y -CONFIG_USB0_VBUS_PIN="PG11" CONFIG_USB0_VBUS_DET="PH7" -CONFIG_USB1_VBUS_PIN="PG10" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" CONFIG_VIDEO_LCD_POWER="PH22" CONFIG_VIDEO_LCD_PANEL_LVDS=y diff --git a/configs/inet1_defconfig b/configs/inet1_defconfig index f81120b1197..77176320132 100644 --- a/configs/inet1_defconfig +++ b/configs/inet1_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_USB0_ID_DET="PH4" CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:24,pclk_khz:52000,le:32,ri:287,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/inet86dz_defconfig b/configs/inet86dz_defconfig index 3405bc423a3..a0097bcc559 100644 --- a/configs/inet86dz_defconfig +++ b/configs/inet86dz_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A23=y CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=63351 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:51000,le:138,ri:162,up:22,lo:10,hs:20,vs:3,sync:3,vmode:0" diff --git a/configs/inet97fv2_defconfig b/configs/inet97fv2_defconfig index d5d2dc32c93..7d14d2e1a6c 100644 --- a/configs/inet97fv2_defconfig +++ b/configs/inet97fv2_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_USB0_ID_DET="PH4" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/inet98v_rev2_defconfig b/configs/inet98v_rev2_defconfig index e4da6c14d04..e3724e71a4c 100644 --- a/configs/inet98v_rev2_defconfig +++ b/configs/inet98v_rev2_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-inet-98v-rev2" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/inet9f_rev03_defconfig b/configs/inet9f_rev03_defconfig index 4485f930236..5e2cb3fad21 100644 --- a/configs/inet9f_rev03_defconfig +++ b/configs/inet9f_rev03_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=408 CONFIG_DRAM_EMR1=4 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_USB0_ID_DET="PH4" CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:24,pclk_khz:33000,le:45,ri:209,up:22,lo:22,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/inet_q972_defconfig b/configs/inet_q972_defconfig index a70a83ebcd0..f78f7ca6b60 100644 --- a/configs/inet_q972_defconfig +++ b/configs/inet_q972_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_CLK=384 CONFIG_DRAM_ZQ=251 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PA15" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:65000,le:280,ri:20,up:22,lo:8,hs:20,vs:8,sync:3,vmode:0" diff --git a/configs/jesurun_q5_defconfig b/configs/jesurun_q5_defconfig index c99be7cea4e..e3d8122763a 100644 --- a/configs/jesurun_q5_defconfig +++ b/configs/jesurun_q5_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-jesurun-q5" CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=312 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_VIDEO_COMPOSITE=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y diff --git a/configs/mixtile_loftq_defconfig b/configs/mixtile_loftq_defconfig index 2f92228eb7b..11e7a3d30b7 100644 --- a/configs/mixtile_loftq_defconfig +++ b/configs/mixtile_loftq_defconfig @@ -5,8 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN6I=y CONFIG_DRAM_ZQ=251 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB1_VBUS_PIN="PH24" -CONFIG_USB2_VBUS_PIN="" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_PHY_REALTEK=y CONFIG_ETH_DESIGNWARE=y diff --git a/configs/mk802_a10s_defconfig b/configs/mk802_a10s_defconfig index 21f7a6e535d..9ac715339c5 100644 --- a/configs/mk802_a10s_defconfig +++ b/configs/mk802_a10s_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_EMR1=0 -CONFIG_USB1_VBUS_PIN="PB10" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/mk802_defconfig b/configs/mk802_defconfig index 416565e5af2..f23993382b4 100644 --- a/configs/mk802_defconfig +++ b/configs/mk802_defconfig @@ -3,7 +3,6 @@ CONFIG_ARCH_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-mk802" CONFIG_SPL=y CONFIG_MACH_SUN4I=y -CONFIG_USB2_VBUS_PIN="PH12" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_I2C_MVTWSI=y CONFIG_SYS_I2C_SLAVE=0x7f diff --git a/configs/orangepi_2_defconfig b/configs/orangepi_2_defconfig index 7aaa5190b3a..50047d9df64 100644 --- a/configs/orangepi_2_defconfig +++ b/configs/orangepi_2_defconfig @@ -5,7 +5,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-orangepi-2" CONFIG_SPL=y CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 -CONFIG_USB1_VBUS_PIN="PG13" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y diff --git a/configs/orangepi_plus_defconfig b/configs/orangepi_plus_defconfig index adffe389e9e..008c09d23c4 100644 --- a/configs/orangepi_plus_defconfig +++ b/configs/orangepi_plus_defconfig @@ -5,8 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_H3=y CONFIG_DRAM_CLK=672 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB1_VBUS_PIN="PG13" -CONFIG_USB3_VBUS_PIN="PG11" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SPL_SYS_I2C_LEGACY=y diff --git a/configs/parrot_r16_defconfig b/configs/parrot_r16_defconfig index 72235ccc071..3b07ee364b9 100644 --- a/configs/parrot_r16_defconfig +++ b/configs/parrot_r16_defconfig @@ -7,7 +7,6 @@ CONFIG_DRAM_CLK=600 CONFIG_DRAM_ZQ=15291 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 CONFIG_USB0_ID_DET="PD10" -CONFIG_USB1_VBUS_PIN="PD12" CONFIG_AXP_GPIO=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_FASTBOOT_CMD_OEM_FORMAT=y diff --git a/configs/pine_h64_defconfig b/configs/pine_h64_defconfig index 4712b8e4694..3937ad10a25 100644 --- a/configs/pine_h64_defconfig +++ b/configs/pine_h64_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN50I_H6=y CONFIG_SUNXI_DRAM_H6_LPDDR3=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB3_VBUS_PIN="PL5" CONFIG_SPL_SPI_SUNXI=y # CONFIG_PSCI_RESET is not set # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/polaroid_mid2407pxe03_defconfig b/configs/polaroid_mid2407pxe03_defconfig index 2155fe6646f..783e9c83c8d 100644 --- a/configs/polaroid_mid2407pxe03_defconfig +++ b/configs/polaroid_mid2407pxe03_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A23=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=63351 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:40,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/polaroid_mid2809pxe04_defconfig b/configs/polaroid_mid2809pxe04_defconfig index 1faf78f1b54..0e77f855b74 100644 --- a/configs/polaroid_mid2809pxe04_defconfig +++ b/configs/polaroid_mid2809pxe04_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A23=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=63351 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:36,ri:210,up:18,lo:22,hs:10,vs:5,sync:3,vmode:0" diff --git a/configs/pov_protab2_ips9_defconfig b/configs/pov_protab2_ips9_defconfig index a62c9f8fa37..0e82c9f5b00 100644 --- a/configs/pov_protab2_ips9_defconfig +++ b/configs/pov_protab2_ips9_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun4i-a10-pov-protab2-ips9" CONFIG_SPL=y CONFIG_MACH_SUN4I=y CONFIG_DRAM_CLK=432 -CONFIG_USB0_VBUS_PIN="PB9" CONFIG_USB0_VBUS_DET="PH5" CONFIG_USB0_ID_DET="PH4" CONFIG_VIDEO_LCD_MODE="x:1024,y:768,depth:18,pclk_khz:100000,le:480,ri:260,up:6,lo:16,hs:320,vs:10,sync:3,vmode:0" diff --git a/configs/q8_a13_tablet_defconfig b/configs/q8_a13_tablet_defconfig index 36252e5f89a..5c3df6c2589 100644 --- a/configs/q8_a13_tablet_defconfig +++ b/configs/q8_a13_tablet_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a13-q8-tablet" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=384 -CONFIG_USB0_VBUS_PIN="PG12" CONFIG_USB0_VBUS_DET="PG1" CONFIG_USB0_ID_DET="PG2" CONFIG_AXP_GPIO=y diff --git a/configs/q8_a23_tablet_800x480_defconfig b/configs/q8_a23_tablet_800x480_defconfig index 08ba34e08ee..1106079d7b9 100644 --- a/configs/q8_a23_tablet_800x480_defconfig +++ b/configs/q8_a23_tablet_800x480_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A23=y CONFIG_DRAM_CLK=432 CONFIG_DRAM_ZQ=63306 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:36,ri:210,up:18,lo:22,hs:10,vs:5,sync:3,vmode:0" diff --git a/configs/q8_a33_tablet_1024x600_defconfig b/configs/q8_a33_tablet_1024x600_defconfig index 6efbd84f7c3..7d3e5bb6b94 100644 --- a/configs/q8_a33_tablet_1024x600_defconfig +++ b/configs/q8_a33_tablet_1024x600_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A33=y CONFIG_DRAM_CLK=456 CONFIG_DRAM_ZQ=15291 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:1024,y:600,depth:18,pclk_khz:51000,le:159,ri:160,up:22,lo:12,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/q8_a33_tablet_800x480_defconfig b/configs/q8_a33_tablet_800x480_defconfig index bf5dcd0d018..0ad945da4ef 100644 --- a/configs/q8_a33_tablet_800x480_defconfig +++ b/configs/q8_a33_tablet_800x480_defconfig @@ -5,7 +5,6 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A33=y CONFIG_DRAM_CLK=456 CONFIG_DRAM_ZQ=15291 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH8" CONFIG_AXP_GPIO=y CONFIG_VIDEO_LCD_MODE="x:800,y:480,depth:18,pclk_khz:33000,le:87,ri:167,up:31,lo:13,hs:1,vs:1,sync:3,vmode:0" diff --git a/configs/r7-tv-dongle_defconfig b/configs/r7-tv-dongle_defconfig index 8875a09b2c9..4a207133766 100644 --- a/configs/r7-tv-dongle_defconfig +++ b/configs/r7-tv-dongle_defconfig @@ -4,7 +4,6 @@ CONFIG_DEFAULT_DEVICE_TREE="sun5i-a10s-r7-tv-dongle" CONFIG_SPL=y CONFIG_MACH_SUN5I=y CONFIG_DRAM_CLK=384 -CONFIG_USB1_VBUS_PIN="PG13" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SPL_I2C=y CONFIG_SYS_I2C_MVTWSI=y diff --git a/configs/sun8i_a23_evb_defconfig b/configs/sun8i_a23_evb_defconfig index a3b1d76d8bb..c3d15d41013 100644 --- a/configs/sun8i_a23_evb_defconfig +++ b/configs/sun8i_a23_evb_defconfig @@ -5,9 +5,7 @@ CONFIG_SPL=y CONFIG_MACH_SUN8I_A23=y CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=63351 -CONFIG_USB0_VBUS_PIN="axp_drivebus" CONFIG_USB0_VBUS_DET="axp_vbus_detect" -CONFIG_USB1_VBUS_PIN="PH7" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_CONS_INDEX=5 CONFIG_USB_EHCI_HCD=y diff --git a/configs/tbs_a711_defconfig b/configs/tbs_a711_defconfig index c17815382ec..4c6727cd36c 100644 --- a/configs/tbs_a711_defconfig +++ b/configs/tbs_a711_defconfig @@ -8,7 +8,6 @@ CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=15355 CONFIG_DRAM_ODT_EN=y CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB0_VBUS_PIN="AXP0-VBUS-ENABLE" CONFIG_USB0_ID_DET="PH11" CONFIG_AXP_GPIO=y # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set diff --git a/configs/teres_i_defconfig b/configs/teres_i_defconfig index b9b22e77203..6a9261eeeba 100644 --- a/configs/teres_i_defconfig +++ b/configs/teres_i_defconfig @@ -6,7 +6,6 @@ CONFIG_MACH_SUN50I=y CONFIG_DRAM_CLK=552 CONFIG_DRAM_ZQ=3881949 CONFIG_MMC_SUNXI_SLOT_EXTRA=2 -CONFIG_USB1_VBUS_PIN="PL7" CONFIG_I2C0_ENABLE=y CONFIG_PREBOOT="setenv usb_pgood_delay 2000; usb start" CONFIG_SPL_SYS_I2C_LEGACY=y
Now that this functionality is modeled using the device tree and regulator uclass, the named GPIO is not referenced anywhere. Remove it, along with the rest of the support for AXP virtual GPIOs.
Signed-off-by: Samuel Holland samuel@sholland.org ---
drivers/gpio/axp_gpio.c | 75 +++++++++++---------------------------- drivers/gpio/sunxi_gpio.c | 8 ----- include/axp221.h | 4 --- include/axp809.h | 4 --- include/axp818.h | 4 --- include/sunxi_gpio.h | 8 ----- 6 files changed, 21 insertions(+), 82 deletions(-)
diff --git a/drivers/gpio/axp_gpio.c b/drivers/gpio/axp_gpio.c index af6631697f5..b10c3fe1934 100644 --- a/drivers/gpio/axp_gpio.c +++ b/drivers/gpio/axp_gpio.c @@ -16,6 +16,9 @@ #include <errno.h> #include <sunxi_gpio.h>
+#define AXP_GPIO_PREFIX "AXP0-" +#define AXP_GPIO_COUNT 4 + static int axp_gpio_set_value(struct udevice *dev, unsigned pin, int val);
static u8 axp_get_gpio_ctrl_reg(unsigned pin) @@ -47,28 +50,14 @@ static int axp_gpio_direction_input(struct udevice *dev, unsigned pin) static int axp_gpio_direction_output(struct udevice *dev, unsigned pin, int val) { - __maybe_unused int ret; u8 reg;
- switch (pin) { -#ifdef AXP_MISC_CTRL_N_VBUSEN_FUNC - /* Only available on later PMICs */ - case SUNXI_GPIO_AXP0_VBUS_ENABLE: - ret = pmic_bus_clrbits(AXP_MISC_CTRL, - AXP_MISC_CTRL_N_VBUSEN_FUNC); - if (ret) - return ret; - - return axp_gpio_set_value(dev, pin, val); -#endif - default: - reg = axp_get_gpio_ctrl_reg(pin); - if (reg == 0) - return -EINVAL; + reg = axp_get_gpio_ctrl_reg(pin); + if (reg == 0) + return -EINVAL;
- return pmic_bus_write(reg, val ? AXP_GPIO_CTRL_OUTPUT_HIGH : - AXP_GPIO_CTRL_OUTPUT_LOW); - } + return pmic_bus_write(reg, val ? AXP_GPIO_CTRL_OUTPUT_HIGH : + AXP_GPIO_CTRL_OUTPUT_LOW); }
static int axp_gpio_get_value(struct udevice *dev, unsigned pin) @@ -76,25 +65,16 @@ static int axp_gpio_get_value(struct udevice *dev, unsigned pin) u8 reg, val, mask; int ret;
- switch (pin) { -#ifdef AXP_MISC_CTRL_N_VBUSEN_FUNC - /* Only available on later PMICs */ - case SUNXI_GPIO_AXP0_VBUS_ENABLE: - ret = pmic_bus_read(AXP_VBUS_IPSOUT, &val); - mask = AXP_VBUS_IPSOUT_DRIVEBUS; - break; -#endif - default: - reg = axp_get_gpio_ctrl_reg(pin); - if (reg == 0) - return -EINVAL; + reg = axp_get_gpio_ctrl_reg(pin); + if (reg == 0) + return -EINVAL;
- ret = pmic_bus_read(AXP_GPIO_STATE, &val); - mask = 1 << (pin + AXP_GPIO_STATE_OFFSET); - } + ret = pmic_bus_read(AXP_GPIO_STATE, &val); if (ret) return ret;
+ mask = 1 << (pin + AXP_GPIO_STATE_OFFSET); + return (val & mask) ? 1 : 0; }
@@ -102,25 +82,12 @@ static int axp_gpio_set_value(struct udevice *dev, unsigned pin, int val) { u8 reg;
- switch (pin) { -#ifdef AXP_MISC_CTRL_N_VBUSEN_FUNC - /* Only available on later PMICs */ - case SUNXI_GPIO_AXP0_VBUS_ENABLE: - if (val) - return pmic_bus_setbits(AXP_VBUS_IPSOUT, - AXP_VBUS_IPSOUT_DRIVEBUS); - else - return pmic_bus_clrbits(AXP_VBUS_IPSOUT, - AXP_VBUS_IPSOUT_DRIVEBUS); -#endif - default: - reg = axp_get_gpio_ctrl_reg(pin); - if (reg == 0) - return -EINVAL; + reg = axp_get_gpio_ctrl_reg(pin); + if (reg == 0) + return -EINVAL;
static const struct dm_gpio_ops gpio_axp_ops = { @@ -135,8 +102,8 @@ static int gpio_axp_probe(struct udevice *dev) struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev);
/* Tell the uclass how many GPIOs we have */ - uc_priv->bank_name = strdup(SUNXI_GPIO_AXP0_PREFIX); - uc_priv->gpio_count = SUNXI_GPIO_AXP0_GPIO_COUNT; + uc_priv->bank_name = AXP_GPIO_PREFIX; + uc_priv->gpio_count = AXP_GPIO_COUNT;
return 0; } diff --git a/drivers/gpio/sunxi_gpio.c b/drivers/gpio/sunxi_gpio.c index e4463a223f7..b5e74a0da94 100644 --- a/drivers/gpio/sunxi_gpio.c +++ b/drivers/gpio/sunxi_gpio.c @@ -247,15 +247,7 @@ int sunxi_name_to_gpio(const char *name) { unsigned int gpio; int ret; -#if !defined CONFIG_SPL_BUILD && defined CONFIG_AXP_GPIO - char lookup[8];
- if (strcasecmp(name, "AXP0-VBUS-ENABLE") == 0) { - sprintf(lookup, SUNXI_GPIO_AXP0_PREFIX "%d", - SUNXI_GPIO_AXP0_VBUS_ENABLE); - name = lookup; - } -#endif ret = gpio_lookup_name(name, NULL, NULL, &gpio);
return ret ? ret : gpio; diff --git a/include/axp221.h b/include/axp221.h index 32b988f3a9c..8a4a3cca82f 100644 --- a/include/axp221.h +++ b/include/axp221.h @@ -53,10 +53,6 @@ #ifdef CONFIG_AXP221_POWER #define AXP_POWER_STATUS 0x00 #define AXP_POWER_STATUS_ALDO_IN BIT(0) -#define AXP_VBUS_IPSOUT 0x30 -#define AXP_VBUS_IPSOUT_DRIVEBUS (1 << 2) -#define AXP_MISC_CTRL 0x8f -#define AXP_MISC_CTRL_N_VBUSEN_FUNC (1 << 4) #define AXP_GPIO0_CTRL 0x90 #define AXP_GPIO1_CTRL 0x92 #define AXP_GPIO_CTRL_OUTPUT_LOW 0x00 /* Drive pin low */ diff --git a/include/axp809.h b/include/axp809.h index 71a7cb2aaa1..3bd71b3d1a3 100644 --- a/include/axp809.h +++ b/include/axp809.h @@ -47,10 +47,6 @@ #ifdef CONFIG_AXP809_POWER #define AXP_POWER_STATUS 0x00 #define AXP_POWER_STATUS_ALDO_IN BIT(0) -#define AXP_VBUS_IPSOUT 0x30 -#define AXP_VBUS_IPSOUT_DRIVEBUS (1 << 2) -#define AXP_MISC_CTRL 0x8f -#define AXP_MISC_CTRL_N_VBUSEN_FUNC (1 << 4) #define AXP_GPIO0_CTRL 0x90 #define AXP_GPIO1_CTRL 0x92 #define AXP_GPIO_CTRL_OUTPUT_LOW 0x00 /* Drive pin low */ diff --git a/include/axp818.h b/include/axp818.h index 08ac35d15fa..b3a9686e0e5 100644 --- a/include/axp818.h +++ b/include/axp818.h @@ -61,10 +61,6 @@ #ifdef CONFIG_AXP818_POWER #define AXP_POWER_STATUS 0x00 #define AXP_POWER_STATUS_ALDO_IN BIT(0) -#define AXP_VBUS_IPSOUT 0x30 -#define AXP_VBUS_IPSOUT_DRIVEBUS (1 << 2) -#define AXP_MISC_CTRL 0x8f -#define AXP_MISC_CTRL_N_VBUSEN_FUNC (1 << 4) #define AXP_GPIO0_CTRL 0x90 #define AXP_GPIO1_CTRL 0x92 #define AXP_GPIO_CTRL_OUTPUT_LOW 0x00 /* Drive pin low */ diff --git a/include/sunxi_gpio.h b/include/sunxi_gpio.h index db3742c0397..31783e08732 100644 --- a/include/sunxi_gpio.h +++ b/include/sunxi_gpio.h @@ -82,7 +82,6 @@ enum sunxi_gpio_number { SUNXI_GPIO_L_START = 352, SUNXI_GPIO_M_START = SUNXI_GPIO_NEXT(SUNXI_GPIO_L), SUNXI_GPIO_N_START = SUNXI_GPIO_NEXT(SUNXI_GPIO_M), - SUNXI_GPIO_AXP0_START = 1024, };
/* SUNXI GPIO number definitions */ @@ -99,8 +98,6 @@ enum sunxi_gpio_number { #define SUNXI_GPM(_nr) (SUNXI_GPIO_M_START + (_nr)) #define SUNXI_GPN(_nr) (SUNXI_GPIO_N_START + (_nr))
-#define SUNXI_GPAXP0(_nr) (SUNXI_GPIO_AXP0_START + (_nr)) - /* GPIO pin function config */ #define SUNXI_GPIO_INPUT 0 #define SUNXI_GPIO_OUTPUT 1 @@ -185,11 +182,6 @@ enum sunxi_gpio_number { #define SUNXI_GPIO_PULL_UP 1 #define SUNXI_GPIO_PULL_DOWN 2
-/* Virtual AXP0 GPIOs */ -#define SUNXI_GPIO_AXP0_PREFIX "AXP0-" -#define SUNXI_GPIO_AXP0_VBUS_ENABLE 5 -#define SUNXI_GPIO_AXP0_GPIO_COUNT 6 - struct sunxi_gpio_plat { void *regs; char bank_name[3];
Andre Przywara
Samuel Holland
