[PATCH] Kconfig: Use spaces not tabs in Kconfig entires
While the Kconfig language seems to accept either form of whitespace, we use a space throughout the project, except in these spots.
Signed-off-by: Tom Rini trini@konsulko.com --- arch/arm/mach-exynos/Kconfig | 2 +- board/freescale/mx6memcal/Kconfig | 4 ++-- 2 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-exynos/Kconfig b/arch/arm/mach-exynos/Kconfig index 0b4276c03628..7df0e176179d 100644 --- a/arch/arm/mach-exynos/Kconfig +++ b/arch/arm/mach-exynos/Kconfig @@ -141,7 +141,7 @@ if ARCH_EXYNOS7 choice prompt "EXYNOS7 board select"
-config TARGET_ESPRESSO7420 +config TARGET_ESPRESSO7420 bool "ESPRESSO7420 board" select ARM64 select ARMV8_MULTIENTRY diff --git a/board/freescale/mx6memcal/Kconfig b/board/freescale/mx6memcal/Kconfig index 9987cba5dcb7..481403ae855d 100644 --- a/board/freescale/mx6memcal/Kconfig +++ b/board/freescale/mx6memcal/Kconfig @@ -87,12 +87,12 @@ choice help Select the type of DDR (DDR3 or LPDDR2) used on your design
-config DDR3 +config DDR3 bool "DDR3" help Select this if your board design uses DDR3.
-config LPDDR2 +config LPDDR2 bool "LPDDR2" help Select this if your board design uses LPDDR2.
