[PATCH 1/3] firmware: scmi: voltage regulator
Implement voltage regulators interfaced by the SCMI voltage domain protocol. The DT bindings are defined in the Linux kernel since SCMI voltage domain and regulators patches [1] and [2] integration in v5.11-rc7.
Link: [1] https://github.com/torvalds/linux/commit/0f80fcec08e9c50b8d2992cf26495673765... Link: [2] https://github.com/torvalds/linux/commit/2add5cacff3531e54c50b0832128299faa9...
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- doc/device-tree-bindings/arm/arm,scmi.txt | 34 +++++ drivers/firmware/scmi/scmi_agent-uclass.c | 35 ++++- drivers/power/regulator/Kconfig | 8 + drivers/power/regulator/Makefile | 1 + drivers/power/regulator/scmi_regulator.c | 170 ++++++++++++++++++++++ include/scmi_protocols.h | 113 ++++++++++++++ 6 files changed, 359 insertions(+), 2 deletions(-) create mode 100644 drivers/power/regulator/scmi_regulator.c
diff --git a/doc/device-tree-bindings/arm/arm,scmi.txt b/doc/device-tree-bindings/arm/arm,scmi.txt index 1f293ea24..a76124f4a 100644 --- a/doc/device-tree-bindings/arm/arm,scmi.txt +++ b/doc/device-tree-bindings/arm/arm,scmi.txt @@ -62,6 +62,20 @@ Required properties: - #power-domain-cells : Should be 1. Contains the device or the power domain ID value used by SCMI commands.
+Regulator bindings for the SCMI Regulator based on SCMI Message Protocol +------------------------------------------------------------ +An SCMI Regulator is permanently bound to a well defined SCMI Voltage Domain, +and should be always positioned as a root regulator. +It does not support any current operation. + +SCMI Regulators are grouped under a 'regulators' node which in turn is a child +of the SCMI Voltage protocol node inside the desired SCMI instance node. + +This binding uses the common regulator binding[6]. + +Required properties: + - reg : shall identify an existent SCMI Voltage Domain. + Sensor bindings for the sensors based on SCMI Message Protocol -------------------------------------------------------------- SCMI provides an API to access the various sensors on the SoC. @@ -105,6 +119,7 @@ Required sub-node properties: [3] Documentation/devicetree/bindings/thermal/thermal.txt [4] Documentation/devicetree/bindings/sram/sram.yaml [5] Documentation/devicetree/bindings/reset/reset.txt +[6] Documentation/devicetree/bindings/regulator/regulator.yaml
Example:
@@ -169,6 +184,25 @@ firmware { reg = <0x16>; #reset-cells = <1>; }; + + scmi_voltage: protocol@17 { + reg = <0x17>; + + regulators { + regulator_devX: regulator@0 { + reg = <0x0>; + regulator-max-microvolt = <3300000>; + }; + + regulator_devY: regulator@9 { + reg = <0x9>; + regulator-min-microvolt = <500000>; + regulator-max-microvolt = <4200000>; + }; + + ... + }; + }; }; };
diff --git a/drivers/firmware/scmi/scmi_agent-uclass.c b/drivers/firmware/scmi/scmi_agent-uclass.c index 516e690ac..03d236426 100644 --- a/drivers/firmware/scmi/scmi_agent-uclass.c +++ b/drivers/firmware/scmi/scmi_agent-uclass.c @@ -50,6 +50,29 @@ int scmi_to_linux_errno(s32 scmi_code) return -EPROTO; }
+static int regulator_devices_bind(struct udevice *dev, struct driver *drv, + ofnode protocol_node) +{ + ofnode regulators_node; + ofnode node; + int ret; + + regulators_node = ofnode_find_subnode(protocol_node, "regulators"); + if (!ofnode_valid(regulators_node)) { + dev_err(dev, "regulators subnode not found\n"); + return -ENXIO; + } + + ofnode_for_each_subnode(node, regulators_node) { + ret = device_bind(dev, drv, ofnode_get_name(node), NULL, node, + NULL); + if (ret) + return ret; + } + + return 0; +} + /* * SCMI agent devices binds devices of various uclasses depeding on * the FDT description. scmi_bind_protocol() is a generic bind sequence @@ -79,6 +102,10 @@ static int scmi_bind_protocols(struct udevice *dev) if (IS_ENABLED(CONFIG_RESET_SCMI)) drv = DM_DRIVER_GET(scmi_reset_domain); break; + case SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN: + if (IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) + drv = DM_DRIVER_GET(scmi_voltage_domain); + break; default: break; } @@ -89,8 +116,12 @@ static int scmi_bind_protocols(struct udevice *dev) continue; }
- ret = device_bind(dev, drv, ofnode_get_name(node), NULL, node, - NULL); + if (protocol_id == SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN) + ret = regulator_devices_bind(dev, drv, node); + else + ret = device_bind(dev, drv, ofnode_get_name(node), + NULL, node, NULL); + if (ret) break; } diff --git a/drivers/power/regulator/Kconfig b/drivers/power/regulator/Kconfig index fbbea18c7..5d6180229 100644 --- a/drivers/power/regulator/Kconfig +++ b/drivers/power/regulator/Kconfig @@ -353,3 +353,11 @@ config DM_REGULATOR_TPS65941 TPS65941 series of PMICs have 5 single phase BUCKs that can also be configured in multi phase modes & 4 LDOs. The driver implements get/set api for value and enable. + +config DM_REGULATOR_SCMI + bool "Enable driver for SCMI voltage domain regulators" + depends on DM_REGULATOR + select SCMI_AGENT + help + Enable this option if you want to support regulators exposed through + the SCMI voltage domain protocol by a SCMI server. diff --git a/drivers/power/regulator/Makefile b/drivers/power/regulator/Makefile index 9d58112dc..b2f5972ea 100644 --- a/drivers/power/regulator/Makefile +++ b/drivers/power/regulator/Makefile @@ -30,3 +30,4 @@ obj-$(CONFIG_DM_REGULATOR_TPS65910) += tps65910_regulator.o obj-$(CONFIG_DM_REGULATOR_TPS62360) += tps62360_regulator.o obj-$(CONFIG_$(SPL_)DM_REGULATOR_STPMIC1) += stpmic1.o obj-$(CONFIG_DM_REGULATOR_TPS65941) += tps65941_regulator.o +obj-$(CONFIG_DM_REGULATOR_SCMI) += scmi_regulator.o diff --git a/drivers/power/regulator/scmi_regulator.c b/drivers/power/regulator/scmi_regulator.c new file mode 100644 index 000000000..072a978a8 --- /dev/null +++ b/drivers/power/regulator/scmi_regulator.c @@ -0,0 +1,170 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2020-2021 Linaro Limited + */ +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <scmi_agent.h> +#include <scmi_protocols.h> +#include <asm/types.h> +#include <dm/device.h> +#include <dm/device_compat.h> +#include <linux/kernel.h> +#include <power/regulator.h> + +/** + * struct scmi_regulator_platdata - Platform data for a scmi voltage domain regulator + * @domain_id: ID representing the regulator for the related SCMI agent + */ +struct scmi_regulator_platdata { + u32 domain_id; +}; + +static int scmi_voltd_set_enable(struct udevice *dev, bool enable) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_config_set_in in = { + .domain_id = pdata->domain_id, + .config = enable ? SCMI_VOLTD_CONFIG_ON : SCMI_VOLTD_CONFIG_OFF, + }; + struct scmi_voltd_config_set_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_CONFIG_SET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent, &msg); + if (ret) + return ret; + + ret = scmi_to_linux_errno(out.status); + if (ret) + return ret; + + return ret; +} + +static int scmi_voltd_get_enable(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_config_get_in in = { + .domain_id = pdata->domain_id, + }; + struct scmi_voltd_config_get_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_CONFIG_GET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent, &msg); + if (ret < 0) + return ret; + + ret = scmi_to_linux_errno(out.status); + if (ret < 0) + return ret; + + return out.config == SCMI_VOLTD_CONFIG_ON; +} + +static int scmi_voltd_set_voltage_level(struct udevice *dev, int uV) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_level_set_in in = { + .domain_id = pdata->domain_id, + .voltage_level = uV, + }; + struct scmi_voltd_level_set_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_LEVEL_SET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent, &msg); + if (ret < 0) + return ret; + + return scmi_to_linux_errno(out.status); +} + +static int scmi_voltd_get_voltage_level(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_level_get_in in = { + .domain_id = pdata->domain_id, + }; + struct scmi_voltd_level_get_out out; + struct scmi_msg msg = SCMI_MSG_IN(SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + SCMI_VOLTAGE_DOMAIN_LEVEL_GET, + in, out); + int ret; + + ret = devm_scmi_process_msg(dev->parent, &msg); + if (ret < 0) + return ret; + + ret = scmi_to_linux_errno(out.status); + if (ret < 0) + return ret; + + return out.voltage_level; +} + +static int scmi_regulator_of_to_plat(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + fdt_addr_t reg; + + reg = dev_read_addr(dev); + if (reg == FDT_ADDR_T_NONE) + return -EINVAL; + + pdata->domain_id = (u32)reg; + + return 0; +} + +static int scmi_regulator_probe(struct udevice *dev) +{ + struct scmi_regulator_platdata *pdata = dev_get_plat(dev); + struct scmi_voltd_attr_in in = { 0 }; + struct scmi_voltd_attr_out out = { 0 }; + struct scmi_msg scmi_msg = { + .protocol_id = SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN, + .message_id = SCMI_VOLTAGE_DOMAIN_ATTRIBUTES, + .in_msg = (u8 *)&in, + .in_msg_sz = sizeof(in), + .out_msg = (u8 *)&out, + .out_msg_sz = sizeof(out), + }; + int ret; + + /* Check voltage domain is known from SCMI server */ + in.domain_id = pdata->domain_id; + + ret = devm_scmi_process_msg(dev->parent, &scmi_msg); + if (ret) { + dev_err(dev, "Failed to query voltage domain %u: %d\n", + pdata->domain_id, ret); + return -ENXIO; + } + + return 0; +} + +static const struct dm_regulator_ops scmi_voltd_ops = { + .get_value = scmi_voltd_get_voltage_level, + .set_value = scmi_voltd_set_voltage_level, + .get_enable = scmi_voltd_get_enable, + .set_enable = scmi_voltd_set_enable, +}; + +U_BOOT_DRIVER(scmi_voltage_domain) = { + .name = "scmi_voltage_domain", + .id = UCLASS_REGULATOR, + .ops = &scmi_voltd_ops, + .probe = scmi_regulator_probe, + .of_to_plat = scmi_regulator_of_to_plat, + .plat_auto = sizeof(struct scmi_regulator_platdata), +}; diff --git a/include/scmi_protocols.h b/include/scmi_protocols.h index ccab97c96..2db71697e 100644 --- a/include/scmi_protocols.h +++ b/include/scmi_protocols.h @@ -23,6 +23,7 @@ enum scmi_std_protocol { SCMI_PROTOCOL_ID_CLOCK = 0x14, SCMI_PROTOCOL_ID_SENSOR = 0x15, SCMI_PROTOCOL_ID_RESET_DOMAIN = 0x16, + SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN = 0x17, };
enum scmi_status_code { @@ -176,4 +177,116 @@ struct scmi_rd_reset_out { s32 status; };
+/* + * SCMI Voltage Domain Protocol + */ + +enum scmi_voltage_domain_message_id { + SCMI_VOLTAGE_DOMAIN_ATTRIBUTES = 0x3, + SCMI_VOLTAGE_DOMAIN_CONFIG_SET = 0x5, + SCMI_VOLTAGE_DOMAIN_CONFIG_GET = 0x6, + SCMI_VOLTAGE_DOMAIN_LEVEL_SET = 0x7, + SCMI_VOLTAGE_DOMAIN_LEVEL_GET = 0x8, +}; + +#define SCMI_VOLTD_NAME_LEN 16 + +#define SCMI_VOLTD_CONFIG_MASK GENMASK(3, 0) +#define SCMI_VOLTD_CONFIG_OFF 0 +#define SCMI_VOLTD_CONFIG_ON 0x7 + +/** + * struct scmi_voltd_attr_in - Payload for VOLTAGE_DOMAIN_ATTRIBUTES message + * @domain_id: SCMI voltage domain ID + */ +struct scmi_voltd_attr_in { + u32 domain_id; +}; + +/** + * struct scmi_voltd_attr_out - Payload for VOLTAGE_DOMAIN_ATTRIBUTES response + * @status: SCMI command status + * @attributes: Retrieved attributes of the voltage domain + * @name: Voltage domain name + */ +struct scmi_voltd_attr_out { + s32 status; + u32 attributes; + char name[SCMI_VOLTD_NAME_LEN]; +}; + +/** + * struct scmi_voltd_config_set_in - Message payload for VOLTAGE_CONFIG_SET cmd + * @domain_id: SCMI voltage domain ID + * @config: Configuration data of the voltage domain + */ +struct scmi_voltd_config_set_in { + u32 domain_id; + u32 config; +}; + +/** + * struct scmi_voltd_config_set_out - Response for VOLTAGE_CONFIG_SET command + * @status: SCMI command status + */ +struct scmi_voltd_config_set_out { + s32 status; +}; + +/** + * struct scmi_voltd_config_get_in - Message payload for VOLTAGE_CONFIG_GET cmd + * @domain_id: SCMI voltage domain ID + */ +struct scmi_voltd_config_get_in { + u32 domain_id; +}; + +/** + * struct scmi_voltd_config_get_out - Response for VOLTAGE_CONFIG_GET command + * @status: SCMI command status + * @config: Configuration data of the voltage domain + */ +struct scmi_voltd_config_get_out { + s32 status; + u32 config; +}; + +/** + * struct scmi_voltd_level_set_in - Message payload for VOLTAGE_LEVEL_SET cmd + * @domain_id: SCMI voltage domain ID + * @flags: Parameter flags for configuring target level + * @voltage_level: Target voltage level in microvolts (uV) + */ +struct scmi_voltd_level_set_in { + u32 domain_id; + u32 flags; + s32 voltage_level; +}; + +/** + * struct scmi_voltd_level_set_out - Response for VOLTAGE_LEVEL_SET command + * @status: SCMI command status + */ +struct scmi_voltd_level_set_out { + s32 status; +}; + +/** + * struct scmi_voltd_level_get_in - Message payload for VOLTAGE_LEVEL_GET cmd + * @domain_id: SCMI voltage domain ID + */ +struct scmi_voltd_level_get_in { + u32 domain_id; +}; + +/** + * struct scmi_voltd_level_get_out - Response for VOLTAGE_LEVEL_GET command + * @status: SCMI command status + * @voltage_level: Voltage level in microvolts (uV) + */ +struct scmi_voltd_level_get_out { + s32 status; + s32 voltage_level; +}; + #endif /* _SCMI_PROTOCOLS_H */
Implement sandbox regulator devices for SCMI voltage domains and test them in DM scmi tests.
Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- arch/sandbox/dts/test.dts | 23 +++ arch/sandbox/include/asm/scmi_test.h | 20 ++ configs/sandbox_defconfig | 1 + drivers/firmware/scmi/sandbox-scmi_agent.c | 203 ++++++++++++++++++- drivers/firmware/scmi/sandbox-scmi_devices.c | 25 ++- test/dm/scmi.c | 64 ++++++ 6 files changed, 333 insertions(+), 3 deletions(-)
diff --git a/arch/sandbox/dts/test.dts b/arch/sandbox/dts/test.dts index e95f4631b..14d6983e7 100644 --- a/arch/sandbox/dts/test.dts +++ b/arch/sandbox/dts/test.dts @@ -451,6 +451,27 @@ reg = <0x16>; #reset-cells = <1>; }; + + protocol@17 { + reg = <0x17>; + + regulators { + #address-cells = <1>; + #size-cells = <0>; + + regul0_scmi0: reg@0 { + reg = <0>; + regulator-name = "sandbox-voltd0"; + regulator-min-microvolt = <1100000>; + regulator-max-microvolt = <3300000>; + }; + regul1_scmi0: reg@1 { + reg = <0x1>; + regulator-name = "sandbox-voltd1"; + regulator-min-microvolt = <1800000>; + }; + }; + }; };
sandbox-scmi-agent@1 { @@ -1217,6 +1238,8 @@ compatible = "sandbox,scmi-devices"; clocks = <&clk_scmi0 7>, <&clk_scmi0 3>, <&clk_scmi1 1>; resets = <&reset_scmi0 3>; + regul0-supply = <®ul0_scmi0>; + regul1-supply = <®ul1_scmi0>; };
pinctrl { diff --git a/arch/sandbox/include/asm/scmi_test.h b/arch/sandbox/include/asm/scmi_test.h index 3e8b0068f..9b7031531 100644 --- a/arch/sandbox/include/asm/scmi_test.h +++ b/arch/sandbox/include/asm/scmi_test.h @@ -31,6 +31,18 @@ struct sandbox_scmi_reset { bool asserted; };
+/** + * struct sandbox_scmi_voltd - Simulated voltage regulator exposed by SCMI + * @id: Identifier of the voltage domain used in the SCMI protocol + * @enabled: Regulator state: true if on, false if off + * @voltage_uv: Regulator current voltage in microvoltd (uV) + */ +struct sandbox_scmi_voltd { + uint id; + bool enabled; + int voltage_uv; +}; + /** * struct sandbox_scmi_agent - Simulated SCMI service seen by SCMI agent * @idx: Identifier for the SCMI agent, its index @@ -38,6 +50,8 @@ struct sandbox_scmi_reset { * @clk_count: Simulated clocks array size * @clk: Simulated reset domains * @clk_count: Simulated reset domains array size + * @voltd: Simulated voltage domains (regulators) + * @voltd_count: Simulated voltage domains array size */ struct sandbox_scmi_agent { uint idx; @@ -45,6 +59,8 @@ struct sandbox_scmi_agent { size_t clk_count; struct sandbox_scmi_reset *reset; size_t reset_count; + struct sandbox_scmi_voltd *voltd; + size_t voltd_count; };
/** @@ -63,12 +79,16 @@ struct sandbox_scmi_service { * @clk_count: Number of clock devices probed * @reset: Array the reset controller devices * @reset_count: Number of reset controller devices probed + * @regul: Array regulator devices + * @regul_count: Number of regulator devices probed */ struct sandbox_scmi_devices { struct clk *clk; size_t clk_count; struct reset_ctl *reset; size_t reset_count; + struct udevice **regul; + size_t regul_count; };
#ifdef CONFIG_SCMI_FIRMWARE diff --git a/configs/sandbox_defconfig b/configs/sandbox_defconfig index 0c7674efc..790158445 100644 --- a/configs/sandbox_defconfig +++ b/configs/sandbox_defconfig @@ -214,6 +214,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_REGULATOR_RK8XX=y CONFIG_REGULATOR_S5M8767=y CONFIG_DM_REGULATOR_SANDBOX=y +CONFIG_DM_REGULATOR_SCMI=y CONFIG_REGULATOR_TPS65090=y CONFIG_DM_PWM=y CONFIG_PWM_SANDBOX=y diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index 35de68c75..3eafc49bd 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -19,14 +19,15 @@ * SCMI protocols embedded in U-Boot. Currently: * - SCMI clock protocol: emulate 2 agents each exposing few clocks * - SCMI reset protocol: emulate 1 agents each exposing a reset + * - SCMI voltage domain protocol: emulate 1 agent exposing 2 regulators * - * Agent #0 simulates 2 clocks and 1 reset domain. + * Agent #0 simulates 2 clocks, 1 reset domain and 1 voltage domain. * See IDs in scmi0_clk[]/scmi0_reset[] and "sandbox-scmi-agent@0" in test.dts. * * Agent #1 simulates 1 clock. * See IDs in scmi1_clk[] and "sandbox-scmi-agent@1" in test.dts. * - * All clocks are default disabled and reset levels down. + * All clocks and regulators are default disabled and reset controller down. * * This Driver exports sandbox_scmi_service_ct() for the test sequence to * get the state of the simulated services (clock state, rate, ...) and @@ -45,6 +46,11 @@ static struct sandbox_scmi_reset scmi0_reset[] = { { .id = 3 }, };
+static struct sandbox_scmi_voltd scmi0_voltd[] = { + { .id = 0, .voltage_uv = 3300000 }, + { .id = 1, .voltage_uv = 1800000 }, +}; + static struct sandbox_scmi_clk scmi1_clk[] = { { .id = 1, .rate = 44 }, }; @@ -81,6 +87,13 @@ static void debug_print_agent_state(struct udevice *dev, char *str) agent->reset_count, agent->reset_count ? agent->reset[0].asserted : -1, agent->reset_count > 1 ? agent->reset[1].asserted : -1); + dev_dbg(dev, " scmi%u_voltd (%zu): %u/%d, %u/%d, ...\n", + agent->idx, + agent->voltd_count, + agent->voltd_count ? agent->voltd[0].enabled : -1, + agent->voltd_count ? agent->voltd[0].voltage_uv : -1, + agent->voltd_count ? agent->voltd[1].enabled : -1, + agent->voltd_count ? agent->voltd[1].voltage_uv : -1); };
static struct sandbox_scmi_clk *get_scmi_clk_state(uint agent_id, uint clock_id) @@ -123,6 +136,20 @@ static struct sandbox_scmi_reset *get_scmi_reset_state(uint agent_id, return NULL; }
+static struct sandbox_scmi_voltd *get_scmi_voltd_state(uint agent_id, + uint domain_id) +{ + size_t n; + + if (agent_id == 0) { + for (n = 0; n < ARRAY_SIZE(scmi0_voltd); n++) + if (scmi0_voltd[n].id == domain_id) + return scmi0_voltd + n; + } + + return NULL; +} + /* * Sandbox SCMI agent ops */ @@ -290,6 +317,160 @@ static int sandbox_scmi_rd_reset(struct udevice *dev, struct scmi_msg *msg) return 0; }
+static int sandbox_scmi_voltd_attribs(struct udevice *dev, struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_attr_in *in = NULL; + struct scmi_voltd_attr_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_attr_in *)msg->in_msg; + out = (struct scmi_voltd_attr_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + memset(out, 0, sizeof(*out)); + snprintf(out->name, sizeof(out->name), "regu%u", in->domain_id); + + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_config_set(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_config_set_in *in = NULL; + struct scmi_voltd_config_set_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_config_set_in *)msg->in_msg; + out = (struct scmi_voltd_config_set_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else if (in->config & ~SCMI_VOLTD_CONFIG_MASK) { + dev_err(dev, "Invalid config value 0x%x\n", in->config); + + out->status = SCMI_INVALID_PARAMETERS; + } else if (in->config != SCMI_VOLTD_CONFIG_ON && + in->config != SCMI_VOLTD_CONFIG_OFF) { + dev_err(dev, "Unexpected custom value 0x%x\n", in->config); + + out->status = SCMI_INVALID_PARAMETERS; + } else { + voltd_state->enabled = in->config == SCMI_VOLTD_CONFIG_ON; + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_config_get(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_config_get_in *in = NULL; + struct scmi_voltd_config_get_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_config_get_in *)msg->in_msg; + out = (struct scmi_voltd_config_get_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + if (voltd_state->enabled) + out->config = SCMI_VOLTD_CONFIG_ON; + else + out->config = SCMI_VOLTD_CONFIG_OFF; + + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_level_set(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_level_set_in *in = NULL; + struct scmi_voltd_level_set_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_level_set_in *)msg->in_msg; + out = (struct scmi_voltd_level_set_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + voltd_state->voltage_uv = in->voltage_level; + out->status = SCMI_SUCCESS; + } + + return 0; +} + +static int sandbox_scmi_voltd_level_get(struct udevice *dev, + struct scmi_msg *msg) +{ + struct sandbox_scmi_agent *agent = dev_get_priv(dev); + struct scmi_voltd_level_get_in *in = NULL; + struct scmi_voltd_level_get_out *out = NULL; + struct sandbox_scmi_voltd *voltd_state = NULL; + + if (!msg->in_msg || msg->in_msg_sz < sizeof(*in) || + !msg->out_msg || msg->out_msg_sz < sizeof(*out)) + return -EINVAL; + + in = (struct scmi_voltd_level_get_in *)msg->in_msg; + out = (struct scmi_voltd_level_get_out *)msg->out_msg; + + voltd_state = get_scmi_voltd_state(agent->idx, in->domain_id); + if (!voltd_state) { + dev_err(dev, "Unexpected domain ID %u\n", in->domain_id); + + out->status = SCMI_NOT_FOUND; + } else { + out->voltage_level = voltd_state->voltage_uv; + out->status = SCMI_SUCCESS; + } + + return 0; +} + static int sandbox_scmi_test_process_msg(struct udevice *dev, struct scmi_msg *msg) { @@ -316,6 +497,22 @@ static int sandbox_scmi_test_process_msg(struct udevice *dev, break; } break; + case SCMI_PROTOCOL_ID_VOLTAGE_DOMAIN: + switch (msg->message_id) { + case SCMI_VOLTAGE_DOMAIN_ATTRIBUTES: + return sandbox_scmi_voltd_attribs(dev, msg); + case SCMI_VOLTAGE_DOMAIN_CONFIG_SET: + return sandbox_scmi_voltd_config_set(dev, msg); + case SCMI_VOLTAGE_DOMAIN_CONFIG_GET: + return sandbox_scmi_voltd_config_get(dev, msg); + case SCMI_VOLTAGE_DOMAIN_LEVEL_SET: + return sandbox_scmi_voltd_level_set(dev, msg); + case SCMI_VOLTAGE_DOMAIN_LEVEL_GET: + return sandbox_scmi_voltd_level_get(dev, msg); + default: + break; + } + break; case SCMI_PROTOCOL_ID_BASE: case SCMI_PROTOCOL_ID_POWER_DOMAIN: case SCMI_PROTOCOL_ID_SYSTEM: @@ -367,6 +564,8 @@ static int sandbox_scmi_test_probe(struct udevice *dev) .clk_count = ARRAY_SIZE(scmi0_clk), .reset = scmi0_reset, .reset_count = ARRAY_SIZE(scmi0_reset), + .voltd = scmi0_voltd, + .voltd_count = ARRAY_SIZE(scmi0_voltd), }; break; case '1': diff --git a/drivers/firmware/scmi/sandbox-scmi_devices.c b/drivers/firmware/scmi/sandbox-scmi_devices.c index 1a6fafbf5..aab5782fd 100644 --- a/drivers/firmware/scmi/sandbox-scmi_devices.c +++ b/drivers/firmware/scmi/sandbox-scmi_devices.c @@ -1,16 +1,18 @@ // SPDX-License-Identifier: GPL-2.0 /* - * Copyright (C) 2020, Linaro Limited + * Copyright (C) 2020-2021, Linaro Limited */
#include <common.h> #include <clk.h> #include <dm.h> +#include <log.h> #include <malloc.h> #include <reset.h> #include <asm/io.h> #include <asm/scmi_test.h> #include <dm/device_compat.h> +#include <power/regulator.h>
/* * Simulate to some extent a SCMI exchange. @@ -21,16 +23,19 @@
#define SCMI_TEST_DEVICES_CLK_COUNT 3 #define SCMI_TEST_DEVICES_RD_COUNT 1 +#define SCMI_TEST_DEVICES_VOLTD_COUNT 2
/* * struct sandbox_scmi_device_priv - Storage for device handles used by test * @clk: Array of clock instances used by tests * @reset_clt: Array of the reset controller instances used by tests + * @regulators: Array of regulator device references used by the tests * @devices: Resources exposed by sandbox_scmi_devices_ctx() */ struct sandbox_scmi_device_priv { struct clk clk[SCMI_TEST_DEVICES_CLK_COUNT]; struct reset_ctl reset_ctl[SCMI_TEST_DEVICES_RD_COUNT]; + struct udevice *regulators[SCMI_TEST_DEVICES_VOLTD_COUNT]; struct sandbox_scmi_devices devices; };
@@ -74,6 +79,8 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) .clk_count = SCMI_TEST_DEVICES_CLK_COUNT, .reset = priv->reset_ctl, .reset_count = SCMI_TEST_DEVICES_RD_COUNT, + .regul = priv->regulators, + .regul_count = SCMI_TEST_DEVICES_VOLTD_COUNT, };
for (n = 0; n < SCMI_TEST_DEVICES_CLK_COUNT; n++) { @@ -92,8 +99,24 @@ static int sandbox_scmi_devices_probe(struct udevice *dev) } }
+ for (n = 0; n < SCMI_TEST_DEVICES_VOLTD_COUNT; n++) { + char name[32]; + + ret = snprintf(name, sizeof(name), "regul%zu-supply", n); + assert(ret >= 0 && ret < sizeof(name)); + + ret = device_get_supply_regulator(dev, name, + priv->devices.regul + n); + if (ret) { + dev_err(dev, "%s: Failed on voltd %zu\n", __func__, n); + goto err_regul; + } + } + return 0;
+err_regul: + n = SCMI_TEST_DEVICES_RD_COUNT; err_reset: for (; n > 0; n--) reset_free(priv->devices.reset + n - 1); diff --git a/test/dm/scmi.c b/test/dm/scmi.c index be60b44b3..f21a3ff97 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -20,6 +20,7 @@ #include <dm/device-internal.h> #include <dm/test.h> #include <linux/kconfig.h> +#include <power/regulator.h> #include <test/ut.h>
static int ut_assert_scmi_state_preprobe(struct unit_test_state *uts) @@ -47,6 +48,8 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, ut_asserteq(3, scmi_devices->clk_count); if (IS_ENABLED(CONFIG_RESET_SCMI)) ut_asserteq(1, scmi_devices->reset_count); + if (IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) + ut_asserteq(2, scmi_devices->regul_count);
/* State of the simulated SCMI server exposed */ scmi_ctx = sandbox_scmi_service_ctx(); @@ -58,6 +61,10 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, ut_assertnonnull(scmi_ctx->agent[0]->clk); ut_asserteq(1, scmi_ctx->agent[0]->reset_count); ut_assertnonnull(scmi_ctx->agent[0]->reset); + if (IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) { + ut_asserteq(2, scmi_ctx->agent[0]->voltd_count); + ut_assertnonnull(scmi_ctx->agent[0]->voltd); + }
ut_assertnonnull(scmi_ctx->agent[1]); ut_assertnonnull(scmi_ctx->agent[1]->clk); @@ -201,3 +208,60 @@ static int dm_test_scmi_resets(struct unit_test_state *uts) }
DM_TEST(dm_test_scmi_resets, UT_TESTF_SCAN_FDT); + +static int dm_test_scmi_voltage_domains(struct unit_test_state *uts) +{ + struct sandbox_scmi_devices *scmi_devices; + struct sandbox_scmi_service *scmi_ctx; + struct sandbox_scmi_voltd *sandbox_voltd; + struct dm_regulator_uclass_plat *uc_pdata; + struct udevice *dev; + struct udevice *regul_dev; + + if (!IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) + return 0; + + ut_assertok(load_sandbox_scmi_test_devices(uts, &dev)); + + scmi_devices = sandbox_scmi_devices_ctx(dev); + scmi_ctx = sandbox_scmi_service_ctx(); + + /* Set/Get an SCMI voltage domain level */ + sandbox_voltd = &scmi_ctx->agent[0]->voltd[0]; + regul_dev = scmi_devices->regul[0]; + ut_assert(regul_dev); + + uc_pdata = dev_get_uclass_plat(regul_dev); + ut_assert(uc_pdata); + + ut_assertok(regulator_set_value(regul_dev, uc_pdata->min_uV)); + ut_asserteq(sandbox_voltd->voltage_uv, uc_pdata->min_uV); + + ut_assert(regulator_get_value(regul_dev) == uc_pdata->min_uV); + + ut_assertok(regulator_set_value(regul_dev, uc_pdata->max_uV)); + ut_asserteq(sandbox_voltd->voltage_uv, uc_pdata->max_uV); + + ut_assert(regulator_get_value(regul_dev) == uc_pdata->max_uV); + + /* Enable/disable SCMI voltage domains */ + ut_assertok(regulator_set_enable(scmi_devices->regul[0], false)); + ut_assertok(regulator_set_enable(scmi_devices->regul[1], false)); + ut_assert(!scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(!scmi_ctx->agent[0]->voltd[1].enabled); + + ut_assertok(regulator_set_enable(scmi_devices->regul[0], true)); + ut_assert(scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(!scmi_ctx->agent[0]->voltd[1].enabled); + + ut_assertok(regulator_set_enable(scmi_devices->regul[1], true)); + ut_assert(scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(scmi_ctx->agent[0]->voltd[1].enabled); + + ut_assertok(regulator_set_enable(scmi_devices->regul[0], false)); + ut_assert(!scmi_ctx->agent[0]->voltd[0].enabled); + ut_assert(scmi_ctx->agent[0]->voltd[1].enabled); + + return release_sandbox_scmi_test_devices(uts, dev); +} +DM_TEST(dm_test_scmi_voltage_domains, UT_TESTF_SCAN_FDT);
Fix inline comments and empty line in scmi driver and test files. Condition SCMI clock and reset tests to U-Boot configuration.
Change-Id: Iac37398cedc1942cf1cc114fc60cbe04c599313e Signed-off-by: Etienne Carriere etienne.carriere@linaro.org --- arch/sandbox/include/asm/scmi_test.h | 5 +++-- drivers/firmware/scmi/sandbox-scmi_agent.c | 4 ++-- test/dm/scmi.c | 21 ++++++++++++--------- 3 files changed, 17 insertions(+), 13 deletions(-)
diff --git a/arch/sandbox/include/asm/scmi_test.h b/arch/sandbox/include/asm/scmi_test.h index 9b7031531..2930e686d 100644 --- a/arch/sandbox/include/asm/scmi_test.h +++ b/arch/sandbox/include/asm/scmi_test.h @@ -24,6 +24,7 @@ struct sandbox_scmi_clk {
/** * struct sandbox_scmi_reset - Simulated reset controller exposed by SCMI + * @id: Identifier of the reset controller used in the SCMI protocol * @asserted: Reset control state: true if asserted, false if desasserted */ struct sandbox_scmi_reset { @@ -48,8 +49,8 @@ struct sandbox_scmi_voltd { * @idx: Identifier for the SCMI agent, its index * @clk: Simulated clocks * @clk_count: Simulated clocks array size - * @clk: Simulated reset domains - * @clk_count: Simulated reset domains array size + * @reset: Simulated reset domains + * @reset_count: Simulated reset domains array size * @voltd: Simulated voltage domains (regulators) * @voltd_count: Simulated voltage domains array size */ diff --git a/drivers/firmware/scmi/sandbox-scmi_agent.c b/drivers/firmware/scmi/sandbox-scmi_agent.c index 3eafc49bd..56125a57b 100644 --- a/drivers/firmware/scmi/sandbox-scmi_agent.c +++ b/drivers/firmware/scmi/sandbox-scmi_agent.c @@ -18,7 +18,7 @@ * processing. It simulates few of the SCMI services for some of the * SCMI protocols embedded in U-Boot. Currently: * - SCMI clock protocol: emulate 2 agents each exposing few clocks - * - SCMI reset protocol: emulate 1 agents each exposing a reset + * - SCMI reset protocol: emulate 1 agent exposing a reset controller * - SCMI voltage domain protocol: emulate 1 agent exposing 2 regulators * * Agent #0 simulates 2 clocks, 1 reset domain and 1 voltage domain. @@ -29,7 +29,7 @@ * * All clocks and regulators are default disabled and reset controller down. * - * This Driver exports sandbox_scmi_service_ct() for the test sequence to + * This Driver exports sandbox_scmi_service_ctx() for the test sequence to * get the state of the simulated services (clock state, rate, ...) and * check back-end device state reflects the request send through the * various uclass devices, as clocks and reset controllers. diff --git a/test/dm/scmi.c b/test/dm/scmi.c index f21a3ff97..cc611c1e0 100644 --- a/test/dm/scmi.c +++ b/test/dm/scmi.c @@ -57,18 +57,24 @@ static int ut_assert_scmi_state_postprobe(struct unit_test_state *uts, ut_asserteq(2, scmi_ctx->agent_count);
ut_assertnonnull(scmi_ctx->agent[0]); - ut_asserteq(2, scmi_ctx->agent[0]->clk_count); - ut_assertnonnull(scmi_ctx->agent[0]->clk); - ut_asserteq(1, scmi_ctx->agent[0]->reset_count); - ut_assertnonnull(scmi_ctx->agent[0]->reset); + if (IS_ENABLED(CONFIG_CLK_SCMI)) { + ut_asserteq(2, scmi_ctx->agent[0]->clk_count); + ut_assertnonnull(scmi_ctx->agent[0]->clk); + } + if (IS_ENABLED(CONFIG_RESET_SCMI)) { + ut_asserteq(1, scmi_ctx->agent[0]->reset_count); + ut_assertnonnull(scmi_ctx->agent[0]->reset); + } if (IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) { ut_asserteq(2, scmi_ctx->agent[0]->voltd_count); ut_assertnonnull(scmi_ctx->agent[0]->voltd); }
ut_assertnonnull(scmi_ctx->agent[1]); - ut_assertnonnull(scmi_ctx->agent[1]->clk); - ut_asserteq(1, scmi_ctx->agent[1]->clk_count); + if (IS_ENABLED(CONFIG_CLK_SCMI)) { + ut_assertnonnull(scmi_ctx->agent[1]->clk); + ut_asserteq(1, scmi_ctx->agent[1]->clk_count); + }
return 0; } @@ -113,7 +119,6 @@ static int dm_test_scmi_sandbox_agent(struct unit_test_state *uts)
return ret; } - DM_TEST(dm_test_scmi_sandbox_agent, UT_TESTF_SCAN_FDT);
static int dm_test_scmi_clocks(struct unit_test_state *uts) @@ -175,7 +180,6 @@ static int dm_test_scmi_clocks(struct unit_test_state *uts)
return release_sandbox_scmi_test_devices(uts, dev); } - DM_TEST(dm_test_scmi_clocks, UT_TESTF_SCAN_FDT);
static int dm_test_scmi_resets(struct unit_test_state *uts) @@ -206,7 +210,6 @@ static int dm_test_scmi_resets(struct unit_test_state *uts)
return release_sandbox_scmi_test_devices(uts, dev); } - DM_TEST(dm_test_scmi_resets, UT_TESTF_SCAN_FDT);
Hi Etienne,
On Thu, 18 Feb 2021 at 05:55, Etienne Carriere etienne.carriere@linaro.org wrote:
- struct sandbox_scmi_reset - Simulated reset controller exposed by SCMI
- @id: Identifier of the reset controller used in the SCMI protocol
- @asserted: Reset control state: true if asserted, false if desasserted
- @idx: Identifier for the SCMI agent, its index
- @clk: Simulated clocks
- @clk_count: Simulated clocks array size
- @clk: Simulated reset domains
- @clk_count: Simulated reset domains array size
- @reset: Simulated reset domains
- @reset_count: Simulated reset domains array size
- @voltd: Simulated voltage domains (regulators)
- @voltd_count: Simulated voltage domains array size
- processing. It simulates few of the SCMI services for some of the
- SCMI protocols embedded in U-Boot. Currently:
- Agent #0 simulates 2 clocks, 1 reset domain and 1 voltage domain.
@@ -29,7 +29,7 @@
- All clocks and regulators are default disabled and reset controller down.
- This Driver exports sandbox_scmi_service_ct() for the test sequence to
- This Driver exports sandbox_scmi_service_ctx() for the test sequence to
- get the state of the simulated services (clock state, rate, ...) and
- check back-end device state reflects the request send through the
- various uclass devices, as clocks and reset controllers.
Why are these needed? Are these options not enabled on sandbox? The goal is to test all the code, not part of it.
} if (IS_ENABLED(CONFIG_DM_REGULATOR_SCMI)) { ut_asserteq(2, scmi_ctx->agent[0]->voltd_count); ut_assertnonnull(scmi_ctx->agent[0]->voltd); } ut_assertnonnull(scmi_ctx->agent[1]);
Hello Simon,
On Fri, 19 Feb 2021 at 05:52, Simon Glass sjg@chromium.org wrote:
Hi Etienne,
@@ -29,7 +29,7 @@
I thought this source file should be flexible to adapt to configuration in case one changes it for some tests. I saw a few other occurrences in the test/dm/*. But looking again it's true there are very very few, almost none.
Fair, i'll discard these config tests in my patch series and post a v2.
Thanks, Etienne
Etienne Carriere
