[U-Boot] [PATCH 21/34] zynq: Add zynq_zc770 xm012 board support
ZC770 is a complete development board based on the Xilinx Zynq-7000 All Programmable SoC, similar to ZC70x board but which has four different daughter cards, like XM010, XM011, XM012 and XM013
ZC770 XM012: - 1GB DDR3 - 64MiB Numonyx NOR flash - USB-UART
Signed-off-by: Jagannadha Sutradharudu Teki jaganna@xilinx.com --- boards.cfg | 1 + include/configs/zynq-common.h | 16 ++++++++++++++++ include/configs/zynq_zc770.h | 4 ++++ 3 files changed, 21 insertions(+)
diff --git a/boards.cfg b/boards.cfg index 11c9bb9..9afcfd1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -348,6 +348,7 @@ Active arm armv7 zynq xilinx zynq zynq_zc70x - Active arm armv7 zynq xilinx zynq zynq_zed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Active arm armv7 zynq xilinx zynq zynq_microzed - Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Active arm armv7 zynq xilinx zynq zynq_zc770_xm010 zynq_zc770:ZC770_XM010 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com +Active arm armv7 zynq xilinx zynq zynq_zc770_xm012 zynq_zc770:ZC770_XM012 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Active arm armv7 zynq xilinx zynq zynq_zc770_xm013 zynq_zc770:ZC770_XM013 Michal Simek monstr@monstr.eu:Jagannadha Sutradharudu Teki jagannadh.teki@gmail.com Active arm armv7:arm720t tegra114 nvidia dalmore dalmore - Tom Warren twarren@nvidia.com Active arm armv7:arm720t tegra20 avionic-design medcom-wide medcom-wide - Thierry Reding thierry.reding@avionic-design.de diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 6b8b6c4..ffe1b93 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -86,6 +86,22 @@ # define CONFIG_SPI_FLASH_WINBOND #endif
+/* NOR */ +#ifndef CONFIG_SYS_NO_FLASH +# define CONFIG_SYS_FLASH_BASE 0xE2000000 +# define CONFIG_SYS_FLASH_SIZE (16 * 1024 * 1024) +# define CONFIG_SYS_MAX_FLASH_BANKS 1 +# define CONFIG_SYS_MAX_FLASH_SECT 512 +# define CONFIG_SYS_FLASH_ERASE_TOUT 1000 +# define CONFIG_SYS_FLASH_WRITE_TOUT 5000 +# define CONFIG_FLASH_SHOW_PROGRESS 10 +# define CONFIG_SYS_FLASH_CFI +# undef CONFIG_SYS_FLASH_EMPTY_INFO +# define CONFIG_FLASH_CFI_DRIVER +# undef CONFIG_SYS_FLASH_PROTECTION +# define CONFIG_SYS_FLASH_USE_BUFFER_WRITE +#endif + /* MMC */ #if defined(CONFIG_ZYNQ_SDHCI0) || defined(CONFIG_ZYNQ_SDHCI1) # define CONFIG_MMC diff --git a/include/configs/zynq_zc770.h b/include/configs/zynq_zc770.h index bcd9a6d..9e7ba77 100644 --- a/include/configs/zynq_zc770.h +++ b/include/configs/zynq_zc770.h @@ -21,6 +21,10 @@ # define CONFIG_ZYNQ_SDHCI0 # define CONFIG_ZYNQ_QSPI
+#elif defined(CONFIG_ZC770_XM012) +# define CONFIG_ZYNQ_SERIAL_UART1 +# undef CONFIG_SYS_NO_FLASH + #elif defined(CONFIG_ZC770_XM013) # define CONFIG_ZYNQ_SERIAL_UART0 # define CONFIG_ZYNQ_GEM1
