I'm looking into booting Linux FIT images from SPL. In board_init_r (common/spl/spl.c), the boot argument is set to CONFIG_SYS_SPL_ARGS_ADDR if defined. When booting a FIT image including a DTB, shouldn't this automatically be set to fdt_addr (struct spl_image_info)? This would ensure a single point of truth for the DTB address (load address as encoded in the FIT image or DTB data start location within the FIT blob if no load address is defined) instead of having to set CONFIG_SYS_SPL_ARGS_ADDR to the DTB load address.
I'm not sure whether I'm interpreting this correctly. It would be nice if somebody could give some advice.
Best regards, Sven
So, the issue is that we don't enforce environment variables existing (typically). The falcon mode code also predates the distro boot stuff that brought us more consistency in fdt related variable naming and usage. Cleanups to the falcon code to make use of this newer code would be appreciated.
Hi Tom,
I think you have have misunderstood me. I meant fdt_addr, the member of struct spl_image_info, not an environment variable with that name. Does that make sense?
Best regards, Sven
Sven Schwermer
