[U-Boot] [PATCH] imx6: apalis: Make the boot process more generic
I'm preparing support for Apalis imx6 boards in OpenWrt and I've ended up with quite huge patchset against upstream U-Boot 2018.03, so I'm trying to propose more generic way of boot process handling.
In OpenWrt we usually have kernel, dtbs and U-Boot boot script in boot partition with ext4fs, so for some use cases it would be handy to be able to replace some of the files
I've added TDX_APALIS_IMX6_BOOT_PART and TDX_APALIS_IMX6_ROOT_PART config variables so this could be distro specific and overridden.
I've added `set_blkcnt` environment variable which is needed for every `mmc write` command as we need to always specify size in block count. This is copy&pasted from official Toradex's flashing scripts, so all the credits for this work belongs to them.
Currently the rootfs location is passed via mmcblk number and the problem with this approach is that the mmcblk number for the boot device changes depending on the kernel version and imx6 SoC type. In order to avoid such issues, use the UUID method to specify the rootfs location.
I've added new boot sequence, where we first try to load and run boot script defined in the new `script` variable, so the boot process could be more generic and overridden by the distro. When the boot script isn't loaded, it will use the previous boot sequence so it should be backward compatible.
For the recovery purposes and better end user experience I've added boot from SDP as the last boot command if every other boot option fails. I plan to use SDP as official flashing/recovery procedure in OpenWrt for Apalis imx6 boards.
I've copy&pasted almost everything from the `f086812a mx6sxsabresd: Use PARTUUID to specify the rootfs location` commit, so credits for the rest of this patch belongs to Fabio.
Cc: Stefan Agner stefan.agner@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Signed-off-by: Petr Štetiar ynezz@true.cz --- board/toradex/apalis_imx6/Kconfig | 15 +++++++++++++++ configs/apalis_imx6_defconfig | 2 ++ include/configs/apalis_imx6.h | 29 ++++++++++++++++++++++++----- 3 files changed, 41 insertions(+), 5 deletions(-)
diff --git a/board/toradex/apalis_imx6/Kconfig b/board/toradex/apalis_imx6/Kconfig index 14f8c10..584bc9f 100644 --- a/board/toradex/apalis_imx6/Kconfig +++ b/board/toradex/apalis_imx6/Kconfig @@ -50,6 +50,21 @@ config TDX_APALIS_IMX6_V1_0 otherwise the UARTs are configuered in DTE mode. default n
+config TDX_APALIS_IMX6_BOOT_PART + int "Partition number to use for boot filesystem" + default 1 + help + The partition number to use for boot filesystem this is the + partition that typically contains boot.scr, DTBs, uImage etc. + +config TDX_APALIS_IMX6_ROOT_PART + int "Partition number to use for root filesystem" + default 2 + help + The partition number to use for root filesystem this is the + partition that is typically specified with root=/dev/sdaX or + which gets converted into a root=PARTUUID=some_uuid. + source "board/toradex/common/Kconfig"
endif diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 133fc1a..279d39f 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y @@ -48,6 +49,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 135b3c9..9af5b29 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -142,9 +142,9 @@ "imx6q-colibri-cam-eval-v3.dtb fat 0 1"
#define EMMC_BOOTCMD \ - "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 " \ + "emmcargs=ip=off root=PARTUUID=${uuid} rw,noatime rootfstype=ext3 " \ "rootwait\0" \ - "emmcboot=run setup; " \ + "emmcboot=run setup; run finduuid;" \ "setenv bootargs ${defargs} ${emmcargs} ${setupargs} " \ "${vidargs}; echo Booting from internal eMMC chip...; " \ "run emmcdtbload; load mmc 0:1 ${kernel_addr_r} " \ @@ -201,10 +201,20 @@ #define FDT_FILE "imx6q-apalis_v1_0-eval.dtb" #endif #define CONFIG_EXTRA_ENV_SETTINGS \ - "bootcmd=run emmcboot ; echo ; echo emmcboot failed ; " \ + "script=boot.scr\0" \ + "mmcbootdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \ + "bootpart=" __stringify(CONFIG_TDX_APALIS_IMX6_BOOT_PART) "\0" \ + "rootpart=" __stringify(CONFIG_TDX_APALIS_IMX6_ROOT_PART) "\0" \ + "finduuid=part uuid mmc ${mmcbootdev}:${rootpart} uuid\0" \ + "loadbootscript=" \ + "load mmc ${mmcbootdev}:${bootpart} ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "bootcmd_default=run emmcboot ; echo ; echo emmcboot failed ; " \ "run nfsboot ; echo ; echo nfsboot failed ; " \ "usb start ;" \ - "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \ + "setenv stdout serial,vga ; setenv stdin serial,usbkbd;" \ + "sdp 0\0" \ "boot_file=uImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \ @@ -232,7 +242,16 @@ "vidargs=mxc_hdmi.only_cea=1 " \ "video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 " \ "video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off " \ - "fbmem=32M\0 " + "fbmem=32M\0 " \ + "set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev ${mmcbootdev};" \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "run bootcmd_default; " \ + "fi; "
/* Miscellaneous configurable options */ #undef CONFIG_SYS_CBSIZE
Hi Petr,
I have read your arguments and I can understand them. But anyway, let me say that this is also in the wrong direction - I know this is not an issue of apalis, but it is a general topic.
The boot process, as set of scripts and variables to be evalueated to boot a board, can be in some times very project specific. The changes you propose goes into the environment - a default environment instead of an "initialized" environment.
We had a long thread last month, see :
https://lists.denx.de/pipermail/u-boot/2018-November/348379.html
Since a long time, we accepted to introduce in CONFIG_EXTRA_ENV any change possible. Anyway, the first environment should not linked together with code, even if this an easy way to do. Any change to the environment requires to change u-boot code, and so on.
In your case, you add also some Kconfig and this adds another dependecy to the bootloader. Much better will be if the initialized environment is not linked directly to the code, and it can be arranged in some way just to have a single binary if secure boot is used and the first environment should be signed. See also Wolfgang's answer to this topic at:
https://lists.denx.de/pipermail/u-boot/2018-November/348569.html
I think we get the limit of current mechanism: each change (even the number of partition) requires to change the U-Boot source and to provide another binary. This does not makes sense, because U-Boot was not changed, just the data that U-Boot uses to starts an OS.
Best regards, Stefano
- int "Partition number to use for boot filesystem"
- default 1
- help
- int "Partition number to use for root filesystem"
- default 2
- help
- "emmcargs=ip=off root=PARTUUID=${uuid} rw,noatime rootfstype=ext3 " \ "rootwait\0" \
- "emmcboot=run setup; run finduuid;" \ "setenv bootargs ${defargs} ${emmcargs} ${setupargs} " \ "${vidargs}; echo Booting from internal eMMC chip...; " \ "run emmcdtbload; load mmc 0:1 ${kernel_addr_r} " \
- "script=boot.scr\0" \
- "mmcbootdev=" __stringify(CONFIG_SYS_MMC_ENV_DEV) "\0" \
- "bootpart=" __stringify(CONFIG_TDX_APALIS_IMX6_BOOT_PART) "\0" \
- "rootpart=" __stringify(CONFIG_TDX_APALIS_IMX6_ROOT_PART) "\0" \
- "finduuid=part uuid mmc ${mmcbootdev}:${rootpart} uuid\0" \
- "loadbootscript=" \
- "bootscript=echo Running bootscript from mmc ...; " \
"source\0" \
- "bootcmd_default=run emmcboot ; echo ; echo emmcboot failed ; " \ "run nfsboot ; echo ; echo nfsboot failed ; " \ "usb start ;" \
"boot_file=uImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \"sdp 0\0" \
"fbmem=32M\0 "
"fbmem=32M\0 " \
- "set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200\0"
"else " \
"fi; "
In OpenWrt we usually have kernel, dtbs and U-Boot boot script in boot partition with ext4fs, so for some use cases it would be handy to be able to replace some of the files in the boot partion, that's why I've added write support to the ext4.
I've added new boot sequence, where we first try to load and run boot script defined in the new `script` variable, so the boot process could be more generic and overridden by the distro. When the boot script isn't loaded, it will use the previous boot sequence.
Cc: Stefan Agner stefan.agner@toradex.com Cc: Max Krummenacher max.krummenacher@toradex.com Signed-off-by: Petr Štetiar ynezz@true.cz --- configs/apalis_imx6_defconfig | 2 ++ include/configs/apalis_imx6.h | 26 +++++++++++++++++++++----- 2 files changed, 23 insertions(+), 5 deletions(-)
Changes since v1:
* Made note about ext4 write support more clear * I've removed Kconfig variables and all variables which were coupled to the code * I've removed the note about backward compatibility from commit message, because I've realized, that this changes are not backward compatible, because this patch is switching to part UUID, so the distributions would need to provide filesystem with part UUID for rootfs.
diff --git a/configs/apalis_imx6_defconfig b/configs/apalis_imx6_defconfig index 133fc1a..279d39f 100644 --- a/configs/apalis_imx6_defconfig +++ b/configs/apalis_imx6_defconfig @@ -39,6 +39,7 @@ CONFIG_CMD_DFU=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y +CONFIG_CMD_PART=y CONFIG_CMD_USB=y CONFIG_CMD_USB_SDP=y CONFIG_CMD_USB_MASS_STORAGE=y @@ -48,6 +49,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_BMP=y CONFIG_CMD_CACHE=y CONFIG_CMD_EXT4=y +CONFIG_CMD_EXT4_WRITE=y CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_ENV_IS_IN_MMC=y diff --git a/include/configs/apalis_imx6.h b/include/configs/apalis_imx6.h index 135b3c9..3601891 100644 --- a/include/configs/apalis_imx6.h +++ b/include/configs/apalis_imx6.h @@ -142,9 +142,9 @@ "imx6q-colibri-cam-eval-v3.dtb fat 0 1"
#define EMMC_BOOTCMD \ - "emmcargs=ip=off root=/dev/mmcblk0p2 rw,noatime rootfstype=ext3 " \ + "emmcargs=ip=off root=PARTUUID=${uuid} rw,noatime rootfstype=ext3 " \ "rootwait\0" \ - "emmcboot=run setup; " \ + "emmcboot=run setup; run finduuid;" \ "setenv bootargs ${defargs} ${emmcargs} ${setupargs} " \ "${vidargs}; echo Booting from internal eMMC chip...; " \ "run emmcdtbload; load mmc 0:1 ${kernel_addr_r} " \ @@ -201,10 +201,17 @@ #define FDT_FILE "imx6q-apalis_v1_0-eval.dtb" #endif #define CONFIG_EXTRA_ENV_SETTINGS \ - "bootcmd=run emmcboot ; echo ; echo emmcboot failed ; " \ + "script=boot.scr\0" \ + "finduuid=part uuid mmc 0:2 uuid\0" \ + "loadbootscript=" \ + "load mmc 0:1 ${loadaddr} ${script};\0" \ + "bootscript=echo Running bootscript from mmc ...; " \ + "source\0" \ + "bootcmd_default=run emmcboot ; echo ; echo emmcboot failed ; " \ "run nfsboot ; echo ; echo nfsboot failed ; " \ "usb start ;" \ - "setenv stdout serial,vga ; setenv stdin serial,usbkbd\0" \ + "setenv stdout serial,vga ; setenv stdin serial,usbkbd;" \ + "sdp 0\0" \ "boot_file=uImage\0" \ "console=ttymxc0\0" \ "defargs=enable_wait_mode=off vmalloc=400M\0" \ @@ -232,7 +239,16 @@ "vidargs=mxc_hdmi.only_cea=1 " \ "video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 " \ "video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off " \ - "fbmem=32M\0 " + "fbmem=32M\0 " \ + "set_blkcnt=setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200\0" + +#define CONFIG_BOOTCOMMAND \ + "mmc dev 0;" \ + "if run loadbootscript; then " \ + "run bootscript; " \ + "else " \ + "run bootcmd_default; " \ + "fi; "
Hello Petr,
I wonder if you couldn't instead move the board to use the common distro environment? Doing that, it allows for easy changing of bootargs from rootfs (well, technically it can be in a single partition or not) and easy to hack / understand syslinux.cfg compatible file.
At OpenEmbedded / Yocto Project, we have been slowly adopting this more and more as it allows very easy integration and is convenient for hacking as well. Take a look at Wandboard as an example of it.
Hi Petr,
[this time to the ML]
I agree a more flexible boot process would be better. There is distro boot for that purpose, and I suggest using that by default. We did enable distro boot in our downstream U-Boot [1] and also make use of it in the Toradex Easy Installer [2] configuration (run distro_bootcmd).
Also check doc/README.distro. I think it should not need changes on OpenWrt side since distro boot loads and executes boot.scr. Additionally, it also guarantees that some variables are setup (e.g. devtype, devnum and distro_bootpart) which allows to write generic boot scripts.
[1] http://git.toradex.com/cgit/u-boot-toradex.git/commit/include/configs/apalis... [2] http://git.toradex.com/cgit/u-boot-toradex.git/commit/?h=2016.11-toradex-nex...
-- Stefan
Changes since v1:
- Made note about ext4 write support more clear
- I've removed Kconfig variables and all variables which were
coupled to the code
- I've removed the note about backward compatibility from commit message, because I've realized, that this changes are not backward compatible, because this patch is switching to part UUID, so the distributions would need to provide filesystem with part UUID for rootfs.
- "finduuid=part uuid mmc 0:2 uuid\0" \
"source\0" \
"fbmem=32M\0 "
"fbmem=32M\0 " \
"mmc dev 0;" \
"else " \
"fi; "
Otavio Salvador
Petr Štetiar
Stefan Agner
Stefano Babic
