[U-Boot] [PATCH v3 0/3] arc: introduce timer driver and update device tree
ARC cores may have up to 2 built-in timers: timer0 and timer1, usually at least one of them exists. They both are driven by the same core clock.
They are controlled through auxiliary registers and so we don't have to remap their control registers as we used to do with MMIO registers of external peripheral devices.
This patch series replaces legacy approach to access ARC timer via specific code in "arch/arc/lib/time.c" and uses timer driver instead.
We want to have common device tree blobs for both Linux and U-Boot. To achieve this the patch updates arc device trees with the following: 1. Separate axs10x.dts device tree in order to reflect the real structure of AXS101 and AXS103 development boards. 2. Add timer device to skeleton ARC device tree. 3. Add core_clk devices to all ARC boards as it is referenced from timer device.
--- Changes v2..v3: - Rebase on top of upstream master
Vlad Zakharov (3): drivers: timer: Introduce ARC timer driver arc: dts: separate single axs10x.dts file arc: use timer driver for ARC boards
arch/Kconfig | 3 + arch/arc/Kconfig | 9 ++- arch/arc/dts/Makefile | 3 +- arch/arc/dts/abilis_tb100.dts | 12 ++- arch/arc/dts/axc001.dtsi | 19 +++++ arch/arc/dts/axc003.dtsi | 19 +++++ arch/arc/dts/axs101.dts | 19 +++++ arch/arc/dts/axs103.dts | 19 +++++ arch/arc/dts/axs10x.dts | 57 -------------- arch/arc/dts/axs10x_mb.dtsi | 66 ++++++++++++++++ arch/arc/dts/nsim.dts | 12 ++- arch/arc/dts/skeleton.dtsi | 19 ++++- arch/arc/include/asm/arcregs.h | 4 + arch/arc/lib/Makefile | 1 - arch/arc/lib/timer.c | 24 ------ board/synopsys/axs10x/Kconfig | 2 +- configs/axs101_defconfig | 4 +- configs/axs103_defconfig | 3 +- doc/device-tree-bindings/timer/arc_timer.txt | 24 ++++++ drivers/timer/Kconfig | 9 +++ drivers/timer/Makefile | 1 + drivers/timer/arc_timer.c | 113 +++++++++++++++++++++++++++ include/configs/axs10x.h | 2 - include/configs/nsim.h | 5 -- include/configs/tb100.h | 5 -- 25 files changed, 344 insertions(+), 110 deletions(-) create mode 100644 arch/arc/dts/axc001.dtsi create mode 100644 arch/arc/dts/axc003.dtsi create mode 100644 arch/arc/dts/axs101.dts create mode 100644 arch/arc/dts/axs103.dts delete mode 100644 arch/arc/dts/axs10x.dts create mode 100644 arch/arc/dts/axs10x_mb.dtsi delete mode 100644 arch/arc/lib/timer.c create mode 100644 doc/device-tree-bindings/timer/arc_timer.txt create mode 100644 drivers/timer/arc_timer.c
This commit introduces timer driver for ARC.
ARC timers are configured via ARC AUX registers so we use special functions to access timer control registers.
This driver allows utilization of either timer0 or timer1 depending on which one is available in real hardware. Essentially only existing timers should be mentioned in board's Device Tree description.
Signed-off-by: Vlad Zakharov vzakhar@synopsys.com Reviewed-by: Simon Glass sjg@chromium.org --- Changes v2..v3: - Rebase on top of upstream master
arch/arc/include/asm/arcregs.h | 4 + doc/device-tree-bindings/timer/arc_timer.txt | 24 ++++++ drivers/timer/Kconfig | 9 +++ drivers/timer/Makefile | 1 + drivers/timer/arc_timer.c | 113 +++++++++++++++++++++++++++ 5 files changed, 151 insertions(+) create mode 100644 doc/device-tree-bindings/timer/arc_timer.txt create mode 100644 drivers/timer/arc_timer.c
diff --git a/arch/arc/include/asm/arcregs.h b/arch/arc/include/asm/arcregs.h index cf999b0..54a9b00 100644 --- a/arch/arc/include/asm/arcregs.h +++ b/arch/arc/include/asm/arcregs.h @@ -33,6 +33,10 @@ #define ARC_AUX_TIMER0_CTRL 0x22 /* Timer 0 control */ #define ARC_AUX_TIMER0_LIMIT 0x23 /* Timer 0 limit */
+#define ARC_AUX_TIMER1_CNT 0x100 /* Timer 1 count */ +#define ARC_AUX_TIMER1_CTRL 0x101 /* Timer 1 control */ +#define ARC_AUX_TIMER1_LIMIT 0x102 /* Timer 1 limit */ + #define ARC_AUX_INTR_VEC_BASE 0x25
/* Data cache related auxiliary registers */ diff --git a/doc/device-tree-bindings/timer/arc_timer.txt b/doc/device-tree-bindings/timer/arc_timer.txt new file mode 100644 index 0000000..5493b21 --- /dev/null +++ b/doc/device-tree-bindings/timer/arc_timer.txt @@ -0,0 +1,24 @@ +ARC Timer + +Required properties: + +- compatible : should be "snps,arc-timer". +- reg : Specifies timer ID, could be either 0 or 1. +- clocks : Specifies clocks that drives the counter. + +Examples: + +timer@0 { + compatible = "snps,arc-timer"; + clocks = <&core_clk>; + reg = <0>; +}; + +timer@1 { + compatible = "snps,arc-timer"; + clocks = <&core_clk>; + reg = <1>; +}; + +NOTE: if you specify both timers, clocks always should be the same +as each timer is driven by the same core clock. diff --git a/drivers/timer/Kconfig b/drivers/timer/Kconfig index 72c1416..e038523 100644 --- a/drivers/timer/Kconfig +++ b/drivers/timer/Kconfig @@ -65,4 +65,13 @@ config STI_TIMER help Select this to enable a timer for STi devices.
+config ARC_TIMER + bool "ARC timer support" + depends on TIMER && ARC && CLK + help + Select this to enable built-in ARC timers. + ARC cores may have up to 2 built-in timers: timer0 and timer1, + usually at least one of them exists. Either of them is supported + in U-Boot. + endmenu diff --git a/drivers/timer/Makefile b/drivers/timer/Makefile index ae94be8..bfe65fc 100644 --- a/drivers/timer/Makefile +++ b/drivers/timer/Makefile @@ -11,3 +11,4 @@ obj-$(CONFIG_X86_TSC_TIMER) += tsc_timer.o obj-$(CONFIG_OMAP_TIMER) += omap-timer.o obj-$(CONFIG_AST_TIMER) += ast_timer.o obj-$(CONFIG_STI_TIMER) += sti-timer.o +obj-$(CONFIG_ARC_TIMER) += arc_timer.o diff --git a/drivers/timer/arc_timer.c b/drivers/timer/arc_timer.c new file mode 100644 index 0000000..e94e4a4 --- /dev/null +++ b/drivers/timer/arc_timer.c @@ -0,0 +1,113 @@ +/* + * Copyright (C) 2016 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <timer.h> +#include <asm/arcregs.h> +#include <asm/io.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define NH_MODE (1 << 1) + +/* + * ARC timer control registers are mapped to auxiliary address space. + * There are special ARC asm command to access that addresses. + * Therefore we use built-in functions to read from and write to timer + * control register. + */ + +/* Driver private data. Contains timer id. Could be either 0 or 1. */ +struct arc_timer_priv { + uint timer_id; +}; + +static int arc_timer_get_count(struct udevice *dev, u64 *count) +{ + u32 val = 0; + struct arc_timer_priv *priv = dev_get_priv(dev); + + switch (priv->timer_id) { + case 0: + val = read_aux_reg(ARC_AUX_TIMER0_CNT); + break; + case 1: + val = read_aux_reg(ARC_AUX_TIMER1_CNT); + break; + } + *count = timer_conv_64(val); + + return 0; +} + +static int arc_timer_probe(struct udevice *dev) +{ + int id; + struct arc_timer_priv *priv = dev_get_priv(dev); + + /* Get registers offset and size */ + id = fdtdec_get_int(gd->fdt_blob, dev->of_offset, "reg", -1); + if (id < 0) + return -EINVAL; + + if (id > 1) + return -ENXIO; + + priv->timer_id = (uint)id; + + /* + * In ARC core there're special registers (Auxiliary or AUX) in its + * separate memory space that are used for accessing some hardware + * features of the core. They are not mapped in normal memory space + * and also always have the same location regardless core configuration. + * Thus to simplify understanding of the programming model we chose to + * access AUX regs of Timer0 and Timer1 separately instead of using + * offsets from some base address. + */ + + switch (priv->timer_id) { + case 0: + /* Disable timer if CPU is halted */ + write_aux_reg(ARC_AUX_TIMER0_CTRL, NH_MODE); + /* Set max value for counter/timer */ + write_aux_reg(ARC_AUX_TIMER0_LIMIT, 0xffffffff); + /* Set initial count value and restart counter/timer */ + write_aux_reg(ARC_AUX_TIMER0_CNT, 0); + break; + case 1: + /* Disable timer if CPU is halted */ + write_aux_reg(ARC_AUX_TIMER1_CTRL, NH_MODE); + /* Set max value for counter/timer */ + write_aux_reg(ARC_AUX_TIMER1_LIMIT, 0xffffffff); + /* Set initial count value and restart counter/timer */ + write_aux_reg(ARC_AUX_TIMER1_CNT, 0); + break; + } + + return 0; +} + + +static const struct timer_ops arc_timer_ops = { + .get_count = arc_timer_get_count, +}; + +static const struct udevice_id arc_timer_ids[] = { + { .compatible = "snps,arc-timer" }, + {} +}; + +U_BOOT_DRIVER(arc_timer) = { + .name = "arc_timer", + .id = UCLASS_TIMER, + .of_match = arc_timer_ids, + .probe = arc_timer_probe, + .ops = &arc_timer_ops, + .flags = DM_FLAG_PRE_RELOC, + .priv_auto_alloc_size = sizeof(struct arc_timer_priv), +};
We want to use the same device tree blobs in both Linux and U-Boot for ARC boards.
Earlier device tree sources in U-Boot were very simplified and hadn't been updated for quite a long period of time.
So this commit is the first step on the road to unified device tree blobs.
First of all we re-organize device tree sources for AXS10X boards. As AXS101 and AXS103 boards consist of AXS10X motherboard and AXC001 and AXC003 cpu tiles respectively we add corresponding device tree source files: axs10x_mb.dtsi for motherboard, axc001.dtsi and axc003.dtsi for cpu tiles and axs101.dts and axs103.dts to represent actual boards.
Also we delete axs10x.dts as it is no longer used.
One more important change - we add timer device to ARC skeleton device tree sources as both ARC700 and ARCHS cores contain such timer. We add core_clk nodes to abilis_tb100, nsim, axc001 and axc003 device tree sources as it is referenced via phandle from timer node in common skeleton.dtsi file.
arch/arc/Kconfig | 9 ++++-- arch/arc/dts/Makefile | 3 +- arch/arc/dts/abilis_tb100.dts | 12 ++++++-- arch/arc/dts/axc001.dtsi | 19 +++++++++++++ arch/arc/dts/axc003.dtsi | 19 +++++++++++++ arch/arc/dts/axs101.dts | 19 +++++++++++++ arch/arc/dts/axs103.dts | 19 +++++++++++++ arch/arc/dts/axs10x.dts | 57 ------------------------------------- arch/arc/dts/axs10x_mb.dtsi | 66 +++++++++++++++++++++++++++++++++++++++++++ arch/arc/dts/nsim.dts | 12 ++++++-- arch/arc/dts/skeleton.dtsi | 19 ++++++++++++- board/synopsys/axs10x/Kconfig | 2 +- configs/axs101_defconfig | 3 +- configs/axs103_defconfig | 2 +- 14 files changed, 190 insertions(+), 71 deletions(-) create mode 100644 arch/arc/dts/axc001.dtsi create mode 100644 arch/arc/dts/axc003.dtsi create mode 100644 arch/arc/dts/axs101.dts create mode 100644 arch/arc/dts/axs103.dts delete mode 100644 arch/arc/dts/axs10x.dts create mode 100644 arch/arc/dts/axs10x_mb.dtsi
diff --git a/arch/arc/Kconfig b/arch/arc/Kconfig index 4c5696b..6e4b1d0 100644 --- a/arch/arc/Kconfig +++ b/arch/arc/Kconfig @@ -118,7 +118,7 @@ config SYS_DCACHE_OFF
choice prompt "Target select" - default TARGET_AXS10X + default TARGET_AXS103
config TARGET_TB100 bool "Support tb100" @@ -126,8 +126,11 @@ config TARGET_TB100 config TARGET_NSIM bool "Support standalone nSIM & Free nSIM"
-config TARGET_AXS10X - bool "Support Synopsys Designware SDP board (AXS101 & AXS103)" +config TARGET_AXS101 + bool "Support Synopsys Designware SDP board AXS101" + +config TARGET_AXS103 + bool "Support Synopsys Designware SDP board AXS103"
endchoice
diff --git a/arch/arc/dts/Makefile b/arch/arc/dts/Makefile index 1d94c08..218a647 100644 --- a/arch/arc/dts/Makefile +++ b/arch/arc/dts/Makefile @@ -2,7 +2,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-dtb-$(CONFIG_TARGET_AXS10X) += axs10x.dtb +dtb-$(CONFIG_TARGET_AXS101) += axs101.dtb +dtb-$(CONFIG_TARGET_AXS103) += axs103.dtb dtb-$(CONFIG_TARGET_NSIM) += nsim.dtb dtb-$(CONFIG_TARGET_TB100) += abilis_tb100.dtb
diff --git a/arch/arc/dts/abilis_tb100.dts b/arch/arc/dts/abilis_tb100.dts index cf395c4..23329ec 100644 --- a/arch/arc/dts/abilis_tb100.dts +++ b/arch/arc/dts/abilis_tb100.dts @@ -8,13 +8,19 @@ #include "skeleton.dtsi"
/ { - #address-cells = <1>; - #size-cells = <1>; - aliases { console = &uart0; };
+ cpu_card { + core_clk: core_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <500000000>; + u-boot,dm-pre-reloc; + }; + }; + uart0: serial@ff100000 { compatible = "snps,dw-apb-uart"; reg = <0xff100000 0x1000>; diff --git a/arch/arc/dts/axc001.dtsi b/arch/arc/dts/axc001.dtsi new file mode 100644 index 0000000..1cf630d --- /dev/null +++ b/arch/arc/dts/axc001.dtsi @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2017 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + cpu_card { + core_clk: core_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <750000000>; + u-boot,dm-pre-reloc; + }; + }; +}; + diff --git a/arch/arc/dts/axc003.dtsi b/arch/arc/dts/axc003.dtsi new file mode 100644 index 0000000..5e9270a --- /dev/null +++ b/arch/arc/dts/axc003.dtsi @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2017 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/include/ "skeleton.dtsi" + +/ { + cpu_card { + core_clk: core_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <100000000>; + u-boot,dm-pre-reloc; + }; + }; +}; + diff --git a/arch/arc/dts/axs101.dts b/arch/arc/dts/axs101.dts new file mode 100644 index 0000000..0a7b982 --- /dev/null +++ b/arch/arc/dts/axs101.dts @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2017 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/dts-v1/; + +/include/ "axc001.dtsi" +/include/ "axs10x_mb.dtsi" + + +/ { + model = "snps,axs101"; + + chosen { + stdout-path = &uart0; + }; +}; + diff --git a/arch/arc/dts/axs103.dts b/arch/arc/dts/axs103.dts new file mode 100644 index 0000000..5ffcef8 --- /dev/null +++ b/arch/arc/dts/axs103.dts @@ -0,0 +1,19 @@ +/* + * Copyright (C) 2017 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ +/dts-v1/; + +/include/ "axc003.dtsi" +/include/ "axs10x_mb.dtsi" + + +/ { + model = "snps,axs103"; + + chosen { + stdout-path = &uart0; + }; +}; + diff --git a/arch/arc/dts/axs10x.dts b/arch/arc/dts/axs10x.dts deleted file mode 100644 index 391d067..0000000 --- a/arch/arc/dts/axs10x.dts +++ /dev/null @@ -1,57 +0,0 @@ -/* - * Copyright (C) 2015 Synopsys, Inc. All rights reserved. - * - * SPDX-License-Identifier: GPL-2.0+ - */ -/dts-v1/; - -#include "skeleton.dtsi" - -/ { - #address-cells = <1>; - #size-cells = <1>; - - aliases { - console = &uart0; - }; - - clocks { - apbclk: apbclk { - compatible = "fixed-clock"; - clock-frequency = <50000000>; - #clock-cells = <0>; - }; - }; - - uart0: serial0@e0022000 { - compatible = "snps,dw-apb-uart"; - reg = <0xe0022000 0x1000>; - reg-shift = <2>; - reg-io-width = <4>; - }; - - ethernet@e0018000 { - #interrupt-cells = <1>; - compatible = "altr,socfpga-stmmac"; - reg = < 0xe0018000 0x2000 >; - interrupts = < 25 >; - interrupt-names = "macirq"; - phy-mode = "gmii"; - snps,pbl = < 32 >; - clocks = <&apbclk>; - clock-names = "stmmaceth"; - max-speed = <100>; - }; - - ehci@0xe0040000 { - compatible = "generic-ehci"; - reg = < 0xe0040000 0x100 >; - interrupts = < 8 >; - }; - - ohci@0xe0060000 { - compatible = "generic-ohci"; - reg = < 0xe0060000 0x100 >; - interrupts = < 8 >; - }; -}; diff --git a/arch/arc/dts/axs10x_mb.dtsi b/arch/arc/dts/axs10x_mb.dtsi new file mode 100644 index 0000000..b74d3c8 --- /dev/null +++ b/arch/arc/dts/axs10x_mb.dtsi @@ -0,0 +1,66 @@ +/* + * Copyright (C) 2017 Synopsys, Inc. All rights reserved. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/ { + axs10x_mb@e0000000 { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0xe0000000 0x10000000>; + u-boot,dm-pre-reloc; + + clocks { + compatible = "simple-bus"; + u-boot,dm-pre-reloc; + + apbclk: apbclk { + compatible = "fixed-clock"; + clock-frequency = <50000000>; + #clock-cells = <0>; + }; + + uartclk: uartclk { + compatible = "fixed-clock"; + clock-frequency = <33333333>; + #clock-cells = <0>; + u-boot,dm-pre-reloc; + }; + }; + + ethernet@18000 { + #interrupt-cells = <1>; + compatible = "altr,socfpga-stmmac"; + reg = < 0x18000 0x2000 >; + interrupts = < 25 >; + interrupt-names = "macirq"; + phy-mode = "gmii"; + snps,pbl = < 32 >; + clocks = <&apbclk>; + clock-names = "stmmaceth"; + max-speed = <100>; + }; + + ehci@0x40000 { + compatible = "generic-ehci"; + reg = < 0x40000 0x100 >; + interrupts = < 8 >; + }; + + ohci@0x60000 { + compatible = "generic-ohci"; + reg = < 0x60000 0x100 >; + interrupts = < 8 >; + }; + + uart0: serial0@22000 { + compatible = "snps,dw-apb-uart"; + reg = <0x22000 0x100>; + clocks = <&uartclk>; + reg-shift = <2>; + reg-io-width = <4>; + }; + }; +}; diff --git a/arch/arc/dts/nsim.dts b/arch/arc/dts/nsim.dts index 69e16c2..af80422 100644 --- a/arch/arc/dts/nsim.dts +++ b/arch/arc/dts/nsim.dts @@ -8,13 +8,19 @@ #include "skeleton.dtsi"
/ { - #address-cells = <1>; - #size-cells = <1>; - aliases { console = &arcuart0; };
+ cpu_card { + core_clk: core_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <70000000>; + u-boot,dm-pre-reloc; + }; + }; + arcuart0: serial@0xc0fc1000 { compatible = "snps,arc-uart"; reg = <0xc0fc1000 0x100>; diff --git a/arch/arc/dts/skeleton.dtsi b/arch/arc/dts/skeleton.dtsi index b41d241..279fc6c 100644 --- a/arch/arc/dts/skeleton.dtsi +++ b/arch/arc/dts/skeleton.dtsi @@ -9,5 +9,22 @@ #size-cells = <1>; chosen { }; aliases { }; - memory { device_type = "memory"; reg = <0 0>; }; + + cpu_card { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + u-boot,dm-pre-reloc; + + timer@0 { + compatible = "snps,arc-timer"; + clocks = <&core_clk>; + reg = <0 1>; + }; + }; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x10000000>; /* 256M */ + }; }; diff --git a/board/synopsys/axs10x/Kconfig b/board/synopsys/axs10x/Kconfig index c60b6a2..dd1305a 100644 --- a/board/synopsys/axs10x/Kconfig +++ b/board/synopsys/axs10x/Kconfig @@ -1,4 +1,4 @@ -if TARGET_AXS10X +if TARGET_AXS101 || TARGET_AXS103
config SYS_BOARD default "axs10x" diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index aed41aa..b2d4bca 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -1,8 +1,9 @@ CONFIG_ARC=y CONFIG_SYS_DCACHE_OFF=y +CONFIG_TARGET_AXS101=y CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_SYS_CLK_FREQ=750000000 -CONFIG_DEFAULT_DEVICE_TREE="axs10x" +CONFIG_DEFAULT_DEVICE_TREE="axs101" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="AXS# " diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index b62e0ad..431eaa4 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -2,7 +2,7 @@ CONFIG_ARC=y CONFIG_ISA_ARCV2=y CONFIG_SYS_TEXT_BASE=0x81000000 CONFIG_SYS_CLK_FREQ=100000000 -CONFIG_DEFAULT_DEVICE_TREE="axs10x" +CONFIG_DEFAULT_DEVICE_TREE="axs103" CONFIG_BOOTDELAY=3 CONFIG_BOARD_EARLY_INIT_F=y CONFIG_SYS_PROMPT="AXS# "
This commit replaces legacy timer code with usage of arc timer driver.
It removes arch/arc/lib/time.c file and selects CONFIG_CLK, CONFIG_TIMER and CONFIG_ARC_TIMER options for all ARC boards by default. Therefore we remove CONFIG_CLK option from less common axs101 and axs103 defconfigs.
Also it removes legacy CONFIG_SYS_TIMER_RATE config symbol from axs10x.h, tb100.h and nsim.h configs files as it is no longer required.
No changes compared to v1 arch/Kconfig | 3 +++ arch/arc/lib/Makefile | 1 - arch/arc/lib/timer.c | 24 ------------------------ configs/axs101_defconfig | 1 - configs/axs103_defconfig | 1 - include/configs/axs10x.h | 2 -- include/configs/nsim.h | 5 ----- include/configs/tb100.h | 5 ----- 8 files changed, 3 insertions(+), 39 deletions(-) delete mode 100644 arch/arc/lib/timer.c
diff --git a/arch/Kconfig b/arch/Kconfig index 76c690f..308c6ea 100644 --- a/arch/Kconfig +++ b/arch/Kconfig @@ -13,6 +13,9 @@ config ARC select HAVE_PRIVATE_LIBGCC select SUPPORT_OF_CONTROL select ARCH_EARLY_INIT_R + select CLK + select TIMER + select ARC_TIMER
config ARM bool "ARM architecture" diff --git a/arch/arc/lib/Makefile b/arch/arc/lib/Makefile index eb62b3c..12097bf 100644 --- a/arch/arc/lib/Makefile +++ b/arch/arc/lib/Makefile @@ -18,7 +18,6 @@ obj-y += memcmp.o obj-y += memcpy-700.o obj-y += memset.o obj-y += reset.o -obj-y += timer.o obj-y += ints_low.o obj-y += init_helpers.o
diff --git a/arch/arc/lib/timer.c b/arch/arc/lib/timer.c deleted file mode 100644 index a0acbbc..0000000 --- a/arch/arc/lib/timer.c +++ /dev/null @@ -1,24 +0,0 @@ -/* - * Copyright (C) 2013-2014 Synopsys, Inc. All rights reserved. - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <asm/arcregs.h> - -#define NH_MODE (1 << 1) /* Disable timer if CPU is halted */ - -int timer_init(void) -{ - write_aux_reg(ARC_AUX_TIMER0_CTRL, NH_MODE); - /* Set max value for counter/timer */ - write_aux_reg(ARC_AUX_TIMER0_LIMIT, 0xffffffff); - /* Set initial count value and restart counter/timer */ - write_aux_reg(ARC_AUX_TIMER0_CNT, 0); - return 0; -} - -unsigned long timer_read_counter(void) -{ - return read_aux_reg(ARC_AUX_TIMER0_CNT); -} diff --git a/configs/axs101_defconfig b/configs/axs101_defconfig index b2d4bca..1af505d 100644 --- a/configs/axs101_defconfig +++ b/configs/axs101_defconfig @@ -19,7 +19,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_CLK=y CONFIG_SYS_I2C_DW=y CONFIG_MMC=y CONFIG_MMC_DW=y diff --git a/configs/axs103_defconfig b/configs/axs103_defconfig index 431eaa4..fb8e72f 100644 --- a/configs/axs103_defconfig +++ b/configs/axs103_defconfig @@ -18,7 +18,6 @@ CONFIG_OF_CONTROL=y CONFIG_OF_EMBED=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_DM=y -CONFIG_CLK=y CONFIG_SYS_I2C_DW=y CONFIG_MMC=y CONFIG_MMC_DW=y diff --git a/include/configs/axs10x.h b/include/configs/axs10x.h index d60db65..768e8fb 100644 --- a/include/configs/axs10x.h +++ b/include/configs/axs10x.h @@ -11,8 +11,6 @@ /* * CPU configuration */ -#define CONFIG_SYS_TIMER_RATE CONFIG_SYS_CLK_FREQ - #define ARC_FPGA_PERIPHERAL_BASE 0xE0000000 #define ARC_APB_PERIPHERAL_BASE 0xF0000000 #define ARC_DWMMC_BASE (ARC_FPGA_PERIPHERAL_BASE + 0x15000) diff --git a/include/configs/nsim.h b/include/configs/nsim.h index 0cc55b7..d6d26c7 100644 --- a/include/configs/nsim.h +++ b/include/configs/nsim.h @@ -10,11 +10,6 @@ #include <linux/sizes.h>
/* - * CPU configuration - */ -#define CONFIG_SYS_TIMER_RATE CONFIG_SYS_CLK_FREQ - -/* * Memory configuration */ #define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_TEXT_BASE diff --git a/include/configs/tb100.h b/include/configs/tb100.h index b719943..115b3b3 100644 --- a/include/configs/tb100.h +++ b/include/configs/tb100.h @@ -10,11 +10,6 @@ #include <linux/sizes.h>
Hi Vlad,
- Separate axs10x.dts device tree in order to reflect the real
Applied to my tree, thanks!
-Alexey
Alexey Brodkin
Vlad Zakharov
