[U-Boot] Please pull u-boot-ti/next
Hello,
The following changes since commit d702b0811df53a1fc2d8049e35431e4591d093c6:
ARM: cache: Move the cp15 CR register read before flushing the cache. (2012-07-07 14:07:44 +0200)
git://git.denx.de/u-boot-ti next
for you to fetch changes up to 9af1a780c81639ca4b6f7035530dc8c7151bf201:
omap: am335x_evm: enable i2c1 channel (2012-07-09 11:12:19 -0700)
---------------------------------------------------------------- Igor Grinberg (1): arm: omap3: cm-t35: minor comment and printf change
Ilya Yanok (1): omap24xx_i2c: add 2-byte address support
Javier Martinez Canillas (2): igep00x0: default to OMAP-specific serial driver igep00x0: default mmcrootfstype to EXT4
Lad, Prabhakar (7): da850/omap-l138: Add MMC support for DA850/OMAP-L138 arm, davinci: perform check for initializing global data and serial init da850/omap-l138: Define SPI specific configs for SPL only when SPI is used da850/omap-l138: Add support to read u-boot image from MMC/SD da850/omap-l138: Fix NAND flash timings da850/omap-l138: Add support for NAND SPL da850/omap-l138: add support for direct NOR boot mode
Peter Meerwald (4): beagle: add eeprom expansion board info for bct brettl4 beagle: make get_expansion_id(), get_board_revision(), beagle_display_init() static beagle: fix termination of buddy env setting beagle: removed unused pr_debug #define
Rajashekhara, Sudhakar (2): da850/omap-l138: modifications for Logic PD Rev.3 AM18xx EVM da850/omap-l138: Make MMC and NOR support mutually exclusive
Stefano Babic (4): mcx: increased buffer for command line OMAP3: mcx: set pinmux for uart4 OMAP3: mcx: updated default environment OMAP3: mcx: read hot-water-button after reset
Steve Sakoman (3): omap: am335x_evm: remove unused definitions omap: am33xx: enable gpio support omap: am335x_evm: enable i2c1 channel
Sughosh Ganu (1): hawkboard/omapl-138: Add support for generating ais image for hawkboard
.gitignore | 3 + Makefile | 5 +- arch/arm/cpu/arm926ejs/davinci/da850_pinmux.c | 11 ++ arch/arm/cpu/arm926ejs/davinci/spl.c | 20 ++-- arch/arm/cpu/armv7/am33xx/board.c | 10 ++ arch/arm/cpu/armv7/am33xx/clock.c | 20 ++++ arch/arm/cpu/armv7/omap-common/Makefile | 2 +- arch/arm/include/asm/arch-am33xx/cpu.h | 20 ++++ arch/arm/include/asm/arch-am33xx/gpio.h | 29 +++++ arch/arm/include/asm/arch-davinci/hardware.h | 1 + arch/arm/include/asm/arch-davinci/pinmux_defs.h | 3 + board/cm_t35/cm_t35.c | 4 +- board/davinci/da8xxevm/da850evm.c | 54 ++++++++-- board/davinci/da8xxevm/hawkboard-ais-nand.cfg | 4 + board/htkw/mcx/mcx.c | 23 ++++ board/htkw/mcx/mcx.h | 11 +- board/ti/am335x/evm.c | 6 +- board/ti/am335x/mux.c | 13 +++ board/ti/beagle/beagle.c | 16 +-- boards.cfg | 1 + drivers/i2c/omap24xx_i2c.c | 58 +++++----- drivers/mmc/Makefile | 4 + drivers/mmc/spl_mmc_load.c | 62 +++++++++++ include/configs/am335x_evm.h | 2 +- include/configs/da850evm.h | 93 ++++++++++++++-- include/configs/hawkboard.h | 1 + include/configs/igep00x0.h | 4 +- include/configs/mcx.h | 132 ++++++++++++++++------- include/configs/omap3_beagle.h | 2 +- include/mmc.h | 2 + 30 files changed, 502 insertions(+), 114 deletions(-) create mode 100644 arch/arm/include/asm/arch-am33xx/gpio.h create mode 100644 board/davinci/da8xxevm/hawkboard-ais-nand.cfg create mode 100644 drivers/mmc/spl_mmc_load.c
This includes the single patch I asked for in u-boot-ti/master as well as a number of other small clean-ups, bugfixes or enhancements that have been around for a bit, but did not meet the merge window and I don't want to forget them. If you want me to carry them in my own /next branch until -rc1 comes out, that's fine and this can just serve as notice to interested parties that yes, really, patches have been picked up.
Hi Tom,
On Mon, 9 Jul 2012 11:46:11 -0700, Tom Rini trini@ti.com wrote:
Hello,
Applied to u-boot-arm/next, to be moved to master after the 12.07 release.
Amicalement,
Albert ARIBAUD
