[U-Boot] [PATCH] ARM: dts: dra72-evm: fix broken ethernet
With commit ceec08f50b6, phy is connected to slave 0, but changing the phy node was missed, fix it by populating the phy node to proper cpsw slave node.
Fixes: ceec08f50b6 ("ARM: dts: dra72-evm: Add mode-gpios entry for mac node") Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Cc: Vignesh R vigneshr@ti.com --- arch/arm/dts/dra72-evm.dts | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/dra72-evm.dts b/arch/arm/dts/dra72-evm.dts index 4ca37fa..e7c5db2 100644 --- a/arch/arm/dts/dra72-evm.dts +++ b/arch/arm/dts/dra72-evm.dts @@ -591,7 +591,7 @@ mode-gpios = <&pcf_gpio_21 4 GPIO_ACTIVE_HIGH>; };
-&cpsw_emac1 { +&cpsw_emac0 { phy_id = <&davinci_mdio>, <3>; phy-mode = "rgmii"; };
Tested-by: Tom Rini trini@konsulko.com
Thanks for tracking this one down, I've enabled the network tests on mine now.
Fixes: ceec08f50b6 ("ARM: dts: dra72-evm: Add mode-gpios entry for mac node") Signed-off-by: Mugunthan V N mugunthanvnm@ti.com Cc: Vignesh R vigneshr@ti.com Tested-by: Tom Rini trini@konsulko.com
Mugunthan V N
