[PATCH] smbios: only look for a SYSINFO udevice if SYSINFO support is enabled
If SYSINFO support isn't enabled, it's a given that uclass_first_device for UCLASS_SYSINFO will not find anything, therefore let's skip the test entirely.
This allows to get rid of the following debug message that may be confusing:
Cannot find uclass for id 118: please add the UCLASS_DRIVER() declaration for this UCLASS_... id
Signed-off-by: Quentin Schulz quentin.schulz@cherry.de --- lib/smbios.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/lib/smbios.c b/lib/smbios.c index b190b010f30..a822acd48e9 100644 --- a/lib/smbios.c +++ b/lib/smbios.c @@ -571,7 +571,7 @@ ulong write_smbios_table(ulong addr) int i;
ctx.node = ofnode_null(); - if (IS_ENABLED(CONFIG_OF_CONTROL)) { + if (IS_ENABLED(CONFIG_OF_CONTROL) && CONFIG_IS_ENABLED(SYSINFO)) { uclass_first_device(UCLASS_SYSINFO, &ctx.dev); if (ctx.dev) parent_node = dev_read_subnode(ctx.dev, "smbios");
--- base-commit: 4f836fb324ba500ecabdba4146c3ca9e1600cdf5 change-id: 20240610-smbios-sysinfo-dca17e76e11d
Quentin Schulz
