[PATCH 1/3] arm: mach-k3: Move R5 specific code into new r5/ directory
This makes it clear these are only to be used by the R5 builds of SPL. And this will be used to later more cleanly split the two builds.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/Makefile | 6 +----- arch/arm/mach-k3/r5/Makefile | 13 +++++++++++++ arch/arm/mach-k3/{ => r5}/am62ax/Makefile | 0 arch/arm/mach-k3/{ => r5}/am62ax/am62a_qos_data.c | 0 arch/arm/mach-k3/{ => r5}/am62ax/clk-data.c | 0 arch/arm/mach-k3/{ => r5}/am62ax/dev-data.c | 0 arch/arm/mach-k3/{ => r5}/am62x/Makefile | 0 arch/arm/mach-k3/{ => r5}/am62x/clk-data.c | 0 arch/arm/mach-k3/{ => r5}/am62x/dev-data.c | 0 arch/arm/mach-k3/{ => r5}/j7200/Makefile | 0 arch/arm/mach-k3/{ => r5}/j7200/clk-data.c | 0 arch/arm/mach-k3/{ => r5}/j7200/dev-data.c | 0 arch/arm/mach-k3/{ => r5}/j721e/Makefile | 0 arch/arm/mach-k3/{ => r5}/j721e/clk-data.c | 0 arch/arm/mach-k3/{ => r5}/j721e/dev-data.c | 0 arch/arm/mach-k3/{ => r5}/j721s2/Makefile | 0 arch/arm/mach-k3/{ => r5}/j721s2/clk-data.c | 0 arch/arm/mach-k3/{ => r5}/j721s2/dev-data.c | 0 arch/arm/mach-k3/{ => r5}/lowlevel_init.S | 0 arch/arm/mach-k3/{ => r5}/r5_mpu.c | 2 +- 20 files changed, 15 insertions(+), 6 deletions(-) create mode 100644 arch/arm/mach-k3/r5/Makefile rename arch/arm/mach-k3/{ => r5}/am62ax/Makefile (100%) rename arch/arm/mach-k3/{ => r5}/am62ax/am62a_qos_data.c (100%) rename arch/arm/mach-k3/{ => r5}/am62ax/clk-data.c (100%) rename arch/arm/mach-k3/{ => r5}/am62ax/dev-data.c (100%) rename arch/arm/mach-k3/{ => r5}/am62x/Makefile (100%) rename arch/arm/mach-k3/{ => r5}/am62x/clk-data.c (100%) rename arch/arm/mach-k3/{ => r5}/am62x/dev-data.c (100%) rename arch/arm/mach-k3/{ => r5}/j7200/Makefile (100%) rename arch/arm/mach-k3/{ => r5}/j7200/clk-data.c (100%) rename arch/arm/mach-k3/{ => r5}/j7200/dev-data.c (100%) rename arch/arm/mach-k3/{ => r5}/j721e/Makefile (100%) rename arch/arm/mach-k3/{ => r5}/j721e/clk-data.c (100%) rename arch/arm/mach-k3/{ => r5}/j721e/dev-data.c (100%) rename arch/arm/mach-k3/{ => r5}/j721s2/Makefile (100%) rename arch/arm/mach-k3/{ => r5}/j721s2/clk-data.c (100%) rename arch/arm/mach-k3/{ => r5}/j721s2/dev-data.c (100%) rename arch/arm/mach-k3/{ => r5}/lowlevel_init.S (100%) rename arch/arm/mach-k3/{ => r5}/r5_mpu.c (98%)
diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index c7ca0fdce56..215c755c5dc 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -3,12 +3,8 @@ # Copyright (C) 2017-2018 Texas Instruments Incorporated - https://www.ti.com/ # Lokesh Vutla lokeshvutla@ti.com
-obj-$(CONFIG_SOC_K3_J721E) += j721e/ j7200/ -obj-$(CONFIG_SOC_K3_J721S2) += j721s2/ -obj-$(CONFIG_SOC_K3_AM625) += am62x/ -obj-$(CONFIG_SOC_K3_AM62A7) += am62ax/ +obj-$(CONFIG_CPU_V7R) += r5/ obj-$(CONFIG_ARM64) += arm64-mmu.o -obj-$(CONFIG_CPU_V7R) += r5_mpu.o lowlevel_init.o obj-$(CONFIG_ARM64) += cache.o obj-$(CONFIG_OF_LIBFDT) += common_fdt.o ifeq ($(CONFIG_OF_LIBFDT)$(CONFIG_OF_SYSTEM_SETUP),yy) diff --git a/arch/arm/mach-k3/r5/Makefile b/arch/arm/mach-k3/r5/Makefile new file mode 100644 index 00000000000..8a6af73a44e --- /dev/null +++ b/arch/arm/mach-k3/r5/Makefile @@ -0,0 +1,13 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2023 Texas Instruments Incorporated - https://www.ti.com/ +# Andrew Davis afd@ti.com + +obj-$(CONFIG_SOC_K3_J721E) += j721e/ +obj-$(CONFIG_SOC_K3_J721E) += j7200/ +obj-$(CONFIG_SOC_K3_J721S2) += j721s2/ +obj-$(CONFIG_SOC_K3_AM625) += am62x/ +obj-$(CONFIG_SOC_K3_AM62A7) += am62ax/ + +obj-y += lowlevel_init.o +obj-y += r5_mpu.o diff --git a/arch/arm/mach-k3/am62ax/Makefile b/arch/arm/mach-k3/r5/am62ax/Makefile similarity index 100% rename from arch/arm/mach-k3/am62ax/Makefile rename to arch/arm/mach-k3/r5/am62ax/Makefile diff --git a/arch/arm/mach-k3/am62ax/am62a_qos_data.c b/arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c similarity index 100% rename from arch/arm/mach-k3/am62ax/am62a_qos_data.c rename to arch/arm/mach-k3/r5/am62ax/am62a_qos_data.c diff --git a/arch/arm/mach-k3/am62ax/clk-data.c b/arch/arm/mach-k3/r5/am62ax/clk-data.c similarity index 100% rename from arch/arm/mach-k3/am62ax/clk-data.c rename to arch/arm/mach-k3/r5/am62ax/clk-data.c diff --git a/arch/arm/mach-k3/am62ax/dev-data.c b/arch/arm/mach-k3/r5/am62ax/dev-data.c similarity index 100% rename from arch/arm/mach-k3/am62ax/dev-data.c rename to arch/arm/mach-k3/r5/am62ax/dev-data.c diff --git a/arch/arm/mach-k3/am62x/Makefile b/arch/arm/mach-k3/r5/am62x/Makefile similarity index 100% rename from arch/arm/mach-k3/am62x/Makefile rename to arch/arm/mach-k3/r5/am62x/Makefile diff --git a/arch/arm/mach-k3/am62x/clk-data.c b/arch/arm/mach-k3/r5/am62x/clk-data.c similarity index 100% rename from arch/arm/mach-k3/am62x/clk-data.c rename to arch/arm/mach-k3/r5/am62x/clk-data.c diff --git a/arch/arm/mach-k3/am62x/dev-data.c b/arch/arm/mach-k3/r5/am62x/dev-data.c similarity index 100% rename from arch/arm/mach-k3/am62x/dev-data.c rename to arch/arm/mach-k3/r5/am62x/dev-data.c diff --git a/arch/arm/mach-k3/j7200/Makefile b/arch/arm/mach-k3/r5/j7200/Makefile similarity index 100% rename from arch/arm/mach-k3/j7200/Makefile rename to arch/arm/mach-k3/r5/j7200/Makefile diff --git a/arch/arm/mach-k3/j7200/clk-data.c b/arch/arm/mach-k3/r5/j7200/clk-data.c similarity index 100% rename from arch/arm/mach-k3/j7200/clk-data.c rename to arch/arm/mach-k3/r5/j7200/clk-data.c diff --git a/arch/arm/mach-k3/j7200/dev-data.c b/arch/arm/mach-k3/r5/j7200/dev-data.c similarity index 100% rename from arch/arm/mach-k3/j7200/dev-data.c rename to arch/arm/mach-k3/r5/j7200/dev-data.c diff --git a/arch/arm/mach-k3/j721e/Makefile b/arch/arm/mach-k3/r5/j721e/Makefile similarity index 100% rename from arch/arm/mach-k3/j721e/Makefile rename to arch/arm/mach-k3/r5/j721e/Makefile diff --git a/arch/arm/mach-k3/j721e/clk-data.c b/arch/arm/mach-k3/r5/j721e/clk-data.c similarity index 100% rename from arch/arm/mach-k3/j721e/clk-data.c rename to arch/arm/mach-k3/r5/j721e/clk-data.c diff --git a/arch/arm/mach-k3/j721e/dev-data.c b/arch/arm/mach-k3/r5/j721e/dev-data.c similarity index 100% rename from arch/arm/mach-k3/j721e/dev-data.c rename to arch/arm/mach-k3/r5/j721e/dev-data.c diff --git a/arch/arm/mach-k3/j721s2/Makefile b/arch/arm/mach-k3/r5/j721s2/Makefile similarity index 100% rename from arch/arm/mach-k3/j721s2/Makefile rename to arch/arm/mach-k3/r5/j721s2/Makefile diff --git a/arch/arm/mach-k3/j721s2/clk-data.c b/arch/arm/mach-k3/r5/j721s2/clk-data.c similarity index 100% rename from arch/arm/mach-k3/j721s2/clk-data.c rename to arch/arm/mach-k3/r5/j721s2/clk-data.c diff --git a/arch/arm/mach-k3/j721s2/dev-data.c b/arch/arm/mach-k3/r5/j721s2/dev-data.c similarity index 100% rename from arch/arm/mach-k3/j721s2/dev-data.c rename to arch/arm/mach-k3/r5/j721s2/dev-data.c diff --git a/arch/arm/mach-k3/lowlevel_init.S b/arch/arm/mach-k3/r5/lowlevel_init.S similarity index 100% rename from arch/arm/mach-k3/lowlevel_init.S rename to arch/arm/mach-k3/r5/lowlevel_init.S diff --git a/arch/arm/mach-k3/r5_mpu.c b/arch/arm/mach-k3/r5/r5_mpu.c similarity index 98% rename from arch/arm/mach-k3/r5_mpu.c rename to arch/arm/mach-k3/r5/r5_mpu.c index 605f7931518..e409fdcfea8 100644 --- a/arch/arm/mach-k3/r5_mpu.c +++ b/arch/arm/mach-k3/r5/r5_mpu.c @@ -9,7 +9,7 @@ #include <common.h> #include <asm/io.h> #include <linux/kernel.h> -#include "common.h" +#include <asm/armv7_mpu.h>
struct mpu_region_config k3_mpu_regions[16] = { /*
The kconfig option SPL means this build supports SPL but not that this build is SPL, nor that this build is the SPL running on R5. For options that are for R5 SPL use CPU_V7R.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/Kconfig | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 9168bf842dc..4d19cf3e353 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -111,7 +111,7 @@ config K3_EARLY_CONS_IDX
config K3_LOAD_SYSFW bool - depends on SPL + depends on CPU_V7R
config K3_SYSFW_IMAGE_NAME string "File name of SYSFW firmware and configuration blob" @@ -158,7 +158,7 @@ config K3_SYSFW_IMAGE_SPI_OFFS
config SYS_K3_SPL_ATF bool "Start Cortex-A from SPL" - depends on SPL && CPU_V7R + depends on CPU_V7R help Enabling this will try to start Cortex-A (typically with ATF) after SPL from R5. @@ -172,7 +172,7 @@ config K3_ATF_LOAD_ADDR
config K3_DM_FW bool "Separate DM firmware image" - depends on SPL && CPU_V7R && (SOC_K3_J721E || SOC_K3_J721S2 || SOC_K3_AM625 || SOC_K3_AM62A7) && !CLK_TI_SCI && !TI_SCI_POWER_DOMAIN + depends on CPU_V7R && (SOC_K3_J721E || SOC_K3_J721S2 || SOC_K3_AM625 || SOC_K3_AM62A7) && !CLK_TI_SCI && !TI_SCI_POWER_DOMAIN default y help Enabling this will indicate that the system has separate DM
SYSFW is only ever loaded by the R5 core, move the code into that directory. While here also move the related Kconfig symbols.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/Kconfig | 51 ++---------------------- arch/arm/mach-k3/Makefile | 1 - arch/arm/mach-k3/r5/Kconfig | 45 +++++++++++++++++++++ arch/arm/mach-k3/r5/Makefile | 4 ++ arch/arm/mach-k3/{ => r5}/sysfw-loader.c | 2 +- 5 files changed, 54 insertions(+), 49 deletions(-) create mode 100644 arch/arm/mach-k3/r5/Kconfig rename arch/arm/mach-k3/{ => r5}/sysfw-loader.c (99%)
diff --git a/arch/arm/mach-k3/Kconfig b/arch/arm/mach-k3/Kconfig index 4d19cf3e353..ced7d3bcba6 100644 --- a/arch/arm/mach-k3/Kconfig +++ b/arch/arm/mach-k3/Kconfig @@ -109,53 +109,6 @@ config K3_EARLY_CONS_IDX Use this option to set the index of the serial device to be used for the early console during SPL execution.
-config K3_LOAD_SYSFW - bool - depends on CPU_V7R - -config K3_SYSFW_IMAGE_NAME - string "File name of SYSFW firmware and configuration blob" - depends on K3_LOAD_SYSFW - default "sysfw.itb" - help - Filename of the combined System Firmware and configuration image tree - blob to be loaded when booting from a filesystem. - -config K3_SYSFW_IMAGE_MMCSD_RAW_MODE_SECT - hex "MMC sector to load SYSFW firmware and configuration blob from" - depends on K3_LOAD_SYSFW && SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR - default 0x3600 - help - Address on the MMC to load the combined System Firmware and - configuration image tree blob from, when the MMC is being used - in raw mode. Units: MMC sectors (1 sector = 512 bytes). - -config K3_SYSFW_IMAGE_MMCSD_RAW_MODE_PART - hex "MMC partition to load SYSFW firmware and configuration blob from" - depends on K3_LOAD_SYSFW && SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION - default 2 - help - Partition on the MMC to the combined System Firmware and configuration - image tree blob from, when the MMC is being used in raw mode. - -config K3_SYSFW_IMAGE_SIZE_MAX - int "Amount of memory dynamically allocated for loading SYSFW blob" - depends on K3_LOAD_SYSFW - default 280000 - help - Amount of memory (in bytes) reserved through dynamic allocation at - runtime for loading the combined System Firmware and configuration image - tree blob. Keep it as tight as possible, as this directly affects the - overall SPL memory footprint. - -config K3_SYSFW_IMAGE_SPI_OFFS - hex "SPI offset of SYSFW firmware and configuration blob" - depends on K3_LOAD_SYSFW - default 0x6C0000 - help - Offset of the combined System Firmware and configuration image tree - blob to be loaded when booting from a SPI flash memory. - config SYS_K3_SPL_ATF bool "Start Cortex-A from SPL" depends on CPU_V7R @@ -187,6 +140,10 @@ config K3_X509_SWRV help SWRV for X509 certificate used for boot images
+if CPU_V7R +source "arch/arm/mach-k3/r5/Kconfig" +endif + source "board/ti/am65x/Kconfig" source "board/ti/am64x/Kconfig" source "board/ti/am62x/Kconfig" diff --git a/arch/arm/mach-k3/Makefile b/arch/arm/mach-k3/Makefile index 215c755c5dc..42161376469 100644 --- a/arch/arm/mach-k3/Makefile +++ b/arch/arm/mach-k3/Makefile @@ -20,6 +20,5 @@ obj-$(CONFIG_SOC_K3_J721S2) += j721s2_init.o obj-$(CONFIG_SOC_K3_AM642) += am642_init.o obj-$(CONFIG_SOC_K3_AM625) += am625_init.o obj-$(CONFIG_SOC_K3_AM62A7) += am62a7_init.o -obj-$(CONFIG_K3_LOAD_SYSFW) += sysfw-loader.o endif obj-y += common.o security.o diff --git a/arch/arm/mach-k3/r5/Kconfig b/arch/arm/mach-k3/r5/Kconfig new file mode 100644 index 00000000000..ae79f8ff6cd --- /dev/null +++ b/arch/arm/mach-k3/r5/Kconfig @@ -0,0 +1,45 @@ +config K3_LOAD_SYSFW + bool + +config K3_SYSFW_IMAGE_NAME + string "File name of SYSFW firmware and configuration blob" + depends on K3_LOAD_SYSFW + default "sysfw.itb" + help + Filename of the combined System Firmware and configuration image tree + blob to be loaded when booting from a filesystem. + +config K3_SYSFW_IMAGE_MMCSD_RAW_MODE_SECT + hex "MMC sector to load SYSFW firmware and configuration blob from" + depends on K3_LOAD_SYSFW && SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR + default 0x3600 + help + Address on the MMC to load the combined System Firmware and + configuration image tree blob from, when the MMC is being used + in raw mode. Units: MMC sectors (1 sector = 512 bytes). + +config K3_SYSFW_IMAGE_MMCSD_RAW_MODE_PART + hex "MMC partition to load SYSFW firmware and configuration blob from" + depends on K3_LOAD_SYSFW && SYS_MMCSD_RAW_MODE_U_BOOT_USE_PARTITION + default 2 + help + Partition on the MMC to the combined System Firmware and configuration + image tree blob from, when the MMC is being used in raw mode. + +config K3_SYSFW_IMAGE_SIZE_MAX + int "Amount of memory dynamically allocated for loading SYSFW blob" + depends on K3_LOAD_SYSFW + default 280000 + help + Amount of memory (in bytes) reserved through dynamic allocation at + runtime for loading the combined System Firmware and configuration image + tree blob. Keep it as tight as possible, as this directly affects the + overall SPL memory footprint. + +config K3_SYSFW_IMAGE_SPI_OFFS + hex "SPI offset of SYSFW firmware and configuration blob" + depends on K3_LOAD_SYSFW + default 0x6C0000 + help + Offset of the combined System Firmware and configuration image tree + blob to be loaded when booting from a SPI flash memory. diff --git a/arch/arm/mach-k3/r5/Makefile b/arch/arm/mach-k3/r5/Makefile index 8a6af73a44e..b99199d3374 100644 --- a/arch/arm/mach-k3/r5/Makefile +++ b/arch/arm/mach-k3/r5/Makefile @@ -11,3 +11,7 @@ obj-$(CONFIG_SOC_K3_AM62A7) += am62ax/
obj-y += lowlevel_init.o obj-y += r5_mpu.o + +ifeq ($(CONFIG_SPL_BUILD),y) +obj-$(CONFIG_K3_LOAD_SYSFW) += sysfw-loader.o +endif diff --git a/arch/arm/mach-k3/sysfw-loader.c b/arch/arm/mach-k3/r5/sysfw-loader.c similarity index 99% rename from arch/arm/mach-k3/sysfw-loader.c rename to arch/arm/mach-k3/r5/sysfw-loader.c index 73a17276e12..51e3b3cd1ca 100644 --- a/arch/arm/mach-k3/sysfw-loader.c +++ b/arch/arm/mach-k3/r5/sysfw-loader.c @@ -23,7 +23,7 @@ #include <spi_flash.h>
#include <asm/io.h> -#include "common.h" +#include "../common.h"
DECLARE_GLOBAL_DATA_PTR;
Hi Andrew
I think a cover-letter with the motivation behind the series could have helped me understand quicker (plus if in case there were any discussion links earlier about doing this)
For the series, applied to u-boot/next, thanks!
Andrew Davis
Neha Malcom Francis
