[PATCH] phy: rockchip-inno-usb2: cleanup comments and make ops static
Thanks to Jagan Teki for noting that three functions should be static and comments from uclass_clk are redundant.
Signed-off-by: Xavier Drudis Ferran xdrudis@tinet.cat --- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 25 +++---------------- 1 file changed, 3 insertions(+), 22 deletions(-)
diff --git a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c index be5f79490c..2b33b6f03c 100644 --- a/drivers/phy/rockchip/phy-rockchip-inno-usb2.c +++ b/drivers/phy/rockchip/phy-rockchip-inno-usb2.c @@ -182,25 +182,12 @@ static struct phy_ops rockchip_usb2phy_ops = { .of_xlate = rockchip_usb2phy_of_xlate, };
-/** - * round_rate() - Adjust a rate to the exact rate a clock can provide. - * @clk: The clock to manipulate. - * @rate: Desidered clock rate in Hz. - * - * Return: rounded rate in Hz, or -ve error code. - */ -ulong rockchip_usb2phy_clk_round_rate(struct clk *clk, ulong rate) +static ulong rockchip_usb2phy_clk_round_rate(struct clk *clk, ulong rate) { return 480000000; }
-/** - * enable() - Enable a clock. - * @clk: The clock to manipulate. - * - * Return: zero on success, or -ve error code. - */ -int rockchip_usb2phy_clk_enable(struct clk *clk) +static int rockchip_usb2phy_clk_enable(struct clk *clk) { struct udevice *parent = dev_get_parent(clk->dev); struct rockchip_usb2phy *priv = dev_get_priv(parent); @@ -217,13 +204,7 @@ int rockchip_usb2phy_clk_enable(struct clk *clk) return 0; }
-/** - * disable() - Disable a clock. - * @clk: The clock to manipulate. - * - * Return: zero on success, or -ve error code. - */ -int rockchip_usb2phy_clk_disable(struct clk *clk) +static int rockchip_usb2phy_clk_disable(struct clk *clk) { struct udevice *parent = dev_get_parent(clk->dev); struct rockchip_usb2phy *priv = dev_get_priv(parent);
The change log should be at below --- , the commit message should be above.
- round_rate() - Adjust a rate to the exact rate a clock can provide.
- @clk: The clock to manipulate.
- @rate: Desidered clock rate in Hz.
- Return: rounded rate in Hz, or -ve error code.
Why is the documentation dropped ?
As these comments seem redundant as in clk-uclass.h definitions, so I asked to drop the same from the driver.
Xavier, can you add the details in the commit message?
Jagan.
El Mon, Jun 19, 2023 at 02:58:50PM +0530, Jagan Teki deia:
Jagan.
Which details ? The commit message says "comments from uclass_clk are redundant" . What should it say ? Do you want me to copy the deleted comments to the commit message ??
Jagan Teki
