[U-Boot] [PATCH] SPI: Winbond: Add W25Q32 to spi flash table
Add W25Q32 to Winbond spi flash table as it is required for snow
Signed-off-by: Rajeshwari Shinde rajeshwari.s@samsung.com --- drivers/mtd/spi/winbond.c | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/spi/winbond.c b/drivers/mtd/spi/winbond.c index f6aab3d..f47634e 100644 --- a/drivers/mtd/spi/winbond.c +++ b/drivers/mtd/spi/winbond.c @@ -67,6 +67,11 @@ static const struct winbond_spi_flash_params winbond_spi_flash_table[] = { .nr_blocks = 128, .name = "W25Q80", }, + { + .id = 0x6016, + .nr_blocks = 64, + .name = "W25Q32", + }, };
struct spi_flash *spi_flash_probe_winbond(struct spi_slave *spi, u8 *idcode)
On Thu, Feb 7, 2013 at 2:07 AM, Rajeshwari Shinde rajeshwari.s@samsung.com wrote:
.id = 0x6016,
.nr_blocks = 64,
.name = "W25Q32",
1.7.4.4
Hi Minkyu Kang,
Please let me know if we can merge this into u-boot-samsung branch or do I need to re-base on some other branch.
Regards, Rajeshwari Shinde
.id = 0x6016,
.nr_blocks = 64,
.name = "W25Q32",
1.7.4.4
Hi Rajeshwari,
On Fri, Mar 22, 2013 at 11:51 AM, Rajeshwari Birje rajeshwari.birje@gmail.com wrote:
Hi Minkyu Kang,
.id = 0x6016,
.nr_blocks = 64,
.name = "W25Q32",
Can you please check that the same part support has been added already in master http://git.denx.de/?p=u-boot/u-boot-spi.git;a=commitdiff;h=772ba15474f73adc9...
Please let me know you are referring a different part. And also the change in above link seems to have incorrect nr_blocks, i will write a mail CC you as well.
Thanks, Jagan.
Jagan Teki
Rajeshwari Birje
Rajeshwari Shinde
