[U-Boot] [PATCH] arch-mx6: fix MX6_PAD_DECLARE macro to work with MX6 duallite
if we build for an i.mx6 (d)ual(l)ite CONFIC_MX6DL we shall use MX6DL_PAD instead the common MX6_PAD.
Signed-off-by: Hannes Schmelzer oe5hpm@oevsv.at ---
arch/arm/include/asm/arch-mx6/mx6-pins.h | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/include/asm/arch-mx6/mx6-pins.h b/arch/arm/include/asm/arch-mx6/mx6-pins.h index 4b6bb18..3465205 100644 --- a/arch/arm/include/asm/arch-mx6/mx6-pins.h +++ b/arch/arm/include/asm/arch-mx6/mx6-pins.h @@ -18,7 +18,7 @@ enum { #include "mx6q_pins.h" #undef MX6_PAD_DECL #define MX6_PAD_DECL(name, pco, mc, mm, sio, si, pc) \ - MX6_PAD_DECLARE(MX6DL_PAD_,name, pco, mc, mm, sio, si, pc), + MX6_PAD_DECLARE(MX6DL_PAD_, name, pco, mc, mm, sio, si, pc), #include "mx6dl_pins.h" }; #elif defined(CONFIG_MX6Q) @@ -30,7 +30,7 @@ enum { #elif defined(CONFIG_MX6DL) || defined(CONFIG_MX6S) enum { #define MX6_PAD_DECL(name, pco, mc, mm, sio, si, pc) \ - MX6_PAD_DECLARE(MX6_PAD_,name, pco, mc, mm, sio, si, pc), + MX6_PAD_DECLARE(MX6DL_PAD_, name, pco, mc, mm, sio, si, pc), #include "mx6dl_pins.h" }; #elif defined(CONFIG_MX6SL)
- MX6_PAD_DECLARE(MX6DL_PAD_, name, pco, mc, mm, sio, si, pc),
Applied to u-boot-imx, -next branch, thanks !
Best regards, Stefano Babic
Please put this for the current release; this is a bugfix and a critical one.
Hi Hannes,
this patch breaks most i.MX6 boards (the not DL) and I revert it. Maybe I had to ask better before, anyway:
Can you better explain the problem you had ? The name is not decisive - the important thing is that the correct include file with the right layout is included, that means mx6dl_pins.h. And this was mainlined since a lot of time.
We have several boards with 6DL into mainline, so I am missing which is your problem.
On 07/20/2016 09:30 AM, Stefano Babic wrote:
Hi Hannes,
Hi Stefano,
sorry for inconvenience, i should have done more testing on this. I just tried to compile several i.mx6 boards and found out that I did not covered the MX6S which are in trouble now.
Signed-off-by: Hannes Schmelzeroe5hpm@oevsv.at
- MX6_PAD_DECLARE(MX6DL_PAD_, name, pco, mc, mm, sio, si, pc), #include "mx6dl_pins.h" }; #elif defined(CONFIG_MX6Q)
Maybe all the time nobody had to use I2C #4 on an i.mx6 duallite chip, doing so i encountered this problem.
The name is decisive for sure, have a closer look to the "MX6_PAD_DECLARE" macro, In conjunction with the correct include file the prefix used to form the final register table declaration.
Next the iomux-v3.h is from interest, the "#define IOMUX_PADS" has dependency on CONFIG_MX6nn, here the previous definition out from mx6-pins.h is used.
I will send some V2 to address this topic fully, ok?
cheers, Hannes
Hi Hannes,
Hi Stefano,
cheers, Hannes
Just looked around a bit more about this. Root cause for failing this patch is, that many boards do not use the 'IOMUX_PADS' macro, instead they just directly use the definition out of "mx6dl_pins.h" for example. So we get in trouble there if we change the MX6_PAD_DECLARE macro for having MX6DL pads instead MX6 pads.
At one point of view it would make sense to me changing all boards to use the IOMUX_PADS macro for accessing pads register, because afterwards the real accessed register would be fully in dependence of CONFIG_MX6nn. On the other hand i cannot fully predict every case could happen if we simply change that with search/replace.
So it would be OK for me to drop this patch and i will use on my board:
MX6DL_PAD_ENET_TX_EN__I2C4_SCL MX6DL_PAD_ENET_TXD1__I2C4_SDA
instead
IOMUX_PADS(PAD_ENET_TX_EN__I2C4_SCL) IOMUX_PADS(MX6DL_PAD_ENET_TXD1__I2C4_SDA )
Whats your thinking about this?
cheers, Hannes
Hi Hannes,
Both are allowed. IOMUX_PADS *must* be used in case the board supports multiple variant of the processor (DL, Quad,..). If the board has just one variant, the MX6 defines from the corresponding header can be used.
I am not getting where is the trouble, because there are already a lot of boards using it. Let's see....
Now I get the point - and yes, there is an exception for I2C in the pinmux. This was discussed at the beginning when IOMUX_PADS was introduced and how to support the different layout of the SOC variants.
We agreed to tread differently I2C. This means that a i2c_pads_info structure must be set for each variant of the SOC that board supports. With help of the is_cpu_type() macro (or one of this family), the correct structure is selected and the pinmux can be set.
The right way to do is:
static struct i2c_pads_info i2c_pad = { .scl = { .i2c_mode = MX6DL_PAD_ENET_TX_EN__I2C4_SCL | <pull up>, .gpio_mode = MX6DL_PAD_ENET_TX_EN__GPIO1_IO28 | <..>, .gp = IMX_GPIO_NR(1, 28) }, .sda = { .i2c_mode = MX6DL_PAD_ENET_TXD1__I2C4_SDA | <pull >, .gpio_mode = MX6DL_PAD_ENET_TXD1__GPIO1_IO29 | <pull>, .gp = IMX_GPIO_NR(1, 29) } };
and then you call setup_i2c() with the structure.
On 07/21/2016 10:28 AM, Stefano Babic wrote:
Hi Hannes,
Hi Stefano,
Yeah! Now i understand the thinkings behind/around that. Many thanks for this, i will implement this for my board.
cheers, Hannes
Hannes Schmelzer
Hannes Schmelzer
Otavio Salvador
Stefano Babic
