[PATCH 1/1] bootm: don't call booti_setup for EFI images
On the arm64 architecture booti_setup() is called for EFI FIT images. This function call fails because EFI images typically do not have a kernel signature.
Check that the operating system property "os" of the image is "linux" before invoking booti_setup().
Fixes: 487b5fa6deb1 ("bootm: Handle kernel_noload on arm64") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- boot/bootm.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/boot/bootm.c b/boot/bootm.c index 4144ff3b03..75f0b4a9af 100644 --- a/boot/bootm.c +++ b/boot/bootm.c @@ -240,7 +240,8 @@ static int bootm_find_os(struct cmd_tbl *cmdtp, int flag, int argc,
if (images.os.type == IH_TYPE_KERNEL_NOLOAD) { if (IS_ENABLED(CONFIG_CMD_BOOTI) && - images.os.arch == IH_ARCH_ARM64) { + images.os.arch == IH_ARCH_ARM64 && + images.os.os == IH_OS_LINUX) { ulong image_addr; ulong image_size;
On Tue, 13 Jun 2023 at 09:11, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
-- 2.40.1
I'm a little wary of this since no tests change. What is needed to test this?
-- 2.40.1
We test loading EFI FIT images with test/py/tests/test_efi_fit.py. The image we use for testing is lib/efi_loader/helloworld.efi.
The its file used on arm64 has:
arch = "arm";
This is why booti_setup() was never executed. We should fix this.
Furthermore all EFI binaries that we create in U-Boot have a kernel signature in the CRT header so booti_setup() will not fail. This is needed to run tools like initrddump.efi with GRUB's linux command.
test_fit.py is skipped on qemu_arm64 but some other test_fit*.py tests are executed. This should ensure regression testing.
Best regards
Heinrich
Hi Heinrich,
On Thu, 15 Jun 2023 at 12:38, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
-- 2.40.1
arch = "arm";
OK good.
