[U-Boot] [PATCHv5 2/2] mucmc52, uc101: delete ata@3a00 node, if no CF card is detected
U-Boot can detect if an IDE device is present or not. If not, and this new config option is activated, U-Boot removes the ATA node from the DTS before booting Linux, so the Linux IDE driver does not probe the device and crash. This is needed for buggy hardware (uc101) where no pull down resistor is connected to the signal IDE5V_DD7.
Signed-off-by: Heiko Schocher hs@denx.de ---
changes since v1: - added comment from Wolfgang Denk, to move this to a more common place, so others can also use it, and made it therefore per CONFIG_OF_IDE_FIXUP selectable.
changes since v2: - add CONFIG_OF_IDE_FIXUP to mpc5200-common.h
changes since v3 - correct spelling in README and commit message, as Detlev Zundel suggested
changes since v4 - added comments from Stefan Roese Coding Style corrections do not longer include the global variable, instead call ide_device_present() - added comment from Jerry Van Baren correct README entry
README | 9 +++++++++ common/cmd_ide.c | 8 ++++++++ cpu/mpc5xxx/cpu.c | 20 ++++++++++++++++++++ include/configs/manroland/mpc5200-common.h | 1 + include/ide.h | 3 +++ 5 files changed, 41 insertions(+), 0 deletions(-)
diff --git a/README b/README index ff4ed8b..8d0cbc9 100644 --- a/README +++ b/README @@ -386,6 +386,15 @@ The following options need to be configured: This define fills in the correct boot CPU in the boot param header, the default value is zero if undefined.
+ CONFIG_OF_IDE_FIXUP + + U-Boot can detect if an IDE device is present or not. + If not, and this new config option is activated, U-Boot + removes the ATA node from the DTS before booting Linux, + so the Linux IDE driver does not probe the device and + crash. This is needed for buggy hardware (uc101) where + no pull down resistor is connected to the signal IDE5V_DD7. + - vxWorks boot parameters:
bootvx constructs a valid bootline using the following diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 4d7a0ac..ec9a1df 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -1624,6 +1624,14 @@ static void ide_led (uchar led, uchar status)
#endif /* CONFIG_IDE_LED */
+#if defined(CONFIG_OF_IDE_FIXUP) +int ide_device_present(int dev) +{ + if (dev >= CONFIG_SYS_IDE_MAXBUS) + return 0; + return (ide_dev_desc[dev].type == DEV_TYPE_UNKNOWN ? 0 : 1); +} +#endif /* ------------------------------------------------------------------------- */
#ifdef CONFIG_ATAPI diff --git a/cpu/mpc5xxx/cpu.c b/cpu/mpc5xxx/cpu.c index f6258c7..7307c05 100644 --- a/cpu/mpc5xxx/cpu.c +++ b/cpu/mpc5xxx/cpu.c @@ -40,6 +40,10 @@ #include <fdt_support.h> #endif
+#if defined(CONFIG_OF_IDE_FIXUP) +#include <ide.h> +#endif + DECLARE_GLOBAL_DATA_PTR;
int checkcpu (void) @@ -137,6 +141,22 @@ void ft_cpu_setup(void *blob, bd_t *bd) do_fixup_by_path(blob, eth_path, "mac-address", enetaddr, 6, 0); do_fixup_by_path(blob, eth_path, "local-mac-address", enetaddr, 6, 0); #endif +#if defined(CONFIG_OF_IDE_FIXUP) + if (ide_device_present(0)) { + /* NO CF card detected -> delete ata node in DTS */ + int nodeoffset = 0; + char nodename[] = "/soc5200@f0000000/ata@3a00"; + + nodeoffset = fdt_path_offset(blob, nodename); + if (nodeoffset >= 0) { + fdt_del_node(blob, nodeoffset); + } else { + printf("%s: cannot find %s node err:%s\n", + __func__, nodename, fdt_strerror(nodeoffset)); + } + } + +#endif } #endif
diff --git a/include/configs/manroland/mpc5200-common.h b/include/configs/manroland/mpc5200-common.h index 2f092b1..b29ef9b 100644 --- a/include/configs/manroland/mpc5200-common.h +++ b/include/configs/manroland/mpc5200-common.h @@ -225,5 +225,6 @@ #define OF_SOC "soc5200@f0000000" #define OF_TBCLK (bd->bi_busfreq / 4) #define OF_STDOUT_PATH "/soc5200@f0000000/serial@2000" +#define CONFIG_OF_IDE_FIXUP
#endif /* __MANROLAND_MPC52XX__COMMON_H */ diff --git a/include/ide.h b/include/ide.h index ddb9579..6a1b7ae 100644 --- a/include/ide.h +++ b/include/ide.h @@ -54,4 +54,7 @@ void ide_init(void); ulong ide_read(int device, lbaint_t blknr, ulong blkcnt, void *buffer); ulong ide_write(int device, lbaint_t blknr, ulong blkcnt, void *buffer);
+#if defined(CONFIG_OF_IDE_FIXUP) +int ide_device_present(int dev); +#endif #endif /* _IDE_H */
Dear Heiko Schocher,
Seems this patch depends on other patches, that add support for the manroland boards, which have not been accepted yet. I think I'm waiting for a resubmit from you?
Hello Wolfgang,
OK, I am reposting it.
bye Heiko
Heiko Schocher
