[U-Boot] [PATCH] multiconfig.sh: replace GNU sed specific match
A SPL/TPL enabled target would was not recognized as such by BSD sed, since it relies on a GNU extension. Instead of or-ing just spell out both matches.
Cc: Masahiro Yamada yamada.m@jp.panasonic.com Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl
--- https://www.gnu.org/software/sed/manual/sed.html:
regexp1|regexp2 Matches either regexp1 or regexp2. Use parentheses to use complex alternative regular expressions. The matching process tries each alternative in turn, from left to right, and the first one that succeeds is used. It is a GNU extension. --- scripts/multiconfig.sh | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/scripts/multiconfig.sh b/scripts/multiconfig.sh index 4a8737f..c489c7f 100644 --- a/scripts/multiconfig.sh +++ b/scripts/multiconfig.sh @@ -69,8 +69,8 @@ get_enabled_subimages() {
# CONFIG_SPL=y -> spl # CONFIG_TPL=y -> tpl - sed -n -e 's/^CONFIG_(SPL|TPL)=y$/\1/p' $KCONFIG_CONFIG | \ - tr '[A-Z]' '[a-z]' + sed -n -e 's/^CONFIG_SPL=y$/spl/p' -e 's/^CONFIG_TPL=y$/tpl/p' \ + $KCONFIG_CONFIG }
do_silentoldconfig () {
Hi Jeroen,
2014-10-02 0:22 GMT+09:00 Jeroen Hofstee jeroen@myspectrum.nl:
Acked-by: Masahiro Yamada yamada.m@jp.panasonic.com
Cc: Masahiro Yamada yamada.m@jp.panasonic.com Signed-off-by: Jeroen Hofstee jeroen@myspectrum.nl Acked-by: Masahiro Yamada yamada.m@jp.panasonic.com
Jeroen Hofstee
Masahiro YAMADA
