[U-Boot] [PATCH v2 0/3] efi_loader: support building UEFI binaries on sandbox
Building helloworld.efi and UEFI binaries needed for unit tests requires that the build system considers the host architecture on which the sandbox is built.
The patch series provides these adjustment and enables building both helloworld.efi and unit test requiring UEFI binaries.
v2: enable building UEFI unit tests requiring UEFI binaries
Heinrich Schuchardt (3): efi_loader: call add_u_boot_and_runtime() on sandbox efi_loader: support building UEFI binaries on sandbox efi_selftest: enable all UEFI unit tests on the sandbox
Makefile | 19 +++++++++++++++++ arch/sandbox/config.mk | 28 ++++++++++++++++++++++++ arch/sandbox/lib/crt0_sandbox_efi.S | 32 ++++++++++++++++++++++++++++ arch/sandbox/lib/reloc_sandbox_efi.c | 32 ++++++++++++++++++++++++++++ cmd/Kconfig | 2 +- include/host_arch.h | 24 +++++++++++++++++++++ lib/efi_loader/Makefile | 3 +++ lib/efi_loader/efi_memory.c | 9 ++++---- lib/efi_selftest/Makefile | 7 ++++-- 9 files changed, 149 insertions(+), 7 deletions(-) create mode 100644 arch/sandbox/lib/crt0_sandbox_efi.S create mode 100644 arch/sandbox/lib/reloc_sandbox_efi.c create mode 100644 include/host_arch.h
-- 2.24.0
On the sandbox we should mark the stack area as EFI runtime memory like we do on any other architecture.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: no change --- lib/efi_loader/efi_memory.c | 9 +++++---- 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/lib/efi_loader/efi_memory.c b/lib/efi_loader/efi_memory.c index 83cbc9154f..d46001f608 100644 --- a/lib/efi_loader/efi_memory.c +++ b/lib/efi_loader/efi_memory.c @@ -738,8 +738,10 @@ static void add_u_boot_and_runtime(void) unsigned long uboot_stack_size = 16 * 1024 * 1024;
/* Add U-Boot */ - uboot_start = (gd->start_addr_sp - uboot_stack_size) & ~EFI_PAGE_MASK; - uboot_pages = (gd->ram_top - uboot_start) >> EFI_PAGE_SHIFT; + uboot_start = ((uintptr_t)map_sysmem(gd->start_addr_sp, 0) - + uboot_stack_size) & ~EFI_PAGE_MASK; + uboot_pages = ((uintptr_t)map_sysmem(gd->ram_top - 1, 0) - + uboot_start + EFI_PAGE_MASK) >> EFI_PAGE_SHIFT; efi_add_memory_map(uboot_start, uboot_pages, EFI_LOADER_DATA, false);
#if defined(__aarch64__) @@ -767,8 +769,7 @@ int efi_memory_init(void) { efi_add_known_memory();
- if (!IS_ENABLED(CONFIG_SANDBOX)) - add_u_boot_and_runtime(); + add_u_boot_and_runtime();
#ifdef CONFIG_EFI_LOADER_BOUNCE_BUFFER /* Request a 32bit 64MB bounce buffer region */ -- 2.24.0
On the sandbox the UEFI binaries must match the host architectures.
Adjust the Makefiles. Provide the PE/COFF header and relocation files.
Allow building helloworld.efi on the sandbox.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: no change --- Makefile | 19 +++++++++++++++++ arch/sandbox/config.mk | 28 ++++++++++++++++++++++++ arch/sandbox/lib/crt0_sandbox_efi.S | 32 ++++++++++++++++++++++++++++ arch/sandbox/lib/reloc_sandbox_efi.c | 32 ++++++++++++++++++++++++++++ cmd/Kconfig | 2 +- include/host_arch.h | 24 +++++++++++++++++++++ lib/efi_loader/Makefile | 3 +++ 7 files changed, 139 insertions(+), 1 deletion(-) create mode 100644 arch/sandbox/lib/crt0_sandbox_efi.S create mode 100644 arch/sandbox/lib/reloc_sandbox_efi.c create mode 100644 include/host_arch.h
diff --git a/Makefile b/Makefile index a9a78c30d6..c746de62be 100644 --- a/Makefile +++ b/Makefile @@ -17,6 +17,25 @@ NAME = # o Look for make include files relative to root of kernel src MAKEFLAGS += -rR --include-dir=$(CURDIR)
+# Determine host architecture +include include/host_arch.h +MK_ARCH="${shell uname -m}" +unexport HOST_ARCH +ifeq ("x86_64", $(MK_ARCH)) + export HOST_ARCH=$(HOST_ARCH_X86_64) +else ifneq (,$(findstring $(MK_ARCH), "i386" "i486" "i586" "i686")) + export HOST_ARCH=$(HOST_ARCH_X86) +else ifneq (,$(findstring $(MK_ARCH), "aarch64" "armv8l")) + export HOST_ARCH=$(HOST_ARCH_AARCH64) +else ifeq ("armv7l", $(MK_ARCH)) + export HOST_ARCH=$(HOST_ARCH_ARM) +else ifeq ("riscv32", $(MK_ARCH)) + export HOST_ARCH=$(HOST_ARCH_RISCV32) +else ifeq ("riscv64", $(MK_ARCH)) + export HOST_ARCH=$(HOST_ARCH_RISCV64) +endif +undefine MK_ARCH + # Avoid funny character set dependencies unexport LC_ALL LC_COLLATE=C diff --git a/arch/sandbox/config.mk b/arch/sandbox/config.mk index 05fbbd7bcc..a225c9cbfa 100644 --- a/arch/sandbox/config.mk +++ b/arch/sandbox/config.mk @@ -27,3 +27,31 @@ cmd_u-boot-spl = (cd $(obj) && $(CC) -o $(SPL_BIN) -Wl,-T u-boot-spl.lds \ $(PLATFORM_LIBS) -Wl,-Map -Wl,u-boot-spl.map -Wl,--gc-sections)
CONFIG_ARCH_DEVICE_TREE := sandbox + +ifeq ($(HOST_ARCH),$(HOST_ARCH_X86_64)) +EFI_LDS := ${SRCDIR}/../../../arch/x86/lib/elf_x86_64_efi.lds +EFI_TARGET := --target=efi-app-x86_64 +else ifeq ($(HOST_ARCH),$(HOST_ARCH_X86)) +EFI_LDS := ${SRCDIR}/../../../arch/x86/lib/elf_ia32_efi.lds +EFI_TARGET := --target=efi-app-ia32 +else ifeq ($(HOST_ARCH),$(HOST_ARCH_AARCH64)) +EFI_LDS := ${SRCDIR}/../../../arch/arm/lib/elf_aarch64_efi.lds +OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .data \ + -j .u_boot_list -j .rela.dyn -j .got -j .got.plt \ + -j .binman_sym_table -j .text_rest \ + -j .efi_runtime -j .efi_runtime_rel +else ifeq ($(HOST_ARCH),$(HOST_ARCH_ARM)) +EFI_LDS := ${SRCDIR}/../../../arch/arm/lib/elf_arm_efi.lds +OBJCOPYFLAGS += -j .text -j .secure_text -j .secure_data -j .rodata -j .hash \ + -j .data -j .got -j .got.plt -j .u_boot_list -j .rel.dyn \ + -j .binman_sym_table -j .text_rest \ + -j .efi_runtime -j .efi_runtime_rel +else ifeq ($(HOST_ARCH),$(HOST_ARCH_RISCV32)) +EFI_LDS := ${SRCDIR}/../../../arch/riscv/lib/elf_riscv32_efi.lds +else ifeq ($(HOST_ARCH),$(HOST_ARCH_RISCV64)) +EFI_LDS := ${SRCDIR}/../../../arch/riscv/lib/elf_riscv64_efi.lds +endif +EFI_CRT0 := crt0_sandbox_efi.o +EFI_RELOC := reloc_sandbox_efi.o +AFLAGS_crt0_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" +CFLAGS_reloc_sandbox_efi.o += -DHOST_ARCH="$(HOST_ARCH)" diff --git a/arch/sandbox/lib/crt0_sandbox_efi.S b/arch/sandbox/lib/crt0_sandbox_efi.S new file mode 100644 index 0000000000..b15766c514 --- /dev/null +++ b/arch/sandbox/lib/crt0_sandbox_efi.S @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * PE/COFF header for EFI applications + * + * Copyright (c) 2019 Heinrich Schuchardt + */ + +#include <host_arch.h> + +#if HOST_ARCH == HOST_ARCH_X86_64 +#include "../../../arch/x86/lib/crt0_x86_64_efi.S" +#endif + +#if HOST_ARCH == HOST_ARCH_X86 +#include "../../../arch/x86/lib/crt0_ia32_efi.S" +#endif + +#if HOST_ARCH == HOST_ARCH_AARCH64 +#include "../../../arch/arm/lib/crt0_aarch64_efi.S" +#endif + +#if HOST_ARCH == HOST_ARCH_ARM +#include "../../../arch/arm/lib/crt0_arm_efi.S" +#endif + +#if HOST_ARCH == HOST_ARCH_RISCV32 +#include "../../../arch/riscv/lib/crt0_riscv_efi.S" +#endif + +#if HOST_ARCH == HOST_ARCH_RISCV64 +#include "../../../arch/riscv/lib/crt0_riscv_efi.S" +#endif diff --git a/arch/sandbox/lib/reloc_sandbox_efi.c b/arch/sandbox/lib/reloc_sandbox_efi.c new file mode 100644 index 0000000000..a21e6757c5 --- /dev/null +++ b/arch/sandbox/lib/reloc_sandbox_efi.c @@ -0,0 +1,32 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * position independent shared object relocator + * + * Copyright (c) 2019 Heinrich Schuchardt + */ + +#include <host_arch.h> + +#if HOST_ARCH == HOST_ARCH_X86_64 +#include "../../../arch/x86/lib/reloc_x86_64_efi.c" +#endif + +#if HOST_ARCH == HOST_ARCH_X86 +#include "../../../arch/x86/lib/reloc_ia32_efi.c" +#endif + +#if HOST_ARCH == HOST_ARCH_AARCH64 +#include "../../../arch/arm/lib/reloc_aarch64_efi.c" +#endif + +#if HOST_ARCH == HOST_ARCH_ARM +#include "../../../arch/arm/lib/reloc_arm_efi.c" +#endif + +#if HOST_ARCH == HOST_ARCH_RISCV32 +#include "../../../arch/riscv/lib/reloc_riscv_efi.c" +#endif + +#if HOST_ARCH == HOST_ARCH_RISCV64 +#include "../../../arch/riscv/lib/reloc_riscv_efi.c" +#endif diff --git a/cmd/Kconfig b/cmd/Kconfig index 99b8a0e218..cf982ff65e 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -320,7 +320,7 @@ config CMD_BOOTEFI
config CMD_BOOTEFI_HELLO_COMPILE bool "Compile a standard EFI hello world binary for testing" - depends on CMD_BOOTEFI && !CPU_V7M && !SANDBOX + depends on CMD_BOOTEFI && !CPU_V7M default y help This compiles a standard EFI hello world application with U-Boot so diff --git a/include/host_arch.h b/include/host_arch.h new file mode 100644 index 0000000000..169d494513 --- /dev/null +++ b/include/host_arch.h @@ -0,0 +1,24 @@ +#if 0 +# SPDX SPDX-License-Identifier: GPL-2.0+ +# +# Constants defining the host architecture in assembler, C, and make files. +# The values are arbitrary. +# +# Copyright 2019 Heinrich Schuchardt xypron.glpk@gmx.de +#endif + +#if 0 +export HOST_ARCH_AARCH64=0xaa64 +export HOST_ARCH_ARM=0x00a7 +export HOST_ARCH_RISCV32=0x5032 +export HOST_ARCH_RISCV64=0x5064 +export HOST_ARCH_X86=0x0386 +export HOST_ARCH_X86_64=0x8664 +#endif + +#define HOST_ARCH_AARCH64 0xaa64 +#define HOST_ARCH_ARM 0x00a7 +#define HOST_ARCH_RISCV32 0x5032 +#define HOST_ARCH_RISCV64 0x5064 +#define HOST_ARCH_X86 0x0386 +#define HOST_ARCH_X86_64 0x8664 diff --git a/lib/efi_loader/Makefile b/lib/efi_loader/Makefile index 01769ea58b..7db4060286 100644 --- a/lib/efi_loader/Makefile +++ b/lib/efi_loader/Makefile @@ -6,6 +6,9 @@ # This file only gets included with CONFIG_EFI_LOADER set, so all # object inclusion implicitly depends on it
+asflags-y += -DHOST_ARCH="$(HOST_ARCH)" +ccflags-y += -DHOST_ARCH="$(HOST_ARCH)" + CFLAGS_efi_boottime.o += \ -DFW_VERSION="0x$(VERSION)" \ -DFW_PATCHLEVEL="0x$(PATCHLEVEL)" -- 2.24.0
As we can build relocation code for the sandbox now we should enable the unit tests that had to be disabled up to now.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- v2: new patch --- lib/efi_selftest/Makefile | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/lib/efi_selftest/Makefile b/lib/efi_selftest/Makefile index 8348014077..487cb4c674 100644 --- a/lib/efi_selftest/Makefile +++ b/lib/efi_selftest/Makefile @@ -5,6 +5,9 @@ # This file only gets included with CONFIG_EFI_LOADER set, so all # object inclusion implicitly depends on it
+asflags-y += -DHOST_ARCH="$(HOST_ARCH)" +ccflags-y += -DHOST_ARCH="$(HOST_ARCH)" + CFLAGS_efi_selftest_miniapp_exit.o := $(CFLAGS_EFI) -Os -ffreestanding CFLAGS_REMOVE_efi_selftest_miniapp_exit.o := $(CFLAGS_NON_EFI) CFLAGS_efi_selftest_miniapp_return.o := $(CFLAGS_EFI) -Os -ffreestanding @@ -55,8 +58,8 @@ obj-y += efi_selftest_block_device.o endif
# TODO: As of v2019.10 the relocation code for the EFI application cannot -# be built on ARMv7-M and Sandbox. -ifeq ($(CONFIG_SANDBOX)$(CONFIG_CPU_V7M),) +# be built on ARMv7-M. +ifeq ($(CONFIG_CPU_V7M),)
obj-y += \ efi_selftest_exception.o \ -- 2.24.0
