[PATCH 1/2] mtd: spi-nor: Enable QE bit for ISSI flash
Enable QE bit for ISSI flash chips.
QE enablement logic is similar to what Micromax has, so reuse the existing code itself.
Cc: Sagar Shrikant Kadam sagar.kadam@sifive.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mtd/spi/spi-nor-core.c | 1 + include/linux/mtd/spi-nor.h | 1 + 2 files changed, 2 insertions(+)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 7b6ad495ac..e0f6e4d6c3 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -325,6 +325,7 @@ static int set_4byte(struct spi_nor *nor, const struct flash_info *info, case SNOR_MFR_MICRON: /* Some Micron need WREN command; all will accept it */ need_wren = true; + case SNOR_MFR_ISSI: case SNOR_MFR_MACRONIX: case SNOR_MFR_WINBOND: if (need_wren) diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index ec144a08d8..233fdc341a 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -22,6 +22,7 @@ #define SNOR_MFR_INTEL CFI_MFR_INTEL #define SNOR_MFR_ST CFI_MFR_ST /* ST Micro <--> Micron */ #define SNOR_MFR_MICRON CFI_MFR_MICRON /* ST Micro <--> Micron */ +#define SNOR_MFR_ISSI CFI_MFR_PMC #define SNOR_MFR_MACRONIX CFI_MFR_MACRONIX #define SNOR_MFR_SPANSION CFI_MFR_AMD #define SNOR_MFR_SST CFI_MFR_SST
IS25WP256 flash chips do support 4byte address opcodes, so enable support for it.
Cc: Sagar Shrikant Kadam sagar.kadam@sifive.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- drivers/mtd/spi/spi-nor-ids.c | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index 973b6f86c9..f95bfb59e6 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -135,7 +135,8 @@ const struct flash_info spi_nor_ids[] = { { INFO("is25wp128", 0x9d7018, 0, 64 * 1024, 256, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("is25wp256", 0x9d7019, 0, 64 * 1024, 512, - SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, + SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ | + SPI_NOR_4B_OPCODES) }, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */
Hi Jagan,
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, April 20, 2020 3:36 PM To: Vignesh R vigneshr@ti.com; u-boot@lists.denx.de Cc: Bin Meng bmeng.cn@gmail.com; linux- amarula@amarulasolutions.com; Jagan Teki jagan@amarulasolutions.com; Sagar Kadam sagar.kadam@sifive.com Subject: [PATCH 2/2] mtd: spi-nor-ids: Enable 4B_OPCODES for is25wp256
[External Email] Do not click links or attachments unless you recognize the sender and know the content is safe
Looks good thanks for including.
Reviewed-by: Sagar Kadam sagar.kadam@sifive.com
Thanks & BR, Sagar Kadam
#endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ /* Macronix */ -- 2.17.1
Hi Jagan,
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, April 20, 2020 3:36 PM To: Vignesh R vigneshr@ti.com; u-boot@lists.denx.de Cc: Bin Meng bmeng.cn@gmail.com; linux- amarula@amarulasolutions.com; Jagan Teki jagan@amarulasolutions.com; Sagar Kadam sagar.kadam@sifive.com Subject: [PATCH 1/2] mtd: spi-nor: Enable QE bit for ISSI flash
nits: s/Micromax/Macronix
Thanks, Sagar Kadam
2.17.1
On Mon, Apr 20, 2020 at 9:56 PM Sagar Kadam sagar.kadam@sifive.com wrote:
Hi Jagan,
Will update while applying, thanks.
Hi Jagan,
-----Original Message----- From: Jagan Teki jagan@amarulasolutions.com Sent: Monday, April 20, 2020 9:58 PM To: Sagar Kadam sagar.kadam@sifive.com Cc: Vignesh R vigneshr@ti.com; u-boot@lists.denx.de; Bin Meng bmeng.cn@gmail.com; linux-amarula@amarulasolutions.com Subject: Re: [PATCH 1/2] mtd: spi-nor: Enable QE bit for ISSI flash
Hi Jagan,
Sure, no issues.
Jagan Teki
Sagar Kadam
