[U-Boot] [PATCH 0/2] lib/vsprintf: print '?' for illegal Unicode sequence
Commit 0e66c10a7d80 ("lib: vsprintf: avoid overflow printing UTF16 strings") broke the Unicode unit tests: an illegal UTF16 code point should be printed as '?'.
Unfortunately the Unicode unit tests were never executed on Travis due to an unmet naming convention. So let's rename the Unicode test functions.
Heinrich Schuchardt (2): lib/vsprintf: print '?' for illegal Unicode sequence test: adjust names of Unicode test functions
lib/vsprintf.c | 2 + test/unicode_ut.c | 98 +++++++++++++++++++++++------------------------ 2 files changed, 51 insertions(+), 49 deletions(-)
Fixes: 0e66c10a7d80 ("lib: vsprintf: avoid overflow printing UTF16 strings") Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- lib/vsprintf.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/lib/vsprintf.c b/lib/vsprintf.c index de5db1aa5c..1b6c154d8d 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -288,6 +288,8 @@ static char *string16(char *buf, char *end, u16 *s, int field_width, for (i = 0; i < len && buf + utf16_utf8_strnlen(str, 1) <= end; ++i) { s32 s = utf16_get(&str);
+ if (s < 0) + s = '?'; utf8_put(s, &buf); } for (; len < field_width; --field_width)
In test/py/conftest.py the assumption is made that for if a test is called with `ut unicode` the test function name starts with 'unicode_test_'. As the Unicode tests did not follow this naming scheme they were not executed by `make tests`.
Rename the Unicode test functions.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- test/unicode_ut.c | 98 +++++++++++++++++++++++------------------------ 1 file changed, 49 insertions(+), 49 deletions(-)
diff --git a/test/unicode_ut.c b/test/unicode_ut.c index 84fc9a3b53..8e1efe6f69 100644 --- a/test/unicode_ut.c +++ b/test/unicode_ut.c @@ -50,7 +50,7 @@ static const char j1[] = {0x6a, 0x31, 0xa1, 0x6c, 0x00}; static const char j2[] = {0x6a, 0x32, 0xc3, 0xc3, 0x6c, 0x00}; static const char j3[] = {0x6a, 0x33, 0xf0, 0x90, 0xf0, 0x00};
-static int ut_u16_strdup(struct unit_test_state *uts) +static int unicode_test_u16_strdup(struct unit_test_state *uts) { u16 *copy = u16_strdup(c4);
@@ -59,9 +59,9 @@ static int ut_u16_strdup(struct unit_test_state *uts) free(copy); return 0; } -UNICODE_TEST(ut_u16_strdup); +UNICODE_TEST(unicode_test_u16_strdup);
-static int ut_u16_strcpy(struct unit_test_state *uts) +static int unicode_test_u16_strcpy(struct unit_test_state *uts) { u16 *r; u16 copy[10]; @@ -71,11 +71,11 @@ static int ut_u16_strcpy(struct unit_test_state *uts) ut_assert(!memcmp(copy, c1, sizeof(c1))); return 0; } -UNICODE_TEST(ut_u16_strcpy); +UNICODE_TEST(unicode_test_u16_strcpy);
/* U-Boot uses UTF-16 strings in the EFI context only. */ #if CONFIG_IS_ENABLED(EFI_LOADER) && !defined(API_BUILD) -static int ut_string16(struct unit_test_state *uts) +static int unicode_test_string16(struct unit_test_state *uts) { char buf[20];
@@ -113,10 +113,10 @@ static int ut_string16(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_string16); +UNICODE_TEST(unicode_test_string16); #endif
-static int ut_utf8_get(struct unit_test_state *uts) +static int unicode_test_utf8_get(struct unit_test_state *uts) { const char *s; s32 code; @@ -152,9 +152,9 @@ static int ut_utf8_get(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf8_get); +UNICODE_TEST(unicode_test_utf8_get);
-static int ut_utf8_put(struct unit_test_state *uts) +static int unicode_test_utf8_put(struct unit_test_state *uts) { char buffer[8] = { 0, }; char *pos; @@ -190,9 +190,9 @@ static int ut_utf8_put(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf8_put); +UNICODE_TEST(unicode_test_utf8_put);
-static int ut_utf8_utf16_strlen(struct unit_test_state *uts) +static int unicode_test_utf8_utf16_strlen(struct unit_test_state *uts) { ut_asserteq(6, utf8_utf16_strlen(d1)); ut_asserteq(8, utf8_utf16_strlen(d2)); @@ -206,9 +206,9 @@ static int ut_utf8_utf16_strlen(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf8_utf16_strlen); +UNICODE_TEST(unicode_test_utf8_utf16_strlen);
-static int ut_utf8_utf16_strnlen(struct unit_test_state *uts) +static int unicode_test_utf8_utf16_strnlen(struct unit_test_state *uts) { ut_asserteq(3, utf8_utf16_strnlen(d1, 3)); ut_asserteq(6, utf8_utf16_strnlen(d1, 13)); @@ -224,7 +224,7 @@ static int ut_utf8_utf16_strnlen(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf8_utf16_strnlen); +UNICODE_TEST(unicode_test_utf8_utf16_strnlen);
/** * ut_u16_strcmp() - Compare to u16 strings. @@ -234,7 +234,7 @@ UNICODE_TEST(ut_utf8_utf16_strnlen); * @count: number of u16 to compare * Return: -1 if a1 < a2, 0 if a1 == a2, 1 if a1 > a2 */ -static int ut_u16_strcmp(const u16 *a1, const u16 *a2, size_t count) +static int unicode_test_u16_strcmp(const u16 *a1, const u16 *a2, size_t count) { for (; (*a1 || *a2) && count; ++a1, ++a2, --count) { if (*a1 < *a2) @@ -245,7 +245,7 @@ static int ut_u16_strcmp(const u16 *a1, const u16 *a2, size_t count) return 0; }
-static int ut_utf8_utf16_strcpy(struct unit_test_state *uts) +static int unicode_test_utf8_utf16_strcpy(struct unit_test_state *uts) { u16 buf[16]; u16 *pos; @@ -253,44 +253,44 @@ static int ut_utf8_utf16_strcpy(struct unit_test_state *uts) pos = buf; utf8_utf16_strcpy(&pos, d1); ut_asserteq(6, pos - buf); - ut_assert(!ut_u16_strcmp(buf, c1, SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, c1, SIZE_MAX));
pos = buf; utf8_utf16_strcpy(&pos, d2); ut_asserteq(8, pos - buf); - ut_assert(!ut_u16_strcmp(buf, c2, SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, c2, SIZE_MAX));
pos = buf; utf8_utf16_strcpy(&pos, d3); ut_asserteq(3, pos - buf); - ut_assert(!ut_u16_strcmp(buf, c3, SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, c3, SIZE_MAX));
pos = buf; utf8_utf16_strcpy(&pos, d4); ut_asserteq(6, pos - buf); - ut_assert(!ut_u16_strcmp(buf, c4, SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, c4, SIZE_MAX));
/* Illegal utf-8 strings */ pos = buf; utf8_utf16_strcpy(&pos, j1); ut_asserteq(4, pos - buf); - ut_assert(!ut_u16_strcmp(buf, L"j1?l", SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, L"j1?l", SIZE_MAX));
pos = buf; utf8_utf16_strcpy(&pos, j2); ut_asserteq(4, pos - buf); - ut_assert(!ut_u16_strcmp(buf, L"j2?l", SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, L"j2?l", SIZE_MAX));
pos = buf; utf8_utf16_strcpy(&pos, j3); ut_asserteq(3, pos - buf); - ut_assert(!ut_u16_strcmp(buf, L"j3?", SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, L"j3?", SIZE_MAX));
return 0; } -UNICODE_TEST(ut_utf8_utf16_strcpy); +UNICODE_TEST(unicode_test_utf8_utf16_strcpy);
-int ut_utf8_utf16_strncpy(struct unit_test_state *uts) +static int unicode_test_utf8_utf16_strncpy(struct unit_test_state *uts) { u16 buf[16]; u16 *pos; @@ -300,41 +300,41 @@ int ut_utf8_utf16_strncpy(struct unit_test_state *uts) utf8_utf16_strncpy(&pos, d1, 4); ut_asserteq(4, pos - buf); ut_assert(!buf[4]); - ut_assert(!ut_u16_strcmp(buf, c1, 4)); + ut_assert(!unicode_test_u16_strcmp(buf, c1, 4));
pos = buf; memset(buf, 0, sizeof(buf)); utf8_utf16_strncpy(&pos, d2, 10); ut_asserteq(8, pos - buf); ut_assert(buf[4]); - ut_assert(!ut_u16_strcmp(buf, c2, SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, c2, SIZE_MAX));
pos = buf; memset(buf, 0, sizeof(buf)); utf8_utf16_strncpy(&pos, d3, 2); ut_asserteq(2, pos - buf); ut_assert(!buf[2]); - ut_assert(!ut_u16_strcmp(buf, c3, 2)); + ut_assert(!unicode_test_u16_strcmp(buf, c3, 2));
pos = buf; memset(buf, 0, sizeof(buf)); utf8_utf16_strncpy(&pos, d4, 2); ut_asserteq(4, pos - buf); ut_assert(!buf[4]); - ut_assert(!ut_u16_strcmp(buf, c4, 4)); + ut_assert(!unicode_test_u16_strcmp(buf, c4, 4));
pos = buf; memset(buf, 0, sizeof(buf)); utf8_utf16_strncpy(&pos, d4, 10); ut_asserteq(6, pos - buf); ut_assert(buf[5]); - ut_assert(!ut_u16_strcmp(buf, c4, SIZE_MAX)); + ut_assert(!unicode_test_u16_strcmp(buf, c4, SIZE_MAX));
return 0; } -UNICODE_TEST(ut_utf8_utf16_strncpy); +UNICODE_TEST(unicode_test_utf8_utf16_strncpy);
-static int ut_utf16_get(struct unit_test_state *uts) +static int unicode_test_utf16_get(struct unit_test_state *uts) { const u16 *s; s32 code; @@ -358,9 +358,9 @@ static int ut_utf16_get(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf16_get); +UNICODE_TEST(unicode_test_utf16_get);
-static int ut_utf16_put(struct unit_test_state *uts) +static int unicode_test_utf16_put(struct unit_test_state *uts) { u16 buffer[4] = { 0, }; u16 *pos; @@ -386,9 +386,9 @@ static int ut_utf16_put(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf16_put); +UNICODE_TEST(unicode_test_utf16_put);
-int ut_utf16_strnlen(struct unit_test_state *uts) +static int unicode_test_utf16_strnlen(struct unit_test_state *uts) { ut_asserteq(3, utf16_strnlen(c1, 3)); ut_asserteq(6, utf16_strnlen(c1, 13)); @@ -404,9 +404,9 @@ int ut_utf16_strnlen(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf16_strnlen); +UNICODE_TEST(unicode_test_utf16_strnlen);
-int ut_utf16_utf8_strlen(struct unit_test_state *uts) +static int unicode_test_utf16_utf8_strlen(struct unit_test_state *uts) { ut_asserteq(6, utf16_utf8_strlen(c1)); ut_asserteq(9, utf16_utf8_strlen(c2)); @@ -420,9 +420,9 @@ int ut_utf16_utf8_strlen(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf16_utf8_strlen); +UNICODE_TEST(unicode_test_utf16_utf8_strlen);
-int ut_utf16_utf8_strnlen(struct unit_test_state *uts) +static int unicode_test_utf16_utf8_strnlen(struct unit_test_state *uts) { ut_asserteq(3, utf16_utf8_strnlen(c1, 3)); ut_asserteq(6, utf16_utf8_strnlen(c1, 13)); @@ -432,9 +432,9 @@ int ut_utf16_utf8_strnlen(struct unit_test_state *uts) ut_asserteq(12, utf16_utf8_strnlen(c4, 3)); return 0; } -UNICODE_TEST(ut_utf16_utf8_strnlen); +UNICODE_TEST(unicode_test_utf16_utf8_strnlen);
-int ut_utf16_utf8_strcpy(struct unit_test_state *uts) +static int unicode_test_utf16_utf8_strcpy(struct unit_test_state *uts) { char buf[16]; char *pos; @@ -477,9 +477,9 @@ int ut_utf16_utf8_strcpy(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf16_utf8_strcpy); +UNICODE_TEST(unicode_test_utf16_utf8_strcpy);
-int ut_utf16_utf8_strncpy(struct unit_test_state *uts) +static int unicode_test_utf16_utf8_strncpy(struct unit_test_state *uts) { char buf[16]; char *pos; @@ -521,9 +521,9 @@ int ut_utf16_utf8_strncpy(struct unit_test_state *uts)
return 0; } -UNICODE_TEST(ut_utf16_utf8_strncpy); +UNICODE_TEST(unicode_test_utf16_utf8_strncpy);
-int ut_utf_to_lower(struct unit_test_state *uts) +static int unicode_test_utf_to_lower(struct unit_test_state *uts) { ut_asserteq('@', utf_to_lower('@')); ut_asserteq('a', utf_to_lower('A')); @@ -538,9 +538,9 @@ int ut_utf_to_lower(struct unit_test_state *uts) #endif return 0; } -UNICODE_TEST(ut_utf_to_lower); +UNICODE_TEST(unicode_test_utf_to_lower);
-int ut_utf_to_upper(struct unit_test_state *uts) +static int unicode_test_utf_to_upper(struct unit_test_state *uts) { ut_asserteq('`', utf_to_upper('`')); ut_asserteq('A', utf_to_upper('a')); @@ -555,7 +555,7 @@ int ut_utf_to_upper(struct unit_test_state *uts) #endif return 0; } -UNICODE_TEST(ut_utf_to_upper); +UNICODE_TEST(unicode_test_utf_to_upper);
int do_ut_unicode(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) {
