[U-Boot] [PATCH 00/13] arm: am57xx: Add support for am574-idk
am574x-idk board is similar to am572x-idk with am574x SoC. This series adds support for this board.
Logs: http://pastebin.ubuntu.com/26207045/
Lokesh Vutla (12): arm: emif-common: Add ecc specific emif registers arm: emif-common: Add suppport for enabling ECC arm: keystone: Move cmd_ddr3 to a common place arm: ti: Generalize cmd_ddr3 command arm: dra762: Add support for device package identification board: ti: am574x-idk: Add epprom support board: ti: am574x-idk: Add hw data support board: ti: am574x-idk: Add ddr data support board: ti: am574x-idk: Update pinmux using latest PMT board: ti: am57xx: Enable CMD_DDR3 ARM: dts: am574x-idk: Add initial support env: ti: Select dtb name for dra76x and am574
Tero Kristo (1): drivers: dma: ti-edma3: add support for memory fill
arch/arm/dts/Makefile | 1 + arch/arm/dts/am572x-idk-common.dtsi | 100 +++++++ arch/arm/dts/am572x-idk.dts | 93 +------ arch/arm/dts/am574x-idk.dts | 22 ++ arch/arm/dts/am57xx-commercial-grade.dtsi | 1 + arch/arm/dts/am57xx-industrial-grade.dtsi | 1 + arch/arm/include/asm/arch-omap5/omap.h | 3 + arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + arch/arm/include/asm/emif.h | 50 +++- arch/arm/include/asm/omap_common.h | 15 ++ arch/arm/include/asm/ti-common/ti-edma3.h | 2 + arch/arm/mach-keystone/Kconfig | 4 + arch/arm/mach-keystone/Makefile | 1 - arch/arm/mach-keystone/include/mach/hardware.h | 1 + arch/arm/mach-omap2/emif-common.c | 95 ++++++- arch/arm/mach-omap2/hwinit-common.c | 33 ++- arch/arm/mach-omap2/omap5/Kconfig | 1 + arch/arm/mach-omap2/omap5/hw_data.c | 4 + arch/arm/mach-omap2/omap5/hwinit.c | 21 ++ arch/arm/mach-omap2/omap5/sdram.c | 4 + board/ti/am57xx/board.c | 64 ++++- board/ti/am57xx/mux_data.h | 299 +++++++++++++++++++++ board/ti/common/Kconfig | 7 + board/ti/common/Makefile | 3 + .../mach-keystone => board/ti/common}/cmd_ddr3.c | 179 +++++++++--- board/ti/dra7xx/evm.c | 17 +- configs/am57xx_evm_defconfig | 2 +- configs/am57xx_hs_evm_defconfig | 2 +- drivers/dma/ti-edma3.c | 55 +++- include/environment/ti/boot.h | 4 +- 30 files changed, 927 insertions(+), 158 deletions(-) create mode 100644 arch/arm/dts/am572x-idk-common.dtsi create mode 100644 arch/arm/dts/am574x-idk.dts rename {arch/arm/mach-keystone => board/ti/common}/cmd_ddr3.c (54%)
Add support for simple memory fill operation. With large data sizes it is much faster to use EDMA for memory fill rather than CPU.
Signed-off-by: Tero Kristo t-kristo@ti.com Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/ti-common/ti-edma3.h | 2 ++ drivers/dma/ti-edma3.c | 55 +++++++++++++++++++++++++++---- 2 files changed, 50 insertions(+), 7 deletions(-)
diff --git a/arch/arm/include/asm/ti-common/ti-edma3.h b/arch/arm/include/asm/ti-common/ti-edma3.h index 6a7a321c1b..3f41d34a7a 100644 --- a/arch/arm/include/asm/ti-common/ti-edma3.h +++ b/arch/arm/include/asm/ti-common/ti-edma3.h @@ -119,5 +119,7 @@ void edma3_set_transfer_params(u32 base, int slot, int acnt, enum edma3_sync_dimension sync_mode); void edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num, void *dst, void *src, size_t len); +void edma3_fill(unsigned long edma3_base_addr, unsigned int edma_slot_num, + void *dst, u8 val, size_t len);
#endif diff --git a/drivers/dma/ti-edma3.c b/drivers/dma/ti-edma3.c index 635eb7876d..852c9e1fd7 100644 --- a/drivers/dma/ti-edma3.c +++ b/drivers/dma/ti-edma3.c @@ -34,10 +34,14 @@ #define EDMA3_QEESR 0x108c #define EDMA3_QSECR 0x1094
+#define EDMA_FILL_BUFFER_SIZE 512 + struct ti_edma3_priv { u32 base; };
+static u8 edma_fill_buffer[EDMA_FILL_BUFFER_SIZE] __aligned(ARCH_DMA_MINALIGN); + /** * qedma3_start - start qdma on a channel * @base: base address of edma @@ -391,7 +395,7 @@ void qedma3_stop(u32 base, struct edma3_channel_config *cfg) }
void __edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num, - void *dst, void *src, size_t len) + void *dst, void *src, size_t len, size_t s_len) { struct edma3_slot_config slot; struct edma3_channel_config edma_channel; @@ -401,7 +405,11 @@ void __edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num, unsigned int addr = (unsigned int) (dst); unsigned int max_acnt = 0x7FFFU;
- if (len > max_acnt) { + if (len > s_len) { + b_cnt_value = (len / s_len); + rem_bytes = (len % s_len); + a_cnt_value = s_len; + } else if (len > max_acnt) { b_cnt_value = (len / max_acnt); rem_bytes = (len % max_acnt); a_cnt_value = max_acnt; @@ -412,7 +420,10 @@ void __edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num, slot.acnt = a_cnt_value; slot.bcnt = b_cnt_value; slot.ccnt = 1; - slot.src_bidx = a_cnt_value; + if (len == s_len) + slot.src_bidx = a_cnt_value; + else + slot.src_bidx = 0; slot.dst_bidx = a_cnt_value; slot.src_cidx = 0; slot.dst_cidx = 0; @@ -438,8 +449,11 @@ void __edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num,
if (rem_bytes != 0) { slot.opt = 0; - slot.src = - (b_cnt_value * max_acnt) + ((unsigned int) src); + if (len == s_len) + slot.src = + (b_cnt_value * max_acnt) + ((unsigned int) src); + else + slot.src = (unsigned int) src; slot.acnt = rem_bytes; slot.bcnt = 1; slot.ccnt = 1; @@ -468,12 +482,39 @@ void __edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num, } }
+void __edma3_fill(unsigned long edma3_base_addr, unsigned int edma_slot_num, + void *dst, u8 val, size_t len) +{ + int xfer_len; + int max_xfer = EDMA_FILL_BUFFER_SIZE * 65535; + + memset((void *)edma_fill_buffer, val, sizeof(edma_fill_buffer)); + + while (len) { + xfer_len = len; + if (xfer_len > max_xfer) + xfer_len = max_xfer; + + __edma3_transfer(edma3_base_addr, edma_slot_num, dst, + edma_fill_buffer, xfer_len, + EDMA_FILL_BUFFER_SIZE); + len -= xfer_len; + dst += xfer_len; + } +} + #ifndef CONFIG_DMA
void edma3_transfer(unsigned long edma3_base_addr, unsigned int edma_slot_num, void *dst, void *src, size_t len) { - __edma3_transfer(edma3_base_addr, edma_slot_num, dst, src, len); + __edma3_transfer(edma3_base_addr, edma_slot_num, dst, src, len, len); +} + +void edma3_fill(unsigned long edma3_base_addr, unsigned int edma_slot_num, + void *dst, u8 val, size_t len) +{ + __edma3_fill(edma3_base_addr, edma_slot_num, dst, val, len); }
#else @@ -488,7 +529,7 @@ static int ti_edma3_transfer(struct udevice *dev, int direction, void *dst,
switch (direction) { case DMA_MEM_TO_MEM: - __edma3_transfer(priv->base, 1, dst, src, len); + __edma3_transfer(priv->base, 1, dst, src, len, len); break; default: pr_err("Transfer type not implemented in DMA driver\n");
This is a slight difference in emif_ddr_phy_status register offsets for DRA7xx/keystone EMIF and older versions. And ecc registers are available only in DRA7xx EMIF. Add support for this difference and ecc registers.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/emif.h | 17 ++++++++++++++++- arch/arm/mach-omap2/emif-common.c | 6 +++--- 2 files changed, 19 insertions(+), 4 deletions(-)
diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index 9a46340deb..a661ba9032 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -664,12 +664,27 @@ struct emif_reg_struct { u32 emif_prio_class_serv_map; u32 emif_connect_id_serv_1_map; u32 emif_connect_id_serv_2_map; - u32 padding8[5]; + u32 padding8; + u32 emif_ecc_ctrl_reg; + u32 emif_ecc_address_range_1; + u32 emif_ecc_address_range_2; + u32 padding8_1; u32 emif_rd_wr_exec_thresh; u32 emif_cos_config; +#if defined(CONFIG_DRA7XX) || defined(CONFIG_ARCH_KEYSTONE) + u32 padding9[2]; + u32 emif_1b_ecc_err_cnt; + u32 emif_1b_ecc_err_thrush; + u32 emif_1b_ecc_err_dist_1; + u32 emif_1b_ecc_err_addr_log; + u32 emif_2b_ecc_err_addr_log; + u32 emif_ddr_phy_status[28]; + u32 padding10[19]; +#else u32 padding9[6]; u32 emif_ddr_phy_status[28]; u32 padding10[20]; +#endif u32 emif_ddr_ext_phy_ctrl_1; u32 emif_ddr_ext_phy_ctrl_1_shdw; u32 emif_ddr_ext_phy_ctrl_2; diff --git a/arch/arm/mach-omap2/emif-common.c b/arch/arm/mach-omap2/emif-common.c index def7fe0f0a..2b03dbecf4 100644 --- a/arch/arm/mach-omap2/emif-common.c +++ b/arch/arm/mach-omap2/emif-common.c @@ -255,7 +255,7 @@ static void update_hwleveling_output(u32 base, const struct emif_regs *regs) u32 *emif_ext_phy_ctrl_reg, *emif_phy_status; u32 reg, i, phy;
- emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[7]; + emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[6]; phy = readl(&emif->emif_ddr_phy_ctrl_1);
/* Update PHY_REG_RDDQS_RATIO */ @@ -269,7 +269,7 @@ static void update_hwleveling_output(u32 base, const struct emif_regs *regs)
/* Update PHY_REG_FIFO_WE_SLAVE_RATIO */ emif_ext_phy_ctrl_reg = (u32 *)&emif->emif_ddr_ext_phy_ctrl_2; - emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[12]; + emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[11]; if (!(phy & EMIF_DDR_PHY_CTRL_1_RDLVLGATE_MASK_MASK)) for (i = 0; i < PHY_FIFO_WE_SLAVE_RATIO_REGS; i++) { reg = readl(emif_phy_status++); @@ -279,7 +279,7 @@ static void update_hwleveling_output(u32 base, const struct emif_regs *regs)
/* Update PHY_REG_WR_DQ/DQS_SLAVE_RATIO */ emif_ext_phy_ctrl_reg = (u32 *)&emif->emif_ddr_ext_phy_ctrl_12; - emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[17]; + emif_phy_status = (u32 *)&emif->emif_ddr_phy_status[16]; if (!(phy & EMIF_DDR_PHY_CTRL_1_WRLVL_MASK_MASK)) for (i = 0; i < PHY_REG_WR_DQ_SLAVE_RATIO_REGS; i++) { reg = readl(emif_phy_status++);
For data integrity, the EMIF1 supports ECC on the data written or read from the SDRAM. Add support for enabling ECC support in EMIF1.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Krunal Bhargav k-bhargav@ti.com --- arch/arm/include/asm/emif.h | 31 ++++++++++++++ arch/arm/mach-omap2/emif-common.c | 89 ++++++++++++++++++++++++++++++++++++++- 2 files changed, 119 insertions(+), 1 deletion(-)
diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index a661ba9032..6a2ccd2350 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -604,6 +604,34 @@
#define EMIF_EXT_PHY_CTRL_TIMING_REG 0x5
+/* EMIF ECC CTRL reg */ +#define EMIF_ECC_CTRL_REG_ECC_EN_SHIFT 31 +#define EMIF_ECC_CTRL_REG_ECC_EN_MASK (1 << 31) +#define EMIF_ECC_CTRL_REG_ECC_ADDR_RGN_PROT_SHIFT 30 +#define EMIF_ECC_CTRL_REG_ECC_ADDR_RGN_PROT_MASK (1 << 31) +#define EMIF_ECC_CTRL_REG_ECC_VERIFY_DIS_SHIFT 29 +#define EMIF_ECC_CTRL_REG_ECC_VERIFY_DIS_MASK (1 << 29) +#define EMIF_ECC_REG_RMW_EN_SHIFT 28 +#define EMIF_ECC_REG_RMW_EN_MASK (1 << 28) +#define EMIF_ECC_REG_ECC_ADDR_RGN_2_EN_SHIFT 1 +#define EMIF_ECC_REG_ECC_ADDR_RGN_2_EN_MASK (1 << 1) +#define EMIF_ECC_REG_ECC_ADDR_RGN_1_EN_SHIFT 0 +#define EMIF_ECC_REG_ECC_ADDR_RGN_1_EN_MASK (1 << 0) + +/* EMIF ECC ADDRESS RANGE */ +#define EMIF_ECC_REG_ECC_END_ADDR_SHIFT 16 +#define EMIF_ECC_REG_ECC_END_ADDR_MASK (0xffff << 16) +#define EMIF_ECC_REG_ECC_START_ADDR_SHIFT 0 +#define EMIF_ECC_REG_ECC_START_ADDR_MASK (0xffff << 0) + +/* EMIF_SYSTEM_OCP_INTERRUPT_RAW_STATUS */ +#define EMIF_INT_ONEBIT_ECC_ERR_SYS_SHIFT 5 +#define EMIF_INT_ONEBIT_ECC_ERR_SYS_MASK (1 << 5) +#define EMIF_INT_TWOBIT_ECC_ERR_SYS_SHIFT 4 +#define EMIF_INT_TWOBIT_ECC_ERR_SYS_MASK (1 << 4) +#define EMIF_INT_WR_ECC_ERR_SYS_SHIFT 3 +#define EMIF_INT_WR_ECC_ERR_SYS_MASK (1 << 3) + /* Reg mapping structure */ struct emif_reg_struct { u32 emif_mod_id_rev; @@ -1205,6 +1233,9 @@ struct emif_regs { u32 emif_connect_id_serv_1_map; u32 emif_connect_id_serv_2_map; u32 emif_cos_config; + u32 emif_ecc_ctrl_reg; + u32 emif_ecc_address_range_1; + u32 emif_ecc_address_range_2; };
struct lpddr2_mr_regs { diff --git a/arch/arm/mach-omap2/emif-common.c b/arch/arm/mach-omap2/emif-common.c index 2b03dbecf4..e3ef37b077 100644 --- a/arch/arm/mach-omap2/emif-common.c +++ b/arch/arm/mach-omap2/emif-common.c @@ -17,6 +17,7 @@ #include <asm/omap_sec_common.h> #include <asm/utils.h> #include <linux/compiler.h> +#include <asm/ti-common/ti-edma3.h>
static int emif1_enabled = -1, emif2_enabled = -1;
@@ -332,6 +333,71 @@ static void dra7_ddr3_leveling(u32 base, const struct emif_regs *regs) update_hwleveling_output(base, regs); }
+static void dra7_reset_ddr_data(u32 base, u32 size) +{ +#if defined(CONFIG_TI_EDMA3) && !defined(CONFIG_DMA) + enable_edma3_clocks(); + + edma3_fill(EDMA3_BASE, 1, (void *)base, 0, size); + + disable_edma3_clocks(); +#else + memset((void *)base, 0, size); +#endif +} + +static void dra7_enable_ecc(u32 base, const struct emif_regs *regs) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)base; + u32 rgn, size; + + /* ECC available only on dra76x EMIF1 */ + if ((base != EMIF1_BASE) || !is_dra76x()) + return; + + if (regs->emif_ecc_ctrl_reg & EMIF_ECC_CTRL_REG_ECC_EN_MASK) { + writel(regs->emif_ecc_address_range_1, + &emif->emif_ecc_address_range_1); + writel(regs->emif_ecc_address_range_2, + &emif->emif_ecc_address_range_2); + writel(regs->emif_ecc_ctrl_reg, &emif->emif_ecc_ctrl_reg); + + /* Set region1 memory with 0 */ + rgn = ((regs->emif_ecc_address_range_1 & + EMIF_ECC_REG_ECC_START_ADDR_MASK) << 16) + + CONFIG_SYS_SDRAM_BASE; + size = (regs->emif_ecc_address_range_1 & + EMIF_ECC_REG_ECC_END_ADDR_MASK) + 0x10000; + + if (regs->emif_ecc_ctrl_reg & + EMIF_ECC_REG_ECC_ADDR_RGN_1_EN_MASK) + dra7_reset_ddr_data(rgn, size); + + /* Set region2 memory with 0 */ + rgn = ((regs->emif_ecc_address_range_2 & + EMIF_ECC_REG_ECC_START_ADDR_MASK) << 16) + + CONFIG_SYS_SDRAM_BASE; + size = (regs->emif_ecc_address_range_2 & + EMIF_ECC_REG_ECC_END_ADDR_MASK) + 0x10000; + + if (regs->emif_ecc_ctrl_reg & + EMIF_ECC_REG_ECC_ADDR_RGN_2_EN_MASK) + dra7_reset_ddr_data(rgn, size); + +#ifdef CONFIG_DRA7XX + /* Clear the status flags and other history */ + writel(readl(&emif->emif_1b_ecc_err_cnt), + &emif->emif_1b_ecc_err_cnt); + writel(0xffffffff, &emif->emif_1b_ecc_err_dist_1); + writel(0x1, &emif->emif_2b_ecc_err_addr_log); + writel(EMIF_INT_WR_ECC_ERR_SYS_MASK | + EMIF_INT_TWOBIT_ECC_ERR_SYS_MASK | + EMIF_INT_ONEBIT_ECC_ERR_SYS_MASK, + &emif->emif_irqstatus_sys); +#endif + } +} + static void dra7_ddr3_init(u32 base, const struct emif_regs *regs) { struct emif_reg_struct *emif = (struct emif_reg_struct *)base; @@ -368,8 +434,29 @@ static void dra7_ddr3_init(u32 base, const struct emif_regs *regs)
writel(regs->ref_ctrl_final, &emif->emif_sdram_ref_ctrl);
- if (regs->emif_rd_wr_lvl_rmp_ctl & EMIF_REG_RDWRLVL_EN_MASK) + if (regs->emif_rd_wr_lvl_rmp_ctl & EMIF_REG_RDWRLVL_EN_MASK) { + /* + * Perform Dummy ECC setup just to allow hardware + * leveling of ECC memories + */ + if (is_dra76x() && (base == EMIF1_BASE) && + (regs->emif_ecc_ctrl_reg & EMIF_ECC_CTRL_REG_ECC_EN_MASK)) { + writel(0, &emif->emif_ecc_address_range_1); + writel(0, &emif->emif_ecc_address_range_2); + writel(EMIF_ECC_CTRL_REG_ECC_EN_MASK | + EMIF_ECC_CTRL_REG_ECC_ADDR_RGN_PROT_MASK, + &emif->emif_ecc_ctrl_reg); + } + dra7_ddr3_leveling(base, regs); + + /* Disable ECC */ + if (is_dra76x()) + writel(0, &emif->emif_ecc_ctrl_reg); + } + + /* Enable ECC as necessary */ + dra7_enable_ecc(base, regs); }
static void omap5_ddr3_init(u32 base, const struct emif_regs *regs)
Move cmd_ddr3 to board/ti/common/ in order to make it build for non-keystone TI platforms.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-keystone/Kconfig | 4 ++++ arch/arm/mach-keystone/Makefile | 1 - board/ti/common/Kconfig | 7 +++++++ board/ti/common/Makefile | 3 +++ {arch/arm/mach-keystone => board/ti/common}/cmd_ddr3.c | 5 ++--- 5 files changed, 16 insertions(+), 4 deletions(-) rename {arch/arm/mach-keystone => board/ti/common}/cmd_ddr3.c (98%)
diff --git a/arch/arm/mach-keystone/Kconfig b/arch/arm/mach-keystone/Kconfig index cababdba52..d24596eccb 100644 --- a/arch/arm/mach-keystone/Kconfig +++ b/arch/arm/mach-keystone/Kconfig @@ -7,16 +7,19 @@ choice config TARGET_K2HK_EVM bool "TI Keystone 2 Kepler/Hawking EVM" select SPL_BOARD_INIT if SPL + select CMD_DDR3 imply DM_I2C
config TARGET_K2E_EVM bool "TI Keystone 2 Edison EVM" select SPL_BOARD_INIT if SPL + select CMD_DDR3 imply DM_I2C
config TARGET_K2L_EVM bool "TI Keystone 2 Lamar EVM" select SPL_BOARD_INIT if SPL + select CMD_DDR3 imply DM_I2C
config TARGET_K2G_EVM @@ -24,6 +27,7 @@ config TARGET_K2G_EVM select BOARD_LATE_INIT select SPL_BOARD_INIT if SPL select TI_I2C_BOARD_DETECT + select CMD_DDR3 imply DM_I2C
endchoice diff --git a/arch/arm/mach-keystone/Makefile b/arch/arm/mach-keystone/Makefile index 8253a3bcc1..3e076e12ec 100644 --- a/arch/arm/mach-keystone/Makefile +++ b/arch/arm/mach-keystone/Makefile @@ -13,7 +13,6 @@ ifndef CONFIG_SPL_BUILD obj-y += cmd_clock.o obj-y += cmd_mon.o obj-y += cmd_poweroff.o -obj-y += cmd_ddr3.o endif obj-y += msmc.o obj-y += ddr3.o diff --git a/board/ti/common/Kconfig b/board/ti/common/Kconfig index c21eb8c2d2..d7c05e2451 100644 --- a/board/ti/common/Kconfig +++ b/board/ti/common/Kconfig @@ -42,3 +42,10 @@ config TI_COMMON_CMD_OPTIONS imply CMD_SPI imply CMD_TIME imply CMD_USB if USB + +config CMD_DDR3 + bool "command for verifying DDR features" + help + Support for testing ddr3 on TI platforms. This command + supports memory verification, memory comapre and ecc + verification if supported. diff --git a/board/ti/common/Makefile b/board/ti/common/Makefile index 7170eac81e..66025040bc 100644 --- a/board/ti/common/Makefile +++ b/board/ti/common/Makefile @@ -4,3 +4,6 @@ #
obj-${CONFIG_TI_I2C_BOARD_DETECT} += board_detect.o +ifndef CONFIG_SPL_BUILD +obj-${CONFIG_CMD_DDR3} += cmd_ddr3.o +endif diff --git a/arch/arm/mach-keystone/cmd_ddr3.c b/board/ti/common/cmd_ddr3.c similarity index 98% rename from arch/arm/mach-keystone/cmd_ddr3.c rename to board/ti/common/cmd_ddr3.c index d3eab0711c..b6435a43f4 100644 --- a/arch/arm/mach-keystone/cmd_ddr3.c +++ b/board/ti/common/cmd_ddr3.c @@ -1,8 +1,7 @@ /* - * Keystone2: DDR3 test commands + * EMIF: DDR3 test commands * - * (C) Copyright 2012-2014 - * Texas Instruments Incorporated, <www.ti.com> + * Copyright (C) 2012-2017 Texas Instruments Incorporated, <www.ti.com> * * SPDX-License-Identifier: GPL-2.0+ */
[snip]
We shouldn't need games like that now to have all strings be discarded, now that we're mandating gcc-6 or later. Thanks!
[snip]
whithout guarding with !SPL_BUILD, following build erroris seen if SPL_ENV is not enabled:
# env/built-in.o:(.data.env_htab+0xc): undefined reference to `env_flags_validate' lib/built-in.o: In function `hsearch_r': /home/lokesh/working/mainline/u-boot/lib/hashtable.c:380: undefined reference to `env_callback_init' /home/lokesh/working/mainline/u-boot/lib/hashtable.c:382: undefined reference to `env_flags_init' scripts/Makefile.spl:343: recipe for target 'spl/u-boot-spl' failed make[1]: *** [spl/u-boot-spl] Error 1 Makefile:1400: recipe for target 'spl/u-boot-spl' failed make: *** [spl/u-boot-spl] Error 2
gcc-6 is being used. Am I missing something?
Thanks and regards, Lokesh
[snip]
Hmmm, I would have expected it to be gc'd away. But I guess we're forcing commands to be linked in for some reason, I'll dig more just so I know again but disregard my comment about removing the guard, thanks!
[snip]
While I'm looking at this again, we should probably mirror cmd/mvebu here and move this to cmd/ti/ instead of board/ti/common/, thanks!
Keystone and DRA7 based TI platforms uses same EMIF memory controller. cmd_ddr3 command is customized for keystone platforms, make it generic so that it can be re used for DRA7 platforms.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/emif.h | 2 + arch/arm/mach-keystone/include/mach/hardware.h | 1 + board/ti/common/cmd_ddr3.c | 174 ++++++++++++++++++++----- 3 files changed, 141 insertions(+), 36 deletions(-)
diff --git a/arch/arm/include/asm/emif.h b/arch/arm/include/asm/emif.h index 6a2ccd2350..b9fa3bb827 100644 --- a/arch/arm/include/asm/emif.h +++ b/arch/arm/include/asm/emif.h @@ -17,7 +17,9 @@ #include <asm/io.h>
/* Base address */ +#ifndef EMIF1_BASE #define EMIF1_BASE 0x4c000000 +#endif #define EMIF2_BASE 0x4d000000
#define EMIF_4D 0x4 diff --git a/arch/arm/mach-keystone/include/mach/hardware.h b/arch/arm/mach-keystone/include/mach/hardware.h index 1969a10ab3..6629406870 100644 --- a/arch/arm/mach-keystone/include/mach/hardware.h +++ b/arch/arm/mach-keystone/include/mach/hardware.h @@ -78,6 +78,7 @@ typedef volatile unsigned int *dv_reg_p; #define KS2_DDR3A_EMIF_CTRL_BASE 0x21010000 #define KS2_DDR3A_EMIF_DATA_BASE 0x80000000 #define KS2_DDR3A_DDRPHYC 0x02329000 +#define EMIF1_BASE KS2_DDR3A_EMIF_CTRL_BASE
#define KS2_DDR3_MIDR_OFFSET 0x00 #define KS2_DDR3_STATUS_OFFSET 0x04 diff --git a/board/ti/common/cmd_ddr3.c b/board/ti/common/cmd_ddr3.c index b6435a43f4..0e35d5cbbd 100644 --- a/board/ti/common/cmd_ddr3.c +++ b/board/ti/common/cmd_ddr3.c @@ -7,23 +7,25 @@ */
#include <asm/arch/hardware.h> -#include <asm/arch/ddr3.h> +#include <asm/cache.h> +#include <asm/emif.h> #include <common.h> #include <command.h>
-DECLARE_GLOBAL_DATA_PTR; - +#ifdef CONFIG_ARCH_KEYSTONE +#include <asm/arch/ddr3.h> #define DDR_MIN_ADDR CONFIG_SYS_SDRAM_BASE -#define STACKSIZE (512 << 10) /* 512 KiB */ - +#define STACKSIZE (512 << 10) /* 512 KiB */ #define DDR_REMAP_ADDR 0x80000000 #define ECC_START_ADDR1 ((DDR_MIN_ADDR - DDR_REMAP_ADDR) >> 17)
-#define ECC_END_ADDR1 (((gd->start_addr_sp - DDR_REMAP_ADDR - \ - STACKSIZE) >> 17) - 2) +#define ECC_END_ADDR1 (((gd->start_addr_sp - DDR_REMAP_ADDR - \ + STACKSIZE) >> 17) - 2) +#endif
#define DDR_TEST_BURST_SIZE 1024
+DECLARE_GLOBAL_DATA_PTR; static int ddr_memory_test(u32 start_address, u32 end_address, int quick) { u32 index_start, value, index; @@ -153,57 +155,157 @@ static int ddr_memory_compare(u32 address1, u32 address2, u32 size) return 0; }
-static int ddr_memory_ecc_err(u32 base, u32 address, u32 ecc_err) +#ifndef CONFIG_ARCH_KEYSTONE +static void ddr_check_ecc_status(void) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)EMIF1_BASE; + u32 err_1b = readl(&emif->emif_1b_ecc_err_cnt); + u32 int_status = readl(&emif->emif_irqstatus_raw_sys); + int ecc_test = 0; + char *env; + + env = env_get("ecc_test"); + if (env) + ecc_test = simple_strtol(env, NULL, 0); + + puts("ECC test Status:\n"); + if (int_status & EMIF_INT_WR_ECC_ERR_SYS_MASK) + puts("\tECC test: DDR ECC write error interrupted\n"); + + if (int_status & EMIF_INT_TWOBIT_ECC_ERR_SYS_MASK) + if (!ecc_test) + panic("\tECC test: DDR ECC 2-bit error interrupted"); + + if (int_status & EMIF_INT_ONEBIT_ECC_ERR_SYS_MASK) + puts("\tECC test: DDR ECC 1-bit error interrupted\n"); + + if (err_1b) + printf("\tECC test: 1-bit ECC err count: 0x%x\n", err_1b); +} +#endif + +static int ddr_memory_ecc_err(u32 addr, u32 ecc_err) { - u32 value1, value2, value3; + struct emif_reg_struct *emif = (struct emif_reg_struct *)EMIF1_BASE; + u32 ecc_ctrl = readl(&emif->emif_ecc_ctrl_reg); + u32 val1, val2, val3; + + debug("Disabling D-Cache before ECC test\n"); + dcache_disable(); + invalidate_dcache_all(); + + puts("Testing DDR ECC:\n"); + puts("\tECC test: Disabling DDR ECC ...\n"); + writel(0, &emif->emif_ecc_ctrl_reg); + + val1 = readl(addr); + val2 = val1 ^ ecc_err; + writel(val2, addr); + + val3 = readl(addr); + printf("\tECC test: addr 0x%x, read data 0x%x, written data 0x%x, err pattern: 0x%x, read after write data 0x%x\n", + addr, val1, val2, ecc_err, val3);
- puts("Disabling DDR ECC ...\n"); - ddr3_disable_ecc(base); + puts("\tECC test: Enabling DDR ECC ...\n"); +#ifdef CONFIG_ARCH_KEYSTONE + ecc_ctrl = ECC_START_ADDR1 | (ECC_END_ADDR1 << 16); + __raw_writel(ecc_ctrl, EMIF1_BASE + KS2_DDR3_ECC_ADDR_RANGE1_OFFSET); + ddr3_enable_ecc(EMIF1_BASE, 1);
- value1 = __raw_readl(address); - value2 = value1 ^ ecc_err; - __raw_writel(value2, address); + val1 = __raw_readl(addr); + printf("ECC err test, addr 0x%x, read data 0x%x\n", addr, val1);
- value3 = __raw_readl(address); - printf("ECC err test, addr 0x%x, read data 0x%x, wrote data 0x%x, err pattern: 0x%x, read after write data 0x%x\n", - address, value1, value2, ecc_err, value3); + ddr3_check_ecc_int(EMIF1_BASE); +#else + writel(ecc_ctrl, &emif->emif_ecc_ctrl_reg);
- __raw_writel(ECC_START_ADDR1 | (ECC_END_ADDR1 << 16), - base + KS2_DDR3_ECC_ADDR_RANGE1_OFFSET); + val1 = readl(addr); + printf("\tECC test: addr 0x%x, read data 0x%x\n", addr, val1);
- puts("Enabling DDR ECC ...\n"); - ddr3_enable_ecc(base, 1); + ddr_check_ecc_status();
- value1 = __raw_readl(address); - printf("ECC err test, addr 0x%x, read data 0x%x\n", address, value1); + debug("Enabling D-cache back after ECC test\n"); + enable_caches(); +#endif
- ddr3_check_ecc_int(base); return 0; }
+static int is_addr_valid(u32 addr) +{ +#ifndef CONFIG_ARCH_KEYSTONE + struct emif_reg_struct *emif = (struct emif_reg_struct *)EMIF1_BASE; + u32 start_addr, end_addr, range, ecc_ctrl; + + ecc_ctrl = readl(&emif->emif_ecc_ctrl_reg); + + printf("%s: emif1_base = 0x%x, Ecc ctrl = 0x%x \n", __func__, EMIF1_BASE, ecc_ctrl); + + /* Check in ecc address range 1 */ + if (ecc_ctrl & EMIF_ECC_REG_ECC_ADDR_RGN_1_EN_MASK) { + range = readl(&emif->emif_ecc_address_range_1); + start_addr = ((range & EMIF_ECC_REG_ECC_START_ADDR_MASK) << 16) + + CONFIG_SYS_SDRAM_BASE; + end_addr = start_addr + (range & EMIF_ECC_REG_ECC_END_ADDR_MASK) + + 0xFFFF; + if ((addr >= start_addr) && (addr <= end_addr)) + /* addr within ecc address range 1 */ + return 1; + } + + /* Check in ecc address range 2 */ + if (ecc_ctrl & EMIF_ECC_REG_ECC_ADDR_RGN_2_EN_MASK) { + range = readl(&emif->emif_ecc_address_range_2); + start_addr = ((range & EMIF_ECC_REG_ECC_START_ADDR_MASK) << 16) + + CONFIG_SYS_SDRAM_BASE; + end_addr = start_addr + (range & EMIF_ECC_REG_ECC_END_ADDR_MASK) + + 0xFFFF; + if ((addr >= start_addr) && (addr <= end_addr)) + /* addr within ecc address range 2 */ + return 1; + } + + return 0; +#else + if ((addr < CONFIG_SYS_SDRAM_BASE) || + (addr > (CONFIG_SYS_SDRAM_BASE + CONFIG_MAX_RAM_BANK_SIZE - 1))) { + puts("Invalid address!\n"); + return 1; + } + + return 1; +#endif +} + +static int is_ecc_enabled(void) +{ + struct emif_reg_struct *emif = (struct emif_reg_struct *)EMIF1_BASE; + u32 ecc_ctrl = readl(&emif->emif_ecc_ctrl_reg); + + return (ecc_ctrl & EMIF_ECC_CTRL_REG_ECC_EN_MASK) && + (ecc_ctrl & EMIF_ECC_REG_RMW_EN_MASK); +} + static int do_ddr_test(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { u32 start_addr, end_addr, size, ecc_err;
if ((argc == 4) && (strncmp(argv[1], "ecc_err", 8) == 0)) { - if (!ddr3_ecc_support_rmw(KS2_DDR3A_EMIF_CTRL_BASE)) { - puts("ECC RMW isn't supported for this SOC\n"); - return 1; + if (!is_ecc_enabled()) { + puts("ECC not enabled. Please Enable ECC any try again\n"); + return CMD_RET_FAILURE; }
start_addr = simple_strtoul(argv[2], NULL, 16); ecc_err = simple_strtoul(argv[3], NULL, 16);
- if ((start_addr < CONFIG_SYS_SDRAM_BASE) || - (start_addr > (CONFIG_SYS_SDRAM_BASE + - CONFIG_MAX_RAM_BANK_SIZE - 1))) { - puts("Invalid address!\n"); - return cmd_usage(cmdtp); + if (!is_addr_valid(start_addr)) { + puts("Invalid address. Please enter ECC supported address!\n"); + return CMD_RET_FAILURE; }
- ddr_memory_ecc_err(KS2_DDR3A_EMIF_CTRL_BASE, - start_addr, ecc_err); + ddr_memory_ecc_err(start_addr, ecc_err); return 0; }
@@ -216,10 +318,10 @@ static int do_ddr_test(cmd_tbl_t *cmdtp,
if ((start_addr < CONFIG_SYS_SDRAM_BASE) || (start_addr > (CONFIG_SYS_SDRAM_BASE + - CONFIG_MAX_RAM_BANK_SIZE - 1)) || + get_effective_memsize() - 1)) || (end_addr < CONFIG_SYS_SDRAM_BASE) || (end_addr > (CONFIG_SYS_SDRAM_BASE + - CONFIG_MAX_RAM_BANK_SIZE - 1)) || (start_addr >= end_addr)) { + get_effective_memsize() - 1)) || (start_addr >= end_addr)) { puts("Invalid start or end address!\n"); return cmd_usage(cmdtp); }
DRA762 comes in two packages: - ABZ: Pin compatible package with DRA742 with DDR@1333MHz - ACD: High performance(OPP_PLUS) package with new IPs
Both the above packages uses the same IDCODE hence needs to differentiate using package information in DIE_ID_2. Add support for the same. Also update clock, ddr, emif information.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/arch-omap5/omap.h | 3 +++ arch/arm/include/asm/arch-omap5/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 14 ++++++++++++ arch/arm/mach-omap2/hwinit-common.c | 33 +++++++++++++++++++++++++++-- arch/arm/mach-omap2/omap5/hw_data.c | 4 ++++ arch/arm/mach-omap2/omap5/hwinit.c | 21 ++++++++++++++++++ arch/arm/mach-omap2/omap5/sdram.c | 4 ++++ board/ti/dra7xx/evm.c | 17 +++++++++++---- 8 files changed, 91 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-omap5/omap.h b/arch/arm/include/asm/arch-omap5/omap.h index 81feac704a..f8e7f06442 100644 --- a/arch/arm/include/asm/arch-omap5/omap.h +++ b/arch/arm/include/asm/arch-omap5/omap.h @@ -66,6 +66,9 @@ #define DRA722_CONTROL_ID_CODE_ES2_0 0x1B9BC02F #define DRA722_CONTROL_ID_CODE_ES2_1 0x2B9BC02F
+#define DRA762_ABZ_PACKAGE 0x2 +#define DRA762_ACD_PACKAGE 0x3 + /* UART */ #define UART1_BASE (OMAP54XX_L4_PER_BASE + 0x6a000) #define UART2_BASE (OMAP54XX_L4_PER_BASE + 0x6c000) diff --git a/arch/arm/include/asm/arch-omap5/sys_proto.h b/arch/arm/include/asm/arch-omap5/sys_proto.h index ab0e7fae9c..a6b3557b50 100644 --- a/arch/arm/include/asm/arch-omap5/sys_proto.h +++ b/arch/arm/include/asm/arch-omap5/sys_proto.h @@ -62,6 +62,7 @@ u32 omap_sdram_size(void); u32 cortex_rev(void); void save_omap_boot_params(void); void init_omap_revision(void); +void init_package_revision(void); void do_io_settings(void); void sri2c_init(void); int omap_vc_bypass_send_value(u8 sa, u8 reg_addr, u8 reg_data); diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 481e9389c4..9624fb81fa 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -743,6 +743,18 @@ static inline u8 is_dra76x(void) extern u32 *const omap_si_rev; return (*omap_si_rev & 0xFFF00000) == DRA76X; } + +static inline u8 is_dra76x_abz(void) +{ + extern u32 *const omap_si_rev; + return (*omap_si_rev & 0xF) == 2; +} + +static inline u8 is_dra76x_acd(void) +{ + extern u32 *const omap_si_rev; + return (*omap_si_rev & 0xF) == 3; +} #endif
/* @@ -778,6 +790,8 @@ static inline u8 is_dra76x(void) #define DRA722_ES2_0 0x07220200 #define DRA722_ES2_1 0x07220210
+#define DRA762_ABZ_ES1_0 0x07620102 +#define DRA762_ACD_ES1_0 0x07620103 /* * silicon device type * Moving to common from cpu.h, since it is shared by various omap devices diff --git a/arch/arm/mach-omap2/hwinit-common.c b/arch/arm/mach-omap2/hwinit-common.c index 56890a0c54..4f491e60f2 100644 --- a/arch/arm/mach-omap2/hwinit-common.c +++ b/arch/arm/mach-omap2/hwinit-common.c @@ -66,7 +66,7 @@ static void omap_rev_string(void) u32 major_rev = (omap_rev & 0x00000F00) >> 8; u32 minor_rev = (omap_rev & 0x000000F0) >> 4;
- const char *sec_s; + const char *sec_s, *package = NULL;
switch (get_device_type()) { case TST_DEVICE: @@ -85,11 +85,29 @@ static void omap_rev_string(void) sec_s = "?"; }
+#if defined(CONFIG_DRA7XX) + if (is_dra76x()) { + switch (omap_rev & 0xF) { + case DRA762_ABZ_PACKAGE: + package = "ABZ"; + break; + case DRA762_ACD_PACKAGE: + default: + package = "ACD"; + break; + } + } +#endif + if (soc_variant) printf("OMAP"); else printf("DRA"); - printf("%x-%s ES%x.%x\n", omap_variant, sec_s, major_rev, minor_rev); + printf("%x-%s ES%x.%x", omap_variant, sec_s, major_rev, minor_rev); + if (package) + printf(" %s package\n", package); + else + puts("\n"); }
#ifdef CONFIG_SPL_BUILD @@ -127,6 +145,16 @@ void s_init(void) { }
+/** + * init_package_revision() - Initialize package revision + * + * Function to get the pacakage information. This is expected to be + * overridden in the SoC family file where desired. + */ +void __weak init_package_revision(void) +{ +} + /** * early_system_init - Does Early system initialization. * @@ -146,6 +174,7 @@ void early_system_init(void) { init_omap_revision(); hw_data_init(); + init_package_revision();
#ifdef CONFIG_SPL_BUILD if (warm_reset()) diff --git a/arch/arm/mach-omap2/omap5/hw_data.c b/arch/arm/mach-omap2/omap5/hw_data.c index 3bdb114bb6..bb05e1920b 100644 --- a/arch/arm/mach-omap2/omap5/hw_data.c +++ b/arch/arm/mach-omap2/omap5/hw_data.c @@ -746,6 +746,8 @@ void __weak hw_data_init(void) *ctrl = &omap5_ctrl; break;
+ case DRA762_ABZ_ES1_0: + case DRA762_ACD_ES1_0: case DRA762_ES1_0: *prcm = &dra7xx_prcm; *dplls_data = &dra76x_dplls; @@ -792,6 +794,8 @@ void get_ioregs(const struct ctrl_ioregs **regs) case DRA752_ES1_1: case DRA752_ES2_0: case DRA762_ES1_0: + case DRA762_ACD_ES1_0: + case DRA762_ABZ_ES1_0: *regs = &ioregs_dra7xx_es1; break; case DRA722_ES1_0: diff --git a/arch/arm/mach-omap2/omap5/hwinit.c b/arch/arm/mach-omap2/omap5/hwinit.c index 14a35dd284..57f2a8664c 100644 --- a/arch/arm/mach-omap2/omap5/hwinit.c +++ b/arch/arm/mach-omap2/omap5/hwinit.c @@ -389,6 +389,27 @@ void init_omap_revision(void) init_cpu_configuration(); }
+void init_package_revision(void) +{ + unsigned int die_id[4] = { 0 }; + u8 package; + + omap_die_id(die_id); + package = (die_id[2] >> 16) & 0x3; + + if (is_dra76x()) { + switch (package) { + case DRA762_ABZ_PACKAGE: + *omap_si_rev = DRA762_ABZ_ES1_0; + break; + case DRA762_ACD_PACKAGE: + default: + *omap_si_rev = DRA762_ACD_ES1_0; + break; + } + } +} + void omap_die_id(unsigned int *die_id) { die_id[0] = readl((*ctrl)->control_std_fuse_die_id_0); diff --git a/arch/arm/mach-omap2/omap5/sdram.c b/arch/arm/mach-omap2/omap5/sdram.c index 8fb962e39d..c0e0e0888c 100644 --- a/arch/arm/mach-omap2/omap5/sdram.c +++ b/arch/arm/mach-omap2/omap5/sdram.c @@ -481,6 +481,8 @@ void __weak emif_get_ext_phy_ctrl_const_regs(u32 emif_nr, *size = ARRAY_SIZE(dra_ddr3_ext_phy_ctrl_const_base_666MHz); break; case DRA762_ES1_0: + case DRA762_ABZ_ES1_0: + case DRA762_ACD_ES1_0: case DRA722_ES2_0: case DRA722_ES2_1: *regs = dra_ddr3_ext_phy_ctrl_const_base_666MHz_es2; @@ -711,6 +713,8 @@ const struct read_write_regs *get_bug_regs(u32 *iterations) *iterations = sizeof(omap5_bug_00339_regs)/ sizeof(omap5_bug_00339_regs[0]); break; + case DRA762_ABZ_ES1_0: + case DRA762_ACD_ES1_0: case DRA762_ES1_0: case DRA752_ES1_0: case DRA752_ES1_1: diff --git a/board/ti/dra7xx/evm.c b/board/ti/dra7xx/evm.c index 6bcfa48231..41868822b1 100644 --- a/board/ti/dra7xx/evm.c +++ b/board/ti/dra7xx/evm.c @@ -285,6 +285,8 @@ void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) break; } break; + case DRA762_ABZ_ES1_0: + case DRA762_ACD_ES1_0: case DRA762_ES1_0: if (emif_nr == 1) *regs = &emif_1_regs_ddr3_666_mhz_1cs_dra76; @@ -347,6 +349,8 @@ void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) ram_size = board_ti_get_emif_size();
switch (omap_revision()) { + case DRA762_ABZ_ES1_0: + case DRA762_ACD_ES1_0: case DRA762_ES1_0: case DRA752_ES1_0: case DRA752_ES1_1: @@ -655,8 +659,10 @@ int board_late_init(void) name = "dra71x"; else name = "dra72x"; - } else if (is_dra76x()) { - name = "dra76x"; + } else if (is_dra76x_abz()) { + name = "dra76x_abz"; + } else if (is_dra76x_acd()) { + name = "dra76x_acd"; } else { name = "dra7xx"; } @@ -793,6 +799,7 @@ void recalibrate_iodelay(void) iodelay = dra742_es1_1_iodelay_cfg_array; niodelays = ARRAY_SIZE(dra742_es1_1_iodelay_cfg_array); break; + case DRA762_ACD_ES1_0: case DRA762_ES1_0: pads = dra76x_core_padconf_array; npads = ARRAY_SIZE(dra76x_core_padconf_array); @@ -801,6 +808,7 @@ void recalibrate_iodelay(void) break; default: case DRA752_ES2_0: + case DRA762_ABZ_ES1_0: pads = dra74x_core_padconf_array; npads = ARRAY_SIZE(dra74x_core_padconf_array); iodelay = dra742_es2_0_iodelay_cfg_array; @@ -1125,9 +1133,10 @@ int board_fit_config_name_match(const char *name) } else if (!strcmp(name, "dra72-evm")) { return 0; } - } else if (is_dra76x() && !strcmp(name, "dra76-evm")) { + } else if (is_dra76x_acd() && !strcmp(name, "dra76-evm")) { return 0; - } else if (!is_dra72x() && !is_dra76x() && !strcmp(name, "dra7-evm")) { + } else if (!is_dra72x() && !is_dra76x_acd() && + !strcmp(name, "dra7-evm")) { return 0; }
am574x-idk is a board based on TI's am574 processor Add eeprom support.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/board.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index f79aefd400..082346d2b1 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -43,6 +43,7 @@ #define board_is_am572x_evm_reva3() \ (board_ti_is("AM572PM_") && \ !strncmp("A.30", board_ti_get_rev(), 3)) +#define board_is_am574x_idk() board_ti_is("AM574IDK") #define board_is_am572x_idk() board_ti_is("AM572IDK") #define board_is_am571x_idk() board_ti_is("AM571IDK")
@@ -481,6 +482,8 @@ void do_board_detect(void) bname = "BeagleBoard X15"; else if (board_is_am572x_evm()) bname = "AM572x EVM"; + else if (board_is_am574x_idk()) + bname = "AM574x IDK"; else if (board_is_am572x_idk()) bname = "AM572x IDK"; else if (board_is_am571x_idk()) @@ -513,6 +516,8 @@ static void setup_board_eeprom_env(void) name = "am57xx_evm_reva3"; else name = "am57xx_evm"; + } else if (board_is_am574x_idk()) { + name = "am574x_idk"; } else if (board_is_am572x_idk()) { name = "am572x_idk"; } else if (board_is_am571x_idk()) {
Update prcm, voltages support for am574x-idk.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/include/asm/omap_common.h | 1 + board/ti/am57xx/board.c | 9 ++++++--- 2 files changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index 9624fb81fa..5710136e88 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -597,6 +597,7 @@ extern struct prcm_regs const dra7xx_prcm; extern struct dplls const **dplls_data; extern struct dplls dra7xx_dplls; extern struct dplls dra72x_dplls; +extern struct dplls dra76x_dplls; extern struct vcores_data const **omap_vcores; extern const u32 sys_clk_array[8]; extern struct omap_sys_ctrl_regs const **ctrl; diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 082346d2b1..2d14ae54fe 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -535,7 +535,7 @@ invalid_eeprom:
void vcores_init(void) { - if (board_is_am572x_idk()) + if (board_is_am572x_idk() || board_is_am574x_idk()) *omap_vcores = &am572x_idk_volts; else if (board_is_am571x_idk()) *omap_vcores = &am571x_idk_volts; @@ -548,6 +548,8 @@ void hw_data_init(void) *prcm = &dra7xx_prcm; if (is_dra72x()) *dplls_data = &dra72x_dplls; + else if (is_dra76x()) + *dplls_data = &dra76x_dplls; else *dplls_data = &dra7xx_dplls; *ctrl = &dra7xx_ctrl; @@ -688,7 +690,7 @@ void recalibrate_iodelay(void) int pconf_sz, iod_sz, delta_iod_sz = 0; int ret;
- if (board_is_am572x_idk()) { + if (board_is_am572x_idk() || board_is_am574x_idk()) { pconf = core_padconf_array_essential_am572x_idk; pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am572x_idk); iod = iodelay_cfg_array_am572x_idk; @@ -995,7 +997,8 @@ int board_eth_init(bd_t *bis) writel(ctrl_val, (*ctrl)->control_core_control_io1);
/* The phy address for the AM57xx IDK are different than x15 */ - if (board_is_am572x_idk() || board_is_am571x_idk()) { + if (board_is_am572x_idk() || board_is_am571x_idk() || + board_is_am574x_idk()) { cpsw_data.slave_data[0].phy_addr = 0; cpsw_data.slave_data[1].phy_addr = 1; }
AM574x-idk has the following DDR parts attached: EMIF1: MT41K256M16HA (1GB with ECC) EMIF2: MT41K256M16HA (1GB without ECC)
Enabling 2GB DDR without interleaving between EMIFs. And enabling ECC on EMIF1.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com Signed-off-by: Krunal Bhargav k-bhargav@ti.com --- board/ti/am57xx/board.c | 47 ++++++++++++++++++++++++++++++++++++++++++++--- 1 file changed, 44 insertions(+), 3 deletions(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 2d14ae54fe..1377c7b1fe 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -89,10 +89,18 @@ static const struct dmm_lisa_map_regs am571x_idk_lisa_regs = { .is_ma_present = 0x1 };
+static const struct dmm_lisa_map_regs am574x_idk_lisa_regs = { + .dmm_lisa_map_2 = 0xc0600200, + .dmm_lisa_map_3 = 0x80600100, + .is_ma_present = 0x1 +}; + void emif_get_dmm_regs(const struct dmm_lisa_map_regs **dmm_lisa_regs) { if (board_is_am571x_idk()) *dmm_lisa_regs = &am571x_idk_lisa_regs; + else if (board_is_am574x_idk()) + *dmm_lisa_regs = &am574x_idk_lisa_regs; else *dmm_lisa_regs = &beagle_x15_lisa_regs; } @@ -231,8 +239,8 @@ static const struct emif_regs am571x_emif1_ddr3_666mhz_emif_regs = { .ref_ctrl = 0x0000514d, .ref_ctrl_final = 0x0000144a, .sdram_tim1 = 0xd333887c, - .sdram_tim2 = 0x40b37fe3, - .sdram_tim3 = 0x409f8ada, + .sdram_tim2 = 0x30b37fe3, + .sdram_tim3 = 0x409f8ad8, .read_idle_ctrl = 0x00050000, .zq_config = 0x5007190b, .temp_alert_config = 0x00000000, @@ -249,17 +257,50 @@ static const struct emif_regs am571x_emif1_ddr3_666mhz_emif_regs = { .emif_rd_wr_exec_thresh = 0x00000305 };
+static const struct emif_regs am574x_emif1_ddr3_666mhz_emif_ecc_regs = { + .sdram_config_init = 0x61863332, + .sdram_config = 0x61863332, + .sdram_config2 = 0x08000000, + .ref_ctrl = 0x0000514d, + .ref_ctrl_final = 0x0000144a, + .sdram_tim1 = 0xd333887c, + .sdram_tim2 = 0x30b37fe3, + .sdram_tim3 = 0x409f8ad8, + .read_idle_ctrl = 0x00050000, + .zq_config = 0x5007190b, + .temp_alert_config = 0x00000000, + .emif_ddr_phy_ctlr_1_init = 0x0024400f, + .emif_ddr_phy_ctlr_1 = 0x0e24400f, + .emif_ddr_ext_phy_ctrl_1 = 0x10040100, + .emif_ddr_ext_phy_ctrl_2 = 0x00910091, + .emif_ddr_ext_phy_ctrl_3 = 0x00950095, + .emif_ddr_ext_phy_ctrl_4 = 0x009b009b, + .emif_ddr_ext_phy_ctrl_5 = 0x009e009e, + .emif_rd_wr_lvl_rmp_win = 0x00000000, + .emif_rd_wr_lvl_rmp_ctl = 0x80000000, + .emif_rd_wr_lvl_ctl = 0x00000000, + .emif_rd_wr_exec_thresh = 0x00000305, + .emif_ecc_ctrl_reg = 0xD0000001, + .emif_ecc_address_range_1 = 0x3FFF0000, + .emif_ecc_address_range_2 = 0x00000000 +}; + void emif_get_reg_dump(u32 emif_nr, const struct emif_regs **regs) { switch (emif_nr) { case 1: if (board_is_am571x_idk()) *regs = &am571x_emif1_ddr3_666mhz_emif_regs; + else if (board_is_am574x_idk()) + *regs = &am574x_emif1_ddr3_666mhz_emif_ecc_regs; else *regs = &beagle_x15_emif1_ddr3_532mhz_emif_regs; break; case 2: - *regs = &beagle_x15_emif2_ddr3_532mhz_emif_regs; + if (board_is_am574x_idk()) + *regs = &am571x_emif1_ddr3_666mhz_emif_regs; + else + *regs = &beagle_x15_emif2_ddr3_532mhz_emif_regs; break; } }
Hi Lokesh,
- .dmm_lisa_map_2 = 0xc0600200,
- .dmm_lisa_map_3 = 0x80600100,
- .is_ma_present = 0x1
- else if (board_is_am574x_idk())
else *dmm_lisa_regs = &beagle_x15_lisa_regs;*dmm_lisa_regs = &am574x_idk_lisa_regs;
- .sdram_tim2 = 0x30b37fe3,
- .sdram_tim3 = 0x409f8ad8, .read_idle_ctrl = 0x00050000, .zq_config = 0x5007190b, .temp_alert_config = 0x00000000,
- .sdram_config_init = 0x61863332,
- .sdram_config = 0x61863332,
- .sdram_config2 = 0x08000000,
- .ref_ctrl = 0x0000514d,
- .ref_ctrl_final = 0x0000144a,
- .sdram_tim1 = 0xd333887c,
- .read_idle_ctrl = 0x00050000,
- .zq_config = 0x5007190b,
- .temp_alert_config = 0x00000000,
- .emif_ddr_phy_ctlr_1_init = 0x0024400f,
- .emif_ddr_phy_ctlr_1 = 0x0e24400f,
- .emif_ddr_ext_phy_ctrl_1 = 0x10040100,
- .emif_ddr_ext_phy_ctrl_2 = 0x00910091,
- .emif_ddr_ext_phy_ctrl_3 = 0x00950095,
- .emif_ddr_ext_phy_ctrl_4 = 0x009b009b,
- .emif_ddr_ext_phy_ctrl_5 = 0x009e009e,
- .emif_rd_wr_lvl_rmp_win = 0x00000000,
- .emif_rd_wr_lvl_rmp_ctl = 0x80000000,
- .emif_rd_wr_lvl_ctl = 0x00000000,
- .emif_rd_wr_exec_thresh = 0x00000305,
- .emif_ecc_ctrl_reg = 0xD0000001,
- .emif_ecc_address_range_1 = 0x3FFF0000,
- .emif_ecc_address_range_2 = 0x00000000
I'm wondering if it would be possible to:
Embed this memory setup (even as binary blob) to SPL FIT -> Those values are generated from TI supplied excel sheet (when memory details are provided).
Pros: ----
- Since the same EMIF controller is used, one could only adjust the binary blob, when new memory (faster, slower, from other manufacturer) is used in the product.
- There would be no need to add such code to the board file.
*regs =
else
*regs =
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Hi Lukas,
On Monday 18 December 2017 04:46 PM, Lukasz Majewski wrote:
Hi Lokesh,
Pros:
yeah, ddr is not the only thing that comes in this bucket, PMIC data as well can be also made in similar way. I mean all the board related information can be moved out. But then the binary size will still remain the same. Also, we will need a new driver to parse these new binary formats.
As of now, the ddr excel sheet outputs the data in the $patch format, so still sticking to this format.
Yeah, i agree that it would be nice if we can come up with the separate binary for all board related info(i guess DT can be re used here).
*regs =
else
*regs =
Lukasz Majewski
Hi Lokesh,
Hi Lukas,
Hi Lokesh,
Pros:
I think that the EMIF controller configuration is a bit special.
As you pointed out - for the whole AM57xx family one EMIF controller type is used.
The goal here would be to not make the binary smaller, but reducing the maintanence effort.
Example use case - company X has a product. They are using single u-boot (with SPL and dts). The only thing, which they need to change is the data needed for setting up proper memory configuration (DDR2/DDR3, speed - 1500, 1333, ECC enabled/disabled, module size, etc). This all is done in EMIF.
With separate EMIF blob configuration they don't need to rebuild u-boot - they only change memory configuration binary data.
This data has a separate room in the non-volatile memory (e.g. SPI-NOR flash).
EMIF configuration data is IIRC 128 B at most. It is even possible to copy 1:1 the binary data to EMIF (as it is now done in the u-boot code).
Hence, the "driver" would boil down to "memcpy".
As stated before, those Ctrl+C and Ctrl+V data are then copied (in for loop) to the EMIF registers.
Why not wrap EMIF binary data to FIT, store on non-volatile memory and on each reset read it and "just" copy this data to EMIF? As fallback we can use the "from excel" structure.
Not all board related info - just EMIF.
DT is not an option here - it would require re-flashing u-boot binary.
*regs =
*regs =
else
*regs =
Lukasz Majewski
Lukasz Majewski
Hi Lukas,
Sorry for the delayed response.
On Tuesday 19 December 2017 03:04 PM, Lukasz Majewski wrote:
Hi Lokesh,
Hi Lukas,
Hi Lokesh,
Pros:
Agreed. This should be doable. Tom, do you have any comments on this new sequence?
On a side node, I will post a v2 for this series with the existing data. Cleanup can be done for the entire supported boards once the above discussion is concluded.
Hi Lokesh,
Hi Lukas,
No problem :-). Happy new year :-)
Hi Lokesh,
Hi Lukas,
Hi Lokesh,
Pros:
Ok. Lets wait for Tom's opinion.
Lukasz Majewski
On Fri, Dec 29, 2017 at 11:47:27AM +0530, Lokesh Vutla wrote:
Hi Lukas,
Hi Lokesh,
Hi Lukas,
Hi Lokesh,
Pros:
Sorry for the delayed response. I'm not sure this is a good idea, at least not without seeing a patch doing it. While a lot of this data is fairly opaque, the structs that say field X is value Y is helpful at times when debugging the odd problem. And there's always the programming sequence issues as well. So, I guess I'd have to see a patch where moving in this direction really does make life easier / cleaner to be convinced it's a good idea. Thanks!
Update the board pinmux for AM574x-IDK board using latest PMT[1] and the board files named am574x_idk_v1p3b_sr2p0 that were auto generated on 13th October, 2017 by "Ahmad Rashed a-rashed@ti.com".
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- board/ti/am57xx/board.c | 7 +- board/ti/am57xx/mux_data.h | 299 +++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 305 insertions(+), 1 deletion(-)
diff --git a/board/ti/am57xx/board.c b/board/ti/am57xx/board.c index 1377c7b1fe..8862ee932c 100644 --- a/board/ti/am57xx/board.c +++ b/board/ti/am57xx/board.c @@ -731,11 +731,16 @@ void recalibrate_iodelay(void) int pconf_sz, iod_sz, delta_iod_sz = 0; int ret;
- if (board_is_am572x_idk() || board_is_am574x_idk()) { + if (board_is_am572x_idk()) { pconf = core_padconf_array_essential_am572x_idk; pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am572x_idk); iod = iodelay_cfg_array_am572x_idk; iod_sz = ARRAY_SIZE(iodelay_cfg_array_am572x_idk); + } else if (board_is_am574x_idk()) { + pconf = core_padconf_array_essential_am574x_idk; + pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am574x_idk); + iod = iodelay_cfg_array_am574x_idk; + iod_sz = ARRAY_SIZE(iodelay_cfg_array_am574x_idk); } else if (board_is_am571x_idk()) { pconf = core_padconf_array_essential_am571x_idk; pconf_sz = ARRAY_SIZE(core_padconf_array_essential_am571x_idk); diff --git a/board/ti/am57xx/mux_data.h b/board/ti/am57xx/mux_data.h index b4a71bd7c8..a48f681840 100644 --- a/board/ti/am57xx/mux_data.h +++ b/board/ti/am57xx/mux_data.h @@ -298,6 +298,226 @@ const struct pad_conf_entry core_padconf_array_delta_x15_sr2_0[] = { {VOUT1_D23, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d23.vout1_d23 */ };
+const struct pad_conf_entry core_padconf_array_essential_am574x_idk[] = { + {GPMC_A0, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a0.vin4b_d0 */ + {GPMC_A1, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a1.vin4b_d1 */ + {GPMC_A2, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a2.vin4b_d2 */ + {GPMC_A3, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a3.vin4b_d3 */ + {GPMC_A4, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a4.vin4b_d4 */ + {GPMC_A5, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a5.vin4b_d5 */ + {GPMC_A6, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a6.vin4b_d6 */ + {GPMC_A7, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a7.vin4b_d7 */ + {GPMC_A8, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a8.vin4b_hsync1 */ + {GPMC_A9, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a9.vin4b_vsync1 */ + {GPMC_A10, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a10.vin4b_clk1 */ + {GPMC_A11, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a11.vin4b_de1 */ + {GPMC_A12, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a12.vin4b_fld1 */ + {GPMC_A13, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a13.qspi1_rtclk */ + {GPMC_A14, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a14.qspi1_d3 */ + {GPMC_A15, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a15.qspi1_d2 */ + {GPMC_A16, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a16.qspi1_d0 */ + {GPMC_A17, (M1 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a17.qspi1_d1 */ + {GPMC_A18, (M1 | PIN_OUTPUT | MANUAL_MODE)}, /* gpmc_a18.qspi1_sclk */ + {GPMC_A19, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a19.mmc2_dat4 */ + {GPMC_A20, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a20.mmc2_dat5 */ + {GPMC_A21, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a21.mmc2_dat6 */ + {GPMC_A22, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a22.mmc2_dat7 */ + {GPMC_A23, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a23.mmc2_clk */ + {GPMC_A24, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a24.mmc2_dat0 */ + {GPMC_A25, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a25.mmc2_dat1 */ + {GPMC_A26, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a26.mmc2_dat2 */ + {GPMC_A27, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_a27.mmc2_dat3 */ + {GPMC_CS1, (M1 | PIN_INPUT_PULLUP)}, /* gpmc_cs1.mmc2_cmd */ + {GPMC_CS2, (M1 | PIN_OUTPUT | MANUAL_MODE)}, /* gpmc_cs2.qspi1_cs0 */ + {VIN1A_D5, (M14 | PIN_OUTPUT)}, /* vin1a_d5.gpio3_9 */ + {VIN1A_D6, (M14 | PIN_OUTPUT)}, /* vin1a_d6.gpio3_10 */ + {VIN1A_D7, (M14 | PIN_OUTPUT)}, /* vin1a_d7.gpio3_11 */ + {VIN1A_D8, (M14 | PIN_OUTPUT)}, /* vin1a_d8.gpio3_12 */ + {VIN1A_D10, (M14 | PIN_INPUT_PULLDOWN)}, /* vin1a_d10.gpio3_14 */ + {VIN1A_D12, (M14 | PIN_INPUT)}, /* vin1a_d12.gpio3_16 */ + {VIN1A_D13, (M14 | PIN_OUTPUT)}, /* vin1a_d13.gpio3_17 */ + {VIN1A_D14, (M14 | PIN_OUTPUT)}, /* vin1a_d14.gpio3_18 */ + {VIN1A_D15, (M14 | PIN_OUTPUT)}, /* vin1a_d15.gpio3_19 */ + {VIN1A_D17, (M14 | PIN_OUTPUT)}, /* vin1a_d17.gpio3_21 */ + {VIN1A_D18, (M14 | PIN_OUTPUT_PULLDOWN)}, /* vin1a_d18.gpio3_22 */ + {VIN1A_D19, (M14 | PIN_OUTPUT_PULLUP)}, /* vin1a_d19.gpio3_23 */ + {VIN1A_D22, (M14 | PIN_INPUT)}, /* vin1a_d22.gpio3_26 */ + {VIN2A_CLK0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_clk0.gpio3_28 */ + {VIN2A_DE0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_de0.gpio3_29 */ + {VIN2A_FLD0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_fld0.gpio3_30 */ + {VIN2A_HSYNC0, (M14 | PIN_INPUT_PULLUP)}, /* vin2a_hsync0.gpio3_31 */ + {VIN2A_VSYNC0, (M14 | PIN_INPUT)}, /* vin2a_vsync0.gpio4_0 */ + {VIN2A_D0, (M11 | PIN_INPUT)}, /* vin2a_d0.pr1_uart0_rxd */ + {VIN2A_D1, (M11 | PIN_OUTPUT)}, /* vin2a_d1.pr1_uart0_txd */ + {VIN2A_D2, (M10 | PIN_OUTPUT)}, /* vin2a_d2.eCAP1_in_PWM1_out */ + {VIN2A_D3, (M11 | PIN_INPUT_PULLDOWN)}, /* vin2a_d3.pr1_edc_latch0_in */ + {VIN2A_D4, (M11 | PIN_OUTPUT)}, /* vin2a_d4.pr1_edc_sync0_out */ + {VIN2A_D5, (M13 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d5.pr1_pru1_gpo2 */ + {VIN2A_D10, (M11 | PIN_OUTPUT_PULLDOWN)}, /* vin2a_d10.pr1_mdio_mdclk */ + {VIN2A_D11, (M11 | PIN_INPUT)}, /* vin2a_d11.pr1_mdio_data */ + {VIN2A_D12, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d12.rgmii1_txc */ + {VIN2A_D13, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d13.rgmii1_txctl */ + {VIN2A_D14, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d14.rgmii1_txd3 */ + {VIN2A_D15, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d15.rgmii1_txd2 */ + {VIN2A_D16, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d16.rgmii1_txd1 */ + {VIN2A_D17, (M3 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d17.rgmii1_txd0 */ + {VIN2A_D18, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d18.rgmii1_rxc */ + {VIN2A_D19, (M3 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* vin2a_d19.rgmii1_rxctl */ + {VIN2A_D20, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d20.rgmii1_rxd3 */ + {VIN2A_D21, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d21.rgmii1_rxd2 */ + {VIN2A_D22, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d22.rgmii1_rxd1 */ + {VIN2A_D23, (M3 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* vin2a_d23.rgmii1_rxd0 */ + {VOUT1_CLK, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_clk.vout1_clk */ + {VOUT1_DE, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_de.vout1_de */ + {VOUT1_FLD, (M14 | PIN_OUTPUT)}, /* vout1_fld.gpio4_21 */ + {VOUT1_HSYNC, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_hsync.vout1_hsync */ + {VOUT1_VSYNC, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_vsync.vout1_vsync */ + {VOUT1_D0, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d0.vout1_d0 */ + {VOUT1_D1, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d1.vout1_d1 */ + {VOUT1_D2, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d2.vout1_d2 */ + {VOUT1_D3, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d3.vout1_d3 */ + {VOUT1_D4, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d4.vout1_d4 */ + {VOUT1_D5, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d5.vout1_d5 */ + {VOUT1_D6, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d6.vout1_d6 */ + {VOUT1_D7, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d7.vout1_d7 */ + {VOUT1_D8, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d8.vout1_d8 */ + {VOUT1_D9, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d9.vout1_d9 */ + {VOUT1_D10, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d10.vout1_d10 */ + {VOUT1_D11, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d11.vout1_d11 */ + {VOUT1_D12, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d12.vout1_d12 */ + {VOUT1_D13, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d13.vout1_d13 */ + {VOUT1_D14, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d14.vout1_d14 */ + {VOUT1_D15, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d15.vout1_d15 */ + {VOUT1_D16, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d16.vout1_d16 */ + {VOUT1_D17, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d17.vout1_d17 */ + {VOUT1_D18, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d18.vout1_d18 */ + {VOUT1_D19, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d19.vout1_d19 */ + {VOUT1_D20, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d20.vout1_d20 */ + {VOUT1_D21, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d21.vout1_d21 */ + {VOUT1_D22, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d22.vout1_d22 */ + {VOUT1_D23, (M0 | PIN_OUTPUT | SLEWCONTROL | MANUAL_MODE)}, /* vout1_d23.vout1_d23 */ + {MDIO_MCLK, (M0 | PIN_INPUT_SLEW)}, /* mdio_mclk.mdio_mclk */ + {MDIO_D, (M0 | PIN_INPUT | SLEWCONTROL)}, /* mdio_d.mdio_d */ + {RGMII0_TXC, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txc.rgmii0_txc */ + {RGMII0_TXCTL, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txctl.rgmii0_txctl */ + {RGMII0_TXD3, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd3.rgmii0_txd3 */ + {RGMII0_TXD2, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd2.rgmii0_txd2 */ + {RGMII0_TXD1, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd1.rgmii0_txd1 */ + {RGMII0_TXD0, (M0 | PIN_OUTPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_txd0.rgmii0_txd0 */ + {RGMII0_RXC, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxc.rgmii0_rxc */ + {RGMII0_RXCTL, (M0 | PIN_INPUT_PULLDOWN | MANUAL_MODE)}, /* rgmii0_rxctl.rgmii0_rxctl */ + {RGMII0_RXD3, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd3.rgmii0_rxd3 */ + {RGMII0_RXD2, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd2.rgmii0_rxd2 */ + {RGMII0_RXD1, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd1.rgmii0_rxd1 */ + {RGMII0_RXD0, (M0 | PIN_INPUT_PULLUP | MANUAL_MODE)}, /* rgmii0_rxd0.rgmii0_rxd0 */ + {USB1_DRVVBUS, (M0 | PIN_OUTPUT | SLEWCONTROL)}, /* usb1_drvvbus.usb1_drvvbus */ + {USB2_DRVVBUS, (M0 | PIN_OUTPUT | SLEWCONTROL)}, /* usb2_drvvbus.usb2_drvvbus */ + {GPIO6_14, (M0 | PIN_OUTPUT)}, /* gpio6_14.gpio6_14 */ + {GPIO6_15, (M0 | PIN_OUTPUT)}, /* gpio6_15.gpio6_15 */ + {GPIO6_16, (M0 | PIN_INPUT_PULLUP)}, /* gpio6_16.gpio6_16 */ + {XREF_CLK0, (M11 | PIN_INPUT_PULLDOWN)}, /* xref_clk0.pr2_mii1_col */ + {XREF_CLK1, (M11 | PIN_INPUT_PULLDOWN)}, /* xref_clk1.pr2_mii1_crs */ + {XREF_CLK2, (M14 | PIN_OUTPUT)}, /* xref_clk2.gpio6_19 */ + {XREF_CLK3, (M9 | PIN_OUTPUT_PULLDOWN)}, /* xref_clk3.clkout3 */ + {MCASP1_ACLKX, (M11 | PIN_OUTPUT_PULLDOWN)}, /* mcasp1_aclkx.pr2_mdio_mdclk */ + {MCASP1_FSX, (M11 | PIN_INPUT | SLEWCONTROL)}, /* mcasp1_fsx.pr2_mdio_data */ + {MCASP1_ACLKR, (M14 | PIN_INPUT)}, /* mcasp1_aclkr.gpio5_0 */ + {MCASP1_FSR, (M14 | PIN_INPUT)}, /* mcasp1_fsr.gpio5_1 */ + {MCASP1_AXR0, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr0.pr2_mii0_rxer */ + {MCASP1_AXR1, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr1.pr2_mii_mt0_clk */ + {MCASP1_AXR2, (M14 | PIN_INPUT)}, /* mcasp1_axr2.gpio5_4 */ + {MCASP1_AXR3, (M14 | PIN_INPUT)}, /* mcasp1_axr3.gpio5_5 */ + {MCASP1_AXR4, (M14 | PIN_OUTPUT)}, /* mcasp1_axr4.gpio5_6 */ + {MCASP1_AXR5, (M14 | PIN_OUTPUT)}, /* mcasp1_axr5.gpio5_7 */ + {MCASP1_AXR6, (M14 | PIN_OUTPUT)}, /* mcasp1_axr6.gpio5_8 */ + {MCASP1_AXR7, (M14 | PIN_OUTPUT)}, /* mcasp1_axr7.gpio5_9 */ + {MCASP1_AXR8, (M11 | PIN_OUTPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr8.pr2_mii0_txen */ + {MCASP1_AXR9, (M11 | PIN_OUTPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr9.pr2_mii0_txd3 */ + {MCASP1_AXR10, (M11 | PIN_OUTPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr10.pr2_mii0_txd2 */ + {MCASP1_AXR11, (M11 | PIN_OUTPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr11.pr2_mii0_txd1 */ + {MCASP1_AXR12, (M11 | PIN_OUTPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr12.pr2_mii0_txd0 */ + {MCASP1_AXR13, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp1_axr13.pr2_mii_mr0_clk */ + {MCASP1_AXR14, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr14.pr2_mii0_rxdv */ + {MCASP1_AXR15, (M11 | PIN_INPUT_SLEW)}, /* mcasp1_axr15.pr2_mii0_rxd3 */ + {MCASP2_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp2_aclkx.pr2_mii0_rxd2 */ + {MCASP2_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_fsx.pr2_mii0_rxd1 */ + {MCASP2_AXR2, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_axr2.pr2_mii0_rxd0 */ + {MCASP2_AXR3, (M11 | PIN_INPUT_SLEW)}, /* mcasp2_axr3.pr2_mii0_rxlink */ + {MCASP2_AXR4, (M14 | PIN_INPUT)}, /* mcasp2_axr4.gpio1_4 */ + {MCASP2_AXR5, (M14 | PIN_OUTPUT)}, /* mcasp2_axr5.gpio6_7 */ + {MCASP2_AXR6, (M14 | PIN_OUTPUT)}, /* mcasp2_axr6.gpio2_29 */ + {MCASP2_AXR7, (M14 | PIN_INPUT)}, /* mcasp2_axr7.gpio1_5 */ + {MCASP3_ACLKX, (M11 | PIN_INPUT_PULLDOWN)}, /* mcasp3_aclkx.pr2_mii0_crs */ + {MCASP3_FSX, (M11 | PIN_INPUT_SLEW)}, /* mcasp3_fsx.pr2_mii0_col */ + {MCASP3_AXR0, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp3_axr0.pr2_mii1_rxer */ + {MCASP3_AXR1, (M11 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* mcasp3_axr1.pr2_mii1_rxlink */ + {MCASP4_ACLKX, (M2 | PIN_INPUT)}, /* mcasp4_aclkx.spi3_sclk */ + {MCASP4_FSX, (M2 | PIN_INPUT)}, /* mcasp4_fsx.spi3_d1 */ + {MCASP4_AXR1, (M2 | PIN_INPUT_PULLUP)}, /* mcasp4_axr1.spi3_cs0 */ + {MCASP5_ACLKX, (M13 | PIN_OUTPUT | MANUAL_MODE)}, /* mcasp5_aclkx.pr2_pru1_gpo1 */ + {MCASP5_FSX, (M12 | PIN_INPUT | MANUAL_MODE)}, /* mcasp5_fsx.pr2_pru1_gpi2 */ + {MMC1_CLK, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_clk.mmc1_clk */ + {MMC1_CMD, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_cmd.mmc1_cmd */ + {MMC1_DAT0, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat0.mmc1_dat0 */ + {MMC1_DAT1, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat1.mmc1_dat1 */ + {MMC1_DAT2, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat2.mmc1_dat2 */ + {MMC1_DAT3, (M0 | PIN_INPUT_PULLUP)}, /* mmc1_dat3.mmc1_dat3 */ + {MMC1_SDCD, (M14 | PIN_INPUT | SLEWCONTROL)}, /* mmc1_sdcd.gpio6_27 */ + {MMC1_SDWP, (M14 | PIN_INPUT | SLEWCONTROL)}, /* mmc1_sdwp.gpio6_28 */ + {GPIO6_10, (M11 | PIN_INPUT_PULLUP)}, /* gpio6_10.pr2_mii_mt1_clk */ + {GPIO6_11, (M11 | PIN_OUTPUT_PULLUP)}, /* gpio6_11.pr2_mii1_txen */ + {MMC3_CLK, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_clk.pr2_mii1_txd3 */ + {MMC3_CMD, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_cmd.pr2_mii1_txd2 */ + {MMC3_DAT0, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_dat0.pr2_mii1_txd1 */ + {MMC3_DAT1, (M11 | PIN_OUTPUT_PULLUP)}, /* mmc3_dat1.pr2_mii1_txd0 */ + {MMC3_DAT2, (M11 | PIN_INPUT_PULLUP)}, /* mmc3_dat2.pr2_mii_mr1_clk */ + {MMC3_DAT3, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat3.pr2_mii1_rxdv */ + {MMC3_DAT4, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat4.pr2_mii1_rxd3 */ + {MMC3_DAT5, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat5.pr2_mii1_rxd2 */ + {MMC3_DAT6, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat6.pr2_mii1_rxd1 */ + {MMC3_DAT7, (M11 | PIN_INPUT_PULLDOWN)}, /* mmc3_dat7.pr2_mii1_rxd0 */ + {SPI1_SCLK, (M14 | PIN_OUTPUT)}, /* spi1_sclk.gpio7_7 */ + {SPI1_D1, (M14 | PIN_OUTPUT)}, /* spi1_d1.gpio7_8 */ + {SPI1_D0, (M14 | PIN_OUTPUT)}, /* spi1_d0.gpio7_9 */ + {SPI1_CS0, (M14 | PIN_OUTPUT)}, /* spi1_cs0.gpio7_10 */ + {SPI1_CS1, (M14 | PIN_OUTPUT)}, /* spi1_cs1.gpio7_11 */ + {SPI1_CS2, (M14 | PIN_INPUT_SLEW)}, /* spi1_cs2.gpio7_12 */ + {SPI1_CS3, (M6 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* spi1_cs3.hdmi1_cec */ + {SPI2_SCLK, (M0 | PIN_INPUT)}, /* spi2_sclk.spi2_sclk */ + {SPI2_D1, (M0 | PIN_INPUT | SLEWCONTROL)}, /* spi2_d1.spi2_d1 */ + {SPI2_D0, (M0 | PIN_INPUT | SLEWCONTROL)}, /* spi2_d0.spi2_d0 */ + {SPI2_CS0, (M0 | PIN_INPUT | SLEWCONTROL)}, /* spi2_cs0.spi2_cs0 */ + {DCAN1_TX, (M15 | PULL_UP)}, /* dcan1_tx.safe for dcan1_tx */ + {DCAN1_RX, (M15 | PULL_UP)}, /* dcan1_rx.safe for dcan1_rx */ + {UART1_RXD, (M14 | PIN_OUTPUT | SLEWCONTROL)}, /* uart1_rxd.gpio7_22 */ + {UART1_TXD, (M14 | PIN_OUTPUT | SLEWCONTROL)}, /* uart1_txd.gpio7_23 */ + {UART2_RXD, (M4 | PIN_INPUT)}, /* uart2_rxd.uart2_rxd */ + {UART2_TXD, (M0 | PIN_OUTPUT)}, /* uart2_txd.uart2_txd */ + {UART2_CTSN, (M2 | PIN_INPUT)}, /* uart2_ctsn.uart3_rxd */ + {UART2_RTSN, (M1 | PIN_OUTPUT)}, /* uart2_rtsn.uart3_txd */ + {I2C1_SDA, (M0 | PIN_INPUT)}, /* i2c1_sda.i2c1_sda */ + {I2C1_SCL, (M0 | PIN_INPUT)}, /* i2c1_scl.i2c1_scl */ + {I2C2_SDA, (M1 | PIN_INPUT)}, /* i2c2_sda.hdmi1_ddc_scl */ + {I2C2_SCL, (M1 | PIN_INPUT)}, /* i2c2_scl.hdmi1_ddc_sda */ + {WAKEUP0, (M0 | PIN_INPUT)}, /* Wakeup0.Wakeup0 */ + {WAKEUP1, (M0 | PIN_INPUT)}, /* Wakeup1.Wakeup1 */ + {WAKEUP2, (M0 | PIN_INPUT)}, /* Wakeup2.Wakeup2 */ + {WAKEUP3, (M0 | PIN_INPUT)}, /* Wakeup3.Wakeup3 */ + {ON_OFF, (M0 | PIN_OUTPUT)}, /* on_off.on_off */ + {RTC_PORZ, (M0 | PIN_INPUT)}, /* rtc_porz.rtc_porz */ + {TMS, (M0 | PIN_INPUT_PULLUP)}, /* tms.tms */ + {TDI, (M0 | PIN_INPUT_PULLUP | SLEWCONTROL)}, /* tdi.tdi */ + {TDO, (M0 | PIN_OUTPUT_PULLUP)}, /* tdo.tdo */ + {TCLK, (M0 | PIN_INPUT_PULLUP)}, /* tclk.tclk */ + {TRSTN, (M0 | PIN_INPUT_PULLDOWN)}, /* trstn.trstn */ + {RTCK, (M0 | PIN_OUTPUT_PULLUP)}, /* rtck.rtck */ + {EMU0, (M0 | PIN_INPUT_PULLUP)}, /* emu0.emu0 */ + {EMU1, (M0 | PIN_INPUT_PULLUP)}, /* emu1.emu1 */ + {RESETN, (M0 | PIN_INPUT)}, /* resetn.resetn */ + {NMIN_DSP, (M0 | PIN_INPUT)}, /* nmin_dsp.nmin_dsp */ + {RSTOUTN, (M0 | PIN_OUTPUT)}, /* rstoutn.rstoutn */ +}; + const struct pad_conf_entry core_padconf_array_essential_am572x_idk[] = { {GPMC_A0, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a0.vin4b_d0 */ {GPMC_A1, (M6 | PIN_INPUT | MANUAL_MODE)}, /* gpmc_a1.vin4b_d1 */ @@ -980,6 +1200,85 @@ const struct iodelay_cfg_entry iodelay_cfg_array_x15_sr2_0[] = { {0x0CEC, 2739, 0}, /* CFG_VOUT1_VSYNC_OUT */ };
+const struct iodelay_cfg_entry iodelay_cfg_array_am574x_idk[] = { + {0x0114, 2199, 621}, /* CFG_GPMC_A0_IN */ + {0x0120, 0, 0}, /* CFG_GPMC_A10_IN */ + {0x012C, 2133, 859}, /* CFG_GPMC_A11_IN */ + {0x0138, 2258, 562}, /* CFG_GPMC_A12_IN */ + {0x0144, 0, 0}, /* CFG_GPMC_A13_IN */ + {0x0150, 2149, 1052}, /* CFG_GPMC_A14_IN */ + {0x015C, 2121, 997}, /* CFG_GPMC_A15_IN */ + {0x0168, 2159, 1134}, /* CFG_GPMC_A16_IN */ + {0x0170, 0, 0}, /* CFG_GPMC_A16_OUT */ + {0x0174, 2135, 1085}, /* CFG_GPMC_A17_IN */ + {0x0188, 0, 0}, /* CFG_GPMC_A18_OUT */ + {0x0198, 1989, 612}, /* CFG_GPMC_A1_IN */ + {0x0204, 2218, 912}, /* CFG_GPMC_A2_IN */ + {0x0210, 2168, 963}, /* CFG_GPMC_A3_IN */ + {0x021C, 2196, 813}, /* CFG_GPMC_A4_IN */ + {0x0228, 2082, 782}, /* CFG_GPMC_A5_IN */ + {0x0234, 2098, 407}, /* CFG_GPMC_A6_IN */ + {0x0240, 2343, 585}, /* CFG_GPMC_A7_IN */ + {0x024C, 2030, 685}, /* CFG_GPMC_A8_IN */ + {0x0258, 2116, 832}, /* CFG_GPMC_A9_IN */ + {0x0374, 0, 0}, /* CFG_GPMC_CS2_OUT */ + {0x0590, 1000, 3900}, /* CFG_MCASP5_ACLKX_OUT */ + {0x05AC, 1000, 3800}, /* CFG_MCASP5_FSX_IN */ + {0x06F0, 451, 0}, /* CFG_RGMII0_RXC_IN */ + {0x06FC, 127, 1571}, /* CFG_RGMII0_RXCTL_IN */ + {0x0708, 165, 1178}, /* CFG_RGMII0_RXD0_IN */ + {0x0714, 136, 1302}, /* CFG_RGMII0_RXD1_IN */ + {0x0720, 0, 1520}, /* CFG_RGMII0_RXD2_IN */ + {0x072C, 28, 1690}, /* CFG_RGMII0_RXD3_IN */ + {0x0740, 121, 0}, /* CFG_RGMII0_TXC_OUT */ + {0x074C, 60, 0}, /* CFG_RGMII0_TXCTL_OUT */ + {0x0758, 153, 0}, /* CFG_RGMII0_TXD0_OUT */ + {0x0764, 35, 0}, /* CFG_RGMII0_TXD1_OUT */ + {0x0770, 0, 0}, /* CFG_RGMII0_TXD2_OUT */ + {0x077C, 172, 0}, /* CFG_RGMII0_TXD3_OUT */ + {0x0A70, 147, 0}, /* CFG_VIN2A_D12_OUT */ + {0x0A7C, 110, 0}, /* CFG_VIN2A_D13_OUT */ + {0x0A88, 18, 0}, /* CFG_VIN2A_D14_OUT */ + {0x0A94, 82, 0}, /* CFG_VIN2A_D15_OUT */ + {0x0AA0, 33, 0}, /* CFG_VIN2A_D16_OUT */ + {0x0AAC, 0, 0}, /* CFG_VIN2A_D17_OUT */ + {0x0AB0, 417, 0}, /* CFG_VIN2A_D18_IN */ + {0x0ABC, 156, 843}, /* CFG_VIN2A_D19_IN */ + {0x0AD4, 223, 1413}, /* CFG_VIN2A_D20_IN */ + {0x0AE0, 169, 1415}, /* CFG_VIN2A_D21_IN */ + {0x0AEC, 43, 1150}, /* CFG_VIN2A_D22_IN */ + {0x0AF8, 0, 1210}, /* CFG_VIN2A_D23_IN */ + {0x0B30, 0, 200}, /* CFG_VIN2A_D5_OUT */ + {0x0B9C, 1281, 497}, /* CFG_VOUT1_CLK_OUT */ + {0x0BA8, 379, 0}, /* CFG_VOUT1_D0_OUT */ + {0x0BB4, 441, 0}, /* CFG_VOUT1_D10_OUT */ + {0x0BC0, 461, 0}, /* CFG_VOUT1_D11_OUT */ + {0x0BCC, 1189, 0}, /* CFG_VOUT1_D12_OUT */ + {0x0BD8, 312, 0}, /* CFG_VOUT1_D13_OUT */ + {0x0BE4, 298, 0}, /* CFG_VOUT1_D14_OUT */ + {0x0BF0, 284, 0}, /* CFG_VOUT1_D15_OUT */ + {0x0BFC, 152, 0}, /* CFG_VOUT1_D16_OUT */ + {0x0C08, 216, 0}, /* CFG_VOUT1_D17_OUT */ + {0x0C14, 408, 0}, /* CFG_VOUT1_D18_OUT */ + {0x0C20, 519, 0}, /* CFG_VOUT1_D19_OUT */ + {0x0C2C, 475, 0}, /* CFG_VOUT1_D1_OUT */ + {0x0C38, 316, 0}, /* CFG_VOUT1_D20_OUT */ + {0x0C44, 59, 0}, /* CFG_VOUT1_D21_OUT */ + {0x0C50, 221, 0}, /* CFG_VOUT1_D22_OUT */ + {0x0C5C, 96, 0}, /* CFG_VOUT1_D23_OUT */ + {0x0C68, 264, 0}, /* CFG_VOUT1_D2_OUT */ + {0x0C74, 421, 0}, /* CFG_VOUT1_D3_OUT */ + {0x0C80, 1257, 0}, /* CFG_VOUT1_D4_OUT */ + {0x0C8C, 432, 0}, /* CFG_VOUT1_D5_OUT */ + {0x0C98, 436, 0}, /* CFG_VOUT1_D6_OUT */ + {0x0CA4, 440, 0}, /* CFG_VOUT1_D7_OUT */ + {0x0CB0, 81, 100}, /* CFG_VOUT1_D8_OUT */ + {0x0CBC, 471, 0}, /* CFG_VOUT1_D9_OUT */ + {0x0CC8, 0, 0}, /* CFG_VOUT1_DE_OUT */ + {0x0CE0, 0, 0}, /* CFG_VOUT1_HSYNC_OUT */ + {0x0CEC, 815, 0}, /* CFG_VOUT1_VSYNC_OUT */ +}; + const struct iodelay_cfg_entry iodelay_cfg_array_am572x_idk[] = { {0x0114, 1861, 901}, /* CFG_GPMC_A0_IN */ {0x0120, 0, 0}, /* CFG_GPMC_A10_IN */
Enable CMD_DDR3 on all am57xx based platforms.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- arch/arm/mach-omap2/omap5/Kconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/arch/arm/mach-omap2/omap5/Kconfig b/arch/arm/mach-omap2/omap5/Kconfig index 8c1730a6be..deb9873cc5 100644 --- a/arch/arm/mach-omap2/omap5/Kconfig +++ b/arch/arm/mach-omap2/omap5/Kconfig @@ -39,6 +39,7 @@ config TARGET_AM57XX_EVM select BOARD_LATE_INIT select DRA7XX select TI_I2C_BOARD_DETECT + select CMD_DDR3 imply SCSI imply SPL_THERMAL imply DM_THERMAL
Hi Lokesh,
- select CMD_DDR3
I'm just curious - what is the purpose of this command?
Lukasz Majewski
Hi Lukas,
On Monday 18 December 2017 04:48 PM, Lukasz Majewski wrote:
Hi Lokesh,
- select CMD_DDR3
This command supports memory testing and ecc testing.
Add initial dts support for am574x-idk
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- - DTS patch posted to kernel: https://patchwork.kernel.org/patch/10118295/ arch/arm/dts/Makefile | 1 + arch/arm/dts/am572x-idk-common.dtsi | 100 ++++++++++++++++++++++++++++++ arch/arm/dts/am572x-idk.dts | 93 +-------------------------- arch/arm/dts/am574x-idk.dts | 22 +++++++ arch/arm/dts/am57xx-commercial-grade.dtsi | 1 + arch/arm/dts/am57xx-industrial-grade.dtsi | 1 + configs/am57xx_evm_defconfig | 2 +- configs/am57xx_hs_evm_defconfig | 2 +- 8 files changed, 128 insertions(+), 94 deletions(-) create mode 100644 arch/arm/dts/am572x-idk-common.dtsi create mode 100644 arch/arm/dts/am574x-idk.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 1c9ac1468b..c0fc414292 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -187,6 +187,7 @@ dtb-$(CONFIG_TARGET_DRA7XX_EVM) += dra72-evm.dtb dra7-evm.dtb \ dtb-$(CONFIG_TARGET_AM57XX_EVM) += am57xx-beagle-x15.dtb \ am57xx-beagle-x15-revb1.dtb \ am57xx-beagle-x15-revc.dtb \ + am574x-idk.dtb \ am572x-idk.dtb \ am571x-idk.dtb dtb-$(CONFIG_TARGET_STV0991) += stv0991.dtb diff --git a/arch/arm/dts/am572x-idk-common.dtsi b/arch/arm/dts/am572x-idk-common.dtsi new file mode 100644 index 0000000000..c6d858b310 --- /dev/null +++ b/arch/arm/dts/am572x-idk-common.dtsi @@ -0,0 +1,100 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include "am57xx-idk-common.dtsi" + +/ { + memory@0 { + device_type = "memory"; + reg = <0x0 0x80000000 0x0 0x80000000>; + }; + + status-leds { + compatible = "gpio-leds"; + cpu0-led { + label = "status0:red:cpu0"; + gpios = <&gpio4 0 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "cpu0"; + }; + + usr0-led { + label = "status0:green:usr"; + gpios = <&gpio3 11 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + heartbeat-led { + label = "status0:blue:heartbeat"; + gpios = <&gpio3 12 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "heartbeat"; + }; + + cpu1-led { + label = "status1:red:cpu1"; + gpios = <&gpio3 10 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "cpu1"; + }; + + usr1-led { + label = "status1:green:usr"; + gpios = <&gpio7 23 GPIO_ACTIVE_HIGH>; + default-state = "off"; + }; + + mmc0-led { + label = "status1:blue:mmc0"; + gpios = <&gpio7 22 GPIO_ACTIVE_HIGH>; + default-state = "off"; + linux,default-trigger = "mmc0"; + }; + }; +}; + +&omap_dwc3_2 { + extcon = <&extcon_usb2>; +}; + +&extcon_usb2 { + id-gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>; + vbus-gpio = <&gpio3 26 GPIO_ACTIVE_HIGH>; +}; + +&sn65hvs882 { + load-gpios = <&gpio3 19 GPIO_ACTIVE_LOW>; +}; + +&pcie1_rc { + status = "okay"; + gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; +}; + +&pcie1_ep { + gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; +}; + +&mailbox5 { + status = "okay"; + mbox_ipu1_ipc3x: mbox_ipu1_ipc3x { + status = "okay"; + }; + mbox_dsp1_ipc3x: mbox_dsp1_ipc3x { + status = "okay"; + }; +}; + +&mailbox6 { + status = "okay"; + mbox_ipu2_ipc3x: mbox_ipu2_ipc3x { + status = "okay"; + }; + mbox_dsp2_ipc3x: mbox_dsp2_ipc3x { + status = "okay"; + }; +}; diff --git a/arch/arm/dts/am572x-idk.dts b/arch/arm/dts/am572x-idk.dts index a578fe97ba..9212931f25 100644 --- a/arch/arm/dts/am572x-idk.dts +++ b/arch/arm/dts/am572x-idk.dts @@ -9,8 +9,7 @@ /dts-v1/;
#include "dra74x.dtsi" -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/irq.h> +#include "am572x-idk-common.dtsi" #include "am57xx-idk-common.dtsi" #include "dra74x-mmc-iodelay.dtsi"
@@ -18,54 +17,6 @@ model = "TI AM5728 IDK"; compatible = "ti,am5728-idk", "ti,am5728", "ti,dra742", "ti,dra74", "ti,dra7"; - - memory@0 { - device_type = "memory"; - reg = <0x0 0x80000000 0x0 0x80000000>; - }; - - status-leds { - compatible = "gpio-leds"; - cpu0-led { - label = "status0:red:cpu0"; - gpios = <&gpio4 0 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "cpu0"; - }; - - usr0-led { - label = "status0:green:usr"; - gpios = <&gpio3 11 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - - heartbeat-led { - label = "status0:blue:heartbeat"; - gpios = <&gpio3 12 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "heartbeat"; - }; - - cpu1-led { - label = "status1:red:cpu1"; - gpios = <&gpio3 10 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "cpu1"; - }; - - usr1-led { - label = "status1:green:usr"; - gpios = <&gpio7 23 GPIO_ACTIVE_HIGH>; - default-state = "off"; - }; - - mmc0-led { - label = "status1:blue:mmc0"; - gpios = <&gpio7 22 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "mmc0"; - }; - }; };
&mmc1 { @@ -85,45 +36,3 @@ pinctrl-1 = <&mmc2_pins_hs>; pinctrl-2 = <&mmc2_pins_ddr_rev20>; }; - -&omap_dwc3_2 { - extcon = <&extcon_usb2>; -}; - -&extcon_usb2 { - id-gpio = <&gpio3 16 GPIO_ACTIVE_HIGH>; - vbus-gpio = <&gpio3 26 GPIO_ACTIVE_HIGH>; -}; - -&sn65hvs882 { - load-gpios = <&gpio3 19 GPIO_ACTIVE_LOW>; -}; - -&pcie1_rc { - status = "okay"; - gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; -}; - -&pcie1_ep { - gpios = <&gpio3 23 GPIO_ACTIVE_HIGH>; -}; - -&mailbox5 { - status = "okay"; - mbox_ipu1_ipc3x: mbox_ipu1_ipc3x { - status = "okay"; - }; - mbox_dsp1_ipc3x: mbox_dsp1_ipc3x { - status = "okay"; - }; -}; - -&mailbox6 { - status = "okay"; - mbox_ipu2_ipc3x: mbox_ipu2_ipc3x { - status = "okay"; - }; - mbox_dsp2_ipc3x: mbox_dsp2_ipc3x { - status = "okay"; - }; -}; diff --git a/arch/arm/dts/am574x-idk.dts b/arch/arm/dts/am574x-idk.dts new file mode 100644 index 0000000000..41e12a382d --- /dev/null +++ b/arch/arm/dts/am574x-idk.dts @@ -0,0 +1,22 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2017 Texas Instruments Incorporated - http://www.ti.com/ + */ + + +/dts-v1/; + +#include "dra76x.dtsi" +#include "am572x-idk-common.dtsi" + +/ { + model = "TI AM5748 IDK"; + compatible = "ti,am5728-idk", "ti,dra762", "ti,dra7"; +}; + +&qspi { + spi-max-frequency = <96000000>; + m25p80@0 { + spi-max-frequency = <96000000>; + }; +}; diff --git a/arch/arm/dts/am57xx-commercial-grade.dtsi b/arch/arm/dts/am57xx-commercial-grade.dtsi index c183654464..3eed6e09c8 100644 --- a/arch/arm/dts/am57xx-commercial-grade.dtsi +++ b/arch/arm/dts/am57xx-commercial-grade.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0 &cpu_alert0 { temperature = <80000>; /* milliCelsius */ }; diff --git a/arch/arm/dts/am57xx-industrial-grade.dtsi b/arch/arm/dts/am57xx-industrial-grade.dtsi index 70c8c4ba19..422f953fc8 100644 --- a/arch/arm/dts/am57xx-industrial-grade.dtsi +++ b/arch/arm/dts/am57xx-industrial-grade.dtsi @@ -1,3 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0 &cpu_alert0 { temperature = <90000>; /* milliCelsius */ }; diff --git a/configs/am57xx_evm_defconfig b/configs/am57xx_evm_defconfig index fc96401d3e..e1738e00d0 100644 --- a/configs/am57xx_evm_defconfig +++ b/configs/am57xx_evm_defconfig @@ -35,7 +35,7 @@ CONFIG_CMD_SPL=y CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y diff --git a/configs/am57xx_hs_evm_defconfig b/configs/am57xx_hs_evm_defconfig index 681e2a54c8..25e620c6dc 100644 --- a/configs/am57xx_hs_evm_defconfig +++ b/configs/am57xx_hs_evm_defconfig @@ -38,7 +38,7 @@ CONFIG_FASTBOOT_FLASH_MMC_DEV=1 CONFIG_ISO_PARTITION=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y -CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk" +CONFIG_OF_LIST="am57xx-beagle-x15 am57xx-beagle-x15-revb1 am57xx-beagle-x15-revc am572x-idk am571x-idk am574x-idk" CONFIG_ENV_IS_IN_MMC=y CONFIG_DM=y CONFIG_SPL_DM=y
What's the status of these DTS/DTSI files wrt the kernel? Thanks!
DTS patches merged today. Will post a v2 of this series soon.
Select dtb name for am574x-idk and dra76x evm with acd package.
Signed-off-by: Lokesh Vutla lokeshvutla@ti.com --- include/environment/ti/boot.h | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/include/environment/ti/boot.h b/include/environment/ti/boot.h index 799d9840aa..0a2342061c 100644 --- a/include/environment/ti/boot.h +++ b/include/environment/ti/boot.h @@ -67,7 +67,7 @@ "setenv fdtfile dra72-evm.dtb; fi;" \ "if test $board_name = dra71x; then " \ "setenv fdtfile dra71-evm.dtb; fi;" \ - "if test $board_name = dra76x; then " \ + "if test $board_name = dra76x_acd; then " \ "setenv fdtfile dra76-evm.dtb; fi;" \ "if test $board_name = beagle_x15; then " \ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ @@ -77,6 +77,8 @@ "setenv fdtfile am57xx-beagle-x15-revc.dtb; fi;" \ "if test $board_name = am572x_idk; then " \ "setenv fdtfile am572x-idk.dtb; fi;" \ + "if test $board_name = am574x_idk; then " \ + "setenv fdtfile am574x-idk.dtb; fi;" \ "if test $board_name = am57xx_evm; then " \ "setenv fdtfile am57xx-beagle-x15.dtb; fi;" \ "if test $board_name = am57xx_evm_reva3; then " \
Lokesh Vutla
Lukasz Majewski
