[PATCH] board_f: cosmetic: change the debug trace to KB in reserve_video
Update the debug trace for the reserved video memory to KB as indicated in the message with "%luk"; before the patch the computed size gd->relocaddr - addr is in bytes.
This patch aligns the debug trace in reserve_video() with others functions, for example on stm32mp157c-dk2:
- Reserving 3080192k for video at: dfd00000 + Reserving 3008k for video at: dfd00000 Reserving 873k for U-Boot at: dfc25000 Reserving 32776k for malloc() at: ddc23000 Reserving 72 Bytes for Board Info at: ddc22fb0 Reserving 280 Bytes for Global Data at: ddc22e90 Reserving 119072 Bytes for FDT at: ddc05d70 Reserving 0x278 Bytes for bootstage at: ddc05af0
Fixes: 5630d2fbc50f3035 ("board: Show memory for frame buffers") Signed-off-by: Patrick Delaunay patrick.delaunay@foss.st.com ---
common/board_f.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 0cddf0359d..203e965799 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -394,7 +394,7 @@ static int reserve_video(void) if (ret) return ret; debug("Reserving %luk for video at: %08lx\n", - (unsigned long)gd->relocaddr - addr, addr); + ((unsigned long)gd->relocaddr - addr) >> 10, addr); gd->relocaddr = addr; #elif defined(CONFIG_LCD) # ifdef CONFIG_FB_ADDR
On Sat, 10 Apr 2021 at 04:02, Patrick Delaunay patrick.delaunay@foss.st.com wrote:
- Reserving 3008k for video at: dfd00000 Reserving 873k for U-Boot at: dfc25000 Reserving 32776k for malloc() at: ddc23000 Reserving 72 Bytes for Board Info at: ddc22fb0 Reserving 280 Bytes for Global Data at: ddc22e90 Reserving 119072 Bytes for FDT at: ddc05d70 Reserving 0x278 Bytes for bootstage at: ddc05af0
On Fri, 9 Apr 2021 18:02:06 +0200 Patrick Delaunay patrick.delaunay@foss.st.com wrote: ...
applied to u-boot-video/master, thanks!
-- Anatolij
Anatolij Gustschin
Patrick Delaunay
