[U-Boot] [PATCH 0/6] ARM: kirkwood: dts conversion round 2
This is the second round of updating kirkwood boards to OF_CONTROL. Most of these boards use spi flash so I've added the u-boot specific "spi-flash" compatible string where appropriate.
Chris Packham (6): ARM: kirkwood: Add device-tree for d2net_v2 & net2big_v2 ARM: kirkwood: Add device-tree for dreamplug ARM: kirkwood: Add device-tree for ds109 ARM: kirkwood: Add device-tree for lschlv2 & lsxhl ARM: kirkwood: Add device-tree for netspace & inetspace ARM: kirkwood: Add device-tree for keymile
arch/arm/dts/kirkwood-d2net.dts | 45 ++ arch/arm/dts/kirkwood-dreamplug.dts | 127 ++++ arch/arm/dts/kirkwood-ds109.dts | 40 ++ arch/arm/dts/kirkwood-is2.dts | 40 ++ arch/arm/dts/kirkwood-km_common.dtsi | 47 ++ arch/arm/dts/kirkwood-km_kirkwood.dts | 31 + arch/arm/dts/kirkwood-lschlv2.dts | 20 + arch/arm/dts/kirkwood-lsxhl.dts | 20 + arch/arm/dts/kirkwood-lsxl.dtsi | 237 +++++++ arch/arm/dts/kirkwood-net2big.dts | 63 ++ arch/arm/dts/kirkwood-netxbig.dtsi | 232 +++++++ arch/arm/dts/kirkwood-ns2-common.dtsi | 97 +++ arch/arm/dts/kirkwood-ns2.dts | 40 ++ arch/arm/dts/kirkwood-ns2lite.dts | 35 + arch/arm/dts/kirkwood-ns2max.dts | 59 ++ arch/arm/dts/kirkwood-ns2mini.dts | 60 ++ arch/arm/dts/kirkwood-synology.dtsi | 855 ++++++++++++++++++++++++ configs/d2net_v2_defconfig | 3 +- configs/dreamplug_defconfig | 3 +- configs/ds109_defconfig | 2 + configs/inetspace_v2_defconfig | 3 +- configs/km_kirkwood_128m16_defconfig | 3 +- configs/km_kirkwood_defconfig | 3 +- configs/km_kirkwood_pci_defconfig | 3 +- configs/kmcoge5un_defconfig | 3 +- configs/kmnusa_defconfig | 3 +- configs/kmsugp1_defconfig | 3 +- configs/kmsuv31_defconfig | 3 +- configs/lschlv2_defconfig | 3 +- configs/lsxhl_defconfig | 3 +- configs/mgcoge3un_defconfig | 3 +- configs/net2big_v2_defconfig | 3 +- configs/netspace_lite_v2_defconfig | 3 +- configs/netspace_max_v2_defconfig | 3 +- configs/netspace_mini_v2_defconfig | 3 +- configs/netspace_v2_defconfig | 3 +- include/dt-bindings/leds/leds-netxbig.h | 18 + include/dt-bindings/leds/leds-ns2.h | 9 + 38 files changed, 2113 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/kirkwood-d2net.dts create mode 100644 arch/arm/dts/kirkwood-dreamplug.dts create mode 100644 arch/arm/dts/kirkwood-ds109.dts create mode 100644 arch/arm/dts/kirkwood-is2.dts create mode 100644 arch/arm/dts/kirkwood-km_common.dtsi create mode 100644 arch/arm/dts/kirkwood-km_kirkwood.dts create mode 100644 arch/arm/dts/kirkwood-lschlv2.dts create mode 100644 arch/arm/dts/kirkwood-lsxhl.dts create mode 100644 arch/arm/dts/kirkwood-lsxl.dtsi create mode 100644 arch/arm/dts/kirkwood-net2big.dts create mode 100644 arch/arm/dts/kirkwood-netxbig.dtsi create mode 100644 arch/arm/dts/kirkwood-ns2-common.dtsi create mode 100644 arch/arm/dts/kirkwood-ns2.dts create mode 100644 arch/arm/dts/kirkwood-ns2lite.dts create mode 100644 arch/arm/dts/kirkwood-ns2max.dts create mode 100644 arch/arm/dts/kirkwood-ns2mini.dts create mode 100644 arch/arm/dts/kirkwood-synology.dtsi create mode 100644 include/dt-bindings/leds/leds-netxbig.h create mode 100644 include/dt-bindings/leds/leds-ns2.h
Import the dts files from Linux 4.17 and enable CONFIG_OF_CONTROL.
Signed-off-by: Chris Packham judge.packham@gmail.com ---
arch/arm/dts/kirkwood-d2net.dts | 45 +++++ arch/arm/dts/kirkwood-net2big.dts | 63 +++++++ arch/arm/dts/kirkwood-netxbig.dtsi | 232 ++++++++++++++++++++++++ configs/d2net_v2_defconfig | 3 +- configs/net2big_v2_defconfig | 3 +- include/dt-bindings/leds/leds-netxbig.h | 18 ++ 6 files changed, 362 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/kirkwood-d2net.dts create mode 100644 arch/arm/dts/kirkwood-net2big.dts create mode 100644 arch/arm/dts/kirkwood-netxbig.dtsi create mode 100644 include/dt-bindings/leds/leds-netxbig.h
diff --git a/arch/arm/dts/kirkwood-d2net.dts b/arch/arm/dts/kirkwood-d2net.dts new file mode 100644 index 000000000000..bd3b266dd766 --- /dev/null +++ b/arch/arm/dts/kirkwood-d2net.dts @@ -0,0 +1,45 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree file for d2 Network v2 + * + * Copyright (C) 2014 Simon Guinot simon.guinot@sequanux.org + * +*/ + +/dts-v1/; + +#include <dt-bindings/leds/leds-ns2.h> +#include "kirkwood-netxbig.dtsi" + +/ { + model = "LaCie d2 Network v2"; + compatible = "lacie,d2net_v2", "lacie,netxbig", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + ns2-leds { + compatible = "lacie,ns2-leds"; + + blue-sata { + label = "d2net_v2:blue:sata"; + slow-gpio = <&gpio0 29 GPIO_ACTIVE_HIGH>; + cmd-gpio = <&gpio0 30 GPIO_ACTIVE_HIGH>; + modes-map = <NS_V2_LED_OFF 1 0 + NS_V2_LED_ON 0 1 + NS_V2_LED_ON 1 1 + NS_V2_LED_SATA 0 0>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + red-fail { + label = "d2net_v2:red:fail"; + gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>; + }; + }; +}; diff --git a/arch/arm/dts/kirkwood-net2big.dts b/arch/arm/dts/kirkwood-net2big.dts new file mode 100644 index 000000000000..3e3ac289e5b0 --- /dev/null +++ b/arch/arm/dts/kirkwood-net2big.dts @@ -0,0 +1,63 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree file for LaCie 2Big Network v2 + * + * Copyright (C) 2014 + * + * Andrew Lunn andrew@lunn.ch + * + * Based on netxbig_v2-setup.c, + * Copyright (C) 2010 Simon Guinot sguinot@lacie.com + * +*/ + +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" +#include "kirkwood-netxbig.dtsi" + +/ { + model = "LaCie 2Big Network v2"; + compatible = "lacie,net2big_v2", "lacie,netxbig", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + fan { + compatible = "gpio-fan"; + alarm-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>; + }; +}; + +®ulators { + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "hdd1power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 17 GPIO_ACTIVE_HIGH>; + }; + + clocks { + g762_clk: g762-oscillator { + compatible = "fixed-clock"; + #clock-cells = <0>; + clock-frequency = <32768>; + }; + }; +}; + +&i2c0 { + g762@3e { + compatible = "gmt,g762"; + reg = <0x3e>; + clocks = <&g762_clk>; + }; +}; diff --git a/arch/arm/dts/kirkwood-netxbig.dtsi b/arch/arm/dts/kirkwood-netxbig.dtsi new file mode 100644 index 000000000000..135ac8021c8c --- /dev/null +++ b/arch/arm/dts/kirkwood-netxbig.dtsi @@ -0,0 +1,232 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Device Tree common file for LaCie 2Big and 5Big Network v2 + * + * Copyright (C) 2014 + * + * Andrew Lunn andrew@lunn.ch + * + * Based on netxbig_v2-setup.c, + * Copyright (C) 2010 Simon Guinot sguinot@lacie.com + * +*/ + +#include <dt-bindings/leds/leds-netxbig.h> +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" + +/ { + chosen { + bootargs = "console=ttyS0,115200n8"; + stdout-path = &uart0; + }; + + ocp@f1000000 { + serial@12000 { + status = "okay"; + }; + + spi@10600 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mxicy,mx25l4005a", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <20000000>; + mode = <0>; + + partition@0 { + reg = <0x0 0x80000>; + label = "u-boot"; + }; + }; + }; + + sata@80000 { + status = "okay"; + nr-ports = <2>; + }; + + }; + + gpio-keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + + /* + * esc and power represent a three position rocker + * switch. Thus the conventional KEY_POWER does not fit + */ + exc { + label = "Back power switch (on|auto)"; + linux,code = <KEY_ESC>; + linux,input-type = <5>; + gpios = <&gpio0 13 GPIO_ACTIVE_LOW>; + }; + power { + label = "Back power switch (auto|off)"; + linux,code = <KEY_1>; + linux,input-type = <5>; + gpios = <&gpio0 15 GPIO_ACTIVE_LOW>; + }; + option { + label = "Function button"; + linux,code = <KEY_OPTION>; + gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; + }; + + }; + + gpio-poweroff { + compatible = "gpio-poweroff"; + gpios = <&gpio0 7 GPIO_ACTIVE_HIGH>; + }; + + regulators: regulators { + status = "okay"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-names = "default"; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "hdd0power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 16 GPIO_ACTIVE_HIGH>; + }; + }; + + netxbig_gpio_ext: netxbig-gpio-ext { + compatible = "lacie,netxbig-gpio-ext"; + + addr-gpios = <&gpio1 15 GPIO_ACTIVE_HIGH + &gpio1 16 GPIO_ACTIVE_HIGH + &gpio1 17 GPIO_ACTIVE_HIGH>; + data-gpios = <&gpio1 12 GPIO_ACTIVE_HIGH + &gpio1 13 GPIO_ACTIVE_HIGH + &gpio1 14 GPIO_ACTIVE_HIGH>; + enable-gpio = <&gpio0 29 GPIO_ACTIVE_HIGH>; + }; + + netxbig-leds { + compatible = "lacie,netxbig-leds"; + + gpio-ext = <&netxbig_gpio_ext>; + + timers = <NETXBIG_LED_TIMER1 500 500 + NETXBIG_LED_TIMER2 500 1000>; + + blue-power { + label = "netxbig:blue:power"; + mode-addr = <0>; + mode-val = <NETXBIG_LED_OFF 0 + NETXBIG_LED_ON 1 + NETXBIG_LED_TIMER1 3 + NETXBIG_LED_TIMER2 7>; + bright-addr = <1>; + max-brightness = <7>; + }; + red-power { + label = "netxbig:red:power"; + mode-addr = <0>; + mode-val = <NETXBIG_LED_OFF 0 + NETXBIG_LED_ON 2 + NETXBIG_LED_TIMER1 4>; + bright-addr = <1>; + max-brightness = <7>; + }; + blue-sata0 { + label = "netxbig:blue:sata0"; + mode-addr = <3>; + mode-val = <NETXBIG_LED_OFF 0 + NETXBIG_LED_ON 7 + NETXBIG_LED_SATA 1 + NETXBIG_LED_TIMER1 3>; + bright-addr = <2>; + max-brightness = <7>; + }; + red-sata0 { + label = "netxbig:red:sata0"; + mode-addr = <3>; + mode-val = <NETXBIG_LED_OFF 0 + NETXBIG_LED_ON 2 + NETXBIG_LED_TIMER1 4>; + bright-addr = <2>; + max-brightness = <7>; + }; + blue-sata1 { + label = "netxbig:blue:sata1"; + mode-addr = <4>; + mode-val = <NETXBIG_LED_OFF 0 + NETXBIG_LED_ON 7 + NETXBIG_LED_SATA 1 + NETXBIG_LED_TIMER1 3>; + bright-addr = <2>; + max-brightness = <7>; + }; + red-sata1 { + label = "netxbig:red:sata1"; + mode-addr = <4>; + mode-val = <NETXBIG_LED_OFF 0 + NETXBIG_LED_ON 2 + NETXBIG_LED_TIMER1 4>; + bright-addr = <2>; + max-brightness = <7>; + }; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <8>; + }; + + ethphy1: ethernet-phy@1 { + reg = <0>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; + +&pinctrl { + pinctrl-names = "default"; + + pmx_button_function: pmx-button-function { + marvell,pins = "mpp34"; + marvell,function = "gpio"; + }; + pmx_button_power_off: pmx-button-power-off { + marvell,pins = "mpp15"; + marvell,function = "gpio"; + }; + pmx_button_power_on: pmx-button-power-on { + marvell,pins = "mpp13"; + marvell,function = "gpio"; + }; +}; + +&i2c0 { + status = "okay"; + + eeprom@50 { + compatible = "atmel,24c04"; + pagesize = <16>; + reg = <0x50>; + }; +}; diff --git a/configs/d2net_v2_defconfig b/configs/d2net_v2_defconfig index 72db1e74a0aa..d054c21780c3 100644 --- a/configs/d2net_v2_defconfig +++ b/configs/d2net_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y CONFIG_IDENT_STRING=" D2 v2" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-d2net" CONFIG_SYS_EXTRA_OPTIONS="D2NET_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -26,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -39,4 +41,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/net2big_v2_defconfig b/configs/net2big_v2_defconfig index d486e4cd7bd2..e7216556be92 100644 --- a/configs/net2big_v2_defconfig +++ b/configs/net2big_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NET2BIG_V2=y CONFIG_IDENT_STRING=" 2Big v2" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-net2big" CONFIG_SYS_EXTRA_OPTIONS="NET2BIG_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -26,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -39,4 +41,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/include/dt-bindings/leds/leds-netxbig.h b/include/dt-bindings/leds/leds-netxbig.h new file mode 100644 index 000000000000..92658b0310b2 --- /dev/null +++ b/include/dt-bindings/leds/leds-netxbig.h @@ -0,0 +1,18 @@ +/* + * This header provides constants for netxbig LED bindings. + * + * This file is licensed under the terms of the GNU General Public + * License version 2. This program is licensed "as is" without any + * warranty of any kind, whether express or implied. + */ + +#ifndef _DT_BINDINGS_LEDS_NETXBIG_H +#define _DT_BINDINGS_LEDS_NETXBIG_H + +#define NETXBIG_LED_OFF 0 +#define NETXBIG_LED_ON 1 +#define NETXBIG_LED_SATA 2 +#define NETXBIG_LED_TIMER1 3 +#define NETXBIG_LED_TIMER2 4 + +#endif /* _DT_BINDINGS_LEDS_NETXBIG_H */
Import the dts file from Linux 4.17 and enable CONFIG_OF_CONTROL.
arch/arm/dts/kirkwood-dreamplug.dts | 127 ++++++++++++++++++++++++++++ configs/dreamplug_defconfig | 3 +- 2 files changed, 129 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/kirkwood-dreamplug.dts
diff --git a/arch/arm/dts/kirkwood-dreamplug.dts b/arch/arm/dts/kirkwood-dreamplug.dts new file mode 100644 index 000000000000..a647a65c20a0 --- /dev/null +++ b/arch/arm/dts/kirkwood-dreamplug.dts @@ -0,0 +1,127 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" + +/ { + model = "Globalscale Technologies Dreamplug"; + compatible = "globalscale,dreamplug-003-ds2001", "globalscale,dreamplug", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x20000000>; + }; + + chosen { + bootargs = "console=ttyS0,115200n8 earlyprintk"; + stdout-path = &uart0; + }; + + ocp@f1000000 { + pinctrl: pin-controller@10000 { + pmx_led_bluetooth: pmx-led-bluetooth { + marvell,pins = "mpp47"; + marvell,function = "gpio"; + }; + pmx_led_wifi: pmx-led-wifi { + marvell,pins = "mpp48"; + marvell,function = "gpio"; + }; + pmx_led_wifi_ap: pmx-led-wifi-ap { + marvell,pins = "mpp49"; + marvell,function = "gpio"; + }; + }; + serial@12000 { + status = "ok"; + }; + + spi@10600 { + status = "okay"; + + m25p40@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mxicy,mx25l1606e", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <50000000>; + mode = <0>; + + partition@0 { + reg = <0x0 0x80000>; + label = "u-boot"; + }; + + partition@100000 { + reg = <0x100000 0x10000>; + label = "u-boot env"; + }; + + partition@180000 { + reg = <0x180000 0x10000>; + label = "dtb"; + }; + }; + }; + + sata@80000 { + status = "okay"; + nr-ports = <1>; + }; + + mvsdio@90000 { + pinctrl-0 = <&pmx_sdio>; + pinctrl-names = "default"; + status = "okay"; + /* No CD or WP GPIOs */ + broken-cd; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_led_bluetooth &pmx_led_wifi + &pmx_led_wifi_ap >; + pinctrl-names = "default"; + + bluetooth { + label = "dreamplug:blue:bluetooth"; + gpios = <&gpio1 15 GPIO_ACTIVE_LOW>; + }; + wifi { + label = "dreamplug:green:wifi"; + gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; + }; + wifi-ap { + label = "dreamplug:green:wifi_ap"; + gpios = <&gpio1 17 GPIO_ACTIVE_LOW>; + }; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; + + ethphy1: ethernet-phy@1 { + reg = <1>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; + +ð1 { + status = "okay"; + ethernet1-port@0 { + phy-handle = <ðphy1>; + }; +}; diff --git a/configs/dreamplug_defconfig b/configs/dreamplug_defconfig index cbd2fb68ad92..8090c9a37793 100644 --- a/configs/dreamplug_defconfig +++ b/configs/dreamplug_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DREAMPLUG=y CONFIG_IDENT_STRING="\nMarvell-DreamPlug" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-dreamplug" CONFIG_BOOTDELAY=3 # CONFIG_DISPLAY_BOARDINFO is not set CONFIG_HUSH_PARSER=y @@ -19,6 +20,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_EXT4=y CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -32,4 +34,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y
arch/arm/dts/kirkwood-ds109.dts | 40 ++ arch/arm/dts/kirkwood-synology.dtsi | 855 ++++++++++++++++++++++++++++ configs/ds109_defconfig | 2 + 3 files changed, 897 insertions(+) create mode 100644 arch/arm/dts/kirkwood-ds109.dts create mode 100644 arch/arm/dts/kirkwood-synology.dtsi
diff --git a/arch/arm/dts/kirkwood-ds109.dts b/arch/arm/dts/kirkwood-ds109.dts new file mode 100644 index 000000000000..29982e7acb7f --- /dev/null +++ b/arch/arm/dts/kirkwood-ds109.dts @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Andrew Lunn andrew@lunn.ch + * Ben Peddell klightspeed@killerwolves.net + * + */ + +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" +#include "kirkwood-synology.dtsi" + +/ { + model = "Synology DS109, DS110, DS110jv20"; + compatible = "synology,ds109", "synology,ds110jv20", + "synology,ds110", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x8000000>; + }; + + chosen { + bootargs = "console=ttyS0,115200n8"; + stdout-path = &uart0; + }; + + gpio-fan-150-32-35 { + status = "okay"; + }; + + gpio-leds-hdd-21-1 { + status = "okay"; + }; +}; + +&rs5c372 { + status = "okay"; +}; diff --git a/arch/arm/dts/kirkwood-synology.dtsi b/arch/arm/dts/kirkwood-synology.dtsi new file mode 100644 index 000000000000..b80d8ee37093 --- /dev/null +++ b/arch/arm/dts/kirkwood-synology.dtsi @@ -0,0 +1,855 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Nodes for Marvell 628x Synology devices + * + * Andrew Lunn andrew@lunn.ch + * Ben Peddell klightspeed@killerwolves.net + * + */ + +/ { + ocp@f1000000 { + pinctrl: pin-controller@10000 { + pmx_alarmled_12: pmx-alarmled-12 { + marvell,pins = "mpp12"; + marvell,function = "gpio"; + }; + + pmx_fanctrl_15: pmx-fanctrl-15 { + marvell,pins = "mpp15"; + marvell,function = "gpio"; + }; + + pmx_fanctrl_16: pmx-fanctrl-16 { + marvell,pins = "mpp16"; + marvell,function = "gpio"; + }; + + pmx_fanctrl_17: pmx-fanctrl-17 { + marvell,pins = "mpp17"; + marvell,function = "gpio"; + }; + + pmx_fanalarm_18: pmx-fanalarm-18 { + marvell,pins = "mpp18"; + marvell,function = "gpo"; + }; + + pmx_hddled_20: pmx-hddled-20 { + marvell,pins = "mpp20"; + marvell,function = "gpio"; + }; + + pmx_hddled_21: pmx-hddled-21 { + marvell,pins = "mpp21"; + marvell,function = "gpio"; + }; + + pmx_hddled_22: pmx-hddled-22 { + marvell,pins = "mpp22"; + marvell,function = "gpio"; + }; + + pmx_hddled_23: pmx-hddled-23 { + marvell,pins = "mpp23"; + marvell,function = "gpio"; + }; + + pmx_hddled_24: pmx-hddled-24 { + marvell,pins = "mpp24"; + marvell,function = "gpio"; + }; + + pmx_hddled_25: pmx-hddled-25 { + marvell,pins = "mpp25"; + marvell,function = "gpio"; + }; + + pmx_hddled_26: pmx-hddled-26 { + marvell,pins = "mpp26"; + marvell,function = "gpio"; + }; + + pmx_hddled_27: pmx-hddled-27 { + marvell,pins = "mpp27"; + marvell,function = "gpio"; + }; + + pmx_hddled_28: pmx-hddled-28 { + marvell,pins = "mpp28"; + marvell,function = "gpio"; + }; + + pmx_hdd1_pwr_29: pmx-hdd1-pwr-29 { + marvell,pins = "mpp29"; + marvell,function = "gpio"; + }; + + pmx_hdd1_pwr_30: pmx-hdd-pwr-30 { + marvell,pins = "mpp30"; + marvell,function = "gpio"; + }; + + pmx_hdd2_pwr_31: pmx-hdd2-pwr-31 { + marvell,pins = "mpp31"; + marvell,function = "gpio"; + }; + + pmx_fanctrl_32: pmx-fanctrl-32 { + marvell,pins = "mpp32"; + marvell,function = "gpio"; + }; + + pmx_fanctrl_33: pmx-fanctrl-33 { + marvell,pins = "mpp33"; + marvell,function = "gpo"; + }; + + pmx_fanctrl_34: pmx-fanctrl-34 { + marvell,pins = "mpp34"; + marvell,function = "gpio"; + }; + + pmx_hdd2_pwr_34: pmx-hdd2-pwr-34 { + marvell,pins = "mpp34"; + marvell,function = "gpio"; + }; + + pmx_fanalarm_35: pmx-fanalarm-35 { + marvell,pins = "mpp35"; + marvell,function = "gpio"; + }; + + pmx_hddled_36: pmx-hddled-36 { + marvell,pins = "mpp36"; + marvell,function = "gpio"; + }; + + pmx_hddled_37: pmx-hddled-37 { + marvell,pins = "mpp37"; + marvell,function = "gpio"; + }; + + pmx_hddled_38: pmx-hddled-38 { + marvell,pins = "mpp38"; + marvell,function = "gpio"; + }; + + pmx_hddled_39: pmx-hddled-39 { + marvell,pins = "mpp39"; + marvell,function = "gpio"; + }; + + pmx_hddled_40: pmx-hddled-40 { + marvell,pins = "mpp40"; + marvell,function = "gpio"; + }; + + pmx_hddled_41: pmx-hddled-41 { + marvell,pins = "mpp41"; + marvell,function = "gpio"; + }; + + pmx_hddled_42: pmx-hddled-42 { + marvell,pins = "mpp42"; + marvell,function = "gpio"; + }; + + pmx_hddled_43: pmx-hddled-43 { + marvell,pins = "mpp43"; + marvell,function = "gpio"; + }; + + pmx_hddled_44: pmx-hddled-44 { + marvell,pins = "mpp44"; + marvell,function = "gpio"; + }; + + pmx_hddled_45: pmx-hddled-45 { + marvell,pins = "mpp45"; + marvell,function = "gpio"; + }; + + pmx_hdd3_pwr_44: pmx-hdd3-pwr-44 { + marvell,pins = "mpp44"; + marvell,function = "gpio"; + }; + + pmx_hdd4_pwr_45: pmx-hdd4-pwr-45 { + marvell,pins = "mpp45"; + marvell,function = "gpio"; + }; + + pmx_fanalarm_44: pmx-fanalarm-44 { + marvell,pins = "mpp44"; + marvell,function = "gpio"; + }; + + pmx_fanalarm_45: pmx-fanalarm-45 { + marvell,pins = "mpp45"; + marvell,function = "gpio"; + }; + }; + + rtc@10300 { + status = "disabled"; + }; + + spi@10600 { + status = "okay"; + + m25p80@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "st,m25p80", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <20000000>; + mode = <0>; + + partition@0 { + reg = <0x00000000 0x00080000>; + label = "RedBoot"; + }; + + partition@80000 { + reg = <0x00080000 0x00200000>; + label = "zImage"; + }; + + partition@280000 { + reg = <0x00280000 0x00140000>; + label = "rd.gz"; + }; + + partition@3c0000 { + reg = <0x003c0000 0x00010000>; + label = "vendor"; + }; + + partition@3d0000 { + reg = <0x003d0000 0x00020000>; + label = "RedBoot config"; + }; + + partition@3f0000 { + reg = <0x003f0000 0x00010000>; + label = "FIS directory"; + }; + }; + }; + + i2c@11000 { + status = "okay"; + clock-frequency = <400000>; + + rs5c372: rs5c372@32 { + status = "disabled"; + compatible = "ricoh,rs5c372"; + reg = <0x32>; + }; + + s35390a: s35390a@30 { + status = "disabled"; + compatible = "sii,s35390a"; + reg = <0x30>; + }; + }; + + serial@12000 { + status = "okay"; + }; + + serial@12100 { + status = "okay"; + }; + + poweroff@12100 { + compatible = "synology,power-off"; + reg = <0x12100 0x100>; + clocks = <&gate_clk 7>; + }; + + sata@80000 { + pinctrl-0 = <&pmx_sata0 &pmx_sata1>; + pinctrl-names = "default"; + status = "okay"; + nr-ports = <2>; + }; + }; + + gpio-fan-150-32-35 { + status = "disabled"; + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fanctrl_32 &pmx_fanctrl_33 &pmx_fanctrl_34 + &pmx_fanalarm_35>; + pinctrl-names = "default"; + gpios = <&gpio1 0 GPIO_ACTIVE_HIGH + &gpio1 1 GPIO_ACTIVE_HIGH + &gpio1 2 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 2200 1 + 2500 2 + 3000 4 + 3300 3 + 3700 5 + 3800 6 + 4200 7 >; + }; + + gpio-fan-150-15-18 { + status = "disabled"; + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fanctrl_15 &pmx_fanctrl_16 &pmx_fanctrl_17 + &pmx_fanalarm_18>; + pinctrl-names = "default"; + gpios = <&gpio0 15 GPIO_ACTIVE_HIGH + &gpio0 16 GPIO_ACTIVE_HIGH + &gpio0 17 GPIO_ACTIVE_HIGH>; + alarm-gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 2200 1 + 2500 2 + 3000 4 + 3300 3 + 3700 5 + 3800 6 + 4200 7 >; + }; + + gpio-fan-100-32-35 { + status = "disabled"; + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fanctrl_32 &pmx_fanctrl_33 &pmx_fanctrl_34 + &pmx_fanalarm_35>; + pinctrl-names = "default"; + gpios = <&gpio1 0 GPIO_ACTIVE_HIGH + &gpio1 1 GPIO_ACTIVE_HIGH + &gpio1 2 GPIO_ACTIVE_HIGH>; + alarm-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 2500 1 + 3100 2 + 3800 3 + 4600 4 + 4800 5 + 4900 6 + 5000 7 >; + }; + + gpio-fan-100-15-18 { + status = "disabled"; + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fanctrl_15 &pmx_fanctrl_16 &pmx_fanctrl_17 + &pmx_fanalarm_18>; + pinctrl-names = "default"; + gpios = <&gpio0 15 GPIO_ACTIVE_HIGH + &gpio0 16 GPIO_ACTIVE_HIGH + &gpio0 17 GPIO_ACTIVE_HIGH>; + alarm-gpios = <&gpio0 18 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 2500 1 + 3100 2 + 3800 3 + 4600 4 + 4800 5 + 4900 6 + 5000 7 >; + }; + + gpio-fan-100-15-35-1 { + status = "disabled"; + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fanctrl_15 &pmx_fanctrl_16 &pmx_fanctrl_17 + &pmx_fanalarm_35>; + pinctrl-names = "default"; + gpios = <&gpio0 15 GPIO_ACTIVE_HIGH + &gpio0 16 GPIO_ACTIVE_HIGH + &gpio0 17 GPIO_ACTIVE_HIGH>; + alarm-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 2500 1 + 3100 2 + 3800 3 + 4600 4 + 4800 5 + 4900 6 + 5000 7 >; + }; + + gpio-fan-100-15-35-3 { + status = "disabled"; + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fanctrl_15 &pmx_fanctrl_16 &pmx_fanctrl_17 + &pmx_fanalarm_35 &pmx_fanalarm_44 &pmx_fanalarm_45>; + pinctrl-names = "default"; + gpios = <&gpio0 15 GPIO_ACTIVE_HIGH + &gpio0 16 GPIO_ACTIVE_HIGH + &gpio0 17 GPIO_ACTIVE_HIGH>; + alarm-gpios = <&gpio1 3 GPIO_ACTIVE_HIGH + &gpio1 12 GPIO_ACTIVE_HIGH + &gpio1 13 GPIO_ACTIVE_HIGH>; + gpio-fan,speed-map = < 0 0 + 2500 1 + 3100 2 + 3800 3 + 4600 4 + 4800 5 + 4900 6 + 5000 7 >; + }; + + gpio-leds-alarm-12 { + status = "disabled"; + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_alarmled_12>; + pinctrl-names = "default"; + + hdd1-green { + label = "synology:alarm"; + gpios = <&gpio0 21 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds-hdd-20 { + status = "disabled"; + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_hddled_20 &pmx_hddled_21 &pmx_hddled_22 + &pmx_hddled_23 &pmx_hddled_24 &pmx_hddled_25 + &pmx_hddled_26 &pmx_hddled_27>; + pinctrl-names = "default"; + + hdd1-green { + label = "synology:green:hdd1"; + gpios = <&gpio0 20 GPIO_ACTIVE_LOW>; + }; + + hdd1-amber { + label = "synology:amber:hdd1"; + gpios = <&gpio0 21 GPIO_ACTIVE_LOW>; + }; + + hdd2-green { + label = "synology:green:hdd2"; + gpios = <&gpio0 22 GPIO_ACTIVE_LOW>; + }; + + hdd2-amber { + label = "synology:amber:hdd2"; + gpios = <&gpio0 23 GPIO_ACTIVE_LOW>; + }; + + hdd3-green { + label = "synology:green:hdd3"; + gpios = <&gpio0 24 GPIO_ACTIVE_LOW>; + }; + + hdd3-amber { + label = "synology:amber:hdd3"; + gpios = <&gpio0 25 GPIO_ACTIVE_LOW>; + }; + + hdd4-green { + label = "synology:green:hdd4"; + gpios = <&gpio0 26 GPIO_ACTIVE_LOW>; + }; + + hdd4-amber { + label = "synology:amber:hdd4"; + gpios = <&gpio0 27 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds-hdd-21-1 { + status = "disabled"; + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_hddled_21 &pmx_hddled_23>; + pinctrl-names = "default"; + + hdd1-green { + label = "synology:green:hdd1"; + gpios = <&gpio0 21 GPIO_ACTIVE_LOW>; + }; + + hdd1-amber { + label = "synology:amber:hdd1"; + gpios = <&gpio0 23 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds-hdd-21-2 { + status = "disabled"; + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_hddled_21 &pmx_hddled_23 &pmx_hddled_20 &pmx_hddled_22>; + pinctrl-names = "default"; + + hdd1-green { + label = "synology:green:hdd1"; + gpios = <&gpio0 21 GPIO_ACTIVE_LOW>; + }; + + hdd1-amber { + label = "synology:amber:hdd1"; + gpios = <&gpio0 23 GPIO_ACTIVE_LOW>; + }; + + hdd2-green { + label = "synology:green:hdd2"; + gpios = <&gpio0 20 GPIO_ACTIVE_LOW>; + }; + + hdd2-amber { + label = "synology:amber:hdd2"; + gpios = <&gpio0 22 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds-hdd-36 { + status = "disabled"; + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_hddled_36 &pmx_hddled_37 &pmx_hddled_38 + &pmx_hddled_39 &pmx_hddled_40 &pmx_hddled_41 + &pmx_hddled_42 &pmx_hddled_43 &pmx_hddled_44 + &pmx_hddled_45>; + pinctrl-names = "default"; + + hdd1-green { + label = "synology:green:hdd1"; + gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + }; + + hdd1-amber { + label = "synology:amber:hdd1"; + gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; + }; + + hdd2-green { + label = "synology:green:hdd2"; + gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + }; + + hdd2-amber { + label = "synology:amber:hdd2"; + gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; + }; + + hdd3-green { + label = "synology:green:hdd3"; + gpios = <&gpio1 8 GPIO_ACTIVE_LOW>; + }; + + hdd3-amber { + label = "synology:amber:hdd3"; + gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; + }; + + hdd4-green { + label = "synology:green:hdd4"; + gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; + }; + + hdd4-amber { + label = "synology:amber:hdd4"; + gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; + }; + + hdd5-green { + label = "synology:green:hdd5"; + gpios = <&gpio1 12 GPIO_ACTIVE_LOW>; + }; + + hdd5-amber { + label = "synology:amber:hdd5"; + gpios = <&gpio1 13 GPIO_ACTIVE_LOW>; + }; + }; + + gpio-leds-hdd-38 { + status = "disabled"; + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_hddled_38 &pmx_hddled_39 &pmx_hddled_36 &pmx_hddled_37>; + pinctrl-names = "default"; + + hdd1-green { + label = "synology:green:hdd1"; + gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + }; + + hdd1-amber { + label = "synology:amber:hdd1"; + gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; + }; + + hdd2-green { + label = "synology:green:hdd2"; + gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + }; + + hdd2-amber { + label = "synology:amber:hdd2"; + gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; + }; + }; + + regulators-hdd-29 { + status = "disabled"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_hdd1_pwr_29 &pmx_hdd2_pwr_31>; + pinctrl-names = "default"; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "hdd1power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio0 29 GPIO_ACTIVE_HIGH>; + }; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "hdd2power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio0 31 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators-hdd-30-1 { + status = "disabled"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_hdd1_pwr_30>; + pinctrl-names = "default"; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "hdd1power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio0 30 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators-hdd-30-2 { + status = "disabled"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_hdd1_pwr_30 &pmx_hdd2_pwr_34>; + pinctrl-names = "default"; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "hdd1power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio0 30 GPIO_ACTIVE_HIGH>; + }; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "hdd2power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators-hdd-30-4 { + status = "disabled"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_hdd1_pwr_30 &pmx_hdd2_pwr_34 + &pmx_hdd3_pwr_44 &pmx_hdd4_pwr_45>; + pinctrl-names = "default"; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "hdd1power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio0 30 GPIO_ACTIVE_HIGH>; + }; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "hdd2power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>; + }; + + regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "hdd3power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; + }; + + regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "hdd4power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators-hdd-31 { + status = "disabled"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_hdd2_pwr_31>; + pinctrl-names = "default"; + + regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "hdd2power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio0 31 GPIO_ACTIVE_HIGH>; + }; + }; + + regulators-hdd-34 { + status = "disabled"; + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_hdd2_pwr_34 &pmx_hdd3_pwr_44 + &pmx_hdd4_pwr_45>; + pinctrl-names = "default"; + + regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "hdd2power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 2 GPIO_ACTIVE_HIGH>; + }; + + regulator@3 { + compatible = "regulator-fixed"; + reg = <3>; + regulator-name = "hdd3power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 12 GPIO_ACTIVE_HIGH>; + }; + + regulator@4 { + compatible = "regulator-fixed"; + reg = <4>; + regulator-name = "hdd4power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + startup-delay-us = <5000000>; + gpio = <&gpio1 13 GPIO_ACTIVE_HIGH>; + }; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + device_type = "ethernet-phy"; + reg = <8>; + }; + + ethphy1: ethernet-phy@1 { + device_type = "ethernet-phy"; + reg = <9>; + }; +}; + +ð0 { + status = "okay"; + + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; + +ð1 { + status = "disabled"; + + ethernet1-port@0 { + phy-handle = <ðphy1>; + }; +}; + +&pciec { + status = "okay"; +}; + +&pcie0 { + status = "okay"; +}; diff --git a/configs/ds109_defconfig b/configs/ds109_defconfig index 43e92d7ef290..c9207433b374 100644 --- a/configs/ds109_defconfig +++ b/configs/ds109_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_DS109=y +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ds109" CONFIG_HUSH_PARSER=y # CONFIG_CMD_FLASH is not set CONFIG_CMD_IDE=y @@ -14,6 +15,7 @@ CONFIG_CMD_PING=y CONFIG_CMD_DATE=y CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set
arch/arm/dts/kirkwood-lschlv2.dts | 20 +++ arch/arm/dts/kirkwood-lsxhl.dts | 20 +++ arch/arm/dts/kirkwood-lsxl.dtsi | 237 ++++++++++++++++++++++++++++++ configs/lschlv2_defconfig | 3 +- configs/lsxhl_defconfig | 3 +- 5 files changed, 281 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/kirkwood-lschlv2.dts create mode 100644 arch/arm/dts/kirkwood-lsxhl.dts create mode 100644 arch/arm/dts/kirkwood-lsxl.dtsi
diff --git a/arch/arm/dts/kirkwood-lschlv2.dts b/arch/arm/dts/kirkwood-lschlv2.dts new file mode 100644 index 000000000000..1d737d903f5f --- /dev/null +++ b/arch/arm/dts/kirkwood-lschlv2.dts @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "kirkwood-lsxl.dtsi" + +/ { + model = "Buffalo Linkstation LS-CHLv2"; + compatible = "buffalo,lschlv2", "buffalo,lsxl", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x4000000>; + }; + + ocp@f1000000 { + serial@12000 { + status = "okay"; + }; + }; +}; diff --git a/arch/arm/dts/kirkwood-lsxhl.dts b/arch/arm/dts/kirkwood-lsxhl.dts new file mode 100644 index 000000000000..a56e0d797778 --- /dev/null +++ b/arch/arm/dts/kirkwood-lsxhl.dts @@ -0,0 +1,20 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "kirkwood-lsxl.dtsi" + +/ { + model = "Buffalo Linkstation LS-XHL"; + compatible = "buffalo,lsxhl", "buffalo,lsxl", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + ocp@f1000000 { + serial@12000 { + status = "okay"; + }; + }; +}; diff --git a/arch/arm/dts/kirkwood-lsxl.dtsi b/arch/arm/dts/kirkwood-lsxl.dtsi new file mode 100644 index 000000000000..92b11c75b8fb --- /dev/null +++ b/arch/arm/dts/kirkwood-lsxl.dtsi @@ -0,0 +1,237 @@ +// SPDX-License-Identifier: GPL-2.0 +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" + +/ { + chosen { + bootargs = "console=ttyS0,115200n8 earlyprintk"; + stdout-path = &uart0; + }; + + ocp@f1000000 { + pinctrl: pin-controller@10000 { + pmx_power_hdd: pmx-power-hdd { + marvell,pins = "mpp10"; + marvell,function = "gpo"; + }; + pmx_usb_vbus: pmx-usb-vbus { + marvell,pins = "mpp11"; + marvell,function = "gpio"; + }; + pmx_fan_high: pmx-fan-high { + marvell,pins = "mpp18"; + marvell,function = "gpo"; + }; + pmx_fan_low: pmx-fan-low { + marvell,pins = "mpp19"; + marvell,function = "gpo"; + }; + pmx_led_function_blue: pmx-led-function-blue { + marvell,pins = "mpp36"; + marvell,function = "gpio"; + }; + pmx_led_alarm: pmx-led-alarm { + marvell,pins = "mpp37"; + marvell,function = "gpio"; + }; + pmx_led_info: pmx-led-info { + marvell,pins = "mpp38"; + marvell,function = "gpio"; + }; + pmx_led_power: pmx-led-power { + marvell,pins = "mpp39"; + marvell,function = "gpio"; + }; + pmx_fan_lock: pmx-fan-lock { + marvell,pins = "mpp40"; + marvell,function = "gpio"; + }; + pmx_button_function: pmx-button-function { + marvell,pins = "mpp41"; + marvell,function = "gpio"; + }; + pmx_power_switch: pmx-power-switch { + marvell,pins = "mpp42"; + marvell,function = "gpio"; + }; + pmx_power_auto_switch: pmx-power-auto-switch { + marvell,pins = "mpp43"; + marvell,function = "gpio"; + }; + pmx_led_function_red: pmx-led-function_red { + marvell,pins = "mpp48"; + marvell,function = "gpio"; + }; + + }; + sata@80000 { + status = "okay"; + nr-ports = <1>; + }; + + spi@10600 { + status = "okay"; + + m25p40@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "m25p40", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <25000000>; + mode = <0>; + + partition@0 { + reg = <0x0 0x60000>; + label = "uboot"; + read-only; + }; + + partition@60000 { + reg = <0x60000 0x10000>; + label = "dtb"; + read-only; + }; + + partition@70000 { + reg = <0x70000 0x10000>; + label = "uboot_env"; + }; + }; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_button_function &pmx_power_switch + &pmx_power_auto_switch>; + pinctrl-names = "default"; + + option { + label = "Function Button"; + linux,code = <KEY_OPTION>; + gpios = <&gpio1 9 GPIO_ACTIVE_LOW>; + }; + reserved { + label = "Power-on Switch"; + linux,code = <KEY_RESERVED>; + linux,input-type = <5>; + gpios = <&gpio1 10 GPIO_ACTIVE_LOW>; + }; + power { + label = "Power-auto Switch"; + linux,code = <KEY_ESC>; + linux,input-type = <5>; + gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; + }; + }; + + gpio_leds { + compatible = "gpio-leds"; + pinctrl-0 = <&pmx_led_function_red &pmx_led_alarm + &pmx_led_info &pmx_led_power + &pmx_led_function_blue>; + pinctrl-names = "default"; + + func_blue { + label = "lsxl:blue:func"; + gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; + }; + + alarm { + label = "lsxl:red:alarm"; + gpios = <&gpio1 5 GPIO_ACTIVE_LOW>; + }; + + info { + label = "lsxl:amber:info"; + gpios = <&gpio1 6 GPIO_ACTIVE_LOW>; + }; + + power { + label = "lsxl:blue:power"; + gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; + default-state = "keep"; + }; + + func_red { + label = "lsxl:red:func"; + gpios = <&gpio1 16 GPIO_ACTIVE_LOW>; + }; + }; + + gpio_fan { + compatible = "gpio-fan"; + pinctrl-0 = <&pmx_fan_low &pmx_fan_high &pmx_fan_lock>; + pinctrl-names = "default"; + gpios = <&gpio0 19 GPIO_ACTIVE_LOW + &gpio0 18 GPIO_ACTIVE_LOW>; + gpio-fan,speed-map = <0 3 + 1500 2 + 3250 1 + 5000 0>; + alarm-gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + }; + + restart_poweroff { + compatible = "restart-poweroff"; + }; + + regulators { + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <0>; + pinctrl-0 = <&pmx_power_hdd &pmx_usb_vbus>; + pinctrl-names = "default"; + + usb_power: regulator@1 { + compatible = "regulator-fixed"; + reg = <1>; + regulator-name = "USB Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 11 0>; + }; + hdd_power: regulator@2 { + compatible = "regulator-fixed"; + reg = <2>; + regulator-name = "HDD Power"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + enable-active-high; + regulator-always-on; + regulator-boot-on; + gpio = <&gpio0 10 0>; + }; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; + + ethphy1: ethernet-phy@8 { + reg = <8>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; + +ð1 { + status = "okay"; + ethernet1-port@0 { + phy-handle = <ðphy1>; + }; +}; diff --git a/configs/lschlv2_defconfig b/configs/lschlv2_defconfig index 1ca3d1272c97..23e68a00ea5d 100644 --- a/configs/lschlv2_defconfig +++ b/configs/lschlv2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-CHLv2" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lschlv2" CONFIG_SYS_EXTRA_OPTIONS="LSCHLV2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -28,6 +29,7 @@ CONFIG_CMD_FS_GENERIC=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MVSATA_IDE=y @@ -42,4 +44,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/lsxhl_defconfig b/configs/lsxhl_defconfig index c88fe37ab163..b523b68284aa 100644 --- a/configs/lsxhl_defconfig +++ b/configs/lsxhl_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_LSXL=y CONFIG_IDENT_STRING=" LS-XHL" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-lsxhl" CONFIG_DISTRO_DEFAULTS=y CONFIG_SYS_EXTRA_OPTIONS="LSXHL" CONFIG_API=y @@ -19,6 +20,7 @@ CONFIG_CMD_SF=y CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y CONFIG_MVSATA_IDE=y @@ -33,4 +35,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y
arch/arm/dts/kirkwood-is2.dts | 40 +++++++++++ arch/arm/dts/kirkwood-ns2-common.dtsi | 97 +++++++++++++++++++++++++++ arch/arm/dts/kirkwood-ns2.dts | 40 +++++++++++ arch/arm/dts/kirkwood-ns2lite.dts | 35 ++++++++++ arch/arm/dts/kirkwood-ns2max.dts | 59 ++++++++++++++++ arch/arm/dts/kirkwood-ns2mini.dts | 60 +++++++++++++++++ configs/inetspace_v2_defconfig | 3 +- configs/netspace_lite_v2_defconfig | 3 +- configs/netspace_max_v2_defconfig | 3 +- configs/netspace_mini_v2_defconfig | 3 +- configs/netspace_v2_defconfig | 3 +- include/dt-bindings/leds/leds-ns2.h | 9 +++ 12 files changed, 350 insertions(+), 5 deletions(-) create mode 100644 arch/arm/dts/kirkwood-is2.dts create mode 100644 arch/arm/dts/kirkwood-ns2-common.dtsi create mode 100644 arch/arm/dts/kirkwood-ns2.dts create mode 100644 arch/arm/dts/kirkwood-ns2lite.dts create mode 100644 arch/arm/dts/kirkwood-ns2max.dts create mode 100644 arch/arm/dts/kirkwood-ns2mini.dts create mode 100644 include/dt-bindings/leds/leds-ns2.h
diff --git a/arch/arm/dts/kirkwood-is2.dts b/arch/arm/dts/kirkwood-is2.dts new file mode 100644 index 000000000000..1bc16a5cdbaa --- /dev/null +++ b/arch/arm/dts/kirkwood-is2.dts @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include <dt-bindings/leds/leds-ns2.h> +#include "kirkwood-ns2-common.dtsi" + +/ { + model = "LaCie Internet Space v2"; + compatible = "lacie,inetspace_v2", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x8000000>; + }; + + ocp@f1000000 { + sata@80000 { + pinctrl-0 = <&pmx_ns2_sata0>; + pinctrl-names = "default"; + status = "okay"; + nr-ports = <1>; + }; + }; + + ns2-leds { + compatible = "lacie,ns2-leds"; + + blue-sata { + label = "ns2:blue:sata"; + slow-gpio = <&gpio0 29 0>; + cmd-gpio = <&gpio0 30 0>; + modes-map = <NS_V2_LED_OFF 1 0 + NS_V2_LED_ON 0 1 + NS_V2_LED_ON 1 1 + NS_V2_LED_SATA 0 0>; + }; + }; +}; + +ðphy0 { reg = <8>; }; diff --git a/arch/arm/dts/kirkwood-ns2-common.dtsi b/arch/arm/dts/kirkwood-ns2-common.dtsi new file mode 100644 index 000000000000..f997bb4df202 --- /dev/null +++ b/arch/arm/dts/kirkwood-ns2-common.dtsi @@ -0,0 +1,97 @@ +// SPDX-License-Identifier: GPL-2.0 +#include "kirkwood.dtsi" +#include "kirkwood-6281.dtsi" + +/ { + chosen { + bootargs = "console=ttyS0,115200n8"; + stdout-path = &uart0; + }; + + ocp@f1000000 { + pinctrl: pin-controller@10000 { + pmx_ns2_sata0: pmx-ns2-sata0 { + marvell,pins = "mpp21"; + marvell,function = "sata0"; + }; + pmx_ns2_sata1: pmx-ns2-sata1 { + marvell,pins = "mpp20"; + marvell,function = "sata1"; + }; + }; + + serial@12000 { + status = "okay"; + }; + + spi@10600 { + status = "okay"; + + flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "mxicy,mx25l4005a", "jedec,spi-nor", "spi-flash"; + reg = <0>; + spi-max-frequency = <20000000>; + mode = <0>; + + partition@0 { + reg = <0x0 0x80000>; + label = "u-boot"; + }; + }; + }; + + i2c@11000 { + status = "okay"; + + eeprom@50 { + compatible = "atmel,24c04"; + pagesize = <16>; + reg = <0x50>; + }; + }; + }; + + gpio_keys { + compatible = "gpio-keys"; + #address-cells = <1>; + #size-cells = <0>; + + power { + label = "Power push button"; + linux,code = <KEY_POWER>; + gpios = <&gpio1 0 GPIO_ACTIVE_HIGH>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + red-fail { + label = "ns2:red:fail"; + gpios = <&gpio0 12 GPIO_ACTIVE_HIGH>; + }; + }; + + gpio_poweroff { + compatible = "gpio-poweroff"; + gpios = <&gpio0 31 GPIO_ACTIVE_HIGH>; + }; + +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@X { + /* overwrite reg property in board file */ + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; diff --git a/arch/arm/dts/kirkwood-ns2.dts b/arch/arm/dts/kirkwood-ns2.dts new file mode 100644 index 000000000000..7b67083e1ec0 --- /dev/null +++ b/arch/arm/dts/kirkwood-ns2.dts @@ -0,0 +1,40 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include <dt-bindings/leds/leds-ns2.h> +#include "kirkwood-ns2-common.dtsi" + +/ { + model = "LaCie Network Space v2"; + compatible = "lacie,netspace_v2", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + ocp@f1000000 { + sata@80000 { + pinctrl-0 = <&pmx_ns2_sata0>; + pinctrl-names = "default"; + status = "okay"; + nr-ports = <1>; + }; + }; + + ns2-leds { + compatible = "lacie,ns2-leds"; + + blue-sata { + label = "ns2:blue:sata"; + slow-gpio = <&gpio0 29 0>; + cmd-gpio = <&gpio0 30 0>; + modes-map = <NS_V2_LED_OFF 1 0 + NS_V2_LED_ON 0 1 + NS_V2_LED_ON 1 1 + NS_V2_LED_SATA 0 0>; + }; + }; +}; + +ðphy0 { reg = <8>; }; diff --git a/arch/arm/dts/kirkwood-ns2lite.dts b/arch/arm/dts/kirkwood-ns2lite.dts new file mode 100644 index 000000000000..b0cb5907ed63 --- /dev/null +++ b/arch/arm/dts/kirkwood-ns2lite.dts @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "kirkwood-ns2-common.dtsi" + +/ { + model = "LaCie Network Space Lite v2"; + compatible = "lacie,netspace_lite_v2", "marvell,kirkwood-88f6192", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x8000000>; + }; + + ocp@f1000000 { + sata@80000 { + pinctrl-0 = <&pmx_ns2_sata0>; + pinctrl-names = "default"; + status = "okay"; + nr-ports = <1>; + }; + }; + + gpio-leds { + compatible = "gpio-leds"; + + blue-sata { + label = "ns2:blue:sata"; + gpios = <&gpio0 30 GPIO_ACTIVE_LOW>; + linux,default-trigger = "disk-activity"; + }; + }; +}; + +ðphy0 { reg = <0>; }; diff --git a/arch/arm/dts/kirkwood-ns2max.dts b/arch/arm/dts/kirkwood-ns2max.dts new file mode 100644 index 000000000000..c0a087e77408 --- /dev/null +++ b/arch/arm/dts/kirkwood-ns2max.dts @@ -0,0 +1,59 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include <dt-bindings/leds/leds-ns2.h> +#include "kirkwood-ns2-common.dtsi" + +/ { + model = "LaCie Network Space Max v2"; + compatible = "lacie,netspace_max_v2", "marvell,kirkwood-88f6281", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x10000000>; + }; + + ocp@f1000000 { + sata@80000 { + pinctrl-0 = <&pmx_ns2_sata0 &pmx_ns2_sata1>; + pinctrl-names = "default"; + status = "okay"; + nr-ports = <2>; + }; + }; + + gpio_fan { + compatible = "gpio-fan"; + gpios = <&gpio0 22 GPIO_ACTIVE_LOW + &gpio0 7 GPIO_ACTIVE_LOW + &gpio1 1 GPIO_ACTIVE_LOW + &gpio0 23 GPIO_ACTIVE_LOW>; + gpio-fan,speed-map = + < 0 0 + 1500 15 + 1700 14 + 1800 13 + 2100 12 + 3100 11 + 3300 10 + 4300 9 + 5500 8>; + alarm-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>; + }; + + ns2-leds { + compatible = "lacie,ns2-leds"; + + blue-sata { + label = "ns2:blue:sata"; + slow-gpio = <&gpio0 29 0>; + cmd-gpio = <&gpio0 30 0>; + modes-map = <NS_V2_LED_OFF 1 0 + NS_V2_LED_ON 0 1 + NS_V2_LED_ON 1 1 + NS_V2_LED_SATA 0 0>; + }; + }; +}; + +ðphy0 { reg = <8>; }; diff --git a/arch/arm/dts/kirkwood-ns2mini.dts b/arch/arm/dts/kirkwood-ns2mini.dts new file mode 100644 index 000000000000..5b9fa14b6428 --- /dev/null +++ b/arch/arm/dts/kirkwood-ns2mini.dts @@ -0,0 +1,60 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include <dt-bindings/leds/leds-ns2.h> +#include "kirkwood-ns2-common.dtsi" + +/ { + /* This machine is embedded in the first LaCie CloudBox product. */ + model = "LaCie Network Space Mini v2"; + compatible = "lacie,netspace_mini_v2", "marvell,kirkwood-88f6192", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x8000000>; + }; + + ocp@f1000000 { + sata@80000 { + pinctrl-0 = <&pmx_ns2_sata0>; + pinctrl-names = "default"; + status = "okay"; + nr-ports = <1>; + }; + }; + + gpio_fan { + compatible = "gpio-fan"; + gpios = <&gpio0 22 GPIO_ACTIVE_LOW + &gpio0 7 GPIO_ACTIVE_LOW + &gpio1 1 GPIO_ACTIVE_LOW + &gpio0 23 GPIO_ACTIVE_LOW>; + gpio-fan,speed-map = + < 0 0 + 3000 15 + 3180 14 + 4140 13 + 4570 12 + 6760 11 + 7140 10 + 7980 9 + 9200 8>; + alarm-gpios = <&gpio0 25 GPIO_ACTIVE_LOW>; + }; + + ns2-leds { + compatible = "lacie,ns2-leds"; + + blue-sata { + label = "ns2:blue:sata"; + slow-gpio = <&gpio0 29 0>; + cmd-gpio = <&gpio0 30 0>; + modes-map = <NS_V2_LED_OFF 1 0 + NS_V2_LED_ON 0 1 + NS_V2_LED_ON 1 1 + NS_V2_LED_SATA 0 0>; + }; + }; +}; + +ðphy0 { reg = <0>; }; diff --git a/configs/inetspace_v2_defconfig b/configs/inetspace_v2_defconfig index 9f8677b74471..2fb7209f31a6 100644 --- a/configs/inetspace_v2_defconfig +++ b/configs/inetspace_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" IS v2" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-is2" CONFIG_SYS_EXTRA_OPTIONS="INETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -26,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -39,4 +41,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/netspace_lite_v2_defconfig b/configs/netspace_lite_v2_defconfig index d37146dc94bb..c0e3651e6e03 100644 --- a/configs/netspace_lite_v2_defconfig +++ b/configs/netspace_lite_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2 Lite" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2lite" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_LITE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -26,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -39,4 +41,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/netspace_max_v2_defconfig b/configs/netspace_max_v2_defconfig index 9b639c017b30..db75e6d55060 100644 --- a/configs/netspace_max_v2_defconfig +++ b/configs/netspace_max_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS Max v2" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2max" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MAX_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -26,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -39,4 +41,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/configs/netspace_mini_v2_defconfig b/configs/netspace_mini_v2_defconfig index ee7554fd3f98..fd774c722afb 100644 --- a/configs/netspace_mini_v2_defconfig +++ b/configs/netspace_mini_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2 Mini" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2mini" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_MINI_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -24,6 +25,7 @@ CONFIG_CMD_EXT2=y CONFIG_CMD_FAT=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -34,4 +36,3 @@ CONFIG_MVGBE=y CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y -CONFIG_OF_LIBFDT=y diff --git a/configs/netspace_v2_defconfig b/configs/netspace_v2_defconfig index 6421706de043..ebdb16b16f58 100644 --- a/configs/netspace_v2_defconfig +++ b/configs/netspace_v2_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x600000 CONFIG_TARGET_NETSPACE_V2=y CONFIG_IDENT_STRING=" NS v2" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-ns2" CONFIG_SYS_EXTRA_OPTIONS="NETSPACE_V2" CONFIG_BOOTDELAY=3 CONFIG_USE_BOOTARGS=y @@ -26,6 +27,7 @@ CONFIG_CMD_FAT=y CONFIG_ISO_PARTITION=y CONFIG_EFI_PARTITION=y # CONFIG_PARTITION_UUIDS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_MVSATA_IDE=y # CONFIG_MMC is not set @@ -39,4 +41,3 @@ CONFIG_KIRKWOOD_SPI=y CONFIG_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y -CONFIG_OF_LIBFDT=y diff --git a/include/dt-bindings/leds/leds-ns2.h b/include/dt-bindings/leds/leds-ns2.h new file mode 100644 index 000000000000..fd615749e703 --- /dev/null +++ b/include/dt-bindings/leds/leds-ns2.h @@ -0,0 +1,9 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +#ifndef _DT_BINDINGS_LEDS_NS2_H +#define _DT_BINDINGS_LEDS_NS2_H + +#define NS_V2_LED_OFF 0 +#define NS_V2_LED_ON 1 +#define NS_V2_LED_SATA 2 + +#endif
arch/arm/dts/kirkwood-km_common.dtsi | 47 +++++++++++++++++++++++++++ arch/arm/dts/kirkwood-km_kirkwood.dts | 31 ++++++++++++++++++ configs/km_kirkwood_128m16_defconfig | 3 +- configs/km_kirkwood_defconfig | 3 +- configs/km_kirkwood_pci_defconfig | 3 +- configs/kmcoge5un_defconfig | 3 +- configs/kmnusa_defconfig | 3 +- configs/kmsugp1_defconfig | 3 +- configs/kmsuv31_defconfig | 3 +- configs/mgcoge3un_defconfig | 3 +- 10 files changed, 94 insertions(+), 8 deletions(-) create mode 100644 arch/arm/dts/kirkwood-km_common.dtsi create mode 100644 arch/arm/dts/kirkwood-km_kirkwood.dts
diff --git a/arch/arm/dts/kirkwood-km_common.dtsi b/arch/arm/dts/kirkwood-km_common.dtsi new file mode 100644 index 000000000000..75dc83914f56 --- /dev/null +++ b/arch/arm/dts/kirkwood-km_common.dtsi @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0 +/ { + chosen { + bootargs = "console=ttyS0,115200n8 earlyprintk"; + stdout-path = &uart0; + }; + + ocp@f1000000 { + pinctrl: pin-controller@10000 { + pinctrl-0 = < &pmx_i2c_gpio_sda &pmx_i2c_gpio_scl >; + pinctrl-names = "default"; + + pmx_i2c_gpio_sda: pmx-gpio-sda { + marvell,pins = "mpp8"; + marvell,function = "gpio"; + }; + pmx_i2c_gpio_scl: pmx-gpio-scl { + marvell,pins = "mpp9"; + marvell,function = "gpio"; + }; + }; + + serial@12000 { + status = "okay"; + }; + }; + + i2c { + compatible = "i2c-gpio"; + gpios = < &gpio0 8 GPIO_ACTIVE_HIGH /* sda */ + &gpio0 9 GPIO_ACTIVE_HIGH>; /* scl */ + i2c-gpio,delay-us = <2>; /* ~100 kHz */ + }; +}; + +&nand { + status = "okay"; + chip-delay = <25>; +}; + +&pciec { + status = "okay"; +}; + +&pcie0 { + status = "okay"; +}; diff --git a/arch/arm/dts/kirkwood-km_kirkwood.dts b/arch/arm/dts/kirkwood-km_kirkwood.dts new file mode 100644 index 000000000000..f035eff1c111 --- /dev/null +++ b/arch/arm/dts/kirkwood-km_kirkwood.dts @@ -0,0 +1,31 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "kirkwood.dtsi" +#include "kirkwood-98dx4122.dtsi" +#include "kirkwood-km_common.dtsi" + +/ { + model = "Keymile Kirkwood Reference Design"; + compatible = "keymile,km_kirkwood", "marvell,kirkwood-98DX4122", "marvell,kirkwood"; + + memory { + device_type = "memory"; + reg = <0x00000000 0x08000000>; + }; +}; + +&mdio { + status = "okay"; + + ethphy0: ethernet-phy@0 { + reg = <0>; + }; +}; + +ð0 { + status = "okay"; + ethernet0-port@0 { + phy-handle = <ðphy0>; + }; +}; diff --git a/configs/km_kirkwood_128m16_defconfig b/configs/km_kirkwood_128m16_defconfig index 5d5b485cf716..e41ec8990d98 100644 --- a/configs/km_kirkwood_128m16_defconfig +++ b/configs/km_kirkwood_128m16_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile Kirkwood 128M16" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_128M16" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/km_kirkwood_defconfig b/configs/km_kirkwood_defconfig index b07f36beaf47..fcab051ad63a 100644 --- a/configs/km_kirkwood_defconfig +++ b/configs/km_kirkwood_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile Kirkwood" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/km_kirkwood_pci_defconfig b/configs/km_kirkwood_pci_defconfig index 31dcd0ca1b17..4fc83a5ec813 100644 --- a/configs/km_kirkwood_pci_defconfig +++ b/configs/km_kirkwood_pci_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile Kirkwood PCI" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_KIRKWOOD_PCI" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmcoge5un_defconfig b/configs/kmcoge5un_defconfig index 116369acf79b..4b1edb4c0a5a 100644 --- a/configs/kmcoge5un_defconfig +++ b/configs/kmcoge5un_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile COGE5UN" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_COGE5UN" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmnusa_defconfig b/configs/kmnusa_defconfig index be7421ca58a4..90d9a557b3f4 100644 --- a/configs/kmnusa_defconfig +++ b/configs/kmnusa_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile NUSA" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_NUSA" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmsugp1_defconfig b/configs/kmsugp1_defconfig index 535e8693b067..132db201ef3e 100644 --- a/configs/kmsugp1_defconfig +++ b/configs/kmsugp1_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile SUGP1" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_SUGP1" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/kmsuv31_defconfig b/configs/kmsuv31_defconfig index 59522e733e6c..7b5b016f2854 100644 --- a/configs/kmsuv31_defconfig +++ b/configs/kmsuv31_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile SUV31" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_SUV31" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y diff --git a/configs/mgcoge3un_defconfig b/configs/mgcoge3un_defconfig index abf9cdcbfaac..baee230c7041 100644 --- a/configs/mgcoge3un_defconfig +++ b/configs/mgcoge3un_defconfig @@ -3,6 +3,7 @@ CONFIG_KIRKWOOD=y CONFIG_SYS_TEXT_BASE=0x07d00000 CONFIG_TARGET_KM_KIRKWOOD=y CONFIG_IDENT_STRING="\nKeymile COGE3UN" +CONFIG_DEFAULT_DEVICE_TREE="kirkwood-km_kirkwood" CONFIG_SYS_EXTRA_OPTIONS="KM_MGCOGE3UN" CONFIG_VERSION_VARIABLE=y # CONFIG_DISPLAY_BOARDINFO is not set @@ -25,6 +26,7 @@ CONFIG_MTDIDS_DEFAULT="nand0=orion_nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=orion_nand:-(ubi0);" CONFIG_CMD_UBI=y # CONFIG_CMD_UBIFS is not set +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_EEPROM=y CONFIG_BOOTCOUNT_LIMIT=y CONFIG_BOOTCOUNT_RAM=y @@ -37,4 +39,3 @@ CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_KIRKWOOD_SPI=y CONFIG_BCH=y -CONFIG_OF_LIBFDT=y
On Thu, May 17, 2018 at 09:45:55PM +1200, Chris Packham wrote:
This is the second round of updating kirkwood boards to OF_CONTROL. Most of these boards use spi flash so I've added the u-boot specific "spi-flash" compatible string where appropriate.
Hi Chris,
Thanks for converting the LaCie boards to device tree. I'll test them as soon as possible.
Simon
Chris Packham (6): ARM: kirkwood: Add device-tree for d2net_v2 & net2big_v2 ARM: kirkwood: Add device-tree for dreamplug ARM: kirkwood: Add device-tree for ds109 ARM: kirkwood: Add device-tree for lschlv2 & lsxhl ARM: kirkwood: Add device-tree for netspace & inetspace ARM: kirkwood: Add device-tree for keymile
arch/arm/dts/kirkwood-d2net.dts | 45 ++ arch/arm/dts/kirkwood-dreamplug.dts | 127 ++++ arch/arm/dts/kirkwood-ds109.dts | 40 ++ arch/arm/dts/kirkwood-is2.dts | 40 ++ arch/arm/dts/kirkwood-km_common.dtsi | 47 ++ arch/arm/dts/kirkwood-km_kirkwood.dts | 31 + arch/arm/dts/kirkwood-lschlv2.dts | 20 + arch/arm/dts/kirkwood-lsxhl.dts | 20 + arch/arm/dts/kirkwood-lsxl.dtsi | 237 +++++++ arch/arm/dts/kirkwood-net2big.dts | 63 ++ arch/arm/dts/kirkwood-netxbig.dtsi | 232 +++++++ arch/arm/dts/kirkwood-ns2-common.dtsi | 97 +++ arch/arm/dts/kirkwood-ns2.dts | 40 ++ arch/arm/dts/kirkwood-ns2lite.dts | 35 + arch/arm/dts/kirkwood-ns2max.dts | 59 ++ arch/arm/dts/kirkwood-ns2mini.dts | 60 ++ arch/arm/dts/kirkwood-synology.dtsi | 855 ++++++++++++++++++++++++ configs/d2net_v2_defconfig | 3 +- configs/dreamplug_defconfig | 3 +- configs/ds109_defconfig | 2 + configs/inetspace_v2_defconfig | 3 +- configs/km_kirkwood_128m16_defconfig | 3 +- configs/km_kirkwood_defconfig | 3 +- configs/km_kirkwood_pci_defconfig | 3 +- configs/kmcoge5un_defconfig | 3 +- configs/kmnusa_defconfig | 3 +- configs/kmsugp1_defconfig | 3 +- configs/kmsuv31_defconfig | 3 +- configs/lschlv2_defconfig | 3 +- configs/lsxhl_defconfig | 3 +- configs/mgcoge3un_defconfig | 3 +- configs/net2big_v2_defconfig | 3 +- configs/netspace_lite_v2_defconfig | 3 +- configs/netspace_max_v2_defconfig | 3 +- configs/netspace_mini_v2_defconfig | 3 +- configs/netspace_v2_defconfig | 3 +- include/dt-bindings/leds/leds-netxbig.h | 18 + include/dt-bindings/leds/leds-ns2.h | 9 + 38 files changed, 2113 insertions(+), 18 deletions(-) create mode 100644 arch/arm/dts/kirkwood-d2net.dts create mode 100644 arch/arm/dts/kirkwood-dreamplug.dts create mode 100644 arch/arm/dts/kirkwood-ds109.dts create mode 100644 arch/arm/dts/kirkwood-is2.dts create mode 100644 arch/arm/dts/kirkwood-km_common.dtsi create mode 100644 arch/arm/dts/kirkwood-km_kirkwood.dts create mode 100644 arch/arm/dts/kirkwood-lschlv2.dts create mode 100644 arch/arm/dts/kirkwood-lsxhl.dts create mode 100644 arch/arm/dts/kirkwood-lsxl.dtsi create mode 100644 arch/arm/dts/kirkwood-net2big.dts create mode 100644 arch/arm/dts/kirkwood-netxbig.dtsi create mode 100644 arch/arm/dts/kirkwood-ns2-common.dtsi create mode 100644 arch/arm/dts/kirkwood-ns2.dts create mode 100644 arch/arm/dts/kirkwood-ns2lite.dts create mode 100644 arch/arm/dts/kirkwood-ns2max.dts create mode 100644 arch/arm/dts/kirkwood-ns2mini.dts create mode 100644 arch/arm/dts/kirkwood-synology.dtsi create mode 100644 include/dt-bindings/leds/leds-netxbig.h create mode 100644 include/dt-bindings/leds/leds-ns2.h
-- 2.17.0
Series applied to u-boot-marvell/master
Thanks, Stefan
Chris Packham
Simon Guinot
Stefan Roese
