[U-Boot] [PATCH] board/g2000/strataflash.c: fix GCC 4.6 build warnings
Fix: strataflash.c: In function 'flash_write_cfiword': strataflash.c:669:11: warning: variable 'ctladdr' set but not used [-Wunused-but-set-variable]
Signed-off-by: Wolfgang Denk wd@denx.de --- board/g2000/strataflash.c | 3 --- 1 files changed, 0 insertions(+), 3 deletions(-)
diff --git a/board/g2000/strataflash.c b/board/g2000/strataflash.c index effe65a..fd72f47 100644 --- a/board/g2000/strataflash.c +++ b/board/g2000/strataflash.c @@ -666,14 +666,11 @@ static ulong flash_get_size (ulong base, int banknum) static int flash_write_cfiword (flash_info_t *info, ulong dest, cfiword_t cword) {
- cfiptr_t ctladdr; cfiptr_t cptr; int flag;
- ctladdr.cp = flash_make_addr(info, 0, 0); cptr.cp = (uchar *)dest;
- /* Check if Flash is (sufficiently) erased */ switch(info->portwidth) { case FLASH_CFI_8BIT:
Dear Wolfgang Denk,
Applied, thanks.
