[PATCH v2 0/6] imx8(m): add optee node to binman FIT image
There have been attempts to get op-tee node integrated upstream in the past [1][2]. The challenge is on how to handle the load and entry addresses where the op-tee image should be loaded to. Different SoC families and architectures have different RAM base addresses. Further the final addresses can vary from board to board (e.g. depending on populated RAM size). This approach follows the TI k3 kconfig solution. To be able to define a sensible default for the new config option, put it in the imx8m kconfig. For other imx families, the RAM start addresses are different and thus finding a common sensible default is not possible. I do not have a working Nano board so I was not able to test imx8mn.
I included usage for PHYTEC boards for examples (with documentation).
[1] https://patchwork.ozlabs.org/project/uboot/patch/20230622173006.3921891-1-th... [2] https://patchwork.ozlabs.org/project/uboot/patch/ZeHDVr-Bzm935-5N@mecka.net/
--- Changes in v2 (from RFC): - Use kconfig instead of trying pure dt approach. - Add load addresses in defconfigs instead of <board>-u-boot dts.
--- Yannic Moog (6): arm: imx8m: add OP-TEE node phycore-imx8mp_defconfig: add optee load address imx8mm-phygate-tauri-l_defconfig: add optee load address phycore-imx8mm_defconfig: add optee load address doc: phytec: imx8mp: add OP-TEE documentation doc: phytec: imx8mm: add OP-TEE integration instructions
arch/arm/dts/imx8mm-u-boot.dtsi | 17 ++++++++++++++++- arch/arm/dts/imx8mn-u-boot.dtsi | 17 ++++++++++++++++- arch/arm/dts/imx8mp-u-boot.dtsi | 17 ++++++++++++++++- arch/arm/mach-imx/imx8m/Kconfig | 8 ++++++++ configs/imx8mm-phygate-tauri-l_defconfig | 1 + configs/phycore-imx8mm_defconfig | 1 + configs/phycore-imx8mp_defconfig | 1 + doc/board/phytec/imx8mm-phygate-tauri-l.rst | 26 +++++++++++++++++++++++++- doc/board/phytec/phycore-imx8mm.rst | 25 ++++++++++++++++++++++++- doc/board/phytec/phycore-imx8mp.rst | 26 +++++++++++++++++++++++++- 10 files changed, 133 insertions(+), 6 deletions(-) --- base-commit: d88bcd6d247a2b5d1683e393d8c9dc0259cd29f0 change-id: 20240903-phytec_imx8m_optee-8674ef012a36
Add tee node in SoC u-boot device trees. Use a kconfig entry to specify load and entry addresses for the op-tee image in the respective defconfig.
Signed-off-by: Yannic Moog y.moog@phytec.de --- arch/arm/dts/imx8mm-u-boot.dtsi | 17 ++++++++++++++++- arch/arm/dts/imx8mn-u-boot.dtsi | 17 ++++++++++++++++- arch/arm/dts/imx8mp-u-boot.dtsi | 17 ++++++++++++++++- arch/arm/mach-imx/imx8m/Kconfig | 8 ++++++++ 4 files changed, 56 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/imx8mm-u-boot.dtsi b/arch/arm/dts/imx8mm-u-boot.dtsi index d31bc822532..ecc2319279e 100644 --- a/arch/arm/dts/imx8mm-u-boot.dtsi +++ b/arch/arm/dts/imx8mm-u-boot.dtsi @@ -164,6 +164,21 @@ }; #endif
+ tee: tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <CONFIG_IMX8M_OPTEE_LOAD_ADDR>; + entry = <CONFIG_IMX8M_OPTEE_LOAD_ADDR>; + + tee-os { + filename = "tee.bin"; + optional; + }; + }; + binman_fip: fip { arch = "arm64"; compression = "none"; @@ -192,7 +207,7 @@ fdt = "fdt-SEQ"; firmware = "uboot"; #ifndef CONFIG_ARMV8_PSCI - loadables = "atf"; + loadables = "atf", "tee"; #endif }; }; diff --git a/arch/arm/dts/imx8mn-u-boot.dtsi b/arch/arm/dts/imx8mn-u-boot.dtsi index 6875c6d44ff..f9108cb75c7 100644 --- a/arch/arm/dts/imx8mn-u-boot.dtsi +++ b/arch/arm/dts/imx8mn-u-boot.dtsi @@ -235,6 +235,21 @@ }; #endif
+ tee: tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <CONFIG_IMX8M_OPTEE_LOAD_ADDR>; + entry = <CONFIG_IMX8M_OPTEE_LOAD_ADDR>; + + tee-os { + filename = "tee.bin"; + optional; + }; + }; + binman_fip: fip { arch = "arm64"; compression = "none"; @@ -263,7 +278,7 @@ fdt = "fdt-SEQ"; firmware = "uboot"; #ifndef CONFIG_ARMV8_PSCI - loadables = "atf"; + loadables = "atf", "tee"; #endif }; }; diff --git a/arch/arm/dts/imx8mp-u-boot.dtsi b/arch/arm/dts/imx8mp-u-boot.dtsi index 56749ccacd2..9ede98a11e4 100644 --- a/arch/arm/dts/imx8mp-u-boot.dtsi +++ b/arch/arm/dts/imx8mp-u-boot.dtsi @@ -185,6 +185,21 @@ }; #endif
+ tee: tee { + description = "OP-TEE"; + type = "tee"; + arch = "arm64"; + compression = "none"; + os = "tee"; + load = <CONFIG_IMX8M_OPTEE_LOAD_ADDR>; + entry = <CONFIG_IMX8M_OPTEE_LOAD_ADDR>; + + tee-os { + filename = "tee.bin"; + optional; + }; + }; + @fdt-SEQ { description = "NAME"; type = "flat_dt"; @@ -204,7 +219,7 @@ fdt = "fdt-SEQ"; firmware = "uboot"; #ifndef CONFIG_ARMV8_PSCI - loadables = "atf"; + loadables = "atf", "tee"; #endif }; }; diff --git a/arch/arm/mach-imx/imx8m/Kconfig b/arch/arm/mach-imx/imx8m/Kconfig index b254a50b091..14f14db6a35 100644 --- a/arch/arm/mach-imx/imx8m/Kconfig +++ b/arch/arm/mach-imx/imx8m/Kconfig @@ -37,6 +37,14 @@ config SYS_HAS_ARMV8_SECURE_BASE If enabled, please also define the value for ARMV8_SECURE_BASE, for i.MX8M, it could be some address in OCRAM.
+config IMX8M_OPTEE_LOAD_ADDR + hex "Load address of OPTEE image" + default 0x56000000 + help + The load and entry address for the OPTEE image. This value defaults to + 0x56000000 if not provided in the board defconfig file. + + choice prompt "NXP i.MX8M board select" optional
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
Hi Yannic,
Thanks for working on this.
Don't you need to protect this block with an #ifdef CONFIG_IMX8M_OPTEE_LOAD_ADDR? I would expect binman to fail if it doesn't find tee.bin and has an empty load/entry address.
Also, when I attempted this patch some time ago it was accepted but failed CI which is something I never had time to figure out and address. The failure had something to do with adding the Kconfig and you should be able to find the discussion with a pointer to the failure in your references above.
Did you make sure CI passes?
Best Regards,
Tim
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
default 0x56000000
help
-- 2.43.0
Hi Tim,
Hi Yannic,
I do not need to do that because the config is defined for all imx8m boards. If I didn't define a default, the kconfig mechanism prompts for a value for the load addr.
I took a look at your patch before working on this series and to the best of my knowledge the challenge was that you defined the kconfig for all boards and failed for other architectures or no architecture in that particular case afaik. The solution is to define a default value, but obviously it should at least be a valid address. To illustrate, some of our (Phytec imx8m) boards have 1GiB RAM (up to 0x80000000) and for e.g. imx93 RAM starts at 0x90000000, the only good option is to put it in the imx8m Kconfig.
I did test the failed CI that Stefano highlighted at the time and that passes. For others I don't know.
Yannic
Best Regards,
Tim
-- 2.43.0
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
default 0x56000000
help
I think this would need to vary based on the platform. I think the addresses may be different depending on Mini, Nano and Plus and also dependent on the available SDRAM.
-- 2.43.0
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
default 0x56000000
help
Indeed the address differs for platform (as the DRAM base address does) and is also based on the DRAM size of the board. Here are my notes for IMX8M:
The address is the link/load address for TEE that should match BL32_BASE for the ATF (for imx8m) and CFG_TZDRAM_START for OPTEE. The BL32_BASE is the same for imx8mm/n/p but it does depend on the size of DRAM. The address should be the top 32MiB of DRAM but because U-Boot is loading tee.bin from a FIT image into DRAM it needs to be a 32bit address and thus needs to be adjusted down if you are on a board with 4GiB: 1GiB DRAM use 0x7e000000 2GiB DRAM use 0xbe000000 3GiB or larger use 0xfe000000
Best Regards,
Tim
I agree the addresses may be different. To my knowledge you can take whatever (32bit) address you want within addressable RAM as load address. I assume you are looking for sensible defaults here. It appears to me the challenge is agreeing on a sensible value. Do you have any suggestions?
Yannic
Best Regards,
Tim
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
tee: tee {
type = "tee";
arch = "arm64";
os = "tee";
tee-os {
optional;
loadables = "atf";
default 0x56000000
help
On my Mini with 2GB of RAM, there are several definitions: PHYS_SDRAM 0x40000000 PHYS_SDRAM_SIZE 0x80000000 /* 2GB DDR */
What we if did a calculation like: PHYS_SDRAM + MIN(PHYS_SDRAM_SIZE, 0xc0000000) - 0x2000000
With 2 GB of RAM, it would be 0xbe000000
My Nano Board has the following:
PHYS_SDRAM 0x40000000 PHYS_SDRAM_SIZE 0x40000000
That calculation should return 7E000000.
I am not sure if we can do MIN and MAX functions in the precompiler, but it would then cap the value to 0xfe000000
adam
Yannic
Best Regards,
Tim
Math looks good to me, however I don't understand where we would put this in the source code. How can we set this as default while having access to the macros?
Yannic
adam
Yannic
Best Regards,
Tim
Hi Adam,
As I don't think it is possible to implement the mechanic as you suggested, I would like to keep it simple.
trusted-firmware-a also has default for BL32_BASE. I would like to set the OPTEE_LOAD_ADDR as they are set in tf-a. This has the advantage that for users who don't change the default, they can rely on it being consistent across projects.
Yannic
Yannic
adam
Yannic
Best Regards,
Tim
upstream mailing list upstream@lists.phytec.de http://lists.phytec.de/cgi-bin/mailman/listinfo/upstream
The phyBOARD-Pollux expects 0x56000000 address to load optee.
Signed-off-by: Yannic Moog y.moog@phytec.de --- configs/phycore-imx8mp_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/phycore-imx8mp_defconfig b/configs/phycore-imx8mp_defconfig index 1240c7fcbd0..910109afd80 100644 --- a/configs/phycore-imx8mp_defconfig +++ b/configs/phycore-imx8mp_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_IMX8M_OPTEE_LOAD_ADDR=0x56000000 CONFIG_PHYTEC_SOM_DETECTION=y CONFIG_SF_DEFAULT_SPEED=80000000 CONFIG_ENV_SIZE=0x10000
Hi Yannic,
Am 07.11.24 um 09:23 schrieb Yannic Moog:
You are already defining a default for IMX8M_OPTEE_LOAD_ADDR in the mach-imx Kconf. You can drop the patches touching the defconfigs.
Regards, Wadim
Hi Wadim,
On Thu, 2024-11-07 at 09:52 +0100, Wadim Egorov wrote:
Hi Yannic,
I would like to keep these patches as the default value is "only" there to get a functioning build. To me it would seem there has been no thought put in to what the actual correct value would be if left as default. Does that make sense?
Yannic
Regards, Wadim
Am 08.11.24 um 13:55 schrieb Yannic Moog:
Hi Wadim,
Hi Yannic,
Yes, this makes sense. Up to you, it was just a hint.
Well, it will become de facto standard if you put a default value into the Kconfig regardless if there has been no thoughts on the best location for it. Other boards will probably just follow and reuse it anyway.
Yannic
Regards, Wadim
The phyGATE-Tauri-L expects 0x56000000 address to load optee.
Signed-off-by: Yannic Moog y.moog@phytec.de --- configs/imx8mm-phygate-tauri-l_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/imx8mm-phygate-tauri-l_defconfig b/configs/imx8mm-phygate-tauri-l_defconfig index c69fe50ec81..2e1071b4058 100644 --- a/configs/imx8mm-phygate-tauri-l_defconfig +++ b/configs/imx8mm-phygate-tauri-l_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_IMX8M_OPTEE_LOAD_ADDR=0x56000000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3C0000 CONFIG_DM_GPIO=y
The phyCORE i.MX 8M Mini expects 0x56000000 address to load optee.
Signed-off-by: Yannic Moog y.moog@phytec.de --- configs/phycore-imx8mm_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/phycore-imx8mm_defconfig b/configs/phycore-imx8mm_defconfig index 48a0c0b8b4e..240b5f75a98 100644 --- a/configs/phycore-imx8mm_defconfig +++ b/configs/phycore-imx8mm_defconfig @@ -5,6 +5,7 @@ CONFIG_SYS_MALLOC_LEN=0x2000000 CONFIG_SPL_GPIO=y CONFIG_SPL_LIBCOMMON_SUPPORT=y CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_IMX8M_OPTEE_LOAD_ADDR=0x56000000 CONFIG_SF_DEFAULT_SPEED=80000000 CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x3C0000
Add documentation for the phyBOARD-Pollux i.MX 8M Plus on OP-TEE integration. Also add missing '-' to TF-A build instruction while at it.
Signed-off-by: Yannic Moog y.moog@phytec.de --- doc/board/phytec/phycore-imx8mp.rst | 26 +++++++++++++++++++++++++- 1 file changed, 25 insertions(+), 1 deletion(-)
diff --git a/doc/board/phytec/phycore-imx8mp.rst b/doc/board/phytec/phycore-imx8mp.rst index fda751aeffb..4bcfa9f39ca 100644 --- a/doc/board/phytec/phycore-imx8mp.rst +++ b/doc/board/phytec/phycore-imx8mp.rst @@ -9,6 +9,7 @@ Quick Start -----------
- Build the ARM Trusted firmware binary +- Build the OP-TEE binary (optional) - Get ddr firmware - Build U-Boot - Boot @@ -20,10 +21,32 @@ Build the ARM Trusted firmware binary
$ git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git $ cd trusted-firmware-a - $ export CROSS_COMPILE=aarch64-linux-gnu + $ export CROSS_COMPILE=aarch64-linux-gnu- $ export IMX_BOOT_UART_BASE=0x30860000 + $ # with optee + $ make PLAT=imx8mp SPD=opteed bl31 + $ # without optee $ make PLAT=imx8mp bl31
+Build the OP-TEE binary (optional) +---------------------------------- + +.. code-block:: bash + + $ git clone https://github.com/OP-TEE/optee_os.git + $ cd optee_os + $ make CFG_ARM64_core=y \ + CFG_TEE_BENCHMARK=n \ + CROSS_COMPILE=aarch64-linux-gnu- \ + CROSS_COMPILE_core=aarch64-linux-gnu- \ + CROSS_COMPILE_ta_arm32=arm-linux-gnueabihf- \ + CROSS_COMPILE_ta_arm64=aarch64-linux-gnu- \ + O=out/arm \ + PLATFORM=imx-mx8mpevk \ + CFG_TZDRAM_START=0x56000000 \ + CFG_DDR_SIZE=0x80000000 \ + CFG_UART_BASE=UART1_BASE + Get the ddr firmware --------------------
@@ -42,6 +65,7 @@ Copy binaries .. code-block:: bash
$ cp <TF-A dir>/build/imx8mp/release/bl31.bin . + $ cp <OP-TEE dir>/out/arm/core/tee-raw.bin tee.bin $ cp firmware-imx-8.19/firmware/ddr/synopsys/lpddr4*.bin .
Build U-Boot
Would it make sense to move these instructions into a more general section, so they could be reused by other imx based boards as well?
Seems you missed to update imx8mm-phygate-tauri-l.rst
- Get ddr firmware
- Build U-Boot
- Boot
- $ export CROSS_COMPILE=aarch64-linux-gnu- $ export IMX_BOOT_UART_BASE=0x30860000
- $ # with optee
- $ make PLAT=imx8mp SPD=opteed bl31
- $ # without optee $ make PLAT=imx8mp bl31
- $ git clone https://github.com/OP-TEE/optee_os.git
- $ cd optee_os
- $ make CFG_ARM64_core=y \
O=out/arm \
Build U-Boot
I have not put much thought into it. At first glance though, when reading the documentation for a board I don't want to be redirected to other pages. So using an include comes to mind. Is that what you had in mind as well?
Should be in the (next) patch for the imx8mm, as Tauri is based on phycore-imx8mm. Let me know if you meant something else.
Yannic
diff --git a/doc/board/phytec/phycore-imx8mp.rst b/doc/board/phytec/phycore-imx8mp.rst index fda751aeffb..4bcfa9f39ca 100644 --- a/doc/board/phytec/phycore-imx8mp.rst +++ b/doc/board/phytec/phycore-imx8mp.rst @@ -9,6 +9,7 @@ Quick Start ----------- - Build the ARM Trusted firmware binary +- Build the OP-TEE binary (optional) - Get ddr firmware - Build U-Boot - Boot @@ -20,10 +21,32 @@ Build the ARM Trusted firmware binary $ git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git $ cd trusted-firmware-a - $ export CROSS_COMPILE=aarch64-linux-gnu + $ export CROSS_COMPILE=aarch64-linux-gnu- $ export IMX_BOOT_UART_BASE=0x30860000 + $ # with optee + $ make PLAT=imx8mp SPD=opteed bl31 + $ # without optee $ make PLAT=imx8mp bl31 +Build the OP-TEE binary (optional) +----------------------------------
Get the ddr firmware -------------------- @@ -42,6 +65,7 @@ Copy binaries .. code-block:: bash $ cp <TF-A dir>/build/imx8mp/release/bl31.bin . + $ cp <OP-TEE dir>/out/arm/core/tee-raw.bin tee.bin $ cp firmware-imx-8.19/firmware/ddr/synopsys/lpddr4*.bin . Build U-Boot
Am 08.11.24 um 13:59 schrieb Yannic Moog:
Yes, I was thinking about using includes to reduce doc duplication.
Ah! I missed that you change both files in the next patch.
Yannic
Build U-Boot
Add instructions on how to build and package OP-TEE for the phycore-imx8mm based boards. The build instructions are identical for phyGATE-Tauri-L and phyBOARD-Polis. Also fix missig '-' for TF-A build instructions.
Signed-off-by: Yannic Moog y.moog@phytec.de --- doc/board/phytec/imx8mm-phygate-tauri-l.rst | 26 +++++++++++++++++++++++++- doc/board/phytec/phycore-imx8mm.rst | 25 ++++++++++++++++++++++++- 2 files changed, 49 insertions(+), 2 deletions(-)
diff --git a/doc/board/phytec/imx8mm-phygate-tauri-l.rst b/doc/board/phytec/imx8mm-phygate-tauri-l.rst index 28b614fd144..d9b5124365e 100644 --- a/doc/board/phytec/imx8mm-phygate-tauri-l.rst +++ b/doc/board/phytec/imx8mm-phygate-tauri-l.rst @@ -9,6 +9,7 @@ Quick Start -----------
$ git clone https://git.trustedfirmware.org/TF-A/trusted-firmware-a.git $ cd trusted-firmware-a - $ export CROSS_COMPILE=aarch64-linux-gnu + $ export CROSS_COMPILE=aarch64-linux-gnu- $ export IMX_BOOT_UART_BASE=0x30880000 + $ # with optee + $ make PLAT=imx8mm BL32_BASE=0x56000000 SPD=opteed bl31 + $ # without optee $ make PLAT=imx8mm bl31
+Build the OP-TEE binary (optional) +---------------------------------- + +.. code-block:: bash + + $ git clone https://github.com/OP-TEE/optee_os.git + $ cd optee_os + $ make CFG_ARM64_core=y \ + CFG_TEE_BENCHMARK=n \ + CROSS_COMPILE=aarch64-linux-gnu- \ + CROSS_COMPILE_core=aarch64-linux-gnu- \ + CROSS_COMPILE_ta_arm32=arm-linux-gnueabihf- \ + CROSS_COMPILE_ta_arm64=aarch64-linux-gnu- \ + O=out/arm \ + PLATFORM=imx-mx8mmevk \ + CFG_TZDRAM_START=0x56000000 \ + CFG_DDR_SIZE=0x80000000 \ + CFG_UART_BASE=UART3_BASE + Get the ddr firmware --------------------
$ cp <TF-A dir>/build/imx8mm/release/bl31.bin . + $ cp <OP-TEE dir>/out/arm/core/tee-raw.bin tee.bin $ cp firmware-imx-8.23/firmware/ddr/synopsys/lpddr4*.bin .
Build U-Boot diff --git a/doc/board/phytec/phycore-imx8mm.rst b/doc/board/phytec/phycore-imx8mm.rst index e9dc2259907..5a4e8a669c6 100644 --- a/doc/board/phytec/phycore-imx8mm.rst +++ b/doc/board/phytec/phycore-imx8mm.rst @@ -9,6 +9,7 @@ Quick Start -----------
participants (5)
Adam Ford
Tim Harvey
Wadim Egorov
Yannic Moog
Yannic Moog
