[U-Boot] [PATCH 1/2] ARM: at91sam9m10g45ek: enable mci0 support
Enable mci0 support. And enable the mmc command in configuration file.
As both CONFIG_CMD_MMC and CONFIG_CMD_USB use the CONFIG_DOS_PARTITION, so remove the redundant CONFIG_DOS_PARTITION definition.
Signed-off-by: Josh Wu josh.wu@atmel.com --- board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c | 28 +++++++++++++++++++++++ include/configs/at91sam9m10g45ek.h | 15 +++++++++++- 2 files changed, 42 insertions(+), 1 deletion(-)
diff --git a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c index b7e2efd..fd6860b 100644 --- a/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c +++ b/board/atmel/at91sam9m10g45ek/at91sam9m10g45ek.c @@ -15,7 +15,9 @@ #include <asm/arch/gpio.h> #include <asm/arch/clk.h> #include <lcd.h> +#include <mmc.h> #include <atmel_lcdc.h> +#include <atmel_mci.h> #if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_MACB) #include <net.h> #endif @@ -217,6 +219,29 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif
+#ifdef CONFIG_GENERIC_ATMEL_MCI +void at91sam9m10g45ek_mci_hw_init(void) +{ + struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC; + + at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* MCI0 CLK */ + at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* MCI0 CDA */ + at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* MCI0 DB0 */ + at91_set_a_periph(AT91_PIO_PORTA, 3, 0); /* MCI0 DB1 */ + at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* MCI0 DB2 */ + at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* MCI0 DB3 */ + + /* Enable clock */ + writel(1 << ATMEL_ID_MCI0, &pmc->pcer); +} + +int board_mmc_init(bd_t *bis) +{ + at91_set_pio_input(AT91_PIO_PORTD, 10, 0); /* MCI0 CD */ + return atmel_mci_init((void *)ATMEL_BASE_MCI0); +} +#endif + int board_early_init_f(void) { at91_seriald_hw_init(); @@ -247,6 +272,9 @@ int board_init(void) #ifdef CONFIG_ATMEL_SPI at91_spi0_hw_init(1 << 4); #endif +#ifdef CONFIG_GENERIC_ATMEL_MCI + at91sam9m10g45ek_mci_hw_init(); +#endif #ifdef CONFIG_MACB at91sam9m10g45ek_macb_hw_init(); #endif diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index ccfda71..df277e7 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -115,6 +115,20 @@
#endif
+/* MMC */ +#define CONFIG_CMD_MMC + +#ifdef CONFIG_CMD_MMC +#define CONFIG_MMC +#define CONFIG_GENERIC_MMC +#define CONFIG_GENERIC_ATMEL_MCI +#endif + +#if defined(CONFIG_CMD_USB) || defined(CONFIG_CMD_MMC) +#define CONFIG_CMD_FAT +#define CONFIG_DOS_PARTITION +#endif + /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII @@ -126,7 +140,6 @@ #define CONFIG_USB_EHCI #define CONFIG_USB_EHCI_ATMEL #define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#define CONFIG_DOS_PARTITION #define CONFIG_USB_STORAGE
#define CONFIG_SYS_LOAD_ADDR 0x22000000 /* load address */
In this configuration the environment will save in file: uboot.env of mmc card.
Signed-off-by: Josh Wu josh.wu@atmel.com --- boards.cfg | 1 + include/configs/at91sam9m10g45ek.h | 20 ++++++++++++++++++++ 2 files changed, 21 insertions(+)
diff --git a/boards.cfg b/boards.cfg index 3a59686..9f7cfd8 100644 --- a/boards.cfg +++ b/boards.cfg @@ -102,6 +102,7 @@ Active arm arm926ejs at91 atmel at91sam9263ek Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash at91sam9263ek:AT91SAM9263,SYS_USE_NORFLASH Stelian Pop stelian@popies.net Active arm arm926ejs at91 atmel at91sam9263ek at91sam9263ek_norflash_boot at91sam9263ek:AT91SAM9263,SYS_USE_BOOT_NORFLASH Stelian Pop stelian@popies.net Active arm arm926ejs at91 atmel at91sam9m10g45ek at91sam9m10g45ek_nandflash at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_NANDFLASH Bo Shenvoice.shen@atmel.com +Active arm arm926ejs at91 atmel at91sam9m10g45ek at91sam9m10g45ek_mmc at91sam9m10g45ek:AT91SAM9M10G45,SYS_USE_MMC Bo Shenvoice.shen@atmel.com Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_mmc at91sam9n12ek:AT91SAM9N12,SYS_USE_MMC Josh Wu josh.wu@atmel.com Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_nandflash at91sam9n12ek:AT91SAM9N12,SYS_USE_NANDFLASH Josh Wu josh.wu@atmel.com Active arm arm926ejs at91 atmel at91sam9n12ek at91sam9n12ek_spiflash at91sam9n12ek:AT91SAM9N12,SYS_USE_SPIFLASH Josh Wu josh.wu@atmel.com diff --git a/include/configs/at91sam9m10g45ek.h b/include/configs/at91sam9m10g45ek.h index df277e7..07b2188 100644 --- a/include/configs/at91sam9m10g45ek.h +++ b/include/configs/at91sam9m10g45ek.h @@ -147,6 +147,7 @@ #define CONFIG_SYS_MEMTEST_START CONFIG_SYS_SDRAM_BASE #define CONFIG_SYS_MEMTEST_END 0x23e00000
+#ifdef CONFIG_SYS_USE_NANDFLASH /* bootstrap + u-boot + env in nandflash */ #define CONFIG_ENV_IS_IN_NAND #define CONFIG_ENV_OFFSET 0xc0000 @@ -162,6 +163,25 @@ "256k(env),256k(env_redundant),256k(spare)," \ "512k(dtb),6M(kernel)ro,-(rootfs) " \ "root=/dev/mtdblock7 rw rootfstype=jffs2" +#elif CONFIG_SYS_USE_MMC +/* bootstrap + u-boot + env + linux in mmc */ +#define FAT_ENV_INTERFACE "mmc" +#define FAT_ENV_DEVICE 0 +#define FAT_ENV_PART 1 +#define FAT_ENV_FILE "uboot.env" +#define CONFIG_ENV_IS_IN_FAT +#define CONFIG_FAT_WRITE +#define CONFIG_ENV_SIZE 0x4000 + +#define CONFIG_BOOTARGS "mem=128M console=ttyS0,115200 " \ + "mtdparts=atmel_nand:" \ + "8M(bootstrap/uboot/kernel)ro,-(rootfs) " \ + "root=/dev/mmcblk0p2 " \ + "rw rootfstype=ext4 rootwait" +#define CONFIG_BOOTCOMMAND "fatload mmc 0:1 0x71000000 dtb; " \ + "fatload mmc 0:1 0x72000000 uImage; " \ + "bootm 0x72000000 - 0x71000000" +#endif
#define CONFIG_BAUDRATE 115200
Hi Josh,
I think we should remove "mem=128M" as we use device tree.
Can we remove rootfstype, so it can compatible with ext2, ext3 and ext4.
Can we switch to zImage? As we try to support multi-platform with single image in kernel.
Best Regards, Bo Shen
Hi, Bo
On 5/21/2014 9:32 AM, Bo Shen wrote:
Hi Josh,
I will update to v2 according to your advise. Thanks.
Best Regards, Josh Wu
Hi Josh,
- struct at91_pmc *pmc = (struct at91_pmc *)ATMEL_BASE_PMC;
- at91_set_a_periph(AT91_PIO_PORTA, 0, 0); /* MCI0 CLK */
- at91_set_a_periph(AT91_PIO_PORTA, 1, 0); /* MCI0 CDA */
- at91_set_a_periph(AT91_PIO_PORTA, 2, 0); /* MCI0 DB0 */
- at91_set_a_periph(AT91_PIO_PORTA, 3, 0); /* MCI0 DB1 */
- at91_set_a_periph(AT91_PIO_PORTA, 4, 0); /* MCI0 DB2 */
- at91_set_a_periph(AT91_PIO_PORTA, 5, 0); /* MCI0 DB3 */
The comments for pin should be DAx while not DBx.
- /* Enable clock */
- writel(1 << ATMEL_ID_MCI0, &pmc->pcer);
- at91_set_pio_input(AT91_PIO_PORTD, 10, 0); /* MCI0 CD */
As we won't use it, so I think we should remove it.
- return atmel_mci_init((void *)ATMEL_BASE_MCI0);
+} +#endif
- int board_early_init_f(void) { at91_seriald_hw_init();
- at91sam9m10g45ek_mci_hw_init();
#endif
- /* Ethernet */ #define CONFIG_MACB #define CONFIG_RMII
Hi, Bo
On 5/21/2014 9:27 AM, Bo Shen wrote:
Hi Josh,
I'll fix it in v2.
Okay. Thanks.
+} +#endif
#endif
Bo Shen
Josh Wu
