[U-Boot] [PATCH] MIPS: bootm: Fix broken boot_env_legacy codepath
This patch fixes 2 bugs introduced by the following commit
2bb5b63 MIPS: bootm: rework and fix broken bootm code
The CONFIG_IS_ENABLED macro prepends 'CONFIG_' Hence, remove CONFIG_ from CONFIG_MIPS_BOOT_ENV_LEGACY usage.
Also, 2bb5b63 reworks bootm so that linux_env_legacy runs before linux_cmdline_legacy. However, linux_env_legacy depends on linux_cmdline_legacy running first as linux_cmdline_init initialilzes linux_argp which linux_env_legacy later depends on during its initialization.
Reorder the code so that linux_cmdline_legacy runs before linux_env_legacy.
Signed-off-by: Zubair Lutfullah Kakakhel Zubair.Kakakhel@imgtec.com
--- Found this while working on SEAD3 u-boot patches (which are not upstream yet) --- arch/mips/lib/bootm.c | 8 ++++---- 1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/mips/lib/bootm.c b/arch/mips/lib/bootm.c index be87762..2b67905 100644 --- a/arch/mips/lib/bootm.c +++ b/arch/mips/lib/bootm.c @@ -279,17 +279,17 @@ static void boot_prep_linux(bootm_headers_t *images) boot_reloc_fdt(images); boot_setup_fdt(images); } else { - if (CONFIG_IS_ENABLED(CONFIG_MIPS_BOOT_ENV_LEGACY)) - linux_env_legacy(images); - if (CONFIG_IS_ENABLED(MIPS_BOOT_CMDLINE_LEGACY)) { linux_cmdline_legacy(images);
- if (!CONFIG_IS_ENABLED(CONFIG_MIPS_BOOT_ENV_LEGACY)) + if (!CONFIG_IS_ENABLED(MIPS_BOOT_ENV_LEGACY)) linux_cmdline_append(images);
linux_cmdline_dump(); } + + if (CONFIG_IS_ENABLED(MIPS_BOOT_ENV_LEGACY)) + linux_env_legacy(images); } }
Am 11.07.2017 um 17:47 schrieb Zubair Lutfullah Kakakhel:
thanks for fixing. Applied to u-boot-mips/master.
Daniel Schwierzeck
