[PATCH] ARM: LS1021A: remove redundant "depends on ARCH_LS1021A"
These config entries are inside the menu block, which already depends on ARCH_LS1021A:
menu "LS102xA architecture" depends on ARCH_LS1021A
Signed-off-by: Masahiro Yamada masahiroy@kernel.org ---
arch/arm/cpu/armv7/ls102xa/Kconfig | 3 --- 1 file changed, 3 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 57d7fd9e5503..937989b27868 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -29,11 +29,9 @@ menu "LS102xA architecture"
config LS1_DEEP_SLEEP bool "Deep sleep" - depends on ARCH_LS1021A
config MAX_CPUS int "Maximum number of CPUs permitted for LS102xA" - depends on ARCH_LS1021A default 2 help Set this number to the maximum number of possible CPUs in the SoC. @@ -98,7 +96,6 @@ config SYS_HAS_SERDES
config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" - depends on ARCH_LS1021A default 8
config SYS_FSL_ERRATUM_A008407
-----Original Message----- From: Masahiro Yamada masahiroy@kernel.org Sent: Wednesday, January 8, 2020 4:17 PM To: u-boot@lists.denx.de Cc: Masahiro Yamada masahiroy@kernel.org; Alison Wang alison.wang@nxp.com; Pankaj Bansal pankaj.bansal@nxp.com; Prabhakar Kushwaha prabhakar.kushwaha@nxp.com; Priyanka Jain priyanka.jain@nxp.com; Shengzhou Liu shengzhou.liu@nxp.com; Tom Rini trini@konsulko.com; Udit Agarwal udit.agarwal@nxp.com Subject: [PATCH] ARM: LS1021A: remove redundant "depends on ARCH_LS1021A"
patch applied in u-boot-fsl-qoriq/master -priyankajain
Masahiro Yamada
Priyanka Jain
