[PATCH V2] phy: nop-phy: Enable reset-gpios support
Some usb-nop-xceiv devices use a gpio to put them in and out of reset. Add a reset function to put them into that state. This is similar to how Linux handles the usb-nop-xceiv driver.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Only use the GPIO functions when DM_GPIO is enabled Add error handling so if the GPIO fails, it will shutdown the clocks and return with the error code. Call nop_phy_reset() instead of repeating the same code.
diff --git a/drivers/phy/nop-phy.c b/drivers/phy/nop-phy.c index 9f12ebc062..2be3d4039b 100644 --- a/drivers/phy/nop-phy.c +++ b/drivers/phy/nop-phy.c @@ -10,17 +10,47 @@ #include <dm/device.h> #include <dm/device_compat.h> #include <generic-phy.h> +#include <asm-generic/gpio.h>
struct nop_phy_priv { struct clk_bulk bulk; +#if CONFIG_IS_ENABLED(DM_GPIO) + struct gpio_desc reset_gpio; +#endif };
+#if CONFIG_IS_ENABLED(DM_GPIO) +static int nop_phy_reset(struct phy *phy) +{ + struct nop_phy_priv *priv = dev_get_priv(phy->dev); + + /* Return if there is no gpio since it's optional */ + if (!dm_gpio_is_valid(&priv->reset_gpio)) + return 0; + + return dm_gpio_set_value(&priv->reset_gpio, false); +} +#endif + static int nop_phy_init(struct phy *phy) { struct nop_phy_priv *priv = dev_get_priv(phy->dev); + int ret = 0; + + if (CONFIG_IS_ENABLED(CLK)) { + ret = clk_enable_bulk(&priv->bulk); + if (ret) + return ret; + }
- if (CONFIG_IS_ENABLED(CLK)) - return clk_enable_bulk(&priv->bulk); + if (CONFIG_IS_ENABLED(DM_GPIO)) { + ret = nop_phy_reset(phy); + if (ret) { + if (CONFIG_IS_ENABLED(CLK)) + clk_disable_bulk(&priv->bulk); + return ret; + } + }
return 0; } @@ -38,6 +68,12 @@ static int nop_phy_probe(struct udevice *dev) } }
+ ret = gpio_request_by_name(dev, "reset-gpios", 0, + &priv->reset_gpio, + GPIOD_IS_OUT); + if (ret != -ENOENT) + return ret; + return 0; }
@@ -49,6 +85,7 @@ static const struct udevice_id nop_phy_ids[] = {
static struct phy_ops nop_phy_ops = { .init = nop_phy_init, + .reset = nop_phy_reset, };
U_BOOT_DRIVER(nop_phy) = {
drivers/phy/nop-phy.c:47:23: error: implicit declaration of function 'nop_phy_reset'; did you mean 'nop_phy_init'? [-Werror=implicit-function-declaration] is what I get now on those platforms.
I apparently forgot to encapsulate the nop_phy_ops reference to the new function in an if-def. I'll send a V3 shortly.
adam
-- Tom
Adam Ford
