[U-Boot] [PATCH 2/3] TCP code. All is new.
Passed through patman, which does not like packed headers. But, packed headers are a requirement to meet protocol header standards.
Signed-off-by: Duncan Hare DuncanCHare@yahoo.com ---
net/Makefile | 3 +- net/tcp.c | 723 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ net/tcp.h | 219 ++++++++++++++++++ 3 files changed, 944 insertions(+), 1 deletion(-) create mode 100644 net/tcp.c create mode 100644 net/tcp.h
diff --git a/net/Makefile b/net/Makefile index ae54eee5af..f83df5b728 100644 --- a/net/Makefile +++ b/net/Makefile @@ -25,7 +25,8 @@ obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_NET) += tftp.o - +obj-$(CONFIG_TCP) += tcp.o +obj-$(CONFIG_CMD_WGET) += wget.o # Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) # and this is intentional usage. diff --git a/net/tcp.c b/net/tcp.c new file mode 100644 index 0000000000..22f43e110c --- /dev/null +++ b/net/tcp.c @@ -0,0 +1,723 @@ +/* + * Copyright 2017 Duncan Hare, all rights reserved. + */ + +/* + * General Desription: + * + * TCP support for the wget command, for fast file downloading. + * + * HTTP/TCP Receiver: + * + * Prequeisites: - own ethernet address + * - own IP address + * - Server IP address + * - HTP client + * - Bootfile path & name + * We want: - Load the Boot file + * Next Step HTTPS? + */ +#include <common.h> +#include <command.h> +#include <console.h> +#include <environment.h> +#include <errno.h> +#include <net.h> +#include "tcp.h" +#include "wget.h" + +/* TCP sliding window control */ +/* used by us to request re-TX */ + +static struct tcp_sack_v tcp_lost; + +/* TCP option timestamp */ +static u32 loc_timestamp; +static u32 rmt_timestamp; + +u32 tcp_seq_init; +u32 tcp_ack_edge; +u32 tcp_seq_max; + +int tcp_activity_count; + +/* Search for TCP_SACK and review the + * comments before the code section + * TCP_SACK is the number of packets + * at the front of the stream + */ + +enum pkt_state {PKT, NOPKT}; +struct sack_r { + struct sack_edges se; + enum pkt_state st; +}; + +struct sack_r edge_a[TCP_SACK]; +unsigned int sack_idx; +unsigned int prev_len; + +/* TCP connection state */ +static enum TCP_STATE tcp_state; + +/* + * An incoming TCP packet handler for the TCP protocol. + * There is also a dymanic function pointer for TCP based commads to + * receive incoming traffic after the TCP protocol code has done its work. + */ + +/* Current TCP RX packet handler */ +static rxhand_tcp *tcp_packet_handler; + +enum TCP_STATE tcp_get_tcp_state(void) +{ + return tcp_state; +} + +void tcp_set_tcp_state(enum TCP_STATE new_state) +{ + tcp_state = new_state; +} + +void tcp_print_buffer(uchar raw[], int pkt_len, int payload_len, + int hdr_len, bool hide) +{ + int i; + + for (i = pkt_len - payload_len; i < pkt_len; i++) { + if (i <= hdr_len) + printf("%02X", raw[i]); + else if ((raw[i] > 0x19) && (raw[i] < 0x7f)) + putc(raw[i]); + else if (hide == 0) + putc(raw[i]); + else + printf("%02X", raw[i]); + } + printf("%s", "\n"); +} + +int tcp_find_in_buffer(uchar raw[], int payload_len, uchar field[], + int field_len) +{ + int i, j; + + for (i = 0; i < payload_len; i++) { + if (raw[i] == field[0]) { + for (j = 1; j < field_len; j++) { + if (raw[i + j] != field[j]) + break; + if (j == field_len) + return i; + } + } + } + return 0; +} + +static void dummy_handler(uchar *pkt, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len) +{ +} + +void tcp_set_tcp_handler(rxhand_tcp *f) +{ + debug_cond(DEBUG_INT_STATE, "--- net_loop TCP handler set (%p)\n", f); + if (!f) + tcp_packet_handler = dummy_handler; + else + tcp_packet_handler = f; +} + +u16 tcp_set_pseudo_header(uchar *pkt, struct in_addr src, struct in_addr dest, + int tcp_len, int pkt_len) +{ + union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + int checksum_len; + + /* + * Pseudo header + * + * Zero the byte after the last byte so that the header checksum + * will always work. + */ + + pkt[pkt_len] = 0x00; + + net_copy_ip((void *)&b->ph.p_src, &src); + net_copy_ip((void *)&b->ph.p_dst, &dest); + b->ph.rsvd = 0x00; + b->ph.p = IPPROTO_TCP; + b->ph.len = htons(tcp_len); + checksum_len = tcp_len + PSEUDO_HDR_SIZE; + + debug_cond(DEBUG_DEV_PKT, + "TCP Pesudo Header (to=%pI4, from=%pI4, Len=%d)\n", + &b->ph.p_dst, &b->ph.p_src, checksum_len); + + return compute_ip_checksum(pkt + PSEUDO_PAD_SIZE, checksum_len); +} + +int net_set_ack_options(union tcp_build_pkt *b) +{ + b->sack.hdr.tcp_hlen = (TCP_HDR_SIZE >> 2) << 4; + + b->sack.t_opt.kind = TCP_O_TS; + b->sack.t_opt.len = TCP_OPT_LEN_A; + b->sack.t_opt.t_snd = htons(loc_timestamp); + b->sack.t_opt.t_rcv = rmt_timestamp; + b->sack.sack_v.kind = 0x01; + b->sack.sack_v.len = 0x00; + + if (tcp_lost.len > TCP_OPT_LEN_2) { + debug_cond(DEBUG_DEV_PKT, "TCP ack opt lost.len %x\n", + tcp_lost.len); + b->sack.sack_v.len = tcp_lost.len; + b->sack.sack_v.kind = TCP_V_SACK; + b->sack.sack_v.hill[0].l = htonl(tcp_lost.hill[0].l); + b->sack.sack_v.hill[0].r = htonl(tcp_lost.hill[0].r); + + /* + * These SACK structures are initialized with NOPs to + * provide TCP header alignment padding. There are 4 + * SACK structures used for both header padding and + * internally. + */ + + b->sack.sack_v.hill[1].l = htonl(tcp_lost.hill[1].l); + b->sack.sack_v.hill[1].r = htonl(tcp_lost.hill[1].r); + b->sack.sack_v.hill[2].l = htonl(tcp_lost.hill[2].l); + b->sack.sack_v.hill[2].r = htonl(tcp_lost.hill[2].r); + b->sack.sack_v.hill[3].l = TCP_O_NOP; + b->sack.sack_v.hill[3].r = TCP_O_NOP; + } + + b->sack.hdr.tcp_hlen = (((TCP_HDR_SIZE + TCP_TSOPT_SIZE + + tcp_lost.len + 3) >> 2) << 4); + return b->sack.hdr.tcp_hlen >> 2; +} + +void net_set_syn_options(union tcp_build_pkt *b) +{ + tcp_lost.len = 0; + b->ip.hdr.tcp_hlen = 0xa0; + + b->ip.mss.kind = TCP_O_MSS; + b->ip.mss.len = TCP_OPT_LEN_4; + b->ip.mss.mss = htons(TCP_MSS); + b->ip.scale.kind = TCP_O_SCL; + b->ip.scale.scale = TCP_SCALE; + b->ip.scale.len = TCP_OPT_LEN_3; + b->ip.sack_p.kind = TCP_P_SACK; + b->ip.sack_p.len = TCP_OPT_LEN_2; + b->ip.t_opt.kind = TCP_O_TS; + b->ip.t_opt.len = TCP_OPT_LEN_A; + loc_timestamp = get_ticks() % 3072; + rmt_timestamp = 0x00000000; + b->ip.t_opt.t_snd = 0; + b->ip.t_opt.t_rcv = 0x00000000; + b->ip.end = TCP_O_END; +} + +int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, + u8 action, u32 tcp_seq_num, u32 tcp_ack_num) +{ + union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + int pkt_hdr_len; + int pkt_len; + int tcp_len; + + b->ip.hdr.tcp_flags = action; + pkt_hdr_len = IP_TCP_HDR_SIZE; + b->ip.hdr.tcp_hlen = 0x50; /* Header is 5 32 bit words */ + /* 4 bits TCP header Length/4*/ + /* 4 bits Reserved */ + /* For options */ + switch (action) { + case TCP_SYN: + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:SYN (%pI4, %pI4, sq=%d, ak=%d)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_num); + tcp_activity_count = 0; + net_set_syn_options(b); + tcp_seq_num = 0; + tcp_ack_num = 0; + pkt_hdr_len = IP_TCP_O_SIZE; + if (tcp_state == TCP_SYN_SENT) { /* Too many sins */ + action = TCP_FIN; + tcp_state = TCP_FIN_WAIT_1; + } else { + tcp_state = TCP_SYN_SENT; + } + break; + case TCP_ACK: + pkt_hdr_len = IP_HDR_SIZE + + net_set_ack_options(b); + b->ip.hdr.tcp_flags = action; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:ACK (%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num, + action); + break; + case TCP_FIN: + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:FIN (%pI4, %pI4, s=%d, a=%d)\n", + &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); + payload_len = 0; + pkt_hdr_len = IP_TCP_HDR_SIZE; + tcp_state = TCP_FIN_WAIT_1; + + break; /* Notify connection closing */ + case (TCP_FIN | TCP_ACK): + case ((TCP_FIN | TCP_ACK) | TCP_PUSH): + if (tcp_state == TCP_CLOSE_WAIT) + tcp_state = TCP_CLOSING; + tcp_ack_edge++; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_edge, action); + /* FALLTHRU */ + default: + pkt_hdr_len = IP_HDR_SIZE + + net_set_ack_options(b); + b->ip.hdr.tcp_flags = action | TCP_PUSH | TCP_ACK; + debug_cond(DEBUG_DEV_PKT, + "TCP Hdr:dft (%pI4, %pI4, s=%d, a=%d, A=%x)\n", + &net_server_ip, &net_ip, + tcp_seq_num, tcp_ack_num, action); + } + + pkt_len = pkt_hdr_len + payload_len; + tcp_len = pkt_len - IP_HDR_SIZE; + + /* + * TCP Header + */ + b->ip.hdr.tcp_ack = htonl(tcp_ack_edge); + b->ip.hdr.tcp_src = htons(sport); + b->ip.hdr.tcp_dst = htons(dport); + b->ip.hdr.tcp_seq = htonl(tcp_seq_num); + tcp_seq_num = tcp_seq_num + payload_len; + + /* + * TCP window size - TCP header variable tcp_win. + * Change tcp_win only if you have an understanding of network + * overruun, congestion, TCP segment sizes, TCP windows, TCP scale, + * queuing theory and packet buffering. If there are too few buffers, + * there will be data loss, recovery may work or the sending TCP, + * the server, could abort the stream transmission. + * MSS is governed by maximum Ethernet frame langth. + * The number of buffers is governed by the desire to have a queue of + * full buffers to be processed at the destination to maximize + * throughput. Temporary memory use for the boot phase on modern + * SOCs is may not be considered a constraint to buffer space, if + * it is, thEn the u-boot tftp or nfs kernel netboot should be + * considered. + */ + + b->ip.hdr.tcp_win = htons(PKTBUFSRX * TCP_MSS >> TCP_SCALE); + + b->ip.hdr.tcp_xsum = 0x0000; + b->ip.hdr.tcp_ugr = 0x0000; + + b->ip.hdr.tcp_xsum = tcp_set_pseudo_header(pkt, net_ip, net_server_ip, + tcp_len, pkt_len); + + /* + * IP Header + */ + + net_set_ip_header((uchar *)&b->ip, net_server_ip, net_ip, + pkt_len, IPPROTO_TCP); + + return pkt_hdr_len; +} + +/* + * Selective Acknowledgment (Essential for fast stream transfer) + * + * Before modifying theis section of code, which the author found difficult + * to write, please be familiar with the SACK (Selective Acknowledgment) RFCs. + */ + +void tcp_hole(u32 tcp_seq_num, u32 len, u32 tcp_seq_max) +{ + unsigned int idx_sack; + unsigned int sack_end = TCP_SACK - 1; + unsigned int sack_in; + unsigned int hill = 0; + enum pkt_state expect = PKT; + + u32 seq = tcp_seq_num - tcp_seq_init; + u32 hol_l = tcp_ack_edge - tcp_seq_init; + u32 hol_r = 0; + + /* Place seq number in correct place */ + + if (prev_len == 0) + prev_len = len; + idx_sack = sack_idx + ((tcp_seq_num - tcp_ack_edge) / prev_len); + if (idx_sack < TCP_SACK) { + edge_a[idx_sack].se.l = tcp_seq_num; + edge_a[idx_sack].se.r = tcp_seq_num + len; + edge_a[idx_sack].st = PKT; + + /* The fin (last) packet is not the same lanegth as data packets, + * and if it's length is recorded ad used for array index + * the arrary index calculations break. + */ + if (prev_len < len) + prev_len = len; + } + + debug_cond(DEBUG_DEV_PKT, + "TCP 1 seq %d, edg %d, len %d, sack_idx %d, sack_end %d\n", + seq, hol_l, len, sack_idx, sack_end); + + /* Right edge of contiguous stream, is the left edge of first hill */ + + hol_l = tcp_seq_num - tcp_seq_init; + hol_r = hol_l + len; + + tcp_lost.len = TCP_OPT_LEN_2; + + debug_cond(DEBUG_DEV_PKT, + "TCP 1 in %d, seq %d, pkt_l %d, pkt_r %d, sack_idx %d, sack_end %d\n", + idx_sack, seq, hol_l, hol_r, sack_idx, sack_end); + + for (sack_in = sack_idx; (sack_in < sack_end) && (hill < TCP_SACK_HILLS); + sack_in++) { + switch (expect) { + case NOPKT: + switch (edge_a[sack_in].st) { + case NOPKT: + debug_cond(DEBUG_INT_STATE, "N"); + break; + case PKT: + debug_cond(DEBUG_INT_STATE, "n"); + tcp_lost.hill[hill].l = + edge_a[sack_in].se.l; + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + expect = PKT; + break; + } + break; + case PKT: + switch (edge_a[sack_in].st) { + case NOPKT: + debug_cond(DEBUG_INT_STATE, "p"); + if ((sack_in > sack_idx) && + (hill < TCP_SACK_HILLS)) { + hill++; + tcp_lost.len += TCP_OPT_LEN_8; + } + expect = NOPKT; + break; + case PKT: + debug_cond(DEBUG_INT_STATE, "P"); + + if (tcp_ack_edge == edge_a[sack_in].se.l) { + tcp_ack_edge = edge_a[sack_in].se.r; + edge_a[sack_in].st = NOPKT; + sack_idx++; + } else { + if (hill < TCP_SACK_HILLS) + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + if (sack_in == sack_end - 1) + tcp_lost.hill[hill].r = + edge_a[sack_in].se.r; + } + break; + } + break; + } + } + debug_cond(DEBUG_INT_STATE, "\n"); + if (tcp_lost.len <= TCP_OPT_LEN_2) + sack_idx = 0; +} + +void tcp_parse_options(uchar *o, int o_len) +{ + struct tcp_t_opt *tsopt; + uchar *p = o; + + for (p = o; p < (o + o_len); p = p + p[1]) { + if (p[1] != 0) { + switch (p[0]) { + case TCP_O_END: + return; + case TCP_O_MSS: + break; + case TCP_O_SCL: + break; + case TCP_P_SACK: + break; + case TCP_V_SACK: + break; + case TCP_O_TS: + tsopt = (struct tcp_t_opt *)p; + rmt_timestamp = tsopt->t_snd; + return; + break; + } + if (p[0] == TCP_O_NOP) + p++; + } else { + return; } + } +} + +u8 tcp_state_machine(u8 tcp_flags, u32 *tcp_seq_num, int payload_len) +{ + u8 tcp_fin = tcp_flags & TCP_FIN; + u8 tcp_syn = tcp_flags & TCP_SYN; + u8 tcp_rst = tcp_flags & TCP_RST; + u8 tcp_push = tcp_flags & TCP_PUSH; + u8 tcp_ack = tcp_flags & TCP_ACK; + u8 action = TCP_DATA; + int i; + + /* + * tcp_flags are examined to determine TX action in a given state + * tcp_push is intrepreted to mean "inform the app" + * urg, ece, cer and nonce flags are not supported. + * + * exe and crw are use to signal and confirm knowledge of congestion. + * This TCP only sends a file request and acks. If it generates + * congestion, the network is broken. + */ + + debug_cond(DEBUG_INT_STATE, "TCP STATE ENTRY %x\n", action); + if (tcp_rst) { + action = TCP_DATA; + tcp_state = TCP_CLOSED; + net_set_state(NETLOOP_FAIL); + debug_cond(DEBUG_INT_STATE, "TCP Reset %x\n", tcp_flags); + return TCP_RST; + } + + switch (tcp_state) { + case TCP_CLOSED: + debug_cond(DEBUG_INT_STATE, "TCP CLOSED %x\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) + action = TCP_DATA; + break; + case TCP_SYN_SENT: + debug_cond(DEBUG_INT_STATE, "TCP_SYN_SENT %x, %d\n", + tcp_flags, *tcp_seq_num); + if (tcp_fin) { + action = action | TCP_PUSH; + tcp_state = TCP_CLOSE_WAIT; + } + if (tcp_syn) { + action = action | TCP_ACK | TCP_PUSH; + if (tcp_ack) { + tcp_seq_init = *tcp_seq_num; + *tcp_seq_num = *tcp_seq_num + 1; + tcp_seq_max = *tcp_seq_num; + tcp_ack_edge = *tcp_seq_num; + sack_idx = 0; + edge_a[sack_idx].se.l = *tcp_seq_num; + edge_a[sack_idx].se.r = *tcp_seq_num; + prev_len = 0; + tcp_state = TCP_ESTABLISHED; + for (i = 0; i < TCP_SACK; i++) + edge_a[i].st = NOPKT; + } + } else { + if (tcp_ack) + action = TCP_DATA; + } + break; + case TCP_ESTABLISHED: + debug_cond(DEBUG_INT_STATE, + "TCP_ESTABLISHED %x\n", tcp_flags); + if (*tcp_seq_num > tcp_seq_max) + tcp_seq_max = *tcp_seq_num; + if (payload_len > 0) { + tcp_hole(*tcp_seq_num, payload_len, tcp_seq_max); + tcp_fin = TCP_DATA; /* cause standalone FIN */ + } + + if ((tcp_fin) && (tcp_lost.len <= TCP_OPT_LEN_2)) { + action = action | TCP_FIN | TCP_PUSH | TCP_ACK; + tcp_state = TCP_CLOSE_WAIT; + } else { + if (tcp_ack) + action = TCP_DATA; + } + if (tcp_push) + action = action | TCP_PUSH; + if (tcp_syn) + action = TCP_ACK + TCP_RST; + break; + case TCP_CLOSE_WAIT: + debug_cond(DEBUG_INT_STATE, "TCP_CLOSE_WAIT (%x)\n", tcp_flags); + action = TCP_DATA; /* Wait for app */ + break; + case TCP_FIN_WAIT_2: + debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_2 (%x)\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_DATA; + if (tcp_ack) { + action = TCP_PUSH | TCP_ACK; + tcp_state = TCP_CLOSED; + puts("\n"); + } + break; + case TCP_FIN_WAIT_1: + debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_1 (%x)\n", tcp_flags); + if (tcp_fin) { + action = TCP_ACK | TCP_FIN; + tcp_state = TCP_FIN_WAIT_2; + } + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) { + tcp_state = TCP_CLOSED; + tcp_seq_num = tcp_seq_num + 1; + } + break; + case TCP_CLOSING: + debug_cond(DEBUG_INT_STATE, "TCP_CLOSING (%x)\n", tcp_flags); + if (tcp_fin) + action = TCP_DATA; + if (tcp_syn) + action = TCP_RST; + if (tcp_ack) { + action = TCP_PUSH; + tcp_state = TCP_CLOSED; + puts("\n"); + } + break; + } + return action; +} + +void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) +{ + int tcp_len = pkt_len - IP_HDR_SIZE; + u16 tcp_rx_xsum = b->ip.hdr.ip_sum; + u8 tcp_action = TCP_DATA; + u32 tcp_seq_num; + u32 tcp_ack_num; + struct in_addr action_and_state; + + int tcp_hdr_len; + int payload_len; + + /* + * Verify ip header + */ + debug_cond(DEBUG_DEV_PKT, + "TCP RX in RX Sum (to=%pI4, from=%pI4, len=%d)\n", + &b->ip.hdr.ip_src, &b->ip.hdr.ip_dst, pkt_len); + + debug_cond(DEBUG_DEV_PKT, + "In__________________________________________\n"); + + b->ip.hdr.ip_src = net_server_ip; + b->ip.hdr.ip_dst = net_ip; + b->ip.hdr.ip_sum = 0x0000; + if (tcp_rx_xsum != compute_ip_checksum(b, IP_HDR_SIZE)) { + debug_cond(DEBUG_DEV_PKT, + "TCP RX IP xum Error (%pI4, =%pI4, len=%d)\n", + &net_ip, &net_server_ip, pkt_len); + return; + } + + /* + * Build Pseudo header and Verify TCP header + */ + tcp_rx_xsum = b->ip.hdr.tcp_xsum; + b->ip.hdr.tcp_xsum = 0x0000; + if (tcp_rx_xsum != tcp_set_pseudo_header((uchar *)b, b->ip.hdr.ip_src, + b->ip.hdr.ip_dst, tcp_len, + pkt_len)) { + debug_cond(DEBUG_DEV_PKT, + "TCP RX TCP xSum Error (%pI4, %pI4, len=%d)\n", + &net_ip, &net_server_ip, tcp_len); + return; + } + + tcp_hdr_len = (b->ip.hdr.tcp_hlen >> 2); + payload_len = tcp_len - tcp_hdr_len; + + if (tcp_hdr_len > TCP_HDR_SIZE) + tcp_parse_options((uchar *)b + IP_TCP_HDR_SIZE, + tcp_hdr_len - TCP_HDR_SIZE); + /* + * Incoming sequence and ack numbers are server's view of the numbers. + * The app must swap the numbers when responding. + */ + + tcp_seq_num = ntohl(b->ip.hdr.tcp_seq); + tcp_ack_num = ntohl(b->ip.hdr.tcp_ack); + + /* + * Send first packet send from server as first to app + * Other packets could be ordered, but are currently not ordered. + */ + + tcp_action = tcp_state_machine(b->ip.hdr.tcp_flags, + &tcp_seq_num, payload_len); + + /* + * State altering command to be sent. + * The packet sequence and ack numbers are in the tcp_seq_num + * and tcp_ack_num variables. The current packet, its position + * in the date stream, is the in the range of those variables. + * + * In the "application push" invocation the TCP header with all + * its information is pointed to by the packet pointer, and the + * other variable "repurposed" (or misused) to carry sequence numbers + * and TCP state. + * + * TCP_PUSH from the state machine with a payload length of 0 is a + * connect or disconnect event + */ + + tcp_activity_count++; + if (tcp_activity_count > TCP_ACTIVITY) { + puts("| "); + tcp_activity_count = 0; + } + + if ((tcp_action & TCP_PUSH) || (payload_len > 0)) { + debug_cond(DEBUG_DEV_PKT, + "TCP Notify (action=%x, Seq=%d,Ack=%d,Pay%d)\n", + tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + + action_and_state.s_addr = tcp_action; + (*tcp_packet_handler) ((uchar *)b + pkt_len - payload_len, + tcp_seq_num, action_and_state, + tcp_ack_num, payload_len); + + } else if (tcp_action != TCP_DATA) { + debug_cond(DEBUG_DEV_PKT, + "TCP Action (action=%x,Seq=%d,Ack=%d,Pay=%d)\n", + tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + + /* + * Warning: Incoming Seq & Ack sequence numbers are transposed here + * to outgoing Seq & Ack sequence numbers + */ + + net_send_tcp_packet(0, ntohs(b->ip.hdr.tcp_src), + ntohs(b->ip.hdr.tcp_dst), + (tcp_action & (~TCP_PUSH)), + tcp_seq_num, tcp_ack_num); + } +} diff --git a/net/tcp.h b/net/tcp.h new file mode 100644 index 0000000000..4d50390c6d --- /dev/null +++ b/net/tcp.h @@ -0,0 +1,219 @@ +/* + * TCP Support for file transfer. + * + * Copyright 2017 Duncan Hare, All rights reserved. + * + * History + * 10/2017 Initial code + */ + +#define TCP_ACTIVITY 127 /* Activity on down loading */ + +struct ip_tcp_hdr { + u8 ip_hl_v; /* header length and version */ + u8 ip_tos; /* type of service */ + u16 ip_len; /* total length */ + u16 ip_id; /* identification */ + u16 ip_off; /* fragment offset field */ + u8 ip_ttl; /* time to live */ + u8 ip_p; /* protocol */ + u16 ip_sum; /* checksum */ + struct in_addr ip_src; /* Source IP address */ + struct in_addr ip_dst; /* Destination IP address */ + u16 tcp_src; /* TCP source port */ + u16 tcp_dst; /* TCP destination port */ + u32 tcp_seq; /* TCP sequence number */ + u32 tcp_ack; /* TCP Acknowledgment number */ + u8 tcp_hlen; /* 4 bits TCP header Length/4 */ + /* 4 bits Reserved */ + /* 2 more bits reserved */ + u8 tcp_flags; /* see defines */ + u16 tcp_win; /* TCP windows size */ + u16 tcp_xsum; /* Checksum */ + u16 tcp_ugr; /* Pointer to urgent data */ +} __packed; + +#define IP_TCP_HDR_SIZE (sizeof(struct ip_tcp_hdr)) +#define TCP_HDR_SIZE (IP_TCP_HDR_SIZE - IP_HDR_SIZE) + +#define TCP_DATA 0x00 /* Data Packet - internal use only */ +#define TCP_FIN 0x01 /* Finish flag */ +#define TCP_SYN 0x02 /* Synch (start) flag */ +#define TCP_RST 0x04 /* reset flag */ +#define TCP_PUSH 0x08 /* Push - Notify app */ +#define TCP_ACK 0x10 /* Acknowledgment of data received */ +#define TCP_URG 0x20 /* Urgent */ +#define TCP_ECE 0x40 /* Congestion control */ +#define TCP_CWR 0x80 /* Congestion Control */ + +/* + * TCP header options, Seq, MSS, and SACK + */ + +#define TCP_SACK 32 /* Number of packets analyzed */ + /* on leading edge of stream */ + +#define TCP_O_END 0x00 /* End of option list */ +#define TCP_1_NOP 0x01 /* Single padding NOP */ +#define TCP_O_NOP 0x01010101 /* NOPs pad to 32 bit boundary */ +#define TCP_O_MSS 0x02 /* MSS Size option */ +#define TCP_O_SCL 0x03 /* Window Scale option */ +#define TCP_P_SACK 0x04 /* SACK permitted */ +#define TCP_V_SACK 0x05 /* SACK values */ +#define TCP_O_TS 0x08 /* Timestanp option */ +#define TCP_OPT_LEN_2 0x02 +#define TCP_OPT_LEN_3 0x03 +#define TCP_OPT_LEN_4 0x04 +#define TCP_OPT_LEN_6 0x06 +#define TCP_OPT_LEN_8 0x08 +#define TCP_OPT_LEN_A 0x0a /* Timestamp Length */ + +/* + * Please reviw the warning in net.c about these two paraeters. + * They are part of a promise of RX buffer size to the sending TCP + */ + +#define TCP_MSS 1460 /* Max segment size - 1460 */ +#define TCP_SCALE 0x01 /* Scale 1 */ + +struct tcp_mss { /* TCP Mex Segment size */ + u8 kind; /* 0x02 */ + u8 len; /* 0x04 */ + u16 mss; /* 1460 - Max segment size */ +} __packed; + +struct tcp_scale { /* TCP Windows Scale */ + u8 kind; /* 0x03 */ + u8 len; /* 0x03 */ + u8 scale; /* win shift fat fast networks */ +} __packed; + +struct tcp_sack_p { /* SACK permitted */ + u8 kind; /* 0x04 */ + u8 len; /* Length */ +} __packed; + +struct sack_edges { + u32 l; + u32 r; +} __packed; + +#define TCP_SACK_SIZE (sizeof(struct sack_edges)) + +#define TCP_SACK_HILLS 4 + +struct tcp_sack_v { + u8 kind; /* 0x05 */ + u8 len; /* Length */ + struct sack_edges hill[TCP_SACK_HILLS]; /* L & R widow edges */ +} __packed; + +struct tcp_t_opt { /* TCP time stamps option */ + u8 kind; /* 0x08 */ + u8 len; /* 0x0a */ + u32 t_snd; /* Sender timestamp */ + u32 t_rcv; /* Receiver timestamp */ +} __packed; + +#define TCP_TSOPT_SIZE (sizeof(struct tcp_t_opt)) + +/* + * ip tcp structure with options + */ + +struct ip_tcp_hdr_o { + struct ip_tcp_hdr hdr; + struct tcp_mss mss; + struct tcp_scale scale; + struct tcp_sack_p sack_p; + struct tcp_t_opt t_opt; + u8 end; +} __packed; + +#define IP_TCP_O_SIZE (sizeof(struct ip_tcp_hdr_o)) + +struct ip_tcp_hdr_s { + struct ip_tcp_hdr hdr; + struct tcp_t_opt t_opt; + struct tcp_sack_v sack_v; + u8 end; +} __packed; + +#define IP_TCP_SACK_SIZE (sizeof(struct ip_tcp_hdr_s)) + +/* + * TCP pseudo header definitions + */ +#define PSEUDO_PAD_SIZE 8 + +struct pseudo_hdr { + u8 padding[PSEUDO_PAD_SIZE]; /* pseudo hdr size = ip_tcp hdr size */ + struct in_addr p_src; + struct in_addr p_dst; + u8 rsvd; + u8 p; + u16 len; +} __packed; + +#define PSEUDO_HDR_SIZE (sizeof(struct pseudo_hdr)) - PSEUDO_PAD_SIZE + +/* + * union for building IP/TCP packet. + * build Pseudo header in packed bufferfirst, calculate TCP checksum + * then build IP header in packe buffer. + */ + +union tcp_build_pkt { + struct pseudo_hdr ph; + struct ip_tcp_hdr_o ip; + struct ip_tcp_hdr_s sack; + uchar raw[1600]; +} __packed; + +/* + * TCP STATE MACHINE STATES FOR SOCKET + */ + +enum TCP_STATE { + TCP_CLOSED, /* Need to send SYN to connect */ + TCP_SYN_SENT, /* Trying to connect, waiting for SYN ACK */ + TCP_ESTABLISHED, /* both server & client have a connection */ + TCP_CLOSE_WAIT, /* Rec FIN, passed to app for FIN, ACK rsp*/ + TCP_CLOSING, /* Rec FIN, sent FIN, ACK waiting for ACK */ + TCP_FIN_WAIT_1, /* Sendt FIN waiting for response */ + TCP_FIN_WAIT_2 /* Rec ACK from FIN sent, waitng for FIN */ +}; + +int tcp_find_in_buffer(uchar raw[], int payload_len, uchar field[], + int field_len); +void tcp_print_buffer(uchar raw[], int pkt_len, int payload_len, + int hdr_len, bool hide); +enum TCP_STATE tcp_get_tcp_state(void); +void tcp_set_tcp_state(enum TCP_STATE new_state); +int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, + u8 action, u32 tcp_seq_num, u32 tcp_ack_num); + +/* + * An incoming packet handler. + * @param pkt pointer to the application packet + * @param dport destination UDP port + * @param sip source IP address + * @param sport source UDP port + * @param len packet length + */ +typedef void rxhand_tcp(uchar *pkt, unsigned int dport, + struct in_addr sip, unsigned int sport, + unsigned int len); +void tcp_set_tcp_handler(rxhand_tcp *f); + +void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int len); + +/* + * An incoming TCP packet handler for the TCP protocol. + * There is also a dymanic function pointer for TCP based commads to + * receive incoming traffic after the TCP protocol code has done its work. + */ + +void rxhand_action(u8 tcp_action, int payload_len, u32 tcp_seq_num, + u32 tcp_ack_num, unsigned int pkt_len, + union tcp_build_pkt *b);
This should be in a notes section for patman. It is acceptable to ignore that checkpatch warning about packed structs.
How about moving this to include/net/tcp.h?
Don't enable the wget build in this patch.
Please also include a SPDX-License-Identifier:.
- General Desription:
- TCP support for the wget command, for fast file downloading.
- HTTP/TCP Receiver:
- own IP address
- Server IP address
- HTP client
Huh? Typo at least - maybe you mean server here? Unclear.
It would be better if you referenced literal U-Boot variables that need to be populated instead of loose naming of them.
Seems like something that would happen only with wget. Maybe this should be moved there.
Next Step HTTPS?
When moved, this could instead be #include <net/tcp.h>
+#include "wget.h"
This doesn't exist yet.
Please use multi-line comment format:
/* * my comment... * continued */
Please use an empty /* line to begin a multi-line comment.
- comments before the code section
- TCP_SACK is the number of packets
- at the front of the stream
enum pkt_state st;
- An incoming TCP packet handler for the TCP protocol.
- There is also a dymanic function pointer for TCP based commads to
- receive incoming traffic after the TCP protocol code has done its work.
return tcp_state;
Should this function only be available with a debug flag?
int i;
if (i <= hdr_len)
putc(raw[i]);
else if (hide == 0)
putc(raw[i]);
else
printf("%s", "\n");
int field_len)
int i, j;
break;
if (j == field_len)
return i;
unsigned int len)
if (!f)
else
int checksum_len;
* Pseudo header
* will always work.
b->ph.rsvd = 0x00;
Bad indent level.
Please add a comment about the alignment you are trying to achieve.
tcp_lost.len);
* internally.
tcp_lost.len = 0;
int pkt_hdr_len;
int pkt_len;
int tcp_len;
/* For options */
switch (action) {
case TCP_SYN:
tcp_seq_num = 0;
tcp_ack_num = 0;
action = TCP_FIN;
} else {
break;
case TCP_ACK:
action);
break;
case TCP_FIN:
payload_len = 0;
Why is this comment on the same like as the break? How does break accomplish this?
tcp_ack_edge++;
/* FALLTHRU */
Indent this the same as the default: label.
default:
* TCP Header
Use single-line comment.
overruun -> overrun
langth -> length
thEn -> then
* considered.
tcp_len, pkt_len);
* IP Header
return pkt_hdr_len;
- Selective Acknowledgment (Essential for fast stream transfer)
- Before modifying theis section of code, which the author found difficult
theis -> this
- to write, please be familiar with the SACK (Selective Acknowledgment) RFCs.
Use a single space between hill and =.
u32 hol_r = 0;
if (prev_len == 0)
prev_len = len;
lanegth -> length
ad -> and
arrary -> array
Fix indentation of this comment block.
if (prev_len < len)
prev_len = len;
Parenthesis around these conditions are not needed.
sack_in++) {
switch (expect) {
case NOPKT:
case NOPKT:
break;
case PKT:
expect = PKT;
break;
break;
case PKT:
case NOPKT:
hill++;
expect = NOPKT;
break;
case PKT:
sack_idx++;
} else {
break;
break;
sack_idx = 0;
uchar *p = o;
if (p[1] != 0) {
switch (p[0]) {
case TCP_O_END:
return;
case TCP_O_MSS:
break;
case TCP_O_SCL:
break;
case TCP_P_SACK:
break;
case TCP_V_SACK:
break;
case TCP_O_TS:
return;
break;
p++;
} else {
return; }
Put the closing brace on its own line.
int i;
intrepreted -> interpreted
if (tcp_rst) {
action = TCP_DATA;
return TCP_RST;
case TCP_CLOSED:
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_RST;
if (tcp_ack)
action = TCP_DATA;
break;
case TCP_SYN_SENT:
if (tcp_fin) {
if (tcp_syn) {
if (tcp_ack) {
sack_idx = 0;
prev_len = 0;
} else {
if (tcp_ack)
action = TCP_DATA;
break;
} else {
if (tcp_ack)
action = TCP_DATA;
if (tcp_push)
if (tcp_syn)
break;
break;
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_DATA;
if (tcp_ack) {
puts("\n");
break;
if (tcp_fin) {
if (tcp_syn)
action = TCP_RST;
if (tcp_ack) {
break;
case TCP_CLOSING:
if (tcp_fin)
action = TCP_DATA;
if (tcp_syn)
action = TCP_RST;
if (tcp_ack) {
action = TCP_PUSH;
puts("\n");
break;
return action;
u32 tcp_seq_num;
u32 tcp_ack_num;
int tcp_hdr_len;
int payload_len;
* Verify ip header
ip -> IP
xum -> xSum
return;
pkt_len)) {
return;
send -> sent
date -> data
invocation,
What other variable. Call it out explicitly.
* and TCP state.
puts("| ");
Fix indentation.
Remove this blank line.
Include a SPDX-License-Identifier.
- History
Git already keeps the history - drop this section.
down loading -> downloading
+} __packed;
- TCP header options, Seq, MSS, and SACK
Timestanp -> Timestamp
- Please reviw the warning in net.c about these two paraeters.
reviw -> review , paraeters ->parameters
- They are part of a promise of RX buffer size to the sending TCP
u8 kind; /* 0x02 */
u8 len; /* 0x04 */
+} __packed;
u8 kind; /* 0x03 */
u8 len; /* 0x03 */
fat -> for?
+} __packed;
u8 kind; /* 0x04 */
+} __packed;
u32 l;
u32 r;
+} __packed;
u8 kind; /* 0x05 */
+} __packed;
u8 kind; /* 0x08 */
u8 len; /* 0x0a */
+} __packed;
- ip tcp structure with options
struct tcp_mss mss;
u8 end;
+} __packed;
u8 end;
+} __packed;
- TCP pseudo header definitions
u8 rsvd;
u8 p;
u16 len;
+} __packed;
- union for building IP/TCP packet.
- build Pseudo header in packed bufferfirst, calculate TCP checksum
bufferfirst -> buffer first
- then build IP header in packe buffer.
packe -> packed
uchar raw[1600];
+} __packed;
- TCP STATE MACHINE STATES FOR SOCKET
+enum TCP_STATE {
Sendt -> Sent
waitng -> waiting
int field_len);
- An incoming packet handler.
- @param pkt pointer to the application packet
- @param dport destination UDP port
- @param sip source IP address
- @param sport source UDP port
- @param len packet length
unsigned int len);
dymanic -> dynamic , commads -> commands
-- 2.11.0
DH@synoia.com
Joe Hershberger
