[U-Boot] [PATCH 13/13 v5] ARM: OMAP3: Add Beagle, EVM and Overo configuration and README
Signed-off-by: Dirk Behme dirk.behme@gmail.com
--- doc/README.omap3 | 94 +++++++++++ include/configs/omap3_beagle.h | 289 ++++++++++++++++++++++++++++++++++++ include/configs/omap3_evm.h | 322 +++++++++++++++++++++++++++++++++++++++++ include/configs/omap3_overo.h | 280 +++++++++++++++++++++++++++++++++++ 4 files changed, 985 insertions(+)
Index: u-boot-main/include/configs/omap3_beagle.h =================================================================== --- /dev/null +++ u-boot-main/include/configs/omap3_beagle.h @@ -0,0 +1,289 @@ +/* + * (C) Copyright 2006-2008 + * Texas Instruments. + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim x0khasim@ti.com + * + * Configuration settings for the TI OMAP3530 Beagle board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> + +/* + * High Level Configuration Options + */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OMAP3_BEAGLE 1 /* working with BEAGLE */ +#define CONFIG_DOS_PARTITION 1 + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE SZ_128K /* Total Size Environment Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK (48000000) /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 /* UART3 on Beagle Rev 2 */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} +#define CONFIG_MMC 1 +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_DOS_PARTITION 1 + +/* commands to include */ + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NAND /* NAND support */ + +#define CONFIG_CMD_AUTOSCRIPT /* autoscript support */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_BOOTD /* bootd */ +#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_ENV /* saveenv */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ +#define CONFIG_CMD_MISC /* misc functions like sleep etc*/ +#define CONFIG_CMD_RUN /* run command in env variable */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* + * Board NAND Info. + */ +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address to access nand at CS0 */ +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define SECTORSIZE 512 + +#define NAND_ALLOW_ERASE_ALL +#define ADDR_COLUMN 1 +#define ADDR_PAGE 2 +#define ADDR_COLUMN_PAGE 3 + +#define NAND_ChipID_UNKNOWN 0x00 +#define NAND_MAX_FLOORS 1 +#define NAND_MAX_CHIPS 1 +#define NAND_NO_RB 1 +#define CONFIG_SYS_NAND_WP + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* size of jffs2 partition */ + +/* Environment information */ +#define CONFIG_BOOTDELAY 10 + +#define CONFIG_BOOTCOMMAND "nand read 80200000 280000 400000 ; bootm 80200000" + +#define CONFIG_BOOTARGS "setenv bootargs console=ttyS2,115200n8 noinitrd root=/dev/mtdblock4 rw rootfstype=jffs2" + +#define CONFIG_NETMASK 255.255.254.0 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_AUTO_COMPLETE 1 +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "OMAP3 beagleboard.org # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + 0x01F00000) /* 31MB */ + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load address */ + +/* 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by + * 32KHz clk, or from external sig. This rate is divided by a local divisor. + */ +#define V_PVT 7 + +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE SZ_128K /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ SZ_4K /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ SZ_4K /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE SZ_32M /* at least 32 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NOR_SIZE_SDPV2 GPMC_SIZE_128M +#define PISMO1_NOR_SIZE GPMC_SIZE_64M + +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M +#define DBG_MPDB_SIZE GPMC_SIZE_16M +#define PISMO2_SIZE 0 + +#define CONFIG_SYS_MAX_FLASH_SECT (520) /* max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* Reserve 2 sectors */ + +#define PHYS_FLASH_SIZE_SDPV2 SZ_128M +#define PHYS_FLASH_SIZE SZ_32M + +#define CONFIG_SYS_FLASH_BASE boot_flash_base +#define PHYS_FLASH_SECT_SIZE boot_flash_sec +/* Dummy declaration of flash banks to get compilation right */ +#define CONFIG_SYS_FLASH_BANKS_LIST {0, 0} + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at start of flash */ +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP + +#define CONFIG_ENV_IS_IN_NAND 1 +#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec +#define CONFIG_ENV_OFFSET boot_flash_off +#define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET + +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ + +/* Flash banks JFFS2 should use */ +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + CONFIG_SYS_MAX_NAND_DEVICE) +#define CONFIG_SYS_JFFS2_MEM_NAND +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS /* use flash_info[2] */ +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#define ENV_IS_VARIABLE 1 + +#ifndef __ASSEMBLY__ +extern unsigned int *nand_cs_base; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + + +#define WRITE_NAND_COMMAND(d, adr)\ + writel(d, (nand_cs_base + OFFS(GPMC_NAND_CMD))) +#define WRITE_NAND_ADDRESS(d, adr)\ + writel(d, (nand_cs_base + OFFS(GPMC_NAND_ADR))) +#define WRITE_NAND(d, adr) writew(d, (nand_cs_base + OFFS(GPMC_NAND_DAT))) +#define READ_NAND(adr) readl((nand_cs_base + OFFS(GPMC_NAND_DAT))) + +/* Other NAND Access APIs */ +#define NAND_WP_OFF() do {readl(GPMC_CONFIG_REG) |= GPMC_CONFIG_WP; } while (0) +#define NAND_WP_ON() do {readl(GPMC_CONFIG_REG) &= ~GPMC_CONFIG_WP; } while (0) +#define NAND_DISABLE_CE(nand) +#define NAND_ENABLE_CE(nand) +#define NAND_WAIT_READY(nand) udelay(10) + +#endif /* __CONFIG_H */ Index: u-boot-main/include/configs/omap3_evm.h =================================================================== --- /dev/null +++ u-boot-main/include/configs/omap3_evm.h @@ -0,0 +1,322 @@ +/* + * (C) Copyright 2006-2008 + * Texas Instruments. + + * Author : + * Manikandan Pillai mani.pillai@ti.com + * Derived from Beagle Board and 3430 SDP code by + * Richard Woodruff r-woodruff2@ti.com + * Syed Mohammed Khasim khasim@ti.com + * + * Manikandan Pillai mani.pillai@ti.com + * + * Configuration settings for the TI OMAP3 EVM board. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> + +/* + * High Level Configuration Options + */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OMAP3_EVM 1 /* working with EVM */ +#define CONFIG_DOS_PARTITION 1 + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE SZ_128K /* Total Size Environment Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK (48000000) /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 1 +#define CONFIG_SYS_NS16550_COM1 OMAP34XX_UART1 +#define CONFIG_SERIAL1 1 /* UART1 on OMAP3 EVM */ + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} +#define CONFIG_MMC 1 +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_DOS_PARTITION 1 + +/* commands to include */ + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_ONENAND /* ONENAND support */ + +#define CONFIG_CMD_AUTOSCRIPT /* autoscript support */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_BOOTD /* bootd */ +#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_ENV /* saveenv */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ +#define CONFIG_CMD_MISC /* misc functions like sleep etc*/ +#define CONFIG_CMD_RUN /* run command in env variable */ +#define CONFIG_CMD_NET /* bootp, tftpboot, rarpboot */ +#define CONFIG_CMD_DHCP +#define CONFIG_CMD_PING +#define CONFIG_CMD_NFS /* NFS support */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* + * Board NAND Info. + */ +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address to access nand at CS0 */ + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define SECTORSIZE 512 + +#define NAND_ALLOW_ERASE_ALL +#define ADDR_COLUMN 1 +#define ADDR_PAGE 2 +#define ADDR_COLUMN_PAGE 3 + +#define NAND_ChipID_UNKNOWN 0x00 +#define NAND_MAX_FLOORS 1 +#define NAND_MAX_CHIPS 1 +#define NAND_NO_RB 1 +#define CONFIG_SYS_NAND_WP + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* sz of jffs2 part */ + +/* Environment information */ +#define CONFIG_BOOTDELAY 10 + +#define CONFIG_BOOTCOMMAND "onenand read 80200000 280000 400000 ; \ + bootm 80200000" + +#define CONFIG_BOOTARGS "setenv bootargs console=ttyS2,115200n8 noinitrd \ + root=/dev/mtdblock4 rw rootfstype=jffs2" + +#define CONFIG_NETMASK 255.255.254.0 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_AUTO_COMPLETE 1 +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "OMAP3_EVM # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + 0x01F00000) /* 31MB */ + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load address */ + +/* 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by + * 32KHz clk, or from external sig. This rate is divided by a local divisor. + */ +#define V_PVT 7 + +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE SZ_128K /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ SZ_4K /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ SZ_4K /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE SZ_32M /* at least 32 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NOR_SIZE_SDPV2 GPMC_SIZE_128M +#define PISMO1_NOR_SIZE GPMC_SIZE_64M + +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M +#define DBG_MPDB_SIZE GPMC_SIZE_16M +#define PISMO2_SIZE 0 + +#define CONFIG_SYS_MAX_FLASH_SECT (520) /* max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* Reserve 2 sectors */ + +#define PHYS_FLASH_SIZE_SDPV2 SZ_128M +#define PHYS_FLASH_SIZE SZ_32M + +#define CONFIG_SYS_FLASH_BASE boot_flash_base +#define PHYS_FLASH_SECT_SIZE boot_flash_sec +/* Dummy declaration of flash banks to get compilation right */ +#define CONFIG_SYS_FLASH_BANKS_LIST {0, 0} + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at start of flash */ +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP + +#define CONFIG_ENV_IS_IN_ONENAND 1 +#define ONENAND_ENV_OFFSET 0x260000 /* environment starts here */ +#define SMNAND_ENV_OFFSET 0x260000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec +#define CONFIG_ENV_OFFSET boot_flash_off +#define CONFIG_ENV_ADDR boot_flash_env_addr + +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ + +/* Flash banks JFFS2 should use */ +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + CONFIG_SYS_MAX_NAND_DEVICE) +#define CONFIG_SYS_JFFS2_MEM_NAND +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS /* use flash_info[2] */ +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#define ENV_IS_VARIABLE 1 + +#ifndef __ASSEMBLY__ +extern unsigned int *nand_cs_base; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + + +#define WRITE_NAND_COMMAND(d, adr)\ + writel(d, (nand_cs_base + OFFS(GPMC_NAND_CMD))) +#define WRITE_NAND_ADDRESS(d, adr)\ + writel(d, (nand_cs_base + OFFS(GPMC_NAND_ADR))) +#define WRITE_NAND(d, adr) writel(d, (nand_cs_base + OFFS(GPMC_NAND_DAT))) +#define READ_NAND(adr) readl((nand_cs_base + OFFS(GPMC_NAND_DAT))) + +/* Other NAND Access APIs */ +#define NAND_WP_OFF() do {readl(GPMC_CONFIG_REG) |= GPMC_CONFIG_WP; } while (0) +#define NAND_WP_ON() do {readl(GPMC_CONFIG_REG) &= ~GPMC_CONFIG_WP; } while (0) +#define NAND_DISABLE_CE(nand) +#define NAND_ENABLE_CE(nand) +#define NAND_WAIT_READY(nand) udelay(10) + + +/*---------------------------------------------------------------------------- + * SMSC9115 Ethernet from SMSC9118 family + * ---------------------------------------------------------------------------- + */ +#if defined(CONFIG_CMD_NET) + +#define CONFIG_DRIVER_SMC911X +#define CONFIG_DRIVER_SMC911X_32_BIT +#define CONFIG_DRIVER_SMC911X_BASE (0x2C000000) + +#endif /* (CONFIG_CMD_NET) */ + +/* + * BOOTP fields + */ + + +#define CONFIG_BOOTP_SUBNETMASK 0x00000001 +#define CONFIG_BOOTP_GATEWAY 0x00000002 +#define CONFIG_BOOTP_HOSTNAME 0x00000004 +#define CONFIG_BOOTP_BOOTPATH 0x00000010 + +#endif /* __CONFIG_H */ Index: u-boot-main/include/configs/omap3_overo.h =================================================================== --- /dev/null +++ u-boot-main/include/configs/omap3_overo.h @@ -0,0 +1,280 @@ +/* + * Configuration settings for the Gumstix Overo board. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __CONFIG_H +#define __CONFIG_H +#include <asm/sizes.h> + +/* + * High Level Configuration Options + */ +#define CONFIG_ARMCORTEXA8 1 /* This is an ARM V7 CPU core */ +#define CONFIG_OMAP 1 /* in a TI OMAP core */ +#define CONFIG_OMAP34XX 1 /* which is a 34XX */ +#define CONFIG_OMAP3430 1 /* which is in a 3430 */ +#define CONFIG_OVERO 1 /* working with overo */ + +#include <asm/arch/cpu.h> /* get chip and board defs */ +#include <asm/arch/omap3.h> + +/* Clock Defines */ +#define V_OSCK 26000000 /* Clock output from T2 */ +#define V_SCLK (V_OSCK >> 1) + +#undef CONFIG_USE_IRQ /* no support for IRQs */ +#define CONFIG_MISC_INIT_R + +#define CONFIG_CMDLINE_TAG 1 /* enable passing of ATAGs */ +#define CONFIG_SETUP_MEMORY_TAGS 1 +#define CONFIG_INITRD_TAG 1 +#define CONFIG_REVISION_TAG 1 + +/* + * Size of malloc() pool + */ +#define CONFIG_ENV_SIZE SZ_128K /* Total Size Environment Sector */ +#define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + SZ_128K) +#define CONFIG_SYS_GBL_DATA_SIZE 128 /* bytes reserved for initial data */ + +/* + * Hardware drivers + */ + +/* + * NS16550 Configuration + */ +#define V_NS16550_CLK (48000000) /* 48MHz (APLL96/2) */ + +#define CONFIG_SYS_NS16550 +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_CLK V_NS16550_CLK + +/* + * select serial console configuration + */ +#define CONFIG_CONS_INDEX 3 +#define CONFIG_SYS_NS16550_COM3 OMAP34XX_UART3 +#define CONFIG_SERIAL3 3 + +/* allow to overwrite serial and ethaddr */ +#define CONFIG_ENV_OVERWRITE +#define CONFIG_BAUDRATE 115200 +#define CONFIG_SYS_BAUDRATE_TABLE {4800, 9600, 19200, 38400, 57600, 115200} +#define CONFIG_MMC 1 +#define CONFIG_SYS_MMC_BASE 0xF0000000 +#define CONFIG_DOS_PARTITION 1 + +/* commands to include */ + +#define CONFIG_CMD_EXT2 /* EXT2 Support */ +#define CONFIG_CMD_FAT /* FAT support */ +#define CONFIG_CMD_JFFS2 /* JFFS2 Support */ + +#define CONFIG_CMD_I2C /* I2C serial bus support */ +#define CONFIG_CMD_MMC /* MMC support */ +#define CONFIG_CMD_NAND /* NAND support */ + +#define CONFIG_CMD_AUTOSCRIPT /* autoscript support */ +#define CONFIG_CMD_BDI /* bdinfo */ +#define CONFIG_CMD_BOOTD /* bootd */ +#define CONFIG_CMD_CONSOLE /* coninfo */ +#define CONFIG_CMD_ECHO /* echo arguments */ +#define CONFIG_CMD_ENV /* saveenv */ +#define CONFIG_CMD_ITEST /* Integer (and string) test */ +#define CONFIG_CMD_LOADB /* loadb */ +#define CONFIG_CMD_MEMORY /* md mm nm mw cp cmp crc base loop mtest */ +#define CONFIG_CMD_MISC /* misc functions like sleep etc*/ +#define CONFIG_CMD_RUN /* run command in env variable */ + +#define CONFIG_SYS_NO_FLASH +#define CONFIG_SYS_I2C_SPEED 100000 +#define CONFIG_SYS_I2C_SLAVE 1 +#define CONFIG_SYS_I2C_BUS 0 +#define CONFIG_SYS_I2C_BUS_SELECT 1 +#define CONFIG_DRIVER_OMAP34XX_I2C 1 + +/* + * Board NAND Info. + */ +#define CONFIG_NAND_OMAP_GPMC +#define CONFIG_SYS_NAND_ADDR NAND_BASE /* physical address to access nand */ +#define CONFIG_SYS_NAND_BASE NAND_BASE /* physical address to access nand at CS0 */ +#define GPMC_NAND_ECC_LP_x16_LAYOUT 1 + +#define CONFIG_SYS_MAX_NAND_DEVICE 1 /* Max number of NAND devices */ +#define SECTORSIZE 512 + +#define NAND_ALLOW_ERASE_ALL +#define ADDR_COLUMN 1 +#define ADDR_PAGE 2 +#define ADDR_COLUMN_PAGE 3 + +#define NAND_ChipID_UNKNOWN 0x00 +#define NAND_MAX_FLOORS 1 +#define NAND_MAX_CHIPS 1 +#define NAND_NO_RB 1 +#define CONFIG_SYS_NAND_WP + +#define CONFIG_JFFS2_NAND +/* nand device jffs2 lives on */ +#define CONFIG_JFFS2_DEV "nand0" +/* start of jffs2 partition */ +#define CONFIG_JFFS2_PART_OFFSET 0x680000 +#define CONFIG_JFFS2_PART_SIZE 0xf980000 /* size of jffs2 partition */ + +/* Environment information */ +#define CONFIG_BOOTDELAY 5 + +#define CONFIG_BOOTCOMMAND "mmcinit; fatload mmc 0 82000000 uImage; bootm 82000000" + +#define CONFIG_BOOTARGS "setenv bootargs console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1" + +#define CONFIG_NETMASK 255.255.254.0 +#define CONFIG_BOOTFILE "uImage" +#define CONFIG_AUTO_COMPLETE 1 +/* + * Miscellaneous configurable options + */ +#define V_PROMPT "Overo # " + +#define CONFIG_SYS_LONGHELP /* undef to save memory */ +#define CONFIG_SYS_PROMPT V_PROMPT +#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ +/* Print Buffer Size */ +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT)+16) +#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ +#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ + +#define CONFIG_SYS_MEMTEST_START (OMAP34XX_SDRC_CS0) /* memtest works on */ +#define CONFIG_SYS_MEMTEST_END (OMAP34XX_SDRC_CS0 + 0x01F00000) /* 31MB */ + +#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ + +#define CONFIG_SYS_LOAD_ADDR (OMAP34XX_SDRC_CS0) /* default load address */ + +/* 2430 has 12 GP timers, they can be driven by the SysClk (12/13/19.2) or by + * 32KHz clk, or from external sig. This rate is divided by a local divisor. + */ +#define V_PVT 7 + +#define CONFIG_SYS_TIMERBASE OMAP34XX_GPT2 +#define CONFIG_SYS_PVT V_PVT /* 2^(pvt+1) */ +#define CONFIG_SYS_HZ ((V_SCLK) / (2 << CONFIG_SYS_PVT)) + +/*----------------------------------------------------------------------- + * Stack sizes + * + * The stack sizes are set up in start.S using the settings below + */ +#define CONFIG_STACKSIZE SZ_128K /* regular stack */ +#ifdef CONFIG_USE_IRQ +#define CONFIG_STACKSIZE_IRQ SZ_4K /* IRQ stack */ +#define CONFIG_STACKSIZE_FIQ SZ_4K /* FIQ stack */ +#endif + +/*----------------------------------------------------------------------- + * Physical Memory Map + */ +#define CONFIG_NR_DRAM_BANKS 2 /* CS1 may or may not be populated */ +#define PHYS_SDRAM_1 OMAP34XX_SDRC_CS0 +#define PHYS_SDRAM_1_SIZE SZ_32M /* at least 32 meg */ +#define PHYS_SDRAM_2 OMAP34XX_SDRC_CS1 + +/* SDRAM Bank Allocation method */ +#define SDRC_R_B_C 1 + +/*----------------------------------------------------------------------- + * FLASH and environment organization + */ + +/* **** PISMO SUPPORT *** */ + +/* Configure the PISMO */ +#define PISMO1_NOR_SIZE_SDPV2 GPMC_SIZE_128M +#define PISMO1_NOR_SIZE GPMC_SIZE_64M + +#define PISMO1_NAND_SIZE GPMC_SIZE_128M +#define PISMO1_ONEN_SIZE GPMC_SIZE_128M +#define DBG_MPDB_SIZE GPMC_SIZE_16M +#define PISMO2_SIZE 0 + +#define CONFIG_SYS_MAX_FLASH_SECT (520) /* max number of sectors on one chip */ +#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of flash banks */ +#define CONFIG_SYS_MONITOR_LEN SZ_256K /* Reserve 2 sectors */ + +#define PHYS_FLASH_SIZE_SDPV2 SZ_128M +#define PHYS_FLASH_SIZE SZ_32M + +#define CONFIG_SYS_FLASH_BASE boot_flash_base +#define PHYS_FLASH_SECT_SIZE boot_flash_sec +/* Dummy declaration of flash banks to get compilation right */ +#define CONFIG_SYS_FLASH_BANKS_LIST {0, 0} + +#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE /* Monitor at start of flash */ +#define CONFIG_SYS_ONENAND_BASE ONENAND_MAP + +#define CONFIG_ENV_IS_IN_NAND 1 +#define ONENAND_ENV_OFFSET 0x240000 /* environment starts here */ +#define SMNAND_ENV_OFFSET 0x240000 /* environment starts here */ + +#define CONFIG_SYS_ENV_SECT_SIZE boot_flash_sec +#define CONFIG_ENV_OFFSET boot_flash_off +#define CONFIG_ENV_ADDR SMNAND_ENV_OFFSET + +/*----------------------------------------------------------------------- + * CFI FLASH driver setup + */ +/* timeout values are in ticks */ +#define CONFIG_SYS_FLASH_ERASE_TOUT (100 * CONFIG_SYS_HZ) /* Timeout for Flash Erase */ +#define CONFIG_SYS_FLASH_WRITE_TOUT (100 * CONFIG_SYS_HZ) /* Timeout for Flash Write */ + +/* Flash banks JFFS2 should use */ +#define CONFIG_SYS_MAX_MTD_BANKS (CONFIG_SYS_MAX_FLASH_BANKS + CONFIG_SYS_MAX_NAND_DEVICE) +#define CONFIG_SYS_JFFS2_MEM_NAND +#define CONFIG_SYS_JFFS2_FIRST_BANK CONFIG_SYS_MAX_FLASH_BANKS /* use flash_info[2] */ +#define CONFIG_SYS_JFFS2_NUM_BANKS 1 + +#define ENV_IS_VARIABLE 1 + +#ifndef __ASSEMBLY__ +extern unsigned int *nand_cs_base; +extern unsigned int boot_flash_base; +extern volatile unsigned int boot_flash_env_addr; +extern unsigned int boot_flash_off; +extern unsigned int boot_flash_sec; +extern unsigned int boot_flash_type; +#endif + + +#define WRITE_NAND_COMMAND(d, adr)\ + writel(d, (nand_cs_base + OFFS(GPMC_NAND_CMD))) +#define WRITE_NAND_ADDRESS(d, adr)\ + writel(d, (nand_cs_base + OFFS(GPMC_NAND_ADR))) +#define WRITE_NAND(d, adr) writel(d, (nand_cs_base + OFFS(GPMC_NAND_DAT))) +#define READ_NAND(adr) readl((nand_cs_base + OFFS(GPMC_NAND_DAT))) + +/* Other NAND Access APIs */ +#define NAND_WP_OFF() do {readl(GPMC_CONFIG_REG) |= GPMC_CONFIG_WP; } while (0) +#define NAND_WP_ON() do {readl(GPMC_CONFIG_REG) &= ~GPMC_CONFIG_WP; } while (0) +#define NAND_DISABLE_CE(nand) +#define NAND_ENABLE_CE(nand) +#define NAND_WAIT_READY(nand) udelay(10) + +#endif /* __CONFIG_H */ Index: u-boot-main/doc/README.omap3 =================================================================== --- /dev/null +++ u-boot-main/doc/README.omap3 @@ -0,0 +1,94 @@ + +Summary +======= + +This README is about U-Boot support for TI's ARM Cortex-A8 based OMAP3 [1] +family of SoCs. TI's OMAP3 SoC family contains an ARM Cortex-A8 core running +at ~600MHz. Additionally some family members contain a TMS320C64x+ DSP ~430MHz +and/or an Imagination SGX 2D/3D graphics processor and various other standard +peripherals. + +Currently the following boards are supported: + +* TI EVM [2] + +* Gumstix Overo [3] + +* TI/DigiKey BeagleBoard [4] + +Toolchain +========= + +While ARM Cortex-A8 support ARM v7 instruction set (-march=armv7a) we compile +with -march=armv5 to allow more compilers to work. For U-Boot code this has +no performance impact. + +Build +===== + +* TI EVM: + +make omap3_evm_config +make + +* Gumstix Overo: + +make omap3_overo_config +make + +* BeagleBoard: + +make omap3_beagle_config +make + +Custom commands +=============== + +To make U-Boot for OMAP3 support NAND device SW or HW ECC calculation, U-Boot +for OMAP3 supports custom user command + +nandecc hw/sw + +To be compatible with NAND drivers using SW ECC (e.g. kernel code) + +nandecc sw + +enables SW ECC calculation. HW ECC enabled with + +nandecc hw + +is typically used to write 2nd stage bootloader (known as 'x-loader') which is +executed by OMAP3's boot rom and therefore has to be written with HW ECC. + +For all other commands see + +help + +Acknowledgements +================ + +OMAP3 U-Boot is based on U-Boot tar ball [5] for BeagleBoard and EVM done by +several TI employees. + +Links +===== + +[1] OMAP3: + +http://focus.ti.com/general/docs/gencontent.tsp?contentId=36915 + +[2] TI EVM: + +http://focus.ti.com/docs/toolsw/folders/print/tmdxevm3503.html + +[3] Gumstix Overo: + +http://www.gumstix.net/Overo/ + +[4] TI/DigiKey BeagleBoard: + +http://beagleboard.org/ + +[5] TI OMAP3 U-Boot: + +http://beagleboard.googlecode.com/files/u-boot_beagle_revb.tar.gz \ No newline at end of file
- (C) Copyright 2006-2008
- Texas Instruments.
- Richard Woodruff r-woodruff2@ti.com
- Syed Mohammed Khasim x0khasim@ti.com
- Configuration settings for the TI OMAP3530 Beagle board.
- project.
- MA 02111-1307 USA
- High Level Configuration Options
^^^^^^^^^^^^^^^^^^^ whitespace please fix
- Size of malloc() pool
- Hardware drivers
- NS16550 Configuration
- select serial console configuration
^^^^^^^^^^^^ whitespace please fix and so on
- Board NAND Info.
too long please split
- Miscellaneous configurable options
too long please split and so on
Best Regards, J.
dirk.behmeï¼ googlemail.com
Jean-Christophe PLAGNIOL-VILLARD
