[PATCH] board_f: show_dram_config: Print also real DRAM size
32-bit U-Boot builds cannot use more than around 2 GB of DDR memory. But on some platforms/boards it is possible to connect also 4 GB SODIMM DDR memory. U-Boot currently prints only effective size of RAM which can use, which may be misleading as somebody would expect that this line prints total size of connected DDR modules. So change show_dram_config code to prints both real and effective DRAM size if they are different. If they are same then print just one number like before. It is possible that effective size is just few bytes smaller than the real size, so print both numbers only in case function print_size() prints formats them differently.
Signed-off-by: Pali Rohár pali@kernel.org --- common/board_f.c | 31 ++++++++++++++++++++++++++++++- 1 file changed, 30 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 9e34fbee147e..3131a06db940 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -54,6 +54,7 @@ #include <asm/sections.h> #include <dm/root.h> #include <linux/errno.h> +#include <linux/log2.h>
/* * Pointer to initial global data area @@ -213,6 +214,30 @@ static int announce_dram_init(void) return 0; }
+/* + * Check if the sizes in their natural units written in decimal format with + * one fraction number are same. + */ +static int sizes_near(unsigned long long size1, unsigned long long size2) +{ + unsigned int size1_scale = ilog2(size1) / 10 * 10; + unsigned int size1_val = (10 * size1 + ((1ULL << size1_scale) >> 1)) >> size1_scale; + unsigned int size2_scale = ilog2(size2) / 10 * 10; + unsigned int size2_val = (10 * size2 + ((1ULL << size2_scale) >> 1)) >> size2_scale; + + if (size1_val == 10240) { + size1_val = 10; + size1_scale += 10; + } + + if (size2_val == 10240) { + size2_val = 10; + size2_scale += 10; + } + + return size1_scale == size2_scale && size1_val == size2_val; +} + static int show_dram_config(void) { unsigned long long size; @@ -229,7 +254,11 @@ static int show_dram_config(void) } debug("\nDRAM: ");
- print_size(size, ""); + print_size(gd->ram_size, ""); + if (!sizes_near(gd->ram_size, size)) { + printf(" (effective "); + print_size(size, ")"); + } board_add_ram_info(0); putc('\n');
Hi Pali,
- Pointer to initial global data area
- Check if the sizes in their natural units written in decimal format with
- one fraction number are same.
Can you put that expression into a function with a comment, etc.? It is a bit hard to understand.
size1_val = 10;
size1_scale += 10;
size2_val = 10;
size2_scale += 10;
If you are doing the same thing to each, why bother? It should not affect the expression below, should it? :
-- 2.20.1
Can we make this testable somehow? You could put the new code into a lib/ function, perhaps, and call it from a C unit test in test/lib ?
On Monday 12 September 2022 07:34:47 Simon Glass wrote:
Hi Pali,
Ok.
size1_val = 10;
size1_scale += 10;
size2_val = 10;
size2_scale += 10;
This is interesting question, and the answer it that it is required and affects comparison expression below. For example for the case when size1 is below 1GB limit, size2 is above 1GB limit and both values are near. Imagine that size1 is approaching value 1GB from the left and size2 from the right side.
-- 2.20.1
Meh... I do not know how to test such code. Due to size / optimization requirements it is not a good idea to make function outside of board_f.c file.
Hi Pali,
Ok.
size1_val = 10;
size1_scale += 10;
size2_val = 10;
size2_scale += 10;
-- 2.20.1
You can use TEST_STATIC from test/export.h this case.
--Sean
Hi Pali,
Hi Pali,
Ok.
size1_val = 10;
size1_scale += 10;
size2_val = 10;
size2_scale += 10;
-- 2.20.1
Good point, Sean.
Also LTO take away most//all of the cost of making a static function global.
Hi Pali,
On Wed, 14 Sept 2022 at 11:32, Pali Rohár pali@kernel.org wrote:
This is not solution as LTO does not work on powerpc and as I figured today, it is broken also on some 32-bit ARM platforms (e.g. mvebu).
Yes, various platforms need debugging of particular issues, as I understand it.
Anyway, Sean's solution should work fine and doesn't need LTO.
- Simon
Now I sent new patch version where I extended comment.
I have still issue with test framework. Could you help me how to write that unit test and run it? Scenario should really simple, just check like this:
sizes_near(87654321, 87654320) == true; sizes_near(87654321, 1000) == false;
Hi Pali,
I suggest copying something like test/lib/sscanf.c and then you can run it in sandbox with 'ut lib <testname>'
--- Changes in v2: * Move calculation code into separate macro and add description of it --- common/board_f.c | 37 ++++++++++++++++++++++++++++++++++++- 1 file changed, 36 insertions(+), 1 deletion(-)
diff --git a/common/board_f.c b/common/board_f.c index 9e34fbee147e..88a6dfff03fc 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -54,6 +54,7 @@ #include <asm/sections.h> #include <dm/root.h> #include <linux/errno.h> +#include <linux/log2.h>
/* * Pointer to initial global data area @@ -213,6 +214,36 @@ static int announce_dram_init(void) return 0; }
+/* + * From input size calculate its nearest rounded unit scale (multiply of 2^10) + * and value in calculated unit scale multiplied by 10 (as fractional fixed + * point number with one decimal digit), which is human natural format, + * same what uses print_size() function for displaying. Mathematically it is: + * round_nearest(val * 2^scale) = size * 10; where: 10 <= val < 10240. + * + * For example for size=87654321 we calculate scale=20 and val=836 which means + * that input has natural human format 83.6 M (mega = 2^20). + */ +#define compute_size_scale_val(size, scale, val) do { \ + scale = ilog2(size) / 10 * 10; \ + val = (10 * size + ((1ULL << scale) >> 1)) >> scale; \ + if (val == 10240) { val = 10; scale += 10; } \ +} while (0) + +/* + * Check if the sizes in their natural units written in decimal format with + * one fraction number are same. + */ +static int sizes_near(unsigned long long size1, unsigned long long size2) +{ + unsigned int size1_scale, size1_val, size2_scale, size2_val; + + compute_size_scale_val(size1, size1_scale, size1_val); + compute_size_scale_val(size2, size2_scale, size2_val); + + return size1_scale == size2_scale && size1_val == size2_val; +} + static int show_dram_config(void) { unsigned long long size; @@ -229,7 +260,11 @@ static int show_dram_config(void) } debug("\nDRAM: ");
Pali Rohár
Sean Anderson
