Pull request: u-boot-rockchip-20230629
Hi Tom,
Please pull the fixex for rockchip platform: - rockchip inno phy fix; - pinctrl driver in SPL arort in specific case; - fix IO port voltage for rock5b-rk3588 board;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/16732
Thanks, - Kever
The following changes since commit 580eb31199be8a822e62f20965854a242f895d03:
Merge branch 'riscv-fixes' of https://source.denx.de/u-boot/custodians/u-boot-riscv (2023-06-27 09:39:58 -0400)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20230629
for you to fetch changes up to d77d5301d7dc333db0425ee82499fe362abd259d:
board: rockchip: rock5b-rk3588: fix description (2023-06-29 18:43:42 +0800)
---------------------------------------------------------------- Eugen Hristev (2): phy: rockchip: inno-usb2: fix phy reg=0 case board: rockchip: rock5b-rk3588: fix description
Jonas Karlman (1): pinctrl: rockchip: Fix Data Abort exception in SPL
Ondrej Jirman (1): pinephone-pro: Fix I/O port voltage (GPIO3D4A is 1.8V)
arch/arm/mach-rockchip/rk3588/Kconfig | 10 ++++---- .../pinephone-pro-rk3399/pinephone-pro-rk3399.c | 6 +++-- drivers/phy/rockchip/phy-rockchip-inno-usb2.c | 2 +- drivers/pinctrl/rockchip/pinctrl-rockchip-core.c | 28 +++++----------------- 4 files changed, 16 insertions(+), 30 deletions(-)
On Thu, Jun 29, 2023 at 08:13:42PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
