[PATCH] bootstd: doc: Fix typos
These typos were found while reading the docs.
Signed-off-by: Paul Barker paul.barker@sancloud.com --- doc/develop/bootstd.rst | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/doc/develop/bootstd.rst b/doc/develop/bootstd.rst index 5e9c0d282bb0..6488c997b65a 100644 --- a/doc/develop/bootstd.rst +++ b/doc/develop/bootstd.rst @@ -21,7 +21,7 @@ feature is typically called `distro boot` (see :doc:`distro`) because it is a way for distributions to boot on any hardware.
Traditionally U-Boot has relied on scripts to implement this feature. See -disto_boodcmd_ for details. This is done because U-Boot has no native support +distro_bootcmd_ for details. This is done because U-Boot has no native support for scanning devices. While the scripts work remarkably well, they can be hard to understand and extend, and the feature does not include tests. They are also making it difficult to move away from ad-hoc CONFIGs, since they are implemented @@ -51,7 +51,7 @@ BootLoaderSpec_ format. which looks something like this:: initrd /initramfs-5.3.7-301.fc31.armv7hl.img
As you can see it specifies a kernel, a ramdisk (initrd) and a directory from -which to load devicetree files. The details are described in disto_boodcmd_. +which to load devicetree files. The details are described in distro_bootcmd_.
The bootflow is provided by the distro. It is not part of U-Boot. U-Boot's job is simply to interpret the file and carry out the instructions. This allows @@ -632,7 +632,7 @@ Other ideas: not need to specify things like `pxefile_addr_r`
-.. _disto_boodcmd: https://github.com/u-boot/u-boot/blob/master/include/config_distro_bootcmd.h +.. _distro_bootcmd: https://github.com/u-boot/u-boot/blob/master/include/config_distro_bootcmd.h .. _BootLoaderSpec: http://www.freedesktop.org/wiki/Specifications/BootLoaderSpec/ .. _distro_boot: https://github.com/u-boot/u-boot/blob/master/boot/distro.c .. _bootflow_h: https://github.com/u-boot/u-boot/blob/master/include/bootflow.h
Thank you.
-.. _disto_boodcmd: https://github.com/u-boot/u-boot/blob/master/include/config_distro_bootcmd.h +.. _distro_bootcmd: https://github.com/u-boot/u-boot/blob/master/include/config_distro_bootcmd.h .. _BootLoaderSpec: http://www.freedesktop.org/wiki/Specifications/BootLoaderSpec/ .. _distro_boot: https://github.com/u-boot/u-boot/blob/master/boot/distro.c .. _bootflow_h: https://github.com/u-boot/u-boot/blob/master/include/bootflow.h -- 2.25.1
Paul Barker
